This topic contains 29 replies, has 2 voices.
Last updated by Carlos Rojas 9 months ago.
August 28, 2019 at 3:02 pm
vittorioF
I have a problem with the slug translation of a custom post type.
When I create the translation of a page from the main language (Italian) to the secondary language (English), in the editing screen (screenshot) I see the slug of the product not in English, although I have set the translation from the WPML settings.
When I click on the preview it also shows me the page, but the post type slug remains untranslated.
I followed all the indications I found in the forum, but I still have the problem.
August 29, 2019 at 10:00 am #4479655
Carlos Rojas
1.- I just visited the site and I assume that the "Portfolio" post type is the one you are referring to. In this case you need to follow this steps:
- Go to WPML -> Settings -> Post Types Translation -> Select the "Portfolio" -> Change the slug there.
As an alternative you can:
- Go to WPML -> String Translation -> Search for the slug -> Translate it there.
2.- Please increase the PHP Memory Limit. Minimum requirements are 128Mb: https://wpml.org/home/minimum-requirements/
/** Memory Limit */
Kind regards,
Carlos
August 29, 2019 at 10:06 am #4479787
vittorioF
Hi Carlos!
1) I've already done these operations, in fact if you go to the pages you should see them translated.
Although I still have problems, do you have any idea what the problem might be?
2) Memory limit increased.
August 29, 2019 at 11:38 am #4480563
Carlos Rojas
Thank you for your feedback.
Just to confirm: You desire to show 'prodotto-orphea' in Italian and 'product-orphea' in English, correct?
Carlos
August 29, 2019 at 11:42 am #4480575
vittorioF
Yes, in "products-orphea".
August 29, 2019 at 12:40 pm #4480933
Carlos Rojas
I applied several troubleshooting options but the issue persists. I have created a test site with a fresh new WordPress install and WPML plugins installed and setup too.
I kindly ask you to log in the test site by using this link: hidden link
and install the plugin or theme that creates this custom post type and let me know if the issue persists.
August 29, 2019 at 1:00 pm #4481131
vittorioF
Hi Carlo,
I added the themes.
Thanks so much.
August 29, 2019 at 1:51 pm #4481493
Carlos Rojas
Could you tell me if the issue persists?
Carlos
August 29, 2019 at 2:01 pm #4481585
vittorioF
Hi Carlos,
in sandbox I set the slug post type and it works.
Instead in the site I continue to have the problem.
Thanks so much.
August 29, 2019 at 2:08 pm #4481645
Carlos Rojas
It seems we might be facing an interacction issue with a third party functionality. In this case I would like to ask you to follow this steps in order to isolate the cause of the issue:
- Back up your site first before making any change, this is for security reasons.
- Update all outdated plugins and themes.
- Flush any cache memory that might exists.
- Deactivate all the plugins that are not related to WPML.
- If the issue is gone, activate one by one to see with which one there is an interaction issue.
Could you tell me the result of this steps?
Carlos
August 29, 2019 at 2:44 pm #4481879
vittorioF
Hi Carlos,
I deactivate all the plugins and I find the plugin that cause the conflict: "wp-category-permalink".
I use this plugin for create a URL that have the category, for example: mysite.com/products/category-product/my-product.
How can I add, with WPML, the main category in the slug?
August 29, 2019 at 7:41 pm #4483319
Carlos Rojas
I think you can add the main category in the slug in Settings -> Permalinks
Carlos
August 30, 2019 at 7:47 am #4485135
vittorioF
Hi Carlos,
in this page i see only the structure for all the permalinks.
If I enter "/%category%/%postname%/" it doesn't work.
The plugin allowed me to add it.
Could you tell me how to add in the name of the category in the slug?
Thank you so much for your support.
August 30, 2019 at 9:00 am #4485455
Carlos Rojas
Could you explain what do you mean by: "it doesn't work"?
- Does the site throws an error? or the URL structure is not what you expected?
Carlos
August 30, 2019 at 10:06 am #4486237
vittorioF
If I set the permalink in this way (screenshot 1).
Then I go in one article of my custom post type but I don't see the category in the slug (screenshot 2).
I need to add the category to the slug, for example: mysite.com/product-category/product-name
