When using custom permalink structure with custom code for a CPT UI post type the translated posts are not loading.
WPML supports only custom slug translation and not custom permalink structure.
When you use CPT UI plugin for a custom permalink structure you can use Permalink Manager plugin as suggested in the plugin document linked next.
Relevant Documentation:
https://wpml.org/documentation/support/translating-slugs-for-custom-post-type-archives/
https://docs.pluginize.com/article/customizing-permalinks/
Last updated by Subash Chandra Poudel 1 year, 3 months ago.
July 31, 2023 at 8:59 am #14124979
rutgerd-3
Hi Subash,
Could you please check the staging website again?
Removed custom code
Edited CPT UI
Should it be correct now? Will try to customize with Permalink Manager.
August 1, 2023 at 12:50 am #14129973
Yes, it seems to work fine as I see the post hidden link and it's translation for example hidden link loads all good without any error.
Subash
August 1, 2023 at 6:41 am #14130541
rutgerd-3
All good. Moved it to live.
