Hi, the theme is atelier the problem at first was on the Meta option, when I click on the overwrite button the system do not overwrite the Meta option than I set to copy all the custom fields and than the tranlated page overwrite the meta option but from than is not possible to make change on the option. The rest of the translated page is ok.
Can you help me?
Since you have marked the fields as copy, you can't add it's translations, could you please mark it to translate or copy once to fix the issue? Does this help?
Further, we recently released new versions of WPML plugins with fixes and improvements so could you please update the plugin to the latest version and let me know if this helps?
NOTE:
+ Make a backup (both files and database) for your site before updating/proceeding anything (Always a good practice!). You can use a plugin for this if you like. I often use the Duplicator plugin for this purpose. See: http://wordpress.org/plugins/duplicator/
Look forward to your reply.
The topic ‘[Closed] Problem with product translation’ is closed to new replies.
