This topic contains 12 replies, has 3 voices.
Last updated by Alejandro 1 year, 1 month ago.
April 17, 2019 at 10:26 am #3629607
giorgioA-4
HI, I NOTICED THAT THE PRODUCTS ARE NOT IN SYNC BETWEEN TRANSLATIONS
PRODUCTS OK hidden link
PRODUCT NOT OK hidden link
HOW CAN I FIX THIS?
THANK YOU
April 17, 2019 at 10:33 am #3629685
giorgioA-4
HI, I HAVE TO RECEIVED A REPLY FOR THIS TICKET https://wpml.org/forums/topic/products-dont-sync-between-languages/ AND THE TICKET IS CLOSED. HOW CAN I FIX THE ISSUE? THANKS
April 17, 2019 at 11:26 am #3630133
Raja Mohammed
I am reassigning this ticket to Alejandro who attended your chat, He will continue to help you with the issue.
It seems your login details are removed due to security reasons, I would request you to please share the details again. I have enabled the private fields for you to securely share the details.
Kind regards
Raja
April 17, 2019 at 1:10 pm #3631059
Alejandro
Hello, could you please flush your site's cache and disable the cache plugin if possible?
if you also have Server-side cache (which i believe you should if you use litespeed) then please flush it and disable it as well too.
Let me know what you did because before the chat went offline, i had checked with our developers and made a few tests and the product element is compatible and should work.
Please let me know how it goes so i can access again and run further tests.
April 17, 2019 at 1:11 pm #3631065
giorgioA-4
HI, HOW SHOULD I DO THAT?
April 18, 2019 at 8:30 am #3637359
Alejandro
You can do that by:
1) Finding LS Cache and flushing your cache (the option is sometimes called "Clear Cache" or "erased cache" )
2) After you clear it, disable the LS cache plugin
LS cache should be also part of your server, so they should have a different type of cache on the server itself, you can ask your hosting support to clear it and disable it for the time being.
I'm asking you to clear and disable it because cache helps us have fast websites but they do so by showing "old versions" of the site, and it's harder to spot what has really been done by us because some changes really don't go through and they are not visible until days or even months.
Let me know how it goes so i can continue.
April 18, 2019 at 9:17 am #3637583
giorgioA-4
HI, WHICH OPTION SHOULD I USE?
PLEASE SEE ATTACHED.
April 18, 2019 at 9:38 am #3637813
Alejandro
You can erase the ones with the red X on the screenshot attached below.
April 18, 2019 at 9:43 am #3637851
giorgioA-4
OK.
IN WHICH ORDER?
April 18, 2019 at 10:12 am #3638041
Alejandro
That shouldn't really matter, but try to do them from first to last (following the order of the buttons)
Regards.
April 18, 2019 at 10:16 am #3638119
giorgioA-4
OK.
CLEARED CACHE AND DEACTIVATED PLUGIN.
WHATS NEXT?
THANK YOU
April 19, 2019 at 1:55 pm #3646213
Alejandro
I found the problem and i believe we're dealing with a bug.
However, i was able to find a workaround in case you're in a hurry..
I explain everything that's happening and walk you through the workaround i just mentioned:
What i explain is basically what's explained in this documentation: https://wpml.org/faq/how-to-link-already-translated-pages/
I'll notify you as soon as the proper fix has been made and has been released.
Regards.
April 23, 2019 at 4:55 pm #3666381
Alejandro
The compatibility team told me that this is not really a bug and it's the way the plugin has been designed to work with this shortcode, so you'll have to change the source language of this page as shown in my last reply, in order to make it work.
Regards.
