Last updated by simonP-14 9 months, 3 weeks ago.
April 22, 2019 at 9:39 am #3654949
simonP-14
I am trying to: Translate Read more and next button with string translation, but it is not working...
I expected to see: written "Več"
Instead, I got: "READ MORE"
On String translation to me it looks normal...
April 22, 2019 at 12:53 pm #3655765
Lauren
Can you please tell me how the Read More button is created? Is it a button that you create within the page, or perhaps an option in the Theme Options for what text to have there?
If it is a theme option, the string may be stored in the admin texts. Can you please go to WPML > String Translation and scroll down to the bottom of the page and click on the link "Translate texts in admin screens »". Then, scroll through that page and see if you find the the string. If so, tick the checkbox and click Apply to add it to the String Translation table. Now you can go back to WPML > String Translation and you should see the string added there.
April 23, 2019 at 7:40 am #3660153
simonP-14
Hi Lauren,
I have checked the admin screens, but I can't seem to find the "read more" string.
April 23, 2019 at 4:46 pm #3666313
Lauren
Our Debugging Procedures
Privacy and Security Policy
**IMPORTANT**
April 24, 2019 at 2:12 pm #3673813
Lauren
I think this may be a conflict issue with your theme. I don't see the Toranj theme on our list of compatible themes: https://wpml.org/documentation/theme-compatibility/
To confirm this, please try temporarily switching to minimal settings. Disable non WPML plugins and switch to a default theme such as Twenty Nineteen (be sure to make a full backup of your site first). Then, see if you are able to translate the default theme Read More strings. If so, switch back to your main theme and check again to see if the string is translated.
Please let me know the results of this test.
April 24, 2019 at 2:35 pm #3674177
simonP-14
at the moment I cannot switch the theme (maybe during holidays), but we also have almost the same site for our vienna gallery... there the translation works fine...
If you want I can give you access to that website too...
April 24, 2019 at 7:39 pm #3676495
Lauren
Is your other site using the exact same theme? I can set up a copy of your site locally and test.
To best troubleshoot the issue, please make a snapshot of your site using the Duplicator plugin: https://wordpress.org/plugins/duplicator/. This will allow me to try and duplicate the error so that I can run further tests without interrupting your live site.
Once the snapshot is complete, either upload the snapshot ZIP file and the installer.php file to a file sharing service such as Dropbox (and share the link in your reply) or right click the Duplicator links in your wp-admin and paste in your reply.
Please note: It is important to reduce the size of the package so please exclude some paths like /cache or /uploads and also exclude archives and media files.
I will also need the username and password of an account that was created BEFORE creating the duplicator package.
I will enable the next reply to be private so only you and I have access to it!
April 29, 2019 at 1:33 pm #3703787
Lauren
Hi Simon, I found that you have String Translation disabled in WPML -> Theme and plugin localization. This is why the Read More translation is not showing. To confirm, I temporarily activated String Translation and I could then see the translation. Please see attached screenshot.
I switched it back to your settings, but in order to see the string translations, just select one of the options to load string translation in WPML -> Theme and plugin localization and this will resolve the issue.
April 29, 2019 at 4:17 pm #3705319
simonP-14
Ok, strange. Sorry about this, but I was sure it's on...
It was a bit strange that string translation was translating the contact details under the menu, even if it was turned off... the screenshots are before I turned it on...
Anyway, I am happy this is solved 🙂
Can you maybe also let me know how can I fix the uneven spacing in language switcher? Thanks
April 29, 2019 at 4:31 pm #3705611
Lauren
Glad I could help to resolve it. As the original issue is resolved may I kindly ask you please to open a new ticket for this question?
This will also help other users with similar problems find solutions when searching the forum as well as we avoid mixing lots of questions in one ticket.
April 29, 2019 at 4:32 pm #3705617
simonP-14
