Problem: I am getting this error:
We have detected a problem with some tables in the database. Please contact WPML support to get this fixed.
Solution: If you have WPML v4.0.7 or earlier, it is safe just to dismiss that notice as it could be a one-time event due to updates, all will be fine for WPML then. We had a similar issue before, but it was handled already in the current version. You see this error since you are just upgrading from the old version (which produced that error) to the new one.
In case you can’t dismiss this notice, you can solve it by removing the empty value from your database table "wp_icl_strings" using database tool like PHPMyAdmin or similar. Before doing that please Backup your database and website for safety.
Last updated by agnesN-2 1 year, 10 months ago.
October 1, 2018 at 10:48 pm #2779617
agnesN-2
I see the following in the backend on the plugins page:
Array
[language] => en
[context] => woocommerce
[gettext_context] =>
[domain_name_context_md5] => 267cc53454cb3dcfb04ec4f77524beff
[name] => 06de17789da6813ae428a4bc3297af73
[value] => Sorry! We tried, but we couldn't connect Jetpack just now ?. Please go to the Plugins tab to connect Jetpack, so that you can finish setting up your store.
[status] => 0
[translation_priority] => optional
[allow_empty_value] =>
I don't see any problem with the site itself. I have this both for my clone site and live site.
October 3, 2018 at 8:38 pm #2785727
Itamar
Thank you for contacting WPML Support. It is safe just to dismiss that notice as it could be a one-time event due to updates, all will be fine for WPML then. We had a similar issue before, but it was handled already in the current version. You see this error since you are just upgrading from the old version (which produced that error) to the new one.
Please, see a reference to this issue in another ticket here.
https://wpml.org/forums/topic/we-have-detected-a-problem-with-some-tables-in-the-database-27/
Is dismissing the message solves the issue for you?
Itamar.
October 4, 2018 at 9:42 pm #2788849
agnesN-2
