Last updated by Itamar 9 months, 1 week ago.
August 28, 2019 at 3:49 pm
saraB-8
I am trying to translate my web. Look at hidden link
Spanish version is ok: hidden link
English version the plugin translates sentences twice and doesn't keep the "content builder creator" that gives structure and contents to the page.
I'm trying to do the same with the home page: but the plugin translates sentences twice and doesn't keep the "content builder creator".
Can you help me?
August 28, 2019 at 4:28 pm #4475915
Itamar
Hi.
Can you please tell me how I can see the issue on your site. When I check things now I see that the English page is trashed (deleted).
Also please correct the following as it might be part of the problem. By looking at the debug info that you have attached I can see that your server WP Memory Limit is set to 40M.
Our recommendations are to have the following as minimal requirements:
- PHP 5.6 and above (this OK with your installation) with a WP Memory Limit of at least 128MB and more if possible.
- MySQL 5.6 and above (this OK with your installation).
Please follow this link for detailed documentation:
Is it possible for you to change those to the minimum requirement?
You may need to contact your hosting provider for that.
Meeting those baseline requirements is most critical before starting to debug and sometimes solves issues like you experiencing.
Most important is to raise the WP Memory Limit.
Please try to raise it before you contact your hosting company.
You can try and do it from the wp-config.php file in your WordPress installation.
Insert this code in that file.
/** Memory Limit */
Add it before this line:
Could you please perform that procedure and see if it help?
Itamar.
The topic ‘[Closed] Repetition of sentences and contents not copied’ is closed to new replies.
