Last updated by Bobby 1 year, 1 month ago.
April 22, 2025 at 7:33 pm #16957153
malinoo
I tried to install and translate my site strese17.de using WPML. I am using the HUSKY - Products Filter Professional for WooCommerce plugin for product filtering.
Without WPML, the product filters from HUSKY work fine. With WPML, the product filters from HUSKY aren't working besides one. This is when I am switching from German to English.
What do I need to do to fix the issue with the product filters?
Is there a bug or known issue with those product filters?
If I delete WPML, how can I ensure that all files are deleted correctly and I do not have some unused files in my WordPress installation?
April 23, 2025 at 5:03 pm #16961579
Bobby
WPML Supporter since 04/2015
When using WPML, your filter do not work only on the translated version, correct?
If possible, please verify that the products on your site are 100% translated and published, if they are not that can cause issues with the way the filter system works as it looks for a specific ID in the database.
The plugin is compatible with WPML:
https://wpml.org/plugin/husky-products-filter-professional-for-woocommerce/
There is a known issue listed here that our teams are working on resolving(does not look related to what you are experiencing):
https://wpml.org/errata/husky-products-filter-professional-for-woocommerce-product-category-links-not-correctly-translated/
Also, if you wish to delete WPML please follow the guide here:
https://wpml.org/faq/how-to-completely-remove-a-language-from-your-site/
https://wpml.org/documentation/getting-started-guide/language-setup/deleting-languages-and-plugin-data-by-doing-a-wpml-reset-on-your-site/
The topic ‘[Closed] Problems with the plugin HUSKY – Products Filter Professional for WooCommerce’ is closed to new replies.
