Last updated by Bobby 1 year, 3 months ago.
Assigned support staff: Bobby.
February 19, 2019 at 1:48 am #3214547
HiroyukiNishizono
Could you teach me if there is the method to register the contents more easily?
ex) use command line
February 20, 2019 at 12:50 am #3219337
Bobby
i apologize but i am not sure i fully understood the question
if possible please provide me with some additional information so i can better understand
WPML offers
1. manual translation (you are able to access the translated content and view the page builder)
2. The Translation Editor (side by side translation)
3. Advanced Translation Editor
=>https://wpml.org/documentation/translating-your-contents/advanced-translation-editor/
February 20, 2019 at 8:21 am #3220214
HiroyukiNishizono
Thank you for your prompt reply.
I need to translate a lot of content.
So, I need a lot of time to register contents because I have to register through UI (1. manual translation).
February 20, 2019 at 7:29 pm #3223515
Bobby
I recommend testing out both the WPML Translation Editor and the Adanced Transaltion editor to see which one would fit best to increase productivity
unfortunately we do not currently have an option to do this through the command line
bellow you will find our hooks library and our wpml coding api also
-> https://wpml.org/documentation/support/wpml-coding-api/wpml-hooks-reference/
February 26, 2019 at 8:39 am #3243504
HiroyukiNishizono
Thank you for your reply.
I understand that the command line can not be used.
We are considering using WordPress site with CI/CD.
For example, we will set the same settings as the content translated in the staging environment,
I would like to apply it easily to production environment.
Could you teach me If you have any good solutions?
February 26, 2019 at 7:17 pm #3246966
Bobby
We do not officially support composer since our plugins are premium.
However, one of our clients was able to use WPML with composer kindly refer https://wpml.org/forums/topic/installing-wpml-via-composer/#post-794991 .
Maybe it can help you as well, Please note we have not tested this and at this moment we don't endorse it. It's up to you to use it on your own risk.
You can send us a feature request directly, we will definitely consider and try to implement the popular request.
https://wpml.org/suggest-a-new-feature-for-wpml
