Last updated by Bigul 1 year, 2 months ago.
November 11, 2020 at 12:52 pm
Sander
I've been having problems with my secondary translated products for quite some time. They seem to randomly disappear. In the past I was able to make them reappear again by disabling the WMPL translation mode, edit the translation, save it and then save the original. But now that doesn't work anymore.
November 11, 2020 at 1:28 pm
November 12, 2020 at 8:31 pm #7438091
Bigul
We have released a new version(4.4.5) of WPML. It has included some important bug fixes and improvements. So please upgrade to the latest versions of WPML after a full site backup and check is there any difference in the result - https://wpml.org/announcements/2020/11/wpml-4-4-5-bug-fixes-for-wpml-core-string-translation-translation-management-media-translation-and-more/
Just to make sure, the issue only happening with the products belonging to this category - hidden link?
Bigul
November 15, 2020 at 11:27 am #7451101
Sander
Hi Bigul,
Unfortunately it's not only happening on that page. It seems the products get randomly out of sync. I also have updated to 4.4.5, but the problem still exists.
I would really appreciate help.
November 16, 2020 at 8:06 pm #7461341
Sander
When can i expect a follow-up ?
November 16, 2020 at 8:38 pm #7461609
Bigul
Thank you for the feedback. It requires further testing. So please allows me to make a duplicator copy of your site using the Duplicator plugin - https://wordpress.org/plugins/duplicator/ for debugging the issue on my local server. It will help us to troubleshoot the issue without affecting the live site.
Bigul
November 17, 2020 at 12:49 pm #7466393
Sander
Hi Bigul,
Do you want me to make the duplicate, or will you do that?
November 17, 2020 at 7:42 pm #7469905
Bigul
Thank you for your permission. I made a copy of the site now, will debug it further locally, and get back to you as early as possible. Please wait.
Bigul
November 19, 2020 at 9:38 pm #7488215
Bigul
I was able to reproduce the issue on my local copy. The issue is existing after the initial WPML and WooCommerce Multilingual troubleshooting steps. But it shows the expected result for me after the following steps. It may be a cache issue.
a) Deactivate all the plugins that are not related to WPML except WooCommerce
b) Then hidden link was showing the expected output
c) Activate the plugins as a group of three or four
So please try the deactivation & reactivation of non WPML plugins after a full site backup and make sure the issue is existing or not.
Bigul
