This topic contains 30 replies, has 2 voices.
Last updated by Mihai Apetrei 1 year, 6 months ago.
Assisted by: Mihai Apetrei.
August 27, 2022 at 7:56 pm #11942109 | |
helenaH-3 |
ok i add the ip. can you please try if it work? |
August 27, 2022 at 8:34 pm #11942123 | |
Mihai Apetrei Supporter
Languages: English (English ) Timezone: Europe/Bucharest (GMT+03:00) |
Hi and thank you for the quick response. Unfortunately, the same issue takes place: I even tried a different browser. I add in the credentials and after I click the "Log In" button, the page simply refreshes, and then I have to introduce the credentials again, and nothing happens, the same issue keeps repeating over and over again. Maybe you can share with me the customer's credentials? Or try to create a new account? It is weird - it doesn't tell me that something is wrong but it also does not connect to the backend. Mihai |
August 28, 2022 at 6:57 am #11943031 | |
helenaH-3 |
The information I sent you is my login information. I will write to the client to arrange FTP access for you. I will send you the information tomorrow. |
August 28, 2022 at 10:03 am #11943437 | |
I see. As you can see in the screenshot that I attached, there's a 302 redirect that shows up when I click login so there's no way I can log in. Just FTP won't be enough for me to debug on this matter - I need access to the WordPress panel. The client can get in touch with the hosting company and tell them to either exclude "Romania" from the security limitations list or turn this off completely for 1-2 days. Otherwise, I am not sure how we will be able to debug this issue. Mihai |
August 28, 2022 at 11:46 am #11944103 | |
helenaH-3 |
ok i will contact my client and let you know. thank you |
August 29, 2022 at 3:39 pm #11951307 | |
Thank you. |
September 8, 2022 at 8:55 am #12011541 | |
helenaH-3 |
Hello, sorry for big delay. |
September 8, 2022 at 5:06 pm #12016529 | |
Hi there and welcome back! I was indeed able to finally log into the backend of the website. Now: 1. Can you please let me know what is the main shop page on this website? 2. Can you please share an example with me where I can see a product in the default language that was translated but it doesn't show up in the EN language? I will be waiting for your response. Mihai |
September 10, 2022 at 2:51 pm #12027097 | |
helenaH-3 |
There is no main page for shop but i sending you some links. The products are all translated but this that are not showing its lasts a couple of months. Greetings, Helena |
September 13, 2022 at 10:46 am #12041743 | |
Hi Helena and thank you for the update. 1. I have noticed that your website’s WP Memory Limit is 40MB. The WP memory limit needs to be increased as the minimum requirement for WPML is 128Mb WP Memory Limit: https://wpml.org/home/minimum-requirements/ ❌ Very important: please make a backup of your site (files & database) before following any of the upcoming steps ❌ Please add this to your wp-config.php file to increase WP memory: /* WP Memory Limit */ define('WP_MEMORY_LIMIT', '256M'); define( 'WP_MAX_MEMORY_LIMIT', '256M' ); Paste it just before: /* That's all, stop editing! Happy blogging. */ These settings can be limited directly by your hosting provider, so, if that’s the case, I recommend you to contact and ask them to modify them directly. If you can get even higher values It would be great. Please make sure you have updated the values successfully, You can verify them from WPML >> Support page. 2. After a backup is created, can you please go here (hidden link) and update everything to the latest version? Please let me know once that's ready. Thank you. Mihai |
September 19, 2022 at 2:51 pm #12080127 | |
helenaH-3 |
Hello, |
September 20, 2022 at 3:51 pm #12089001 | |
Hi there. If I can get written approval to duplicate the website in a local testing environment, then I can try things on my own without the risk to affect the live/production site. Please let me know if that would be ok for you/the client. Mihai |
September 22, 2022 at 8:14 am #12101649 | |
helenaH-3 |
Hello, the client approve to duplicate website to your server. Greetings. |
September 22, 2022 at 3:02 pm #12105413 | |
Hi there. Thank you for the confirmation. I'm leaving the ticket assigned to myself for now and as soon as I have more information, I will get back to you. Mihai |
September 28, 2022 at 8:28 pm #12144439 | |
Hi there. I wanted to get back with a short update, letting you know that I'm still digging into this very very strange issue which might prove to be a compatibility issue in the end. The site is already duplicated on my local and that's where I'm running the tests from. There are indeed some plugins (not the WPML ones) that break the site when you update them so I had to undo that process and just update the WPML plugins. As soon as I have any information, I will get back to you so that you can update the client, too. I'm leaving the ticket assigned to myself until then. Thank you a lot for your amazing patience throughout the debugging process. Mihai |
