Problem:Registration problem
Solution:This error might also be happening due to the repositories.xml missing from /vendor/otgs/installer.
Go to wp-content\plugins\sitepress-multilingual-cms\vendor\otgs\installer using FTP and from place the repositories.xml file .
repositories.xml file: =>https://plugins.svn.wordpress.org/woocommerce-multilingual/trunk/vendor/otgs/installer/repositories.xml
Once thats done you need to press "Check for updates"
Relevant Documentation:
Last updated by Michal 3 years, 11 months ago.
Assigned support staff: Bobby.
April 6, 2017 at 7:41 pm #1249248
Michal
Hello WPML team,
I want register WPML plugin to get automatic updates.
Inserting site key cause me error mesage about wrong URL during quick setup and I skipped it. Now is visible button Register WPML as on first attached picture. But when I click on button request is redirected to page with commerical plugins and I can't do anything.
My site is not accessible from whole Internet for visitors now, but I can eg. install plugins from WordPress repository.
I want block unknow external HTTP requests by WordPress parameter WP_HTTP_BLOCK_EXTERNAL, but I tried disable for while and nothing changed with my registration problem. Please define which hosts must be accessible for WordPress parameter WP_ACCESSIBLE_HOSTS, In similar request I found host "d2salfytceyqoe.cloudfront.net" but I am not sure it is correct and only one.
April 6, 2017 at 7:45 pm #1249251
Michal
I forgot attach screenshots...
April 6, 2017 at 9:35 pm #1249311
Bobby
Perhaps you don't have a DNS server that can resolve our servers or you might have some restrictions because of a firewall.
It is recommended to whitelist our servers api.wpml.org with IP 74.50.57.129 and wpml.org with IP 74.50.57.118 and test again.
please contact your hosting company and ask if their firewall is blocking access to WPML.org API ( api.wpml.org ) ?
we have two different calls being made so that installer can run and the WPML plugins can be updated.
One is the Amazon Cloud service where the initial URL would be: hidden link and the IP is 54.192.129.188 ( note that this being an external service the IP can change, we have no control over it )
The other is to the WPML specific API with the following IP: 74.50.57.24
Note : This may take some time to update to re-fetch the repositories again.
You can try installing any cron tasks management plugin and run the task for this manually.
April 7, 2017 at 8:42 am #1249548
Michal
Hello Bobby,
I have own server for hosting WordPress and everything is under my control.
Outgoing requests are not blocked by any firewall, only by WordPress configuration where I have:
define('WP_HTTP_BLOCK_EXTERNAL', true);
define('WP_ACCESSIBLE_HOSTS', 'api.wordpress.org,downloads.wordpress.org,wpml.org,api.wpml.org,d2salfytceyqoe.cloudfront.net');
I tried temporarily disable WP_HTTP_BLOCK_EXTERNAL, but nothing changed.
DNS resolving works fine, both api.wpml.org and wpml.org direct to IP address 74.50.57.24.
Is there anything what I can try?
April 7, 2017 at 4:54 pm #1250131
Bobby
Did you just add our IP addresses ? do note that it might take some time for the repositories to re-fetch
Try and go to Updates > Check for new updates and try to run them if any.
April 10, 2017 at 10:00 am #1250943
Michal
Where do I add your address?
I tried search new updates (/wp-admin/update-core.php?force-check=1) but nothing changed.
Why is view of commercial plugins empty? (No repositories defined.)
Is there something what I can to do?
April 10, 2017 at 5:19 pm #1251446
Bobby
May i kindly ask you to please share with me the contents of your .htaccess folder .
Q : Why is view of commercial plugins empty? (No repositories defined.)
A : This usually happens when your host cant reach our servers.
The quick way around it would be to manually update WPML by downloading our plugins from
=>https://wpml.org/account/downloads/
April 10, 2017 at 8:30 pm #1251566
Michal
Sure, my .htaccess file in DocumentRoot has content which created WordPress, nothing special:
# BEGIN WordPress
<IfModule mod_rewrite.c>
RewriteEngine On
RewriteBase /
RewriteRule ^index\.php$ - [L]
RewriteCond %{REQUEST_FILENAME} !-f
RewriteCond %{REQUEST_FILENAME} !-d
RewriteRule . /index.php [L]
</IfModule>
# END WordPress
Workaround with manual download for update WPML is clear.
April 10, 2017 at 11:49 pm #1251625
Bobby
If you are using Apache, please review the following documentation regarding on how to Allow hosts , and make sure you have allowed our IP's correctly for apache.
May 29, 2017 at 8:41 am #1286192
Michal
sorry for delay. I changed the settings according to your advice.
I allowed access from you IP addresses:
- 74.50.57.24
- 74.50.57.118
- 74.50.57.129
WordPresss parameter WP_ACCESSIBLE_HOSTS contains:
- wpml.org
- api.wpml.org
- d2salfytceyqoe.cloudfront.net
But nothing changed, registration of plugin is still needed.
Do you have another idea?
May 29, 2017 at 9:28 pm #1286848
Bobby
**Before we proceed I recommend to please take FULL BACKUP of your database and your website.**
I often use the Duplicator plugin for this purpose See: http://wordpress.org/plugins/duplicator/
I would like to request temporary access (wp-admin and FTP) to your site to fix the issue.
Thank you,
Bobby
May 31, 2017 at 12:05 pm #1288297
Michal
Grant access to the production environment will not be possible. Is it really not possible to try something else?
Maybe I could prepare another test environment, but it could take several weeks...
May 31, 2017 at 6:00 pm #1288718
Bobby
Let me know if that helped.
June 1, 2017 at 10:26 am #1289259
Michal
Hello Bobby,
you're right. File repositories.xml was missing, because I download beta version of WPML Multilingual CMS by mistake.
I made a manual upgrade to latest version all WPML components and registration has been smoothly completed.
WPML Media 2.1.24 => 2.2.0
WPML Multilingual CMS 3.7.0-beta-2 => 3.7.1
WPML Sticky Links 1.4.0 => 1.4.1
WPML String Translation 2.5.2 => 2.5.4
WPML Translation Management 2.2.7 => 2.3.1
Thank you for help.
