Related products don't appear on secondary language.
Setting the custom field '_wcrp_related_ids' to 'translate' solves the issue.
-On WPML > Settings > Custom Fields Translation, click 'Show system fields' -search for the custom field '_wcrp_related_ids' and set it to 'Translate' -Save. -edit the product. edit it on the original language. -translate the product. You should have the ID field in the WCML editor to add the ID of the translated related product.
Last updated by Craig 1 year ago.
Assigned support staff: Dennis.
May 1, 2019 at 8:39 pm
Craig
I have installed this plugin : https://wordpress.org/plugins/woo-custom-related-products/#description on Jupiter theme (Version: 6.1.6) but the related products seen here : hidden link don't show up on the alternate language view : hidden link
I can't seen to find any other control in WPML to make them show up ?
May 2, 2019 at 6:45 am #3722137
Dennis
Welcome to WPML Support forum.
I noticed the issue on your site. To be able to test why this is happening, please, can I install the Duplicator to make a copy of your site and install it on my test environment? This will help me debug the problem.
Kind regards,
Dennis
May 2, 2019 at 12:22 pm #3724421
Craig
Thank you Dennis. Please do go ahead..
regards
May 3, 2019 at 6:22 am #3731083
Dennis
Thank you for your reply.
I have successfully created a duplicator package. I will download a copy and try deploy it on my local machine. Then I will continue debugging your site locally and will give you feedback when I got some results.
Kind regards,
Dennis
May 3, 2019 at 8:16 am #3732083
Dennis
Could you please try these steps?
-Save.
Does it help? Please let me know how it goes.
Kind regards,
Dennis
May 6, 2019 at 12:26 am #3744131
Craig
Hi Dennis, Sorry I missed your reply. I followed those steps and do see the ID in the WPML translation editor.. but it doesn't show in the front end. Are you seeing the same on your test site ?
thanks
May 6, 2019 at 1:45 am #3744195
Dennis
It could be that you have assigned a wrong product ID for French translation. You should use the french product ID.
For example for 'Coffee Infographic' product the English product ID is 980, while its French product ID is 981.
Hope this helps. Please let me know how it goes.
Kind regards,
Dennis
May 6, 2019 at 3:25 pm #3750355
Craig
