Last updated by Shekhar Bhandari 2 years ago.
May 9, 2018 at 4:59 am #2042926
jayC-4
I am trying to: Translate an entire website to Chinese, but the translation editor is missing certain parts of my website including a couple of pie charts. When I translate them directly on the WPBakery Front-end editor, they appear to work for a while but then revert back to English.
Link to a page where the issue can be seen: hidden link and hidden link
I am using Pillar Multi-language Theme by tommyrhodus and the WPBakery page builder.
May 10, 2018 at 4:34 am #2064979
Shekhar Bhandari
Hello there,
It seems like the shortcode used to create that content is not registered, could you please check which shortcode is being used there and create a wpml-config.xml file to translate it accordingly as shown in the below documentation:
You can know more about creating configuration files here: https://wpml.org/documentation/support/language-configuration-files/
Let me know if this helps.
May 10, 2018 at 5:11 am #2065156
jayC-4
Thank you for your reply. I checked and added the shortcode "pillar_card" in the xml file but it is still not working. I tried both with and without adding the attribute tag. Please see the attached screenshots for reference.
May 10, 2018 at 5:15 am #2065160
Shekhar Bhandari
Hello there,
This seems unusual, to further debug this issue,I need to request temporary access (wp-admin and FTP) to your site in order to be of better help. You will find the needed fields for this below the comment area when you log in to leave your next reply. hidden link
These info is private, and available to you and supporters only. Read more about this: https://wpml.org/purchase/support-policy/privacy-and-security-when-providing-debug-information-for-support/
Note that:
#1
Backup (both files and database) your site before giving us your credentials. You can use a plugin for this if you like. I often use the Duplicator plugin for this purpose.
See: http://wordpress.org/plugins/duplicator/
Duplicator instruction
It would be better if you give me the test site rather than the live site.
#3
If the issues need some changes in the plugins updates/disabling we will install a plugin called “duplicator” and replicate the site in our local server for testing.
Look forward to your reply.
The topic ‘[Closed] Problem with Translation Editor Missing Text’ is closed to new replies.
