Last updated by Riffaz 1 year, 1 month ago.
April 2, 2019 at 1:00 pm #3517311
rikkeL
I have a customer who is using WPML for translations, and she is using the Polo theme (hidden link)
The product carousel in the theme does not display products in the correct language.
hidden link (Se vores produkter) - is sometimes showing the english products in the product slider
hidden link (See all our products) - is sometimes showing the Danish version of the product slider
We have tried contacting the theme developers, but they told us that it is a WPML problem.
April 3, 2019 at 4:30 am #3522571
Riffaz
I could not find the polo theme in our compatibility list : https://wpml.org/documentation/theme-compatibility/
Anyhow, if the theme follows the standard procedure of WooCommerce and WordPress and then its should be translated correctly.
Since it's a new for us it might be a bug or need to do something in code level.
To confirm this we have to check / reproduce this in a fresh installation.
please:
1. go to hidden link
2. install your theme
3. configure the WPML as you have it in your site. at the last steps just click next (sitekey)
4. create only two products. one for main language and another one for another language
5. recreate the issue with the carousel.
6. let us know how to check this. please explain with screenshots and URLs for better understanding.
April 9, 2019 at 6:08 pm #3569923
rikkeL
I am sorry for the late response, it was more difficult to get the theme installed, than we thought it would be.
We have now created two products, translated these to Danish.
Test 1 - English (sorry for the text being in Danish, but it shouldn't matter in order to see the difference): hidden link
Test 2 - English: hidden link
Test 1 - Danish: hidden link
Test 2 - Danish: hidden link
We have added the Polo Product Carousel to the front page, and translated this into Danish:
Danish: hidden link
Both of these displays the Danish versions of the products.
Rikke
April 10, 2019 at 2:56 pm #3577591
Riffaz
Thank you for this.
I escalated this to our second tier.
Please be patient till we get back to you.
April 14, 2019 at 6:39 am #3607065
Riffaz
the problem is here:
wp-content/plugins/polo_extension/visual-composer-addons/woocommerce/product-slider.php line 157
            if ( false === ( $the_query = get_transient( 'crum_product_slider_transient' . $transient_id ) ) ) {
                $the_query = new WP_Query( $args );
                set_transient( 'crum_product_slider_transient' . $transient_id, $the_query );
                $this->update_id_option( $transient_id );
the addon plugin gets the products from the slider using transients (which WPML can't translate so far). If the transients are set, it uses them. If not, it queries again.
As a workaround, we can add after that piece of code the following:
if ( defined( 'ICL_SITEPRESS_VERSION' ) ) {
You can check the workaround works fine here:
Danish: hidden link
If you are not sure about this you can show this reply to your theme support.
Let me know how it goes.
April 16, 2019 at 7:15 am #3618787
Riffaz
Also, you can sow them this:
there is a simpler way of resolving this:
transients are stored in
wp_options
every option has a filter option_xxxxxxxxxx
so in theory you could add this code to, for example, functions.php in the theme:
add_filter( 'option_crum_product_slider_transient', '__return_false' );
this way, the transient is always recalculated because it always returns false.
April 16, 2019 at 7:24 am #3618869
rikkeL
Thank you so much for all your help. As a first we are trying to get the theme developers to implement the change, otherwise, we will have to do it ourselves.
I will let you know when we have the issue fixed, and thank you once again for absolutely great and fast support - I wish everybody was as helpful as you guys 🙂
April 16, 2019 at 7:26 am #3618901
Riffaz
You are welcome.
I am updating the ticket status.
