This topic contains 33 replies, has 2 voices.
Last updated by alinam-2 8 months, 2 weeks ago.
May 9, 2019 at 5:03 am #3773121
Raja Mohammed
I can understand your concerns, I would like to apologize for the situation.
The issue is escalated to our developers the issue is quite strange to us since all the settings seems to be fine the stock update is not happening, We would have a clear record of why the issue is happening, unfortunately, we don't have any track of errors which is causing the issue which is delaying the fix.
May you are already displaying the store in a single language which is the only recommendation we have as of now. I am closely following the issue in the developer's queue I will keep you posted with the happenings.
Kind regards
Raja
May 9, 2019 at 2:12 pm #3776933
alinam-2
I did not think to be alone on this issue.
When exploring on my own, I found this note in the journal of WC. Could it help?
Kind regards
2019-04-14T15:38:31+00:00 CRITICAL Object of class WP_Error could not be converted to string in /home/polinacoutu/public_html/wp-content/plugins/wpml-translation-management/inc/translation-proxy/wpml-pro-translation.class.php on line 586
May 10, 2019 at 12:55 pm #3784397
alinam-2
WPML is becoming more instable
Got this error today:
Une erreur de type E_ERROR a été causée dans la ligne 186 du fichier /home/polinacoutu/public_html/wp-content/plugins/wpml-string-translation/classes/filters/db-cache/class-wpml-st-db-translation-retrieve.php. Message d’erreur : Allowed memory size of 134217728 bytes exhausted (tried to allocate 147456 bytes)
Kind regards
May 10, 2019 at 1:55 pm #3785177
Raja Mohammed
The latest error is related to memory limit exceed during a process. which can be fixed by increasing the memory limit by adding the below code to the wp-config.php file
/** Memory Limit */
May 16, 2019 at 4:22 am #3821881
alinam-2
that is now 3 weeks that WCML doesn't work.
When do you plan to do something?
Kind regards
