Last updated by Riffaz 8 months ago.
October 2, 2019 at 11:06 am #4679467
danilod-5
hi, i would like to translate my website. I have problems with page translation made with the king composer plugin. I read this guide:
https://wpml.org/forums/topic/how-to-translate-pages-created-by-king-composer/
but unfortunately I can't select the manual translation (see screenshot), how can I do it? thank you, Danilo
October 2, 2019 at 1:11 pm #4680403
Riffaz
That option was removed from there in latest versions.
Off this option: hidden link
You will get a popup.
select "All the site's contents"
Then you will be able to translate independently .
Hopefully this will fix your issue.
Riffaz.
October 2, 2019 at 2:16 pm #4681327
danilod-5
OK thanks 🙂
do you have any advice for me about king composer translation?
thank you, Danilo
October 3, 2019 at 6:32 am #4684807
Riffaz
you are welcome.
Nothing much. you have to translate it like creating another page. 🙂 that's all.
King Composer is not listed in our list of compatible plugins: https://wpml.org/documentation/plugins-compatibility/
As King Composer is a page builder that uses shortcodes, it only need the wpml-config XML file to achieve compatibility. You can read more here:
- https://wpml.org/documentation/translating-your-contents/page-builders/
- https://wpml.org/documentation/support/wpml-integration-with-page-builders-that-use-shortcodes/
You can contact King Composer support and ask them to participate in our Go-Global Program, this way our team can help them achieve compatibility: https://wpml.org/documentation/theme-compatibility/go-global-program/
Riffaz.
