Last updated by Minesh 4 years, 8 months ago.
Assigned support staff: Minesh.
February 2, 2015 at 11:07 am #552645
dominicH
I am trying to get my site to load faster.
In webmaster tools (Time spent downloading a page (in milliseconds)) I get bad results and when using P3 profiler 2,4 sec is used to load Sitepress Multilingual Cms and 1,8 sec for Wpml String Translation. Basically P3 is giving me the same results as Webmaster tools 5.5 sec average load time.
WordPress Plugin Profile Report
Report date: 2015/02/02
Theme name: Genesis
Pages browsed: 24
Avg. load time: 5.5199 sec
Number of plugins: 17
Plugin impact: 88.43% of load time
Avg. plugin time: 4.8811 sec
Avg. core time: 0.3673 sec
Avg. theme time: 0.0723 sec
Avg. mem usage: 111.54 MB
Avg. ticks: 70,541
Avg. db queries : 99.62
Margin of error : 0.1993 sec
Sitepress Multilingual Cms - 2.4667 sec - 50.54%
Wpml String Translation - 1.8044 sec - 36.97%
Thank you for your help.
February 2, 2015 at 1:57 pm #552782
Minesh
Hello and thank you for contacting WPML support!!
1)
Can you please check next link:
=> http://wpml.org/2012/01/can-your-site-run-faster/
2)
I can see that you are suing W3 Total Cache plugin. For this plugin if you are using Disk caching ( even the enhanced version ) please deactivate it as its the main cause of slowness.
Also, Can you plase give a try by deactivating W3 Total Cache plugin?
February 2, 2015 at 2:26 pm #552824
dominicH
After disabling page cache in W3 Total Cache I got the following results (making it worse):
Theme name: Genesis
Pages browsed: 10
Avg. load time: 7.8962 sec
Plugin impact: 93.26% of load time
Avg. plugin time: 7.3643 sec
Avg. core time: 0.2058 sec
Avg. theme time: 0.0533 sec
Avg. mem usage: 120.38 MB
Avg. ticks: 85,862
Avg. db queries : 98.90
Margin of error : 0.2728 sec
Sitepress Multilingual Cms - 4.4412 sec - 60.31%
W3 Total Cache - 1.5549 sec - 21.11%
Wpml String Translation - 1.0450 sec - 14.19%
After disabling W3 Total Cache I got these results:
Theme name: Genesis
Pages browsed: 6
Avg. load time: 2.4887 sec
Number of plugins: 16
Plugin impact: 68.18% of load time
Avg. plugin time: 1.6967 sec
Avg. core time: 0.3156 sec
Avg. theme time: 0.0698 sec
Avg. mem usage: 128.13 MB
Avg. ticks: 107,990
Avg. db queries : 143.67
Margin of error : 0.4066 sec
Sitepress Multilingual Cms - 0.7179 sec - 42.31%
Wpml String Translation - 0.5886 sec - 34.69%
With W3C enabled I got in webpagetest.org a first view time to render of 1.5 sec and a repeat view of 0.8 sec.
Now (after disabeling W3C) I have a first run of 2.2 sec and a repeat view of 0.17 sec but a terrible first byte time on first render.
What's your take?
February 2, 2015 at 2:48 pm #552849
Minesh
In order to isolate the issue I would suggest that you should run a test by deactivating all non-WPML plugins + by switching your theme to default and check your issue.
2)
Try to increase your memory by adding next lines to your wp-config.php file.
define( 'WP_MEMORY_LIMIT', '512M' );
define( 'WP_MAX_MEMORY_LIMIT', '512M' );
February 2, 2015 at 3:20 pm #552894
dominicH
Set the theme to twenty fifteen and set memory to 512MB
I've run it with everything disabled except P3 profiler and WMPL
Theme name: Genesis
Pages browsed: 7
Avg. load time: 1.3892 sec
Number of plugins: 3
Plugin impact: 58.64% of load time
Avg. plugin time: 0.8146 sec
Avg. core time: 0.2557 sec
Avg. theme time: 0.0800 sec
Avg. mem usage: 80.18 MB
Avg. ticks: 59,073
Avg. db queries : 73.71
Margin of error : 0.2389 sec
Plugin list:
P3 (Plugin Performance Profiler) - 0.0112 sec - 1.38%
Sitepress Multilingual Cms - 0.4031 sec - 49.49%
Wpml String Translation - 0.4003 sec - 49.14%
and Webpage test similar results a before (1.727 sec and a repeat view of 0.643s sec but a terrible first byte time on first render).
and after disabeling P3 profiler I ran Webpage test again with the same results.
I've enabled all the plugins again.
February 3, 2015 at 10:57 am #553454
Minesh
*** Please take FULL BACKUP of your database and website. ***
We have released WPML beta version v3.1.9-b3 with performance improvements. Please see next link for changelog.
=> http://wpml.org/download/cms-beta-package-2/?section=changelog
You can download it from:
=> wpml.org => Account => Downloads
Can you please give a try with WPML v3.1.9-b3 and check your issue.
February 12, 2015 at 12:02 pm #559590
dominicH
I have a few concerns regarding the update to the beta version after reading http://wpml.org/2015/01/wpml-3-1-9-beta-supports-object-caching/
I'm running PHP version 5.3.29, W3 Total Cache everything runs on disk and most important of all my site is like 50 pages big (not a big site at all).
I'll try it if you confirm the beta is suited for this issue and my site.
Personally I'd rather like to wait until it is out of Beta.
Do you have any ETA?
February 12, 2015 at 12:09 pm #559596
Minesh
I do not have ETA but I can tell you it will be as soon as possible. You do not have to wait for for long period.
The topic ‘[Closed] Site performance (speed) with WMPL’ is closed to new replies.
