Last updated by Shekhar Bhandari 1 year, 9 months ago.
May 15, 2018 at 8:01 am #2130537
awnv
I want to re-order the order of my products.
But I want to do this per language, so that I can set another order in English and yet another order in Dutch.
Is this possible, and if so, can you tell me how I can fix this?
Thank you!
Kind regards,
Jasper
May 16, 2018 at 6:24 am #2150061
Shekhar Bhandari
Hello there,
I am not able to understand your requirement completely, could you please elaborate it, are you trying to re-order the orders you have received from the WooCommerce->Orders? Or are you trying to order the orders on your my-account page? Could you please attach few screenshots to make this clear?
Look forward to your reply.
May 17, 2018 at 10:37 am #2173910
awnv
Hi Shekhar,
Thank you for your reply...
I will try to explain my question:
In the frontend I want a different order / sequence on the Dutch version of my website... so I want to change the order / sequence in the backend of the webshop by hand (Dutch & English seperated). So that I can set a different order / sequence for each language.
Hope it is clear for you now... 🙂
Jasper
May 18, 2018 at 7:31 am #2187318
Shekhar Bhandari
I want a different order/sequence on the Dutch version of my website.
I think you are talking about how the products are showing on your website, like how it's sorted, this thing totally depends on the theme and how it's configured, if you want a different order for the secondary language you should edit the query which is loading the product itself and add args for the order.
I am not sure how your theme is creating the query to load the product but this might help.
https://codex.wordpress.org/Class_Reference/WP_Query
Being said so, to achieve this you need custom programming work which is beyond the scope of our support.
At this point, I would suggest you consider contacting one of our certified partners from this link: http://wpml.org/documentation/support/wpml-contractors/
Before doing so please have a look also here:
http://wpml.org/documentation/support/wpml-contractors/guidelines-for-people-looking-for-consulting-help/
You will get the custom assistance you need to get on with your project.
