Last updated by Carlos Rojas 1 year ago.
April 26, 2019 at 9:57 am #3689369
Damir
Hi!
I have problem with translation Woocommerce sorting product's option.
I have translated sorting in string translation, but noting changes in my store.
April 26, 2019 at 2:29 pm #3691557
Carlos Rojas
I would like to ask you to update all outdated plugins and themes to their latest version, specially WPML plugins. Outdated functionalities can cause conflicts in the code.
Note: Please don't forget to create a full backup of the site before any change.
If the issue persists after updating the plugins, then I recommend you to check if for some reason the string translated is not the correct one, for this case you should take a look at the admin texts by following the steps described in this link: https://wpml.org/documentation/getting-started-guide/string-translation/#admin_texts
I also recommend you to re-save the translation of the strings in WPML -> String Translation, this will refresh the entry in the database for this string.
Could you tell me the result of the steps above?
Kind regards,
Carlos
April 29, 2019 at 8:46 am #3701211
Damir
I still need assistance.
Tried steps above, but nothing changes.
Everything is upadated.
April 29, 2019 at 7:14 pm #3706285
Carlos Rojas
Our Debugging Procedures
Carlos
May 2, 2019 at 8:29 am #3722705
Damir
Thanks for help! Migration is ready 🙂
May 2, 2019 at 7:40 pm #3728867
Carlos Rojas
Thank you very much for your update.
I was able to reproduce the issue and I found a new issue related to WPML in the site. I already escalated this ticket to our 2nd tier of support where our 2nd tier specialists will try to find a solution for this issue.
I will keep you updated about the evolution of the ticket.
Carlos
May 20, 2019 at 7:27 am #3844147
Carlos Rojas
Our 2nd tier specialists solved the issue in the live site. Could you confirm that the issue is solved?
Carlos
May 20, 2019 at 7:54 am #3844459
Damir
Hello Carlos.
In the live site hidden link, sorting is still in English language. I don't see any changes.
May 20, 2019 at 8:28 am #3844767
Carlos Rojas
Thanks for your message.
I will double check with our 2nd tier supporter and I will get back to you.
Thank you very much for your patience.
Carlos
May 20, 2019 at 2:16 pm #3847789
Carlos Rojas
I visited the site and the issue seems to be solved, see attached images. Could you double check the issue on your side? Maybe visiting the site using incognito mode to avoid any outdated cache memory in the browser will help.
Carlos
May 21, 2019 at 8:49 am #3853313
Damir
My issue is resolved now. Thank you a lot!
May 21, 2019 at 8:59 am #3853411
Carlos Rojas
I'm glad to hear that the issue is solved 🙂
Please don't hesitate to contact us if you need our help in the future with WPML. We will be more than happy to help.
Carlos
