Our next available supporter will start replying to tickets in about 1.76 hours from now. Thank you for your understanding.
Last updated by amjadA 6 years, 6 months ago.
Assigned support staff: Beda.
January 14, 2015 at 11:47 am #542315
amjadA
Please help me
My web site English Arabic
I have big data
I install plugin wpml after that i upload data then
The problem of theme and technical support to Theme appeared upload WooCommerce Multilingual
after that every thing is ok but in arabic web site Size & color No in all products
this Arabic
this English hidden link
Please help me Thread fateful and data very large
January 14, 2015 at 3:54 pm #542526
Beda
Hello Amjad
I will take care of your ticket.
Could you please share your Debug Informations with me?
Please make sure all Plugins and the Theme is updated correctly.
Please also make sure that "Translate with WPML" is selected in WPML > Theme and Plugin localization.
Can you confirm to have correctly translated your product attributes and categories?
Do you have selected to Synchronize all taxonomies and category parents to translations in WPML > Translation Management > Multilingual Content Setup?
Could you also elaborate who you imported your data?
Was it already translated on import, or did you translate it afterwards?
Please also let me know if you would prefer a Arabic Speaking Supporter.
Thank you
January 16, 2015 at 7:41 am #543589
amjadA
Thanks For replaying
My problem was solved
Everything is good
But I have a small problem
There are some words did not translate to me and did not find it
You can see print screen
Please help me
January 18, 2015 at 7:44 am #544432
amjadA
Please help me
January 18, 2015 at 2:09 pm #544484
Beda
Hello Amjad
Please double check in WPML > WooCommerce Multilingual > General Settings if all store pages have been created properly
(if no error warnings display there, all should be good.)
Please also try to search for those words (strings) in WPML > String Translation.
If you find them untranslated, please translate them and save them.
In case you don't find them, please scan the plugin "WooCommerce" for new strings in WPML > Theme and Plugin localization, after having activated "Translate with WPML"
If this all does not work please try it with this settings:
1. WP Theme Twenty Fourteen enabled
2. ALL Plugins disabled but WPML + AddOns, WooCommerce + WooCommerce Multilingual
Please let me know if it works afterwards.
Thank you
January 18, 2015 at 2:37 pm #544492
amjadA
Hello Beda
For this point
"Please also try to search for those words (strings) in WPML > String Translation.
If you find them untranslated, please translate them and save them."
Found and translators
For another points
I am afraid of the use of any process
Because the data is very important I do not have a backup
Please help me
January 18, 2015 at 5:57 pm #544556
Beda
Hello Amjad
I understand the issue was solved?
""Please also try to search for those words (strings) in WPML > String Translation.
Found and translators"
==> Are the strings now translated and properly displaying on your front-end?
If not, please check again all WooCommerce pages have been created, all WooCommerce Translations are installed and in WPML > String Translation all regarding Strings are translated and saved.
If you want to follow the recommended Debug Steps, please perform a full database and website backup so you are on the safe site if some data gets lost (which usually doesn't happen)
Please let me know if this works afterwards.
A backup is fully required even if we would solve the issue by having access.
We as support Team are not allowed to work on your site without having your permission and your confirmation that a backup has been made.
Always some data can get lost by error, this is why a full backup is so important.
Thank you
January 20, 2015 at 5:40 pm #546024
amjadA
For this i found words (strings) They present in WPML with translation but in my web site it's still no translation
For this point I will Scan them and i tell you whats happen
Thank you
January 21, 2015 at 1:08 pm #546546
Beda
Hello Amjad
I assume you have either some outdated WooCommerce Translations or not all pages of WooCommerce installed properly.
I also assume you will be able find and translate all those words (strings) in WPML > String Translation
(if the strings are generated by WooCommerce and not another 3rd party plugin/theme)
I have also double checked this issue with our Arabic Forum Supporter and he can confirm that all this words come translated by default if you correctly install and setup WooCommerce Multilingual.
Please inform me on the outcome
Thank you
January 21, 2015 at 1:30 pm #546574
amjadA
I am lost and do not know where to start, and this causes me a lot of problems
January 21, 2015 at 1:54 pm #546597
amjadA
I have another Question
I have tow plugin Discussion on Product Options for WooCommerce and WooTabs,Add Extra Tabs to WooCommerce Product Page
when i use any one in product English there no show in Arabic Why ?
Can you see this link hidden link
under the small photo you can see tab size then go the Arabic no
Why ?
please help me
January 21, 2015 at 5:52 pm #546756
Beda
Hello Amjad
Please could I gently ask you to open a new thread with the new issue?
This simplifies the search for solutions for other users.
Please provide me temporary access (WP-Admin and FTP) to your site
- preferably to a test site where the problem has been replicated if possible -
in order to be of better help.
==> Please backup your database and website <==
Please note that I can not perform the translations for you.
I can point you to the correct solution, and check the configurations in your Installation.
I will, according to this threads subject, check why the in the screenshots provided words (strings) don't get translated.
Thank you
January 22, 2015 at 11:58 am #547169
amjadA
Thank you My issue is resolved
