Last updated by patrickW-37 11 months, 4 weeks ago.
September 10, 2019 at 8:57 pm #4548877
patrickW-37
Hi, thanks for fixing my last problem with WooCommerce Multilingual. I found another problem this time connected with official WooCommerce Product Add-ons plugin.
WPML tries to 'translate' (try to change currency) of custom values even if field is percentage type.
For example - we can set 20% discount field then WPML changes this value as simple currency for example USD to EUR. Then we don't have 20% any more just 18.11%.
I think percentage values should not be edited. It would be nice if you could prepare for me testing env so I can set all plugins so you can fix that problem.
September 11, 2019 at 9:05 am #4551911
Alejandro
Hello!
Welcome to WPML Support.
I'll do my best to help you solve this issue.
Could you upload that plugin in this sandbox: hidden link
Then, replicate the problem over there and lastly tell me how to do so, so i can take a look and determine if we're talking about a compatibility issue (it sounds like it).
Thanks in advance.
September 11, 2019 at 6:13 pm #4555885
patrickW-37
Hi, I uploaded WooCommerce Product Add-ons plugin but I wasn't able to update WPML CMS Multilang. plugin so WooCommerce Multilingual was not working (undefined error when after clicking update button). I deleted these outdated plugins and tried to install my, up-to-date wpml plugins but upload speed to your testing env. is very very slow...
So - could you install newst versions of your WPML plugins on the testing env so I can finish replicating my problem?
September 12, 2019 at 6:01 am #4558537
Alejandro
Try now, please.
September 13, 2019 at 7:32 pm #4570511
patrickW-37
Ok, so as you can see. Value1 (-20%) is constant, percentage value and it shouldn't be changed when user switches currency to EUR from PLN.
But now - if you try to change currency then -20% is changed to 4.62%.
Other fields with lets say 'int' values are converted correctly.
September 16, 2019 at 8:30 am #4577407
Alejandro
Hello, i just wanted to let you know that the problem seems to be a bug, i ran a lot of tests and the result didn't change.
I asked one of our developers to take a look at it and i'm waiting on his feedback.
I'll let you know once i have it.
September 16, 2019 at 8:41 am #4577485
patrickW-37
Thank you very much for your support 😉
I am waiting for your reply
September 16, 2019 at 1:33 pm #4580809
Alejandro
As i thought, It's actually the first time we hear about this issue and there weren't any other related issues about WooCommerce Add-ons either so you definitely spotted a bug.
Our Compatibility team has checked out the issue and they are now working to find a solution to the problem.
I'll update you as soon as i have more information.
Regards.
September 26, 2019 at 3:03 pm #4648177
Alejandro
We found a workaround while we work on a permanent fix.
Go to wp-content/plugins/woocommerce-multilingual/compatibility/class-wcml-product-addons.php and change the foreach loop from:
				foreach ( $addon['options'] as $key => $option ) {
					if (
						$is_custom_prices_on &&
						isset( $option[ 'price_' . $client_currency ] ) &&
						$addons[ $add_id ]['options'][ $key ]['price'] = $option[ 'price_' . $client_currency ];
					} else {
						$addons[ $add_id ]['options'][ $key ]['price'] = apply_filters( 'wcml_raw_price_amount', $option['price'] );
to:
					if (
					} else {
						if ($option["price_type"] !== "percentage_based" ){
Try it out and let me know how it goes.
Regards.
September 29, 2019 at 11:37 am #4660647
patrickW-37
Thanks for your support. Modified code works fine, I think now it should be added in the next update 😉
