Last updated by Bruno Kos 11 months, 1 week ago.
Assigned support staff: Bruno Kos.
June 26, 2019 at 6:22 am #4089265
Kostas
Hi there. As in the title, i need the same products in both languages of the site.
The client was using qTranslate, i migrated, everything is fine, but now i have the same products in two languages. We do not want that.
So, the right steps will be (?)
1. delete all products in the other language (not main)
2. delete WooCommerce WPML plugin
3. make the right selection at the settings (links below)
is this correct? with these steps, will i get the same products at loops for example, in both languages? i have read this articles too.
https://wpml.org/forums/topic/use-same-products-categories-for-both-languages/
https://wpml.org/documentation/related-projects/woocommerce-multilingual/displaying-untranslated-products-in-secondary-languages/
thanks
Kostas
June 26, 2019 at 8:30 am #4090465
Bruno Kos
Hi Kostas,
If I got your scenario right, this is how you would do it:
As for:
I would definitely not suggest this, if only for the following reasons:
- it will add some other capabilities when it comes to multilingual WooCommerce setup
- it will not force you to translate products - you can freely use the option link above even with this plug-in active
- it will allow you to use stuff like multicurrency, translating slugs (if needed), troubleshooting if needed and other functions
Bruno Kos
June 26, 2019 at 4:08 pm #4094031
Kostas
Hi there, first of all, thanks for getting back to me that fast.
I tried the above method but it only worked with NEW added products. For existing products it gives a 404 page. Is there something else i should do?
June 26, 2019 at 4:10 pm #4094037
Kostas
Sorry i just realised that it gave an error cause the product was in the trash... When i completely deleted it, it worked just fine... 🙂 So... i guess it is resolved!
June 26, 2019 at 6:00 pm #4094465
Kostas
i got an error about the product_type taxonomy sync.
What do i do here??
June 27, 2019 at 7:12 am #4097195
Bruno Kos
You should be seeing a button below this text which should allow you fix it - can you try clicking? If the issue is still there, can you check these topics and try what has been suggested there:
https://wpml.org/forums/topic/product_type/#post-3936959
https://wpml.org/forums/topic/i-get-a-notification-for-product_types/#post-2969567
https://wpml.org/forums/topic/product_type-field-was-set-incorrectly-for-some-product-translations-3/#post-2876745
https://wpml.org/forums/topic/we-detected-that-the-product_type-field-was-set-incorrectly-for-some-product-tra-4/#post-2868778
These all cover the same issue, but there are different approaches on how to resolve based on what is causing it on your specific setup.
Bruno Kos
July 1, 2019 at 5:13 pm #4121341
Kostas
The above is resolved, but i have another issue now that my client found out.. I will try to describe it the better way i can...
1. I DO NOT translate the products, there are only in one language
2. I need to translate the categories ONLY
Right now, we have no categories at the e-shop in English, the categories ARE translated but not visible at the widget.
At the taxonomy translation, i have chosen the first option (i attach an image), is that right?
When i select the third, i can see the categories at the site but not the right categories. I guess that it has something to do with the products not being assigned to them (i mean only in greek, not in english).
I am really confused here, sorry if i confused you too but i do not now what to do... sorry
Thanks in advance,
Kostas
July 2, 2019 at 6:57 am #4124391
Bruno Kos
I'm afraid that it will not work - if you translate categories, these will be different categories now and not the ones to which the original products are assigned to, meaning that if you do not translate (or duplicate) these products, nothing will show up.
Can you have a look at this answer? I think it may give some ideas what is behind this (assuming that what you're asking is the same):
https://wpml.org/forums/topic/fallback-woocommerce-products-do-not-have-the-translated-taxonomies-associated/#post-4106573
Bruno Kos
