Last updated by Radu 1 year, 3 months ago.
Assigned support staff: Radu.
April 20, 2019 at 10:38 am #3650037
lauriL-5
For some reason I cannot change/translate some of the links in my global footer to Finnish language. In the page translation (original Estonian translation to Finnish) I translated the global footer, but several links do not change although after saving the translation the links in the translated box are saved correctly. But when I check the translation in the Finnish language homepage the link is still incorrect. Could you please let me know what should I do to fix this issue.
Lauri
April 22, 2019 at 9:08 am #3654747
Radu
Hey Lauri,
Is there any chance that you could give me access to the dashboard area of your website? This way I'll be able to check this out a bit closer and see what's going on. Also, a link to the edit page of the footer would be great. This way I can make sure that I'm looking at the right part.
I made the next reply to be private so you can safely send the credentials.
Radu
April 24, 2019 at 7:41 am #3669851
Radu
Hey Lauri,
Can you tell me how did you edit the links from the footer, please? Did you use this library hidden link and just add the links through the frontend builder? I just want to see how this was created so I can look how can it be translated.
Radu
The topic ‘[Closed] Problem with the Divi global footer links.’ is closed to new replies.
