Last updated by John-Pierre Cornelissen 9 months, 3 weeks ago.
February 5, 2021 at 12:07 pm #8016205
Is it possible to retranslate a page with the ATE and use a different processor? The page was translated with Microsoft, but gives bad results, so I want to retranslate with Deepl.
February 5, 2021 at 12:45 pm #8016489
I just compared the translation with the online tools from Deepl and Azure/Bing, and it looks like it is translated with Deepl after all. So the translation is ok now.
I'd still appreciate how I can force a re-translation with a different engine when that's needed.
JP
February 8, 2021 at 12:10 pm #8031439
Raja Mohammed
The best way to re translate is to remove the translation and send the pages for translation again that wold generally force re translation based on the translation engine.
Regards
Raja
February 8, 2021 at 12:39 pm #8031941
Remove as in delete the translated post?
So if it were a blogpost, I would go to the posts page, search the post in the language I want to delete, and then delete it?
February 8, 2021 at 12:56 pm #8032473
Raja Mohammed
Yes, delete the translated post to get the translation done using new engines.
February 8, 2021 at 1:27 pm #8032877
Ok, thank you. That's what I did indeed.
