we just translated the pages to DE in IT languages. But the META box values from JetEngine did not copy to the other language.
We are attaching the screenshots.
In this case, I kindly ask you to:
1.- Share the URL of the content where the issue can be seen and that we can use as a reference.
2.- Also, please share the access credentials to the site in your next message, which I have set private, so I can reproduce the issue and double-check the WPML configuration.
I kindly ask you to be more specific and tell me exactly which custom fields are missing. This will help me isolate the cause of this behavior and find a solution.
these are all missing that are seen on the attached photo. They are missing here: hidden link - on the german version of the back end of page Central Bled House. Its the same for other accommodation subpages.
There is a misunderstanding. The meta boxes won't appear when manually editing the translated post. They will be translated in the translation editor when translating the content.
we are attaching the screenshot, where you can find the filters that can use the data from the metaboxes. See the difference between DE in EN versions for example.
