Last updated by marijnA 5 years, 8 months ago.
Assigned support staff: Mladen Andrejic.
November 18, 2015 at 5:29 pm #749420
marijnA
I am trying to: display products on my site
URL of (my) website where problem appears:
hidden link works
hidden link gives 404
hidden link gives 500
I expected to see:
translated products
Instead, I got: error as above
November 19, 2015 at 10:00 am #749911
Mladen Andrejic
1. Can you please do the following for permalinks :
- Go to WPML > String Translation
- Find the slug permalink (and it's translations)
- Mark that string and under the table click on "Delete String"
- Then go to Settings > Permalinks
- Click on Save (to re save them)
- Now go to WPML > Translation Management > Multilingual Content Setup
- Under Custom Post Type you will see the Products and also slug for main language
- Click on "Use different slugs for Products" and enter the translation
- Hit Save
2. If the problem still persist, please check it when
- All non WPML Plugins are disabled
- Theme is set to default Twenty Fourteen
3. Activate WordPress debug.log and see if there are any errors displayed? Here are the instructions for activating it : https://wpml.org/documentation/support/debugging-wpml/
4. You can also check the Chrome built-in JavaScript Console for errors. To open the console go to Menu (Three Bars) > Tools > JavaScript Console
Please paste here any errors that you see in the WordPress debug.log or in JS Console.
// For 500 error - Please create a new ticket, as this is separate issue.
November 20, 2015 at 3:47 pm #751418
marijnA
great, the issue with the products is now solved.
Will create a separate issue for the 500 error
