Problem: The user was having some Javascript errors that prevented him from finishing the Translation Management wizard. Uncaught ReferenceError: OTGSUI is not defined Solution: Copy \sitepress-multilingual-cms\vendor\otgs\ui\dist into root folder
Last updated by patrycjaS-3 8 months, 3 weeks ago.
September 4, 2019 at 3:45 pm #4512591
patrycjaS-3
When I want to set up my translation management I see following error
September 4, 2019 at 4:57 pm #4513041
Jamal
Timezone: Africa/Casablanca (GMT+00:00)
We have had a previous ticket similar to this one and we were able to work around it by copying the folder \sitepress-multilingual-cms\vendor\otgs\ui\dist in the root folder of the website.
Can you try this workaround? Or maybe allow me to access your backend and try it?
Jamal
WPML Support
September 6, 2019 at 2:51 pm #4526097
Jamal
Thank you for the access information. I was able to log in.
The FTP access in the other hand lands me to a folder that contains other folders and I don't know which one is your website.
So, I installed the "File Manager" plugin to browse the website files, but I only can access the wp-admin folder.
Can I take a Duplicator package of your website and check if I could resolve the issue locally?
Jamal
September 10, 2019 at 10:18 am #4543893
patrycjaS-3
Hi Jamal, thank you for your support. I added the proper folder in the past private massage for you (by editing - pls check it).
September 10, 2019 at 10:33 am #4544231
Jamal
Thank you. I think I got the right folder and copied \sitepress-multilingual-cms\vendor\otgs\ui\dist from WPML Multilingual CMS to the root folder of the website. It seems to resolve the issue of the Translation Management Wizard.
Would you try now?
Jamal
September 10, 2019 at 10:44 am #4544305
patrycjaS-3
