May 28, 2020 at 12:22 am #6233813
violaH-2
Product variant values for sizes are not in the correct language: German values are on the English page and the German page does not have any values.
In some cases "Größe" and "Size" are correct, in some cases not.
I have already done
- woocommerce multilingual trouble shooting page
- clear cache in wpml - support
- tried to translate a product
May 28, 2020 at 12:26 am #6233815
violaH-2
do you have a hint to my question?
May 29, 2020 at 8:49 pm #6252931
Marcos Vinicios Barreto
Timezone: America/Bahia (GMT-03:00)
Thank you for contacting WPML Support. From the provided debug info I noticed you are running outdated versions of the WPML related plugin including the WooCommerce Multilingual plugin which had similar issues which is now solved on its most recent version, so, before a more detailed look, please try the following:
IMPORTANT: Please, note, a backup is required for security reasons and to avoid any data loss, you can use the https://wordpress.org/plugins/backupwordpress/ plugin for these backup needs.
1 - Make sure all the WPML related plugins are updated to their most recent vesions including the WooCommerce Multilingual plugin from your WordPress Dashboard > Plugins > Add New > Commercial tab settings;
2 - Now, proceed to your WordPress Dashboard > WooCommerce > WooCommerce Multilingual settings and click the 'Status' tab, then click the 'Troubleshooting' link and then click to synchronize your products variations;
Please, let me know if it solves your issue, have a nice day.
May 30, 2020 at 6:46 am #6254695
violaH-2
I installed the latest version 4.3.14 and the system showed several Fatal Errors. I was unable to proceed.
May 30, 2020 at 6:50 am #6254765
violaH-2
A main problem is, that I cannot save products in - Woocommerce - Multlingal - Product . The field for the english version of product attributes is empty then.
How to change product attributes in the 2nd language?
June 2, 2020 at 12:23 am #6268825
Thank you for the updates and sorry for the waiting here due the weekend. I would like to request temporary access (wp-admin and FTP) to your site to take better look at the issue. You will find the needed fields for this below the comment area when you log in to leave your next reply. The information you will enter is private which means only you and I can see and have access to it.
Our Debugging Procedures
Privacy and Security Policy
**IMPORTANT**
Please, let me know if you need any additional details. Have a nice day.
June 2, 2020 at 8:25 pm #6277305
Raja Mohammed
Hey Marcos, The client has migrated the site to the cloudways in a different ticket please check the migrated site details here https://wpml.org/forums/topic/fatal-error-after-wpml-update/#post-6243529 The ticket also has the site access.
June 4, 2020 at 7:07 am #6289997
violaH-2
hello,
did you check the installation on cloudways?
thx Georg
June 4, 2020 at 3:24 pm #6296321
violaH-2
I found that the attribute for Size/Größe is named differently in English and German.
German
<select id="grose" class="" name="attribute_grose" data-attribute_name="attribute_grose" data-show_option_none="yes"><option value="">Wähle eine Ausführung</option><option value="3-4 Jahre / 98-104 cm" class="attached enabled">3-4 Jahre / 98-104 cm</option><option value="5-6 Jahre / 110-116 cm" class="attached enabled">5-6 Jahre / 110-116 cm</option><option value="7-8 Jahre / 122-128 cm" class="attached enabled">7-8 Jahre / 122-128 cm</option><option value="9-11 Jahre / 134-140 cm" class="attached enabled">9-11 Jahre / 134-140 cm</option><option value="12-14 Jahre / 146-152 cm" class="attached enabled">12-14 Jahre / 146-152 cm</option></select>
English
<select id="groesse" class="" name="attribute_groesse" data-attribute_name="attribute_groesse" data-show_option_none="yes"><option value="">Choose an option</option><option value="3-4 years / 98-104 cm" class="attached enabled">3-4 years / 98-104 cm</option><option value="5-6 years / 110-116 cm" class="attached enabled">5-6 years / 110-116 cm</option><option value="7-8 years / 122-128 cm" class="attached enabled">7-8 years / 122-128 cm</option><option value="9-11 years / 134-140 cm" class="attached enabled">9-11 years / 134-140 cm</option><option value="12-14 years / 146-152 cm" class="attached enabled">12-14 years / 146-152 cm</option></select>
June 4, 2020 at 7:27 pm #6298297
Raja Mohammed
I am handling the issue on another ticket here https://wpml.org/forums/topic/fatal-error-after-wpml-update/ this ticket can be closed
June 4, 2020 at 11:36 pm #6299359
Thank you, Raja. Closing it now.
