Problem: Suppress filters is not working correctly on the query. It's retrieving all posts regardless of language.
Solution: Make sure you are using the WP_Query method of fetching posts instead of the get_posts. With WP_Query you can use the suppress_filters parameter but with get_posts you will have to use the "pre_get_posts" action to insert the suppress_filters parameter in the query.
This topic contains 7 replies, has 4 voices.
Last updated by Michael 4 years, 1 month ago.
Assigned support staff: Yuri.
April 28, 2016 at 7:02 pm #871541
yuriyY-2
I'm having problems to show all posts in all languages of a custom post type in a query. 'suppress_filters' => true not working.
$wp_query = new WP_Query();
     query_posts(
        array(
         'suppress_filters' => true,
         'post_type' => 'blog_post',
         'showposts' => -1,
         'tax_query' => array(
                 array(
                     'taxonomy' => 'blog_category',
                     'field'    => 'slug',
                     'terms'    => 'update-notes',
                     'operator' => 'NOT IN'
     if(have_posts()):
     while ($wp_query -> have_posts()) : $wp_query -> the_post($post->ID);
     the_title();
     endwhile; endif;
     wp_reset_query();
April 29, 2016 at 1:29 pm #872120
Yuri
Hi Yuri, I've noticed that in your code you are instancing the WP_Query object and assigning it to the $wp_query variable but you are not using it to create you query. You are triggering the query_posts function without assigning it to any variable.
Can you rework your code to use only the WP_Query instance with the parameters you configured for the query_posts call? This should resolve the issue.
Yuri.
April 29, 2016 at 2:33 pm #872195
yuriyY-2
Hi, I already did that, same result.
    $args = array(
        'showposts' => -1,
                array(
                    'field'    => 'slug',
    $wp_query = new WP_Query($args);
    if(have_posts()):
    the_title();
    endwhile; endif;
    wp_reset_query();
April 29, 2016 at 3:35 pm #872243
Yuri
Hi Yuri, since the query is run by the WP_Query object you should have the resulting SQL query in the array returned. Would you mind posting that SQL query here so I can check to see what might be the issue with it?
Yuri.
April 30, 2016 at 12:54 am #872426
yuriyY-2
So if this method doesn't works, what is the right way?
April 30, 2016 at 12:55 pm #872537
yuriyY-2
I solved the problem by myself.
I would like to share with you, here it is:
    $args = array(
        'showposts'        => -1,
                array(
                    'field'    => 'slug',
    if($wp_query->have_posts() ):
        while ($wp_query->have_posts()) : $wp_query->the_post();
            the_title();
       endwhile;
    endif;
    wp_reset_postdata();
and more this piece of code in my functions.php
    add_action( 'pre_get_posts', 'wpml_custom_query' );
    function wpml_custom_query( $query ) {
         if( is_page('blog') ) {
              $query->query_vars['suppress_filters'] = true;
January 11, 2018 at 2:41 pm #1481689
arvinA-2
Hello. I used the solution of add action in functions that yuriyY-2 provided and it's working for me.
For some reason the paremeter "supress_filters" is not working in WP_QUERY.
September 25, 2019 at 9:13 am #4637095
Michael
Adding the 'pre_get_posts' action works for me too... except when I have a tax_query added to my query.
Does anybody have a solution to that ?
EDIT: It works with tax_queries when combined with this solution : https://wpml.org/forums/topic/custom-taxonomy-query-in-two-languages/#post-1453955
