Last updated by Amber Martin 6 years, 3 months ago.
Assigned support staff: Amber Martin.
April 29, 2014 at 6:19 pm #390324
Richard
Last month or so I submitted some speed optimizations for WPML. I was told some of these would be implemented. I've upgraded to 3.1.5, and found that they were not.
I've re-implemented my changes again 3.1.5, and reduced CPU usage, DB usage again for my installation.
If possible, please consider making these changes in the next release.
Please do a diff for the file sitepress.class.php to find my changes.
My changed file is here:
http://pastebin.com/LJs5q31Y
I'm including two screenshots from P3 Plugin Profiler, to show the speed gains that can be attained.
The greatest improvements comes from a very minor change to
function check_settings_integrity
It avoids doing 2 DB queries (1 very costly), which is done multiple times, almost on every load of the plugin.
The other changes, are to properly cache 2 queries in 2 other methods, that are not being cached in certain scenarios (they are never being cached in my installation under the stock 3.1.5.).
Rich
April 29, 2014 at 7:39 pm #390383
Amber Martin
I will send this to our developers to review and will get back to you as soon as I can.
Amber
April 29, 2014 at 11:10 pm #390490
Richard
Ok great.
I just uploaded a new image, because I realized I showed detail on the wrong plugin. In any case, I'm thinking that P3 Profiler is not totally accurate as I get different numbers, every time I run it (I'm thinking its attempt to avoid page cache are not succesful).
In any case, I hope this provides some data.
Rich
April 29, 2014 at 11:14 pm #390491
Richard
For reference,
Here is my previous post.
http://wpml.org/forums/topic/possible-speed-optimizations/
April 30, 2014 at 1:00 pm #390987
Amber Martin
Thank you, I have that. I will let you know as soon as i have some feedback.
Amber
The topic ‘[Closed] Speed Optimizations in 3.1.5’ is closed to new replies.
