Last updated by Marcos Vinicios Barreto 10 months ago.
Assigned support staff: Marcos Vinicios Barreto.
October 1, 2019 at 9:15 am #4670073
maxL-15
The description of the .nl domain is gone for this specific product. In other languages, it is shown correctly. I tried updating it but it is still hidden. How can we fix this?
October 1, 2019 at 5:59 pm #4674533
Timezone: America/Bahia (GMT-03:00)
Thank you for contacting WPML Support. Can you please confirm if you see the product short description content in the backend? Here is how you can confirm it:
1 - In your WordPress Dashboard > Products settings click to edit the mentioned plugin and switch the dutch language.
2 - Now, check if the product short description is visible in the product editing screen, if not, please manually enter it and take a look at the product frontend again.
Please, let me know if it fixes your issue, have a nice day.
October 1, 2019 at 7:09 pm #4675027
maxL-15
Sorry, what are you meaning by: click to edit the mentioned plugin and switch the dutch language?? What has a plugin to do with this?
October 1, 2019 at 7:10 pm #4675029
maxL-15
If you are asking me to check if there is a description in the product, then Yes there is a description. A short and long one. It all looks fine.
October 1, 2019 at 7:17 pm #4675039
Sorry for the confusion. I meant 'click to edit the mentioned product and switch the dutch language'. If there's a description for your product and it doesn't show in the website frontend, then we need an additional investigation here, for that, please consider:
Our Debugging Procedures
Privacy and Security Policy
**IMPORTANT**
Please, let me know if you need any additional details. Have a nice day.
October 3, 2019 at 7:02 pm #4690905
Thank you for the provided details. I took a detailed look for the mentioned product description in your edit product admin section and noticed there was a lot of html markup not really needed to present the description and it seemed to be the cause of the issue as HTML output in most cases are stripped as PHP code output in your theme files.
I removed the extra markup and use just the standard ones exactly as it is in the english product desciption, now it is working properly as you can confirm at: hidden link.
Please, let me know if you need any additional assistance and clarifications, have a nice day.
