Please make sure to update to WPML 4.3.4 before reporting any issue
Hi, Amit here, I am the WPML Support Manager, our current ticket queue is high, update your WPML plugins and make sure you meet the minimal requirements for running WPML before reporting an issue please - many tickets are resolved doing that
Please look at our updated list of Known Issues and you can also use our support search to find helpful information and of course review our documentation before opening a ticket.
If you do need to open a ticket please make sure to provide us with all the needed information as described in this page
Last updated by Noman 1 month ago.
Assigned support staff: Noman.
October 17, 2019 at 1:26 pm #4774181
daveB-3
I am trying to: Use the sort function in english of german
I expected to see: The items sorted by price
Instead, I got: The items randomly sorted
October 17, 2019 at 1:56 pm #4774425
daveB-3
The IP restriction is off, please take a look
October 17, 2019 at 4:23 pm #4775817
Noman
Thanks for turning off IP restriction, I’m still unable to open that page as it’s password protected. Could you please send me the password.
I have enabled private input box for your next reply.
Thank you
October 21, 2019 at 11:54 am #4794229
daveB-3
Hi Noman,
The password is: jenieuwewebsite.
thanks!
October 22, 2019 at 1:59 pm #4803071
Noman
Could you please follow the below steps and let me know how it goes?
1. Please check for a possible theme and plugin conflict. To do that you can switch back to any default theme (e.g. Twenty Seventeen theme), Disable all plugins except WPML and Woocommerce and see if this issue goes away with default theme and only WPML activated?
2. Please delete all sorts of caches on your site / server cache (if any) / plugin cache / CDN cache (if any), clear browser cache and see if this resolves your issue.
3. If still issue persists, please provide temporary access (WP-Admin and FTP Login info) to your site (preferably staging site), so that I can look into your setup and debug the issue.
✙ I would additionally need your permission to de-activate and re-activate Plugins and the Theme, and to change configurations on the site. This is also a reason the backup is really important.
Thank you
The topic ‘[Closed] Sorting products doesnt work in other language’ is closed to new replies.
