Last updated by Peter 8 months, 3 weeks ago.
August 30, 2019 at 10:26 pm
Peter
I am trying to: Hi, I set up a booking system with a booking calendar. The calendar is displayed via a shortcode that the Elementor Popup pulls from a custom field. It works fine in the original language but it is not being displayed in the translations. I tried using ACF for a change but it does not work either. I am suspecting I have some wrong settings. You can check the CPT City Tours and Day Trips and the Jet Popups that I use to display it.
I expected to see: hidden link
Instead, I got: hidden link
August 30, 2019 at 11:08 pm #4489393
Bruno
Thank you for contacting us. I would be very happy to help you but I didn't fully understand what is the issue.
Where this calendar is created. For example, I see that you are using the shortcode [appointment_form id="18938", but where is it created? Which ID 18938 belongs to which calendar?
Can you please elaborate a little more so I can better understand? Sometimes screenshots illustrating what you mean may go a long way to clarify what words fail to transmit so if you like make use of "upload an image" below the comment area.
September 10, 2019 at 8:48 pm #4548861
Peter
Hi team, actually your questions pointed me in the right direction. The number in the shortcode was pulled from the Woocommerce product and of course I had to translate the shortcode and replace the English product ID with the foreign language one in those translations. Finally it worked!
