Last updated by Marcel 8 months, 1 week ago.
Assigned support staff: Marcel.
September 23, 2019 at 8:22 pm #4626503
jesperH-9
I use WPML on my ecommerce site where I have a .dk domain (default) and a .se domain with a swedish translation.
It seems like my site is not registering correctly when it should use SEK instead of DKK (DKK is the default currency). The products, the "Cart" page and the "Checkout" page is showing the currency correctly in SEK when on the .se site, but when the order is submitted the order currency is then DKK. Is there a way I can solve this? A few weeks ago I did not have this problem when I made test orders, so could it maybe also be an issue with the new plugin updates after 9/9?
Maybe the following error message from when I look at the individual orders in the control panel is related to the issue (the error is at the bottom of every order when the WPML string translations plugin is activated (Maybe there is some issue with my "WPML String Translation" plugin or something else??)):
Fatal error: Uncaught Exception: Invalid order. in /var/www/---/wp-content/plugins/woocommerce/includes/data-stores/abstract-wc-order-data-store-cpt.php:101 Stack trace: #0 /var/www/---/wp-content/plugins/woocommerce/includes/class-wc-data-store.php(159): Abstract_WC_Order_Data_Store_CPT->read(Object(WC_Order)) #1 /var/www/---/wp-content/plugins/woocommerce/includes/abstracts/abstract-wc-order.php(111): WC_Data_Store->read(Object(WC_Order)) #2 /var/www/---/wp-content/plugins/woocommerce-multilingual/inc/currencies/class-wcml-multi-currency-orders.php(143): WC_Abstract_Order->__construct(5139) #3 /var/www/---/wp-includes/class-wp-hook.php(288): WCML_Multi_Currency_Orders->_use_order_currency_symbol('kr') #4 /var/www/---/wp-includes/plugin.php(208): WP_Hook->apply_filters('kr', Array) #5 /var/www/---/wp-content/plugins/woocommerce/includes/wc-co in /var/www/---/wp-content/plugins/woocommerce/includes/data-stores/abstract-wc-order-data-store-cpt.php on line 101
I hope you can help with this issue.
Jesper
September 24, 2019 at 4:57 pm #4633137
Marcel
Hi Jesper,
Thank you for contacting WPML Support. The error message looks connected. Can you please try to deactivate all plugins except WPML and try if it works? I would recommend you do this first on a Staging environment, if you need to work on production please create a full backup before.
Please let me know.
Best Marcel
September 24, 2019 at 7:09 pm #4633787
jesperH-9
Hi Marcel,
I have just tested it, and the error message is still there - maybe it can be something with that in both dansih and swedish the currency symbol is "kr"?
Best Jesper
September 25, 2019 at 10:41 am #4637965
Marcel
Hi Jesper,
I want to check this on your site using a PHP Debugging. For this, I need to request temporary access (WP-Admin and FTP) to your site
in order to be of better help and check if some configurations might need to be changed
✙ I would additionally need your permission to de-activate and re-activate Plugins and the Theme, and to change configurations on the site. This is also a reason the backup is really important.
Thank you
Best Marcel
The topic ‘[Closed] Products shows curency in SEK, but when order is submitted it is DKK (default)’ is closed to new replies.
