Last updated by Richard 5 years, 9 months ago.
Assigned support staff: Robert.
November 5, 2014 at 7:37 am #505840
Richard
Speed up WPML
In my futile attempt to help the developers as WPML to improve their product, I'm writing this post.
I have been trying to get the developers to fix some caching issues in WPML to speed it up for almost 1 year now.
I point to my last post on this for my observations.
https://wpml.org/forums/topic/speed-optimizations-in-3-1-7-1/
This post I think was the 2nd or third post related to this issue in previous releases.
Every release, I am forced to put in the code changes.
In fact, I believe they are bugs. In two places, sitepress-cms is not properly caching data, when it is clear that the code is trying to cache this data.
function pre_option_page_on_front
and
function pre_option_page_for_posts
In my scenarios, the queries returns 0 (because that is what is in the option table). The code tests this ( if($page_on_front ) and if($page_for_posts) ), and NEVER enters the code block that does the caching. It then repeats this query for infinity...always getting 0 back from the database, and NEVER NEVER NEVER actually caching the 0.
The last code change, is in the check_settings_integrity method, where the code is doing 2 expensive db queries. It then checks the setup_complete variable. If setup is NOT complete, it then uses the data from these 2 expensive queries....I would assume that close to 100% of the time, setup_complete is true, so it does not need the data from these queries. From my testing, it was doing these queries, many many, many times as check_settings_integrity is called at several points in the code.
At this point, I'm quite frustrated with WPML. Couple this with me reporting a bug 2 months ago that broke a part of my site, and now to find with the latest release, that my entire site is now broken because of it, I'm about to pull all my hair out....
Rich
November 5, 2014 at 9:14 am #505916
Richard
Actually, in my previous post, which I pointed to, I wrote the fixes incorrectly.
Here is a correct fix.
Note, I also include the fix for convert_url function, as without this, I can not use WPML on my site.
You can find my code changes by searching for the string "rich".
I am using this version currently on my site.
Rich
sitepress.class.php
<?php
* Main SitePress Class
* @package wpml-core
class SitePress
private $settings;
private $active_languages = array();
private $this_lang;
private $wp_query;
private $admin_language = null;
private $user_preferences = array();
private $current_user;
public $footer_preview = false;
public $queries = array();
* @var icl_cache
public $icl_translations_cache;
* @var icl_cache
public $icl_locale_cache;
* @var icl_cache
public $icl_flag_cache;
* @var icl_cache
public $icl_language_name_cache;
* @var icl_cache
public $icl_term_taxonomy_cache;
function __construct()
do_action('wpml_before_startup');
global $wpdb, $pagenow;
$this->settings = get_option( 'icl_sitepress_settings' );
//@tODO: To remove in WPML 3.5
//@since 3.1
if(is_admin() && !$this->get_setting('icl_capabilities_verified')) {
icl_enable_capabilities();
// set up current user early
// no authentication
if ( defined( 'LOGGED_IN_COOKIE' ) && isset( $_COOKIE[ LOGGED_IN_COOKIE ] ) ) {
list( $username ) = explode( '|', $_COOKIE[ LOGGED_IN_COOKIE ] );
$user_id = $wpdb->get_var( $wpdb->prepare( "SELECT ID FROM {$wpdb->users} WHERE user_login = %s", array($username) ) );
} else {
$user_id = 0;
$this->current_user = new WP_User( $user_id );
if ( is_null( $pagenow ) && is_multisite() ) {
include ICL_PLUGIN_PATH . '/inc/hacks/vars-php-multisite.php';
if ( false != $this->settings ) {
$this->verify_settings();
if ( isset( $_GET[ 'icl_action' ] ) ) {
require_once ABSPATH . WPINC . '/pluggable.php';
if ( $_GET[ 'icl_action' ] == 'reminder_popup' ) {
add_action( 'init', array( $this, 'reminders_popup' ) );
} elseif ( $_GET[ 'icl_action' ] == 'dismiss_help' ) {
$this->settings[ 'dont_show_help_admin_notice' ] = true;
$this->save_settings();
if ( isset( $_GET[ 'page' ] ) && $_GET[ 'page' ] == ICL_PLUGIN_FOLDER . '/menu/troubleshooting.php' && isset( $_GET[ 'debug_action' ] ) ) {
ob_start();
if ( isset( $_REQUEST[ 'icl_ajx_action' ] ) ) {
add_action( 'init', array( $this, 'ajax_setup' ), 15 );
add_action( 'admin_footer', array( $this, 'icl_nonces' ) );
// Process post requests
if ( !empty( $_POST ) ) {
add_action( 'init', array( $this, 'process_forms' ) );
add_action( 'plugins_loaded', array( $this, 'initialize_cache' ), 0 );
add_action( 'plugins_loaded', array( $this, 'init' ), 1 );
add_action( 'init', array( $this, 'on_wp_init' ), 1 );
add_action( 'admin_print_scripts', array( $this, 'js_scripts_setup' ) );
add_action( 'admin_print_styles', array( $this, 'css_setup' ) );
// Administration menus
add_action( 'admin_menu', array( $this, 'administration_menu' ) );
add_action( 'admin_menu', array( $this, 'administration_menu2' ), 30 );
add_action( 'init', array( $this, 'plugin_localization' ) );
//add_filter('tag_template', array($this, 'load_taxonomy_template'));
if ( $this->settings[ 'existing_content_language_verified' ] && ( $this->settings[ 'setup_complete' ] || ( !empty($_GET[ 'page' ]) && $this->settings['setup_wizard_step']==3 && $_GET[ 'page' ] == ICL_PLUGIN_FOLDER . '/menu/languages.php' ) ) ) {
// Post/page language box
if ( $pagenow == 'post.php' || $pagenow == 'post-new.php' || $pagenow == 'edit.php' ) {
add_action( 'admin_head', array( $this, 'post_edit_language_options' ) );
//For when it will be possible to add custom bulk actions
//add_action( 'bulk_actions-edit-post', array( $this, 'bulk_actions' ) );
// Post/page save actions
add_action( 'save_post', array( $this, 'save_post_actions' ), 100, 2 );
add_action( 'updated_post_meta', array( $this, 'update_post_meta' ), 100, 4 );
add_action( 'added_post_meta', array( $this, 'update_post_meta' ), 100, 4 );
add_action( 'updated_postmeta', array( $this, 'update_post_meta' ), 100, 4 ); // ajax
add_action( 'added_postmeta', array( $this, 'update_post_meta' ), 100, 4 ); // ajax
add_action( 'delete_postmeta', array( $this, 'delete_post_meta' ) ); // ajax
// Post/page delete actions
// add_action('delete_post', array($this,'delete_post_actions'));
add_action( 'before_delete_post', array( $this, 'before_delete_post_actions' ) );
add_action( 'deleted_post', array( $this, 'deleted_post_actions' ) );
add_action( 'wp_trash_post', array( $this, 'trash_post_actions' ) );
add_action( 'untrashed_post', array( $this, 'untrashed_post_actions' ) );
add_filter( 'posts_join', array( $this, 'posts_join_filter' ), 10, 2 );
add_filter( 'posts_where', array( $this, 'posts_where_filter' ), 10, 2 );
add_filter( 'comment_feed_join', array( $this, 'comment_feed_join' ) );
add_filter( 'comments_clauses', array( $this, 'comments_clauses' ), 10, 2 );
// Allow us to filter the Query vars before the posts query is being built and executed
add_filter( 'pre_get_posts', array( $this, 'pre_get_posts' ) );
add_action( 'loop_start', array( $this, 'loop_start' ), 10 );
add_filter( 'the_posts', array( $this, 'the_posts' ), 10 );
add_filter( 'get_pages', array( $this, 'get_pages' ), 100, 2 );
// Filter links to the root page
add_filter('page_link', array($this, 'filter_root_permalink'), 10, 2);
if ( $pagenow == 'edit.php' ) {
add_action( 'admin_footer', array( $this, 'language_filter' ) );
add_action( 'quick_edit_custom_box', array( 'WPML_Terms_Translations', 'quick_edit_terms_removal' ), 10, 2 );
add_filter( 'get_pages', array( $this, 'exclude_other_language_pages2' ) );
add_filter( 'wp_dropdown_pages', array( $this, 'wp_dropdown_pages' ) );
// posts and pages links filters
add_filter( 'post_link', array( $this, 'permalink_filter' ), 1, 2 );
add_filter( 'post_type_link', array( $this, 'permalink_filter' ), 1, 2 );
add_filter( 'page_link', array( $this, 'permalink_filter' ), 1, 2 );
add_filter( 'get_comment_link', array( $this, 'get_comment_link_filter' ) );
// filter the saving of terms so that the taxonomy_ids of translated terms are correctly adjusted across taxonomies
add_action('created_term_translation', array( 'WPML_Terms_Translations', 'sync_ttid_action' ), 10, 3 );
// filters terms by language for the term/tag-box autoselect
if ( ( isset( $_GET[ 'action' ] ) && ( $_GET[ 'action' ] == 'ajax-tag-search' )
|| isset( $_POST[ 'action' ] ) && $_POST[ 'action' ] == 'get-tagcloud' ) ) {
add_filter( 'get_terms', array( 'WPML_Terms_Translations', 'get_terms_filter' ), 10, 2 );
$this->set_term_filters_and_hooks();
// The delete filter only ensures the synchronizing of delete actions beween translations of a term.
add_action( 'delete_term', array( 'WPML_Terms_Translations', 'delete_term_filter' ), 1, 3 );
add_filter('pre_term_slug', array( 'WPML_Terms_Translations', 'pre_term_slug_filter' ), 10, 2 );
add_action( 'set_object_terms', array( 'WPML_Terms_Translations', 'set_object_terms_action' ), 10, 6 );
// AJAX Actions for the post edit screen
add_action( 'wp_ajax_wpml_get_post_parent_id_by_lang', array( 'WPML_Post_Edit_Ajax', 'wpml_get_post_parent_id_by_lang' ) );
add_action( 'wp_ajax_wpml_get_taxonomy_terms_json', array( 'WPML_Post_Edit_Ajax', 'wpml_get_taxonomy_terms_json' ) );
add_action( 'wp_ajax_wpml_add_term_to_post', array( 'WPML_Post_Edit_Ajax', 'wpml_add_term_to_post' ) );
add_action( 'wp_ajax_wpml_remove_terms_from_post', array( 'WPML_Post_Edit_Ajax', 'wpml_remove_terms_from_post' ) );
add_action( 'wp_ajax_wpml_switch_post_language', array( 'WPML_Post_Edit_Ajax', 'wpml_switch_post_language' ) );
add_action( 'wp_ajax_wpml_before_switch_post_language', array( 'WPML_Post_Edit_Ajax', 'wpml_before_switch_post_language' ) );
add_action( 'wp_ajax_wpml_set_post_edit_lang', array( 'WPML_Post_Edit_Ajax', 'wpml_set_post_edit_lang' ) );
add_action( 'wp_ajax_wpml_get_translated_taxonomies', array( 'WPML_Post_Edit_Ajax', 'wpml_get_translated_taxonomies' ) );
add_action( 'wp_ajax_wpml_get_translations_table_data', array( 'WPML_Post_Edit_Ajax', 'wpml_get_translations_table_data' ) );
add_action( 'wp_ajax_wpml_get_post_permalink', array( 'WPML_Post_Edit_Ajax', 'wpml_get_post_permalink' ) );
add_action( 'wp_ajax_wpml_get_default_lang', array( 'WPML_Post_Edit_Ajax', 'wpml_get_default_lang' ) );
// Ajax Action for the updating of term names on the troubleshooting page
add_action( 'wp_ajax_wpml_update_term_names_troubleshoot', array( 'WPML_Troubleshooting_Terms_Menu', 'wpml_update_term_names_troubleshoot' ) );
// short circuit get default category
add_filter( 'pre_option_default_category', array( $this, 'pre_option_default_category' ) );
add_filter( 'update_option_default_category', array( $this, 'update_option_default_category' ), 1, 2 );
add_action( 'after-category-table', array( 'WPML_Terms_Translations', 'category_display_action' ), 1, 1 );
// custom hook for adding the language selector to the template
add_action( 'icl_language_selector', array( $this, 'language_selector' ) );
// front end js
add_action( 'wp_head', array( $this, 'front_end_js' ) );
add_action( 'wp_head', array( $this, 'rtl_fix' ) );
add_action( 'admin_print_styles', array( $this, 'rtl_fix' ) );
add_action( 'restrict_manage_posts', array( $this, 'restrict_manage_posts' ) );
add_filter( 'get_edit_post_link', array( $this, 'get_edit_post_link' ), 1, 3 );
// adjacent posts links
add_filter( 'get_previous_post_join', array( $this, 'get_adjacent_post_join' ) );
add_filter( 'get_next_post_join', array( $this, 'get_adjacent_post_join' ) );
add_filter( 'get_previous_post_where', array( $this, 'get_adjacent_post_where' ) );
add_filter( 'get_next_post_where', array( $this, 'get_adjacent_post_where' ) );
// feeds links
add_filter( 'feed_link', array( $this, 'feed_link' ) );
// commenting links
add_filter( 'post_comments_feed_link', array( $this, 'post_comments_feed_link' ) );
add_filter( 'trackback_url', array( $this, 'trackback_url' ) );
add_filter( 'user_trailingslashit', array( $this, 'user_trailingslashit' ), 1, 2 );
// date based archives
add_filter( 'year_link', array( $this, 'archives_link' ) );
add_filter( 'month_link', array( $this, 'archives_link' ) );
add_filter( 'day_link', array( $this, 'archives_link' ) );
add_filter( 'getarchives_join', array( $this, 'getarchives_join' ) );
add_filter( 'getarchives_where', array( $this, 'getarchives_where' ) );
add_filter( 'pre_option_home', array( $this, 'pre_option_home' ) );
if ( !is_admin() ) {
add_filter( 'attachment_link', array( $this, 'attachment_link_filter' ), 10, 2 );
// Filter custom type archive link (since WP 3.1)
add_filter( 'post_type_archive_link', array( $this, 'post_type_archive_link_filter' ), 10, 2 );
add_filter( 'author_link', array( $this, 'author_link' ) );
add_filter( 'wp_unique_post_slug', array( $this, 'wp_unique_post_slug' ), 100, 5 );
add_filter( 'home_url', array( $this, 'home_url' ), 1, 4 );
// language negotiation
add_action( 'query_vars', array( $this, 'query_vars' ) );
add_filter( 'language_attributes', array( $this, 'language_attributes' ) );
add_action( 'locale', array( $this, 'locale' ) );
if ( isset( $_GET[ '____icl_validate_domain' ] ) ) {
echo '<!--' . get_home_url() . '-->';
exit;
add_filter( 'pre_option_page_on_front', array( $this, 'pre_option_page_on_front' ) );
add_filter( 'pre_option_page_for_posts', array( $this, 'pre_option_page_for_posts' ) );
add_filter( 'option_sticky_posts', array( $this, 'option_sticky_posts' ) );
add_filter( 'request', array( $this, 'request_filter' ) );
add_action( 'wp_head', array( $this, 'set_wp_query' ) );
add_action( 'show_user_profile', array( $this, 'show_user_options' ) );
add_action( 'personal_options_update', array( $this, 'save_user_options' ) );
// column with links to translations (or add translation) - low priority
add_action( 'init', array( $this, 'configure_custom_column' ), 1010 ); // accommodate Types init@999
add_action( 'wp_head', array( $this, 'meta_generator_tag' ) );
require_once ICL_PLUGIN_PATH . '/inc/wp-nav-menus/iclNavMenu.class.php';
new iclNavMenu;
if ( is_admin() || defined( 'XMLRPC_REQUEST' ) || preg_match( '#wp-comments-post\.php$#', $_SERVER[ 'REQUEST_URI' ] ) ) {
global $iclTranslationManagement, $ICL_Pro_Translation;
$iclTranslationManagement = new TranslationManagement;
$ICL_Pro_Translation = new ICL_Pro_Translation();
add_action( 'wp_login', array( $this, 'reset_admin_language_cookie' ) );
if ( $this->settings[ 'seo' ][ 'canonicalization_duplicates' ] ) {
add_action( 'template_redirect', array( $this, 'setup_canonical_urls' ), 100 );
add_action( 'init', array( $this, '_taxonomy_languages_menu' ), 99 ); //allow hooking in
if ( $this->settings[ 'seo' ][ 'head_langs' ] ) {
add_action( 'wp_head', array( $this, 'head_langs' ) );
* add extra debug information
add_filter( 'icl_get_extra_debug_info', array( $this, 'add_extra_debug_info' ) );
} //end if the initial language is set - existing_content_language_verified
add_action( 'wp_dashboard_setup', array( $this, 'dashboard_widget_setup' ) );
if ( is_admin() && $pagenow == 'index.php' ) {
add_action( 'icl_dashboard_widget_notices', array( $this, 'print_translatable_custom_content_status' ) );
add_filter( 'core_version_check_locale', array( $this, 'wp_upgrade_locale' ) );
if ( $pagenow == 'post.php' && isset( $_REQUEST[ 'action' ] ) && $_REQUEST[ 'action' ] == 'edit' && isset( $_GET[ 'post' ] ) ) {
add_action( 'init', '_icl_trash_restore_prompt' );
add_action( 'init', array( $this, 'js_load' ), 2 ); // enqueue scripts - higher priority
add_filter( 'get_pagenum_link', array( $this, 'get_pagenum_link' ) );
add_action('switch_blog', array($this, 'init_settings'));
add_filter('url_to_postid', array($this, 'url_to_postid'));
//cron job to update WPML config index file from CDN
add_action('update_wpml_config_index', array($this,'update_wpml_config_index_event'));
//update WPML config files
add_action('wp_ajax_update_wpml_config_index', array($this,'update_wpml_config_index_event_ajax'));
add_action( 'after_switch_theme', array( $this, 'update_wpml_config_index_event' ) );
add_action( 'activated_plugin', array( $this, 'update_wpml_config_index_event' ) );
add_action('core_upgrade_preamble', array($this, 'update_index_screen'));
add_shortcode('wpml_language_selector_widget', 'icl_language_selector');
add_shortcode('wpml_language_selector_footer', 'icl_language_selector_footer');
add_filter('get_search_form', array($this, 'get_search_form_filter'));
add_action('plugins_loaded', array($this, 'load_dependencies'), 10000);
do_action('wpml_after_startup');
function get_pagenum_link( $url ) {
// fix cases like that in url:
// lang=pl%2F%3Flang%3Dpl
// lang=pl/?lang=pl
$current_language = $this->get_current_language();
$find[ ] = 'lang=' . $current_language . '%2F%3Flang%3D' . $current_language;
$find[ ] = 'lang=' . $current_language . '/?lang=' . $current_language;
$replace = 'lang=' . $current_language;
$url = str_replace( $find, $replace, $url );
// fix cases like that:
// ?lang=pl/page/3/?lang=pl
$pattern = '/(\?lang=' . $current_language . ')(\/page\/\d+)/';
$url = preg_replace( $pattern, '$2', $url );
return $url;
function init()
do_action('wpml_before_init');
global $wpdb;
$this->get_user_preferences();
$this->set_admin_language();
$default_language = $this->get_default_language();
// default value for theme_localization_type OR
// reset theme_localization_type if string translation was on (theme_localization_type was set to 2) and then it was deactivated
if ( !isset( $this->settings[ 'theme_localization_type' ] ) || ( $this->settings[ 'theme_localization_type' ] == 1 && !defined( 'WPML_ST_VERSION' ) && !defined( 'WPML_DOING_UPGRADE' ) ) ) {
global $sitepress_settings;
$this->settings[ 'theme_localization_type' ] = $sitepress_settings[ 'theme_localization_type' ] = 2;
//configure callbacks for plugin menu pages
if ( defined( 'WP_ADMIN' ) && isset( $_GET[ 'page' ] ) && 0 === strpos( $_GET[ 'page' ], basename( ICL_PLUGIN_PATH ) . '/' ) ) {
add_action( 'icl_menu_footer', array( $this, 'menu_footer' ) );
//Run only if existing content language has been verified, and is front-end or settings are not corrupted
if (!empty( $this->settings[ 'existing_content_language_verified' ] ) && (!is_admin() || SitePress::check_settings_integrity()) ) {
if ( $this->settings[ 'language_negotiation_type' ] == 1 && $this->settings[ 'urls' ][ 'directory_for_default_language' ] && $this->settings[ 'urls' ][ 'show_on_root' ] == 'page' ) {
include ICL_PLUGIN_PATH . '/inc/home-url-functions.php';
if ($this->settings[ 'language_negotiation_type' ] == 2) {
add_filter( 'allowed_redirect_hosts', array( $this, 'allowed_redirect_hosts' ) );
if ( defined( 'WP_ADMIN' ) ) {
if ( $this->settings[ 'language_negotiation_type' ] == 2 ) {
//Login and Logout
add_filter( 'login_url', array( $this, 'convert_url' ) );
add_filter( 'logout_url', array( $this, 'convert_url' ) );
add_filter( 'site_url', array( $this, 'convert_url' ) );
if (isset($_GET['post']) && is_numeric($_GET['post'])) {
$post_type = get_post_type($_GET['post']);
$current_user = wp_get_current_user();
if ( isset( $_GET[ 'lang' ] ) ) {
$this->this_lang = rtrim( strip_tags( $_GET[ 'lang' ] ), '/' );
$al = $this->get_active_languages();
$al[ 'all' ] = true;
if ( empty( $al[ $this->this_lang ] ) ) {
$this->this_lang = $default_language;
// force default language for string translation
// we also make sure it's not saved in the cookie
} elseif ( isset( $_GET[ 'page' ] ) && ( ( defined( 'WPML_ST_FOLDER' ) && $_GET[ 'page' ] == WPML_ST_FOLDER . '/menu/string-translation.php' ) || ( defined( 'WPML_TM_FOLDER' ) && $_GET[ 'page' ] == WPML_TM_FOLDER . '/menu/translations-queue.php' ) )
} elseif ( wpml_is_ajax() ) {
if ( isset( $_POST[ 'lang' ] ) && isset( $al[ $_POST[ 'lang' ] ] ) ) {
$this->this_lang = $_POST[ 'lang' ];
} else {
if ($this->check_if_admin_action_from_referer()){
$this->this_lang = $this->get_admin_language_cookie();
} elseif(isset($_SERVER['HTTP_REFERER'])) {
$this->this_lang = $this->get_language_from_url($_SERVER['HTTP_REFERER']);
} elseif ( $lang = $this->get_admin_language_cookie() ) {
$this->this_lang = $lang;
} elseif ( isset($_POST['action']) && $_POST['action'] == 'editpost' && isset($_POST['icl_post_language'])) {
$this->this_lang = $_POST['icl_post_language'];
} elseif ( isset($_GET['post']) && is_numeric($_GET['post']) && isset($post_type) && $this->is_translated_post_type($post_type)) {
$this->this_lang = $this->get_language_for_element($_GET['post'], 'post_' . $post_type);
} elseif(isset($current_user->data)) {
$lang = $this->get_user_admin_language( $current_user->data->ID );
$this->this_lang = $lang ? $lang : $default_language;
$update_admin_language_cookie = false;
$update_admin_language_cookie |= is_admin() && isset($_GET['lang']) && ( $this->get_current_language() != $this->get_admin_language_cookie() );
$update_admin_language_cookie |= isset( $_GET[ 'admin_bar' ] ) && ( $_GET[ 'admin_bar' ] == 1 ) && !isset( $_GET[ 'page' ] );
$update_admin_language_cookie |= !defined( 'WPML_ST_FOLDER' ) || ( isset($_GET[ 'page' ]) && $_GET[ 'page' ] != WPML_ST_FOLDER . '/menu/string-translation.php' );
$update_admin_language_cookie |= !$this->get_admin_language_cookie();
if ( $update_admin_language_cookie ) {
$this->set_admin_language_cookie();
} else {
foreach ( $al as $l ) {
$active_languages[ ] = $l[ 'code' ];
$active_languages[ ] = 'all';
$s = isset( $_SERVER[ 'HTTPS' ] ) && $_SERVER[ 'HTTPS' ] == 'on' ? 's' : '';
$home = get_home_url();
if ( $s ) {
$home = preg_replace( '#^hidden link', 'hidden link', $home );
$url_parts = parse_url( $home );
$non_default_port = ( isset( $url_parts[ 'port' ] ) && $url_parts[ 'port' ] != 80 ) ? ':' . $url_parts[ 'port' ] : '';
$request = 'http' . $s . '://' . $this->get_server_host_name() . $_SERVER[ 'REQUEST_URI' ];
$blog_path = ! empty( $url_parts[ 'path' ] ) ? $url_parts[ 'path' ] : '';
switch ( $this->settings[ 'language_negotiation_type' ] ) {
case 1:
$path = str_replace( $home, '', $request );
$parts = explode( '?', $path );
$path = $parts[ 0 ];
$exp = explode( '/', trim( $path, '/' ) );
$language_part = $exp[ 0 ];
if ( in_array( $language_part, $active_languages ) ) {
$this->this_lang = $exp[ 0 ];
// before hijacking the SERVER[REQUEST_URI]
// override the canonical_redirect action
// keep a copy of the original request uri
remove_action( 'template_redirect', 'redirect_canonical' );
global $_icl_server_request_uri;
$_icl_server_request_uri = $_SERVER[ 'REQUEST_URI' ];
add_action( 'template_redirect', array($this,'icl_redirect_canonical_wrapper'), 0 );
//deal with situations when template files need to be called directly
add_action( 'template_redirect', array( $this, '_allow_calling_template_file_directly' ) );
//$_SERVER['REQUEST_URI'] = preg_replace('@^'. $blog_path . '/' . $this->this_lang.'@i', $blog_path ,$_SERVER['REQUEST_URI']);
// Check for special case of hidden link where the / is missing on the end
$parts = parse_url( $_SERVER[ 'REQUEST_URI' ] );
if ( strlen( $parts[ 'path' ] ) == 0 ) {
$_SERVER[ 'REQUEST_URI' ] = '/' . $_SERVER[ 'REQUEST_URI' ];
} else {
/* If we access the root url via a non root slug/parameter combination,
* we redirect accordingly.
$filtered_root_url = $this->filter_root_permalink( wpml_strip_subdir_from_url( site_url() ) . $_SERVER[ 'REQUEST_URI' ] );
if ( $filtered_root_url != wpml_strip_subdir_from_url( site_url() ) . $_SERVER[ 'REQUEST_URI' ] ) {
wp_redirect( $filtered_root_url, 302 );
exit();
if ( $this->is_root_page() ) {
if ( $this->settings[ 'urls' ][ 'show_on_root' ] == 'html_file' ) {
// html file
if ( false === strpos( $this->settings[ 'urls' ][ 'root_html_file_path' ], '/' ) ) {
$html_file = ABSPATH . $this->settings[ 'urls' ][ 'root_html_file_path' ];
} else {
$html_file = $this->settings[ 'urls' ][ 'root_html_file_path' ];
/** @noinspection PhpIncludeInspection */
include $html_file;
exit;
} else {
wpml_home_url_setup_root_page();
break;
case 2:
foreach( $this->settings[ 'language_domains' ] as $language_code => $domain ){
if( rtrim( $this->get_server_host_name() . $blog_path, '/' ) == rtrim( preg_replace( '@^https?://@', '', $domain ), '/' ) ){
$this->this_lang = $language_code;
break;
if ( defined( 'ICL_USE_MULTIPLE_DOMAIN_LOGIN' ) && ICL_USE_MULTIPLE_DOMAIN_LOGIN ) {
include ICL_PLUGIN_PATH . '/modules/multiple-domains-login.php';
break;
case 3:
default:
$this->this_lang = preg_replace( "/[^0-9a-zA-Z-]/i", '', strip_tags( $_GET[ 'lang' ] ) );
// set the language based on the content id - for short links
} elseif ( isset( $_GET[ 'page_id' ] ) ) {
$language_code_prepared = $wpdb->prepare( "SELECT language_code FROM {$wpdb->prefix}icl_translations WHERE element_type='post_page' AND element_id=%d", $_GET[ 'page_id' ] );
$this->this_lang = $wpdb->get_var( $language_code_prepared );
} elseif ( isset( $_GET[ 'p' ] ) ) {
$post_type_prepared = $wpdb->prepare( "SELECT post_type FROM {$wpdb->posts} WHERE ID=%d", $_GET[ 'p' ] );
$post_type = $wpdb->get_var( $post_type_prepared );
$language_code_prepared = $wpdb->prepare( "SELECT language_code FROM {$wpdb->prefix}icl_translations WHERE element_type=%s AND element_id=%d", 'post_' . $post_type, $_GET[ 'p' ] );
} elseif ( isset( $_GET[ 'cat_ID' ] ) ) {
$cat_tax_id_prepared = $wpdb->prepare( "SELECT term_taxonomy_id FROM {$wpdb->term_taxonomy} WHERE term_id=%d AND taxonomy=%s", $_GET[ 'cat_ID' ], 'category' );
$cat_tax_id = $wpdb->get_var( $cat_tax_id_prepared );
$language_code_prepared = $wpdb->prepare( "SELECT language_code FROM {$wpdb->prefix}icl_translations WHERE element_type='tax_category' AND element_id=%d", $cat_tax_id );
} elseif ( isset( $_GET[ 'tag' ] ) ) {
$tag_tax_id_prepared = $wpdb->prepare( "
SELECT x.term_taxonomy_id FROM {$wpdb->term_taxonomy} x JOIN {$wpdb->terms} t ON t.term_id = x.term_id
WHERE t.slug=%s AND x.taxonomy='post_tag'", $_GET[ 'tag' ] );
$tag_tax_id = $wpdb->get_var( $tag_tax_id_prepared );
WHERE element_type='tax_post_tag' AND element_id=%d", $tag_tax_id );
if ( !isset( $_GET[ 'lang' ] ) && ( $this->this_lang && $this->this_lang != $default_language ) ) {
if ( !isset( $GLOBALS[ 'wp_rewrite' ] ) ) {
require_once ABSPATH . WPINC . '/rewrite.php';
$GLOBALS[ 'wp_rewrite' ] = new WP_Rewrite();
define( 'ICL_DOING_REDIRECT', true );
wp_redirect( get_page_link( $_GET[ 'page_id' ] ), '301' );
exit;
wp_redirect( get_permalink( $_GET[ 'p' ] ), '301' );
exit;
wp_redirect( get_term_link( intval( $_GET[ 'cat_ID' ] ), 'category' ) );
exit;
wp_redirect( get_term_link( $_GET[ 'tag' ], 'post_tag' ) );
exit;
} else {
if ( isset( $this->settings[ 'taxonomies_sync_option' ] ) ) {
$taxs = array_keys( (array)$this->settings[ 'taxonomies_sync_option' ] );
foreach ( $taxs as $t ) {
if ( isset( $_GET[ $t ] ) ) {
$term_obj = $wpdb->get_row( $wpdb->prepare( "SELECT * FROM {$wpdb->terms} t JOIN {$wpdb->term_taxonomy} x ON t.term_id = x.term_id
WHERE t.slug=%s AND x.taxonomy=%s", $_GET[ $t ], $t ) );
$term_link = get_term_link( $term_obj, $t );
$term_link = str_replace( '&', '&', $term_link ); // fix
if ( $term_link && !is_wp_error( $term_link ) ) {
wp_redirect( $term_link );
exit;
if ( empty( $this->this_lang ) ) {
// allow forcing the current language when it can't be decoded from the URL
$this->this_lang = apply_filters( 'icl_set_current_language', $this->this_lang );
//reorder active language to put 'this_lang' in front
foreach ( $this->active_languages as $k => $al ) {
if ( $al[ 'code' ] == $this->this_lang ) {
unset( $this->active_languages[ $k ] );
$this->active_languages = array_merge( array( $k => $al ), $this->active_languages );
WPML_Troubleshooting_Terms_Menu::display_terms_with_suffix_admin_notice();
// filter some queries
add_filter( 'query', array( $this, 'filter_queries' ) );
add_filter( 'option_rewrite_rules', array( $this, 'rewrite_rules_filter' ) );
$this->set_language_cookie();
if ( is_admin() && ( !isset( $_GET[ 'page' ] ) || !defined( 'WPML_ST_FOLDER' ) || $_GET[ 'page' ] != WPML_ST_FOLDER . '/menu/string-translation.php' ) && ( !isset( $_GET[ 'page' ] ) || !defined( 'WPML_TM_FOLDER' ) || $_GET[ 'page' ] != WPML_TM_FOLDER . '/menu/translations-queue.php' )
if ( version_compare( $GLOBALS[ 'wp_version' ], '3.3', '<' ) ) {
// Legacy code for admin language switcher
if ( !$this->is_rtl() && version_compare( $GLOBALS[ 'wp_version' ], '3.3', '>' ) ) {
add_action( 'admin_notices', 'wpml_set_admin_language_switcher_place', 100 );
add_action( 'network_admin_notices', 'wpml_set_admin_language_switcher_place', 100 );
add_action( 'user_admin_notices', 'wpml_set_admin_language_switcher_place', 100 );
function wpml_set_admin_language_switcher_place()
echo '<br clear="all" />';
add_action( 'in_admin_header', array( $this, 'admin_language_switcher_legacy' ) );
} else {
// Admin language switcher goes to the WP admin bar
add_action( 'wp_before_admin_bar_render', array( $this, 'admin_language_switcher' ) );
if ( !is_admin() && defined( 'DISQUS_VERSION' ) ) {
include ICL_PLUGIN_PATH . '/modules/disqus.php';
* If user perform bulk taxonomy deletion when displaying non-default
* language taxonomies, after deletion should stay with same language
if ( is_admin() &&
isset($_POST['_wp_http_referer'])
&& false !== strpos($_POST['_wp_http_referer'], 'edit-tags.php')
&& !empty($_POST['delete_tags'])
&& is_array($_POST['delete_tags'])
&& !empty($_GET['lang'])
$_POST['action'] == 'delete' || $_POST['action2'] == 'delete'
add_filter('wp_redirect', array($this, 'preserve_lang_param_after_bulk_category_delete'));
if ( $this->is_rtl() ) {
$GLOBALS[ 'text_direction' ] = 'rtl';
if (!wpml_is_ajax() && is_admin() && empty( $this->settings[ 'dont_show_help_admin_notice' ] ) ) {
if ( !$this->get_setting('setup_wizard_step') ) {
if(SitePress::check_settings_integrity()) {
add_action( 'admin_notices', array( $this, 'help_admin_notice' ) );
$short_v = implode( '.', array_slice( explode( '.', ICL_SITEPRESS_VERSION ), 0, 3 ) );
if ( is_admin() && ( !isset( $this->settings[ 'hide_upgrade_notice' ] ) || $this->settings[ 'hide_upgrade_notice' ] != $short_v ) ) {
add_action( 'admin_notices', array( $this, 'upgrade_notice' ) );
require ICL_PLUGIN_PATH . '/inc/template-constants.php';
if ( defined( 'WPML_LOAD_API_SUPPORT' ) ) {
require ICL_PLUGIN_PATH . '/inc/wpml-api.php';
add_action( 'wp_footer', array( $this, 'display_wpml_footer' ), 20 );
if ( defined( 'XMLRPC_REQUEST' ) && XMLRPC_REQUEST ) {
add_action( 'xmlrpc_call', array( $this, 'xmlrpc_call_actions' ) );
add_filter( 'xmlrpc_methods', array( $this, 'xmlrpc_methods' ) );
if ( defined( 'WPML_TM_VERSION' ) && is_admin() ) {
require ICL_PLUGIN_PATH . '/inc/quote.php';
add_action( 'init', array( $this, 'set_up_language_selector' ) );
global $pagenow;
if ( $pagenow == 'admin-ajax.php' ) {
if(isset($_REQUEST['action']) && $_REQUEST['action'] == 'wpml_tt_show_terms') {
//@todo: remove the following live after WPML 3.5 release
//$this->switch_lang($default_language, true);
// set language to default and remove language switcher when in Taxonomy Translation page
// If the page uses AJAX and the language must be forced to default, please use the
// if ( $pagenow == 'admin-ajax.php' )above
if ( is_admin() && isset( $_GET[ 'page' ] ) && ( $_GET[ 'page' ] == ICL_PLUGIN_FOLDER . '/menu/taxonomy-translation.php' || $_GET[ 'page' ] == ICL_PLUGIN_FOLDER . '/menu/menus-sync.php' ) ) {
$default_language = $this->get_admin_language();
add_action( 'init', array( $this, 'remove_admin_language_switcher'));
/* Posts and new inline created terms, can only be saved in an active language.
* Also the content of the post-new.php should always be filtered for one specific
* active language, so to display the correct taxonomy terms for selection.
if ( $pagenow == 'post-new.php' ) {
if ( ! $this->is_active_language( $this->get_current_language() ) ) {
$this->switch_lang( $default_language, true );
//Code to run when reactivating the plugin
$recently_activated = $this->get_setting('just_reactivated');
if($recently_activated) {
add_action( 'init', array( $this, 'rebuild_language_information' ), 1000 );
do_action('wpml_after_init');
* @param bool|String $requested_url String If this is specified the value of $url will be checked for whether it's the root page.
* Checks whether the currently requested page is the root page.
* @return bool
function is_root_page( $requested_url = false ) {
* A request leads to the root page under the following conditions.
* 1. The get parameter on it specifically requests the root page via either:
* ?preview_id = {root_page_id}
* ?page_id = {root_page_id}
* ?p = {root_page_id}
* 2. The root page slug is the first slug after the domain.
* 3. There is no slug after the domain and the get parameters are not set as to redirect
* to another page meaning:
* no ?p, ?page_id or similar query parameter redirects to another post/page
* no get parameter such as ?cat redirects to an archive page
$is_root = true;
// before checking anything see if the site even uses a root page
$urls = $this->get_setting( 'urls' );
if ( ! $urls
|| ! isset( $urls[ 'directory_for_default_language' ] )
|| ! $urls[ 'directory_for_default_language' ]
|| ! isset( $urls[ 'root_page' ] )
|| $urls[ 'root_page' ] == 0
$is_root = false;
} elseif ( isset( $_SERVER[ 'REQUEST_URI' ] ) || $requested_url !== false ) {
$root_id = $urls[ 'root_page' ];
$root_slug = false;
if ( $root_id ) {
$root_page_object = get_post( $root_id );
if ( $root_page_object && isset( $root_page_object->post_name ) ) {
$root_slug = $root_page_object->post_name;
if ( $root_slug === false ) {
$is_root = false;
} else {
if ( $requested_url ) {
$request_uri = parse_url( $requested_url, PHP_URL_PATH );
$query_string = parse_url( $requested_url, PHP_URL_QUERY );
if( $query_string ) {
$request_uri .= '?' . $query_string;
} else {
$request_uri = $_SERVER[ 'REQUEST_URI' ];
//If the get parameter ? is not preceeded by a /, add a '/'
if ( strpos( $request_uri, '?' ) !== false && strpos( $request_uri, '/?' ) === false ) {
$request_uri = str_replace( '?', '/?', $request_uri );
$request_uri = wpml_strip_subdir_from_url( $request_uri );
//First get the slug of the requested url, should there be one.
$slugs_and_get_params = explode( '/', $request_uri );
foreach ( $slugs_and_get_params as $key => $slug ) {
if ( ! trim( $slug ) ) {
unset( $slugs_and_get_params[ $key ] );
// if we have any slugs or get parameters it could be we are not on the root page
if ( ! empty( $slugs_and_get_params ) ) {
$get_query_string = '';
// First of all see if we have get parameters
if ( isset( $_GET ) && ! empty( $_GET ) ) {
$get_query_string = array_pop( $slugs_and_get_params );
/* In case we have get parameters we can instantly be sure to be on the root page
* This can be done by either id parameters or by slug/name parameters.
* ID parametes as of WP 4.1 are : p, page_id
* Name parameters as of WP 4.1 are: name, pagename
if ( ( isset( $_GET[ 'p' ] ) && $_GET[ 'p' ] != $root_id )
|| ( isset( $_GET[ 'page_id' ] ) && $_GET[ 'page_id' ] != $root_id )
|| ( isset( $_GET[ 'name' ] ) && $_GET[ 'name' ] != $root_slug )
|| ( isset( $_GET[ 'pagename' ] ) && $_GET[ 'pagename' ] != $root_slug )
$is_root = false;
* Next up there are other get parameters that allow us to recognize not being on the root page for certain.
* These only come into play when neither of the above page parameters is set and therefore no specific page is queried for.
if ( ! ( isset( $_GET[ 'pagename' ] ) || isset( $_GET[ 'name' ] ) || isset( $_GET[ 'page_id' ] ) || isset( $_GET[ 'p' ] ) ) ) {
/* The under these conditions excluded parameters, that ensure the root page to not be queried for, are determined in this way:
* First we fetch all rewrite rules. This has to be done from the options cache since the actual rewrite object is not initialized yet.
* Initializing it would impose a siginificant performance hit too.
$query = new WP_Query( str_replace( '?', '', $get_query_string ) );
if ( ( $query->is_archive() ) ) {
$is_root = false;
// In case we have slugs, we need to check the last slug for whether it is the slug of the root page
if ( $is_root && ! empty( $slugs_and_get_params ) ) {
$slugs = $slugs_and_get_params;
$last_slug = array_pop( $slugs );
$second_slug = array_pop( $slugs );
if ( ( $root_slug != $last_slug && ! is_numeric( $last_slug )
|| ( is_numeric( $last_slug ) && $second_slug != null && $root_slug != $second_slug && 'page' != $second_slug ) )
&& ( ! ( isset( $_GET[ 'p' ] ) && $_GET[ 'p' ] == $root_id )
|| ! ( isset( $_GET[ 'page_id' ] ) && $_GET[ 'page_id' ] == $root_id )
|| ! ( isset( $_GET[ 'name' ] ) && $_GET[ 'name' ] == $root_slug )
|| ! ( isset( $_GET[ 'pagename' ] ) && $_GET[ 'pagename' ] == $root_slug ) )
/* If the last slug is not the root slug or numeric,
* then the current page is not the root page. This condition only holds though
* in case no page/post parameters are appended to the request, that point towards the root page.
$is_root = false;
return $is_root;
* @param $url
* Filters links to the root page, so that they are displayed properly in the front-end.
* @return mixed
function filter_root_permalink( $url ) {
$url = str_replace( ' ', '', $url );
$url = str_replace( '%20/', '/', $url );
if ( $this->is_root_page( $url ) ) {
// Remove all whitespaces from urls
$method = '';
$new_url = str_replace( 'hidden link', '', $url );
if ( $new_url != $url ) {
$method = 'hidden link';
} else {
$query = '';
if ( strpos( $new_url, '?' ) !== false ) {
$split_by_get_url = explode( '?', $new_url );
$url_without_query = array_shift( $split_by_get_url );
$query = implode( '?', $split_by_get_url );
} else {
$url_without_query = $new_url;
$slugs = explode( '/', $url_without_query );
foreach ( $slugs as $key => $slug ) {
if ( $slug == '' || strpos( $slug, parse_url( $url, PHP_URL_HOST ) ) !== false ) {
unset( $slugs[ $key ] );
if ( $second_slug == $root_slug && ( is_numeric( $last_slug ) || $last_slug == "" ) ) {
$url_without_query = str_replace( '/' . $second_slug . '/', '/', $url_without_query );
$potential_lang_slug = array_pop( $slugs );
} elseif ( $last_slug == $root_slug ) {
$url_without_query = str_replace( '/' . $last_slug, '/', $url_without_query );
$potential_lang_slug = $second_slug;
} else {
$all_langs = $this->get_active_languages();
foreach ( $all_langs as $lang ) {
if ( $lang[ 'code' ] == $potential_lang_slug ) {
$url_without_query = str_replace( '/' . $potential_lang_slug, '/', $url_without_query );
break;
$new_url = trailingslashit($url_without_query);
if ( $query != '' ) {
$new_url = $new_url . '?' . $query;
/* Only if we actually have a root url, do we filter the url here.
* This is to ensure that cases like url/wp-admin/members/root-slug are properly
* differentiated from actualy root page calls, in case of root-slug's with
* generic names potentially causing collisions.
if ( empty( $slugs ) ) {
$url = $method . $new_url;
return $url;
function load_dependencies() {
do_action('wpml_load_dependencies');
* Sets up all term/taxonomy actions for use outside Translations Management or the Post Edit screen
function set_term_filters_and_hooks(){
add_filter( 'terms_clauses', array( $this, 'terms_clauses' ), 10, 4 );
add_filter( 'list_terms_exclusions', array( $this, 'exclude_other_terms' ), 1, 2 );
add_filter( 'term_link', array( $this, 'tax_permalink_filter' ), 1, 2 );
add_action( 'create_term', array( $this, 'create_term' ), 1, 2 );
add_action( 'edit_term', array( $this, 'create_term' ), 1, 2 );
add_filter( 'get_terms_args', array( $this, 'get_terms_args_filter' ) );
add_filter( 'get_edit_term_link', array( $this, 'get_edit_term_link' ), 1, 4 );
add_action('wp_ajax_icl_repair_broken_type_and_language_assignments', 'icl_repair_broken_type_and_language_assignments');
//Taxonomies
if ( version_compare( preg_replace( '#-RC[0-9]+(-[0-9]+)?$#', '', $GLOBALS[ 'wp_version' ] ), '3.1', '<' ) ) {
add_filter( 'category_link', array( $this, 'category_permalink_filter' ), 1, 2 );
add_filter( 'tag_link', array( $this, 'tax_permalink_filter' ), 1, 2 );
add_filter( 'taxonomy_template', array( $this, 'slug_template' ) );
add_filter( 'category_template', array( $this, 'slug_template' ) );
//post/page delete taxonomy
add_action( 'deleted_term_relationships', array( $this, 'deleted_term_relationships' ), 10, 2 );
// adjust queried categories and tags ids according to the language
if ( $this->settings[ 'auto_adjust_ids' ] ) {
add_action( 'parse_query', array( $this, 'parse_query' ) );
add_action( 'wp_list_pages_excludes', array( $this, 'adjust_wp_list_pages_excludes' ) );
add_filter( 'get_term', array( $this, 'get_term_adjust_id' ), 1, 1 );
add_filter( 'category_link', array( $this, 'category_link_adjust_id' ), 1, 2 );
add_filter( 'get_terms', array( $this, 'get_terms_adjust_ids' ), 1, 3 );
add_filter( 'get_pages', array( $this, 'get_pages_adjust_ids' ), 1, 2 );
function icl_redirect_canonical_wrapper()
$requested_url = ( !empty( $_SERVER[ 'HTTPS' ] ) && mb_strtolower( $_SERVER[ 'HTTPS' ] ) == 'on' ) ? 'hidden link' : 'hidden link';
$requested_url .= $this->get_server_host_name();
$requested_url .= $_icl_server_request_uri;
redirect_canonical( $requested_url );
* @param string $location Url where browser will redirect
* @return string Url where browser will redirect
function preserve_lang_param_after_bulk_category_delete($location) {
if (empty($_GET['lang'])) {
return $location;
$location = add_query_arg( 'lang', $_GET['lang'], $location );
return $location;
function remove_admin_language_switcher() {
remove_action( 'wp_before_admin_bar_render', array( $this, 'admin_language_switcher' ) );
function rebuild_language_information() {
$this->set_setting('just_reactivated', 0);
global $iclTranslationManagement;
if ( isset( $iclTranslationManagement ) ) {
$iclTranslationManagement->add_missing_language_information();
function on_wp_init()
if ( is_admin() && current_user_can( 'manage_options' ) ) {
if ( $this->icl_account_configured() ) {
add_action( 'admin_notices', array( $this, 'icl_reminders' ) );
include ICL_PLUGIN_PATH . '/inc/translation-management/taxonomy-translation.php';
function setup()
$setup_complete = $this->get_setting('setup_complete');
if(!$setup_complete) {
$this->set_setting('setup_complete', false);
return $setup_complete;
function get_current_user()
global $current_user;
if ( did_action( 'set_current_user' ) ) {
return $current_user;
} else {
return $this->current_user; // created early / no authentication
function ajax_setup()
require ICL_PLUGIN_PATH . '/ajax.php';
function check_if_admin_action_from_referer() {
$result = false;
if ( isset( $_SERVER[ 'HTTP_REFERER' ] ) ) {
$http_referer = parse_url( $_SERVER[ 'HTTP_REFERER' ] );
$referer_path = $http_referer[ 'path' ];
$referer_parts = explode( '/', $referer_path );
if ( in_array( 'wp-admin', $referer_parts ) ) {
$result = true;
return $result;
function configure_custom_column()
global $pagenow, $wp_post_types;
$pagenow_ = '';
$is_ajax = false;
if ( isset( $_POST[ 'action' ] ) && $_POST[ 'action' ] == 'inline-save' || isset( $_GET[ 'action' ] ) && $_GET[ 'action' ] == 'fetch-list'
$is_ajax = true;
if ( ( $pagenow == 'edit.php' || $pagenow_ == 'edit-pages.php' || $is_ajax ) ) {
$post_type = isset( $_REQUEST[ 'post_type' ] ) ? $_REQUEST[ 'post_type' ] : 'post';
switch ( $post_type ) {
case 'post':
case 'page':
add_filter( 'manage_' . $post_type . 's_columns', array( $this, 'add_posts_management_column' ) );
if ( isset( $_GET[ 'post_type' ] ) && $_GET[ 'post_type' ] == 'page' ) {
add_action( 'manage_' . $post_type . 's_custom_column', array( $this, 'add_content_for_posts_management_column' ) );
add_action( 'manage_posts_custom_column', array( $this, 'add_content_for_posts_management_column' ) );
break;
default:
if ( in_array( $post_type, array_keys( $this->get_translatable_documents() ) ) ) {
add_filter( 'manage_' . $post_type . '_posts_columns', array( $this, 'add_posts_management_column' ) );
if ( $wp_post_types[ $post_type ]->hierarchical ) {
add_action( 'manage_pages_custom_column', array( $this, 'add_content_for_posts_management_column' ) );
add_action( 'manage_posts_custom_column', array( $this, 'add_content_for_posts_management_column' ) ); // add this too - for more types plugin
} else {
add_action( 'admin_print_scripts', array( $this, '__set_posts_management_column_width' ) );
function _taxonomy_languages_menu()
// tags language selection
global $pagenow;
if ( $pagenow == 'edit-tags.php' ) {
// handle case of the tax edit page (after a taxonomy has been added)
// needs to redirect back to
if ( isset( $_GET[ 'trid' ] ) && isset( $_GET[ 'source_lang' ] ) ) {
$translations = $this->get_element_translations( $_GET[ 'trid' ], 'tax_' . $_GET[ 'taxonomy' ] );
if ( isset( $translations[ $_GET[ 'lang' ] ] ) ) {
wp_redirect( get_edit_term_link( $translations[ $_GET[ 'lang' ] ]->term_id, $_GET[ 'taxonomy' ] ) );
exit;
} else {
add_action( 'admin_notices', array( $this, '_tax_adding' ) );
$taxonomy = isset( $_GET[ 'taxonomy' ] ) ? esc_sql( $_GET[ 'taxonomy' ] ) : 'post_tag';
if ( $this->is_translated_taxonomy( $taxonomy ) ) {
add_action( 'admin_print_scripts-edit-tags.php', array( $this, 'js_scripts_tags' ) );
if ( $taxonomy == 'category' ) {
add_action( 'edit_category_form', array( $this, 'edit_term_form' ) );
} else {
add_action( 'add_tag_form', array( $this, 'edit_term_form' ) );
add_action( 'edit_tag_form', array( $this, 'edit_term_form' ) );
add_action( 'admin_footer', array( $this, 'terms_language_filter' ) );
add_filter( 'wp_dropdown_cats', array( $this, 'wp_dropdown_cats_select_parent' ) );
function _tax_adding()
if ( !empty( $translations ) && isset( $translations[ $_GET[ 'source_lang' ] ]->name ) ) {
$tax_name = apply_filters( 'the_category', $translations[ $_GET[ 'source_lang' ] ]->name );
echo '<div id="icl_tax_adding_notice" class="updated fade"><p>' . sprintf( __( 'Adding translation for: %s.', 'sitepress' ), $tax_name ) . '</p></div>';
* @param WP_Query $query
function loop_start($query) {
if ( isset( $query->post_count ) && $query->post_count ) {
$this->cache_translations( $query->posts );
* Cache translated posts
* @param $posts
function cache_translations($posts) {
global $wpdb, $wp_query, $sitepress;
static $last_query=false;
if ( defined( 'WPML_DISABLE_CACHE_TRANSLATIONS' ) && is_admin() ){
return;
if ( isset( $sitepress ) && isset( $wp_query ) && $wp_query->is_main_query() ) {
if($last_query == $wp_query->query_vars_hash) return;
$sticky_posts_ids = get_option( 'sticky_posts' );
if ( $sticky_posts_ids ) {
if ( count( $sticky_posts_ids ) == 1 ) {
$sticky_posts_prepared = $wpdb->prepare( "SELECT * FROM {$wpdb->posts} WHERE ID = %d", array( $sticky_posts_ids[0] ) );
} else {
$sticky_posts_prepared = "SELECT * FROM {$wpdb->posts} WHERE ID IN (" . implode( ',', array_filter( $sticky_posts_ids ) ) . ")";
$sticky_posts = $wpdb->get_results( $sticky_posts_prepared );
$posts_objects = array_map( 'get_post', $sticky_posts );
if ( !$posts ) {
$posts = $posts_objects;
} else {
$posts = array_merge( $posts, $posts_objects );
//Remove duplicates
$posts = array_map( "unserialize", array_unique( array_map( "serialize", $posts ) ) );
if ( $posts ) {
$terms = array();
//Query specific cache
$cache_key = $wp_query->query_vars_hash;
$cache_group = 'wp_query:posts_translations';
$cached_posts_translations = wp_cache_get( $cache_key, $cache_group );
if ( !$cached_posts_translations ) {
$post_types = array();
foreach ( $posts as $post ) {
$post_types[ $post->post_type ][] = $post->ID;
$trids = array();
if ( $post_types ) {
$trid_cache_group = 'element_trid';
foreach ( $post_types as $post_type => $posts_ids ) {
$element_type = 'post_' . $post_type;
$s_post_type_ids = join( ',', array_filter($posts_ids) );
$trids_prepared = $wpdb->prepare( "SELECT trid, element_id, language_code, source_language_code FROM {$wpdb->prefix}icl_translations WHERE element_id IN (" . $s_post_type_ids . ") AND element_type=%s GROUP BY trid", array( $element_type ) );
$post_type_trids_data = $wpdb->get_results( $trids_prepared );
foreach($post_type_trids_data as $post_type_trid_data) {
$element_id = $post_type_trid_data->element_id;
$trid_cache_key = $element_id . ':post_' . $post_type;
$trid = wp_cache_get($trid_cache_key, $trid_cache_group);
if(!$trid) {
$trid = $post_type_trid_data->trid;
$trids[] = $trid;
wp_cache_add($trid_cache_key, $trid, $trid_cache_group);
if($trid) {
$element_language_details_cache_group = 'element_language_details';
$element_language_details = wp_cache_get($trid_cache_key, $element_language_details_cache_group);
if(!$element_language_details) {
$details = new stdClass();
$details->trid = $trid;
$details->language_code = $post_type_trid_data->language_code;
$details->source_language_code = $post_type_trid_data->source_language_code;
wp_cache_add($trid_cache_key, $details, $element_language_details_cache_group);
//Deal with taxonomies
//$_taxonomies = get_post_taxonomies($element_id);
$_taxonomies= get_post_taxonomies($element_id);
foreach($_taxonomies as $_taxonomy) {
if($sitepress->is_translated_taxonomy($_taxonomy)) {
$_terms = wp_get_post_terms($element_id, $_taxonomy);
foreach($_terms as $_term) {
$terms[$_term->taxonomy][] = $_term->term_id;
if ( $trids ) {
if(count($trids)==1) {
$posts_translations_prepared = $wpdb->prepare( "SELECT * FROM {$wpdb->prefix}icl_translations WHERE trid = %d ", array($trids[0]) );
}else {
$posts_translations_prepared = "SELECT * FROM {$wpdb->prefix}icl_translations WHERE trid IN (" . join( ',', array_filter($trids) ) . ") ";
$posts_translations = $wpdb->get_results( $posts_translations_prepared );
$post_ids = array();
foreach($posts_translations as $posts_translation) {
$post_ids[] = $posts_translation->element_id;
$posts_data = wp_cache_get($cache_key, 'wp_query:posts');
if(!$posts_data && $post_ids) {
$posts_prepared = "SELECT * FROM {$wpdb->posts} WHERE ID IN (" . join( ',', array_filter($post_ids) ) . ") ";
$posts_data = $wpdb->get_results( $posts_prepared );
wp_cache_set($cache_key, $posts_data, 'wp_query:posts');
if ( $posts_data ) {
foreach($posts_data as $post) {
$_post = wp_cache_get( $post->ID, 'posts' );
if ( ! $_post ) {
$_post = $post;
$_post = sanitize_post( $_post, 'raw' );
wp_cache_add( $_post->ID, $_post, 'posts' );
if ( $terms ) {
$cache_group = 'element_language_details';
foreach ( $terms as $taxonomy => $term_ids ) {
$element_type = 'tax_' . $taxonomy;
$terms_translations_prepared = $wpdb->prepare( "SELECT * FROM {$wpdb->prefix}icl_translations WHERE element_type = %s AND element_id IN (" . join( ',', $term_ids ) . ")", array( $element_type ) );
$terms_translations = $wpdb->get_results( $terms_translations_prepared );
foreach ( $terms_translations as $terms_translation ) {
$cache_key = $terms_translation->element_id . ':' . $terms_translation->element_type;
$cached_details = wp_cache_get( $cache_key, $cache_group );
if ( !$cached_details ) {
wp_cache_set( $cache_key, $terms_translation, $cache_group );
$icl_object_id_cache_group = 'icl_object_id';
$icl_object_id_cache_key_args = array( $terms_translation->element_id, $taxonomy, false, $terms_translation->language_code );
$icl_object_id_cache_key = implode( ':', array_filter( $icl_object_id_cache_key_args ) );
$icl_object_id = wp_cache_get( $cache_key, $cache_group );
if ( !$icl_object_id ) {
wp_cache_set( $icl_object_id_cache_key, $terms_translation->element_id, $icl_object_id_cache_group );
$icl_object_id_cache_key_args = array( $terms_translation->element_id, $taxonomy, true, $terms_translation->language_code );
$last_query = $wp_query->query_vars_hash;
function the_posts( $posts ) {
if ( !is_admin() && isset( $this->settings[ 'show_untranslated_blog_posts' ] ) && $this->settings[ 'show_untranslated_blog_posts' ] && $this->get_current_language() != $this->get_default_language() ) {
// show untranslated posts
global $wpdb, $wp_query;
$debug_backtrace = $this->get_backtrace(4, true); //Limit to first 4 stack frames, since 3 is the highest index we use
/** @var $custom_wp_query WP_Query */
$custom_wp_query = isset( $debug_backtrace[ 3 ][ 'object' ] ) ? $debug_backtrace[ 3 ][ 'object' ] : false;
//exceptions
if ( ( $current_language == $default_language )
// original language
( $wp_query != $custom_wp_query )
// called by a custom query
( !$custom_wp_query->is_posts_page && !$custom_wp_query->is_home )
// not the blog posts page
$wp_query->is_singular
//is singular
!empty( $custom_wp_query->query_vars[ 'category__not_in' ] )
//|| !empty($custom_wp_query->query_vars['category__in'])
//|| !empty($custom_wp_query->query_vars['category__and'])
!empty( $custom_wp_query->query_vars[ 'tag__not_in' ] ) ||
!empty( $custom_wp_query->query_vars[ 'post__in' ] ) ||
!empty( $custom_wp_query->query_vars[ 'post__not_in' ] ) ||
!empty( $custom_wp_query->query_vars[ 'post_parent' ] )
return $posts;
// get the posts in the default language instead
$this_lang = $this->this_lang;
remove_filter( 'the_posts', array( $this, 'the_posts' ) );
$custom_wp_query->query_vars[ 'suppress_filters' ] = 0;
if ( isset( $custom_wp_query->query_vars[ 'pagename' ] ) && !empty( $custom_wp_query->query_vars[ 'pagename' ] ) ) {
if ( isset( $custom_wp_query->queried_object_id ) && !empty( $custom_wp_query->queried_object_id ) ) {
$page_id = $custom_wp_query->queried_object_id;
} else {
// urlencode added for languages that have urlencoded post_name field value
$custom_wp_query->query_vars[ 'pagename' ] = urlencode( $custom_wp_query->query_vars[ 'pagename' ] );
$page_id = $wpdb->get_var( "SELECT ID FROM {$wpdb->posts} WHERE post_name='{$custom_wp_query->query_vars['pagename']}' AND post_type='page'" );
if ( $page_id ) {
$tr_page_id = icl_object_id( $page_id, 'page', false, $default_language );
if ( $tr_page_id ) {
$custom_wp_query->query_vars[ 'pagename' ] = $wpdb->get_var( "SELECT post_name FROM {$wpdb->posts} WHERE ID={$tr_page_id}" );
// look for posts without translations
if ( $posts ) {
$pids = false;
foreach ( $posts as $p ) {
$pids[ ] = $p->ID;
if ( $pids ) {
$trids = $wpdb->get_col( "
SELECT trid
WHERE element_type='post_post' AND element_id IN (" . join( ',', $pids ) . ") AND language_code = '" . $this_lang . "'" );
if ( !empty( $trids ) ) {
$posts_not_translated = $wpdb->get_col( "
SELECT element_id, COUNT(language_code) AS c
WHERE trid IN (" . join( ',', $trids ) . ") GROUP BY trid HAVING c = 1
if ( !empty( $posts_not_translated ) ) {
$GLOBALS[ '__icl_the_posts_posts_not_translated' ] = $posts_not_translated;
add_filter( 'posts_where', array( $this, '_posts_untranslated_extra_posts_where' ), 99 );
//fix page for posts
unset( $custom_wp_query->query_vars[ 'pagename' ] );
unset( $custom_wp_query->query_vars[ 'page_id' ] );
unset( $custom_wp_query->query_vars[ 'p' ] );
$my_query = new WP_Query( $custom_wp_query->query_vars );
add_filter( 'the_posts', array( $this, 'the_posts' ) );
$this->this_lang = $this_lang;
// create a map of the translated posts
$trans_posts[ $post->ID ] = $post;
// loop original posts
foreach ( $my_query->posts as $k => $post ) { // loop posts in the default language
$trid = $this->get_element_trid( $post->ID );
$translations = $this->get_element_translations( $trid ); // get translations
if ( isset( $translations[ $current_language ] ) ) { // if there is a translation in the current language
if ( isset( $trans_posts[ $translations[ $current_language ]->element_id ] ) ) { //check the map of translated posts
$my_query->posts[ $k ] = $trans_posts[ $translations[ $current_language ]->element_id ];
} else { // check if the translated post exists in the database still
$_post = $wpdb->get_row( $wpdb->prepare( "SELECT * FROM $wpdb->posts WHERE ID = %d AND post_status='publish' LIMIT 1", $translations[ $current_language ]->element_id ) );
if ( !empty( $_post ) ) {
$_post = sanitize_post( $_post );
$my_query->posts[ $k ] = $_post;
} else {
$my_query->posts[ $k ]->original_language = true;
} else {
if ( $custom_wp_query == $wp_query ) {
$wp_query->max_num_pages = $my_query->max_num_pages;
$posts = $my_query->posts;
unset( $GLOBALS[ '__icl_the_posts_posts_not_translated' ] );
remove_filter( 'posts_where', array( $this, '_posts_untranslated_extra_posts_where' ), 99 );
// cache translated posts
$this->cache_translations($posts);
return $posts;
function get_pages($pages, $r) {
$this->cache_translations($pages);
return $pages;
function _posts_untranslated_extra_posts_where( $where )
global $wpdb;
$where .= ' OR ' . $wpdb->posts . '.ID IN (' . join( ',', $GLOBALS[ '__icl_the_posts_posts_not_translated' ] ) . ')';
return $where;
function initialize_cache()
require_once ICL_PLUGIN_PATH . '/inc/cache.php';
$this->icl_translations_cache = new icl_cache();
$this->icl_locale_cache = new icl_cache( 'locale', true );
$this->icl_flag_cache = new icl_cache( 'flags', true );
$this->icl_language_name_cache = new icl_cache( 'language_name', true );
$this->icl_term_taxonomy_cache = new icl_cache();
function set_admin_language()
global $wpdb;
$found = false;
$cache_key = "active_languages";
$cache_group = "set_admin_lang";
$active_languages = wp_cache_get($cache_key, $cache_group, false, $found);
if(!$found) {
//don't use method get_active_language()
$active_languages_col = $wpdb->get_col( "SELECT code FROM {$wpdb->prefix}icl_languages WHERE active=1" );
$active_languages = array_keys( $active_languages_col );
wp_cache_set($cache_key, $active_languages, $cache_group);
if ( !empty( $this->get_current_user()->ID ) ) {
$this->admin_language = $this->get_user_admin_language( $this->get_current_user()->ID );
if ( $this->admin_language != '' && !in_array( $this->admin_language, $active_languages ) ) {
delete_user_meta( $this->get_current_user()->ID, 'icl_admin_language' );
if ( empty( $this->settings[ 'admin_default_language' ] ) || !in_array( $this->settings[ 'admin_default_language' ], $active_languages ) ) {
$this->settings[ 'admin_default_language' ] = '_default_';
if ( !$this->admin_language ) {
$this->admin_language = $this->settings[ 'admin_default_language' ];
if ( $this->admin_language == '_default_' && $default_language ) {
$this->admin_language = $default_language;
function get_admin_language()
$current_user = $this->get_current_user();
if ( isset( $current_user->ID ) && get_user_meta( $current_user->ID, 'icl_admin_language_for_edit', true ) && icl_is_post_edit() ) {
$admin_language = $this->get_current_language();
} else {
$admin_language = $this->admin_language;
return $admin_language;
function get_user_admin_language( $user_id )
static $lang = array();
if ( !isset( $lang[ $user_id ] ) ) {
$lang[ $user_id ] = get_user_meta( $user_id, 'icl_admin_language', true );
if ( empty( $lang[ $user_id ] ) ) {
$admin_default_language = $this->get_setting( 'admin_default_language' );
if ( $admin_default_language ) {
$lang[ $user_id ] = $admin_default_language;
if ( empty( $lang[ $user_id ] ) || '_default_' == $lang[ $user_id ] ) {
$lang[ $user_id ] = $this->get_admin_language();
return $lang[ $user_id ];
function administration_menu()
if(!SitePress::check_settings_integrity()) return;
ICL_AdminNotifier::removeMessage( 'setup-incomplete' );
$main_page = apply_filters( 'icl_menu_main_page', basename( ICL_PLUGIN_PATH ) . '/menu/languages.php' );
if ( SitePress_Setup::setup_complete() ) {
add_menu_page( __( 'WPML', 'sitepress' ), __( 'WPML', 'sitepress' ), 'wpml_manage_languages', $main_page, null, ICL_PLUGIN_URL . '/res/img/icon16.png' );
add_submenu_page( $main_page, __( 'Languages', 'sitepress' ), __( 'Languages', 'sitepress' ), 'wpml_manage_languages', basename( ICL_PLUGIN_PATH ) . '/menu/languages.php' );
//By Gen, moved Translation management after language, because problems with permissions
do_action( 'icl_wpml_top_menu_added' );
add_submenu_page( $main_page, __( 'Theme and plugins localization', 'sitepress' ), __( 'Theme and plugins localization', 'sitepress' ), 'wpml_manage_theme_and_plugin_localization', basename( ICL_PLUGIN_PATH ) . '/menu/theme-localization.php' );
if ( !defined( 'WPML_TM_VERSION' ) ) {
add_submenu_page( $main_page, __( 'Translation options', 'sitepress' ), __( 'Translation options', 'sitepress' ), 'wpml_manage_translation_options', basename( ICL_PLUGIN_PATH ) . '/menu/translation-options.php' );
} else {
$main_page = basename( ICL_PLUGIN_PATH ) . '/menu/languages.php';
add_menu_page( __( 'WPML', 'sitepress' ), __( 'WPML', 'sitepress' ), 'manage_options', $main_page, null, ICL_PLUGIN_URL . '/res/img/icon16.png' );
add_submenu_page( $main_page, __( 'Languages', 'sitepress' ), __( 'Languages', 'sitepress' ), 'wpml_manage_languages', $main_page );
if ((!isset($_REQUEST['page']) || $_REQUEST['page']!=ICL_PLUGIN_FOLDER . '/menu/troubleshooting.php') && !SitePress_Setup::languages_table_is_complete() ) {
$troubleshooting_url = admin_url( 'admin.php?page=' . ICL_PLUGIN_FOLDER . '/menu/troubleshooting.php' );
$troubleshooting_link = '<a href="' . $troubleshooting_url . '" title="' . esc_attr( __( 'Troubleshooting', 'sitepress' ) ) . '">' . __( 'Troubleshooting', 'sitepress' ) . '</a>';
$message = '';
$message .= __( 'WPML is missing some records in the languages tables and it cannot fully work until this issue is fixed.', 'sitepress' );
$message .= '<br />';
$message .= sprintf( __( 'Please go to the %s page and click on %s to fix this problem.', 'sitepress' ), $troubleshooting_link, __( 'Fix languages tables', 'sitepress' ) );
$message .= __( 'This warning will disappear once this issue is fixed.', 'sitepress' );
ICL_AdminNotifier::addMessage( 'setup-incomplete', $message, 'error', false, false, false, 'setup', true );
ICL_AdminNotifier::displayMessages( 'setup' );
add_submenu_page( $main_page, __( 'Support', 'sitepress' ), __( 'Support', 'sitepress' ), 'wpml_manage_support', ICL_PLUGIN_FOLDER . '/menu/support.php' );
$this->troubleshooting_menu(ICL_PLUGIN_FOLDER . '/menu/support.php');
$this->debug_information_menu(ICL_PLUGIN_FOLDER . '/menu/support.php');
private function troubleshooting_menu( $main_page ) {
$submenu_slug = basename( ICL_PLUGIN_PATH ) . '/menu/troubleshooting.php';
//if ( isset( $_GET[ 'page' ] ) && $_GET[ 'page' ] == $submenu_slug ) {
add_submenu_page( $main_page, __( 'Troubleshooting', 'sitepress' ), __( 'Troubleshooting', 'sitepress' ), 'wpml_manage_troubleshooting', $submenu_slug );
return $submenu_slug;
private function debug_information_menu( $main_page ) {
$submenu_slug = basename( ICL_PLUGIN_PATH ) . '/menu/debug-information.php';
add_submenu_page( $main_page, __( 'Debug information', 'sitepress' ), __( 'Debug information', 'sitepress' ), 'wpml_manage_troubleshooting', $submenu_slug );
// lower priority
function administration_menu2()
$main_page = apply_filters( 'icl_menu_main_page', ICL_PLUGIN_FOLDER . '/menu/languages.php' );
if ( $this->setup() ) {
add_submenu_page( $main_page, __( 'Taxonomy Translation', 'sitepress' ), __( 'Taxonomy Translation', 'sitepress' ), 'wpml_manage_taxonomy_translation', ICL_PLUGIN_FOLDER . '/menu/taxonomy-translation.php' );
public function init_settings() {
if ($this->get_setting('setup_wizard_step') == 4 && $this->get_setting('setup_complete') && !ms_is_switched()) {
$sitepress_settings = $this->settings;
return $sitepress_settings;
return null;
function save_settings( $settings = null )
if ( !is_null( $settings ) ) {
foreach ( $settings as $k => $v ) {
if ( is_array( $v ) ) {
foreach ( $v as $k2 => $v2 ) {
$this->settings[ $k ][ $k2 ] = $v2;
} else {
$this->settings[ $k ] = $v;
if ( !empty( $this->settings ) ) {
update_option( 'icl_sitepress_settings', $this->settings );
do_action( 'icl_save_settings', $settings );
private function check_settings() {
if ( !isset( $this->settings ) ) {
$this->settings = $this->init_settings();
* @since 3.1
function get_settings()
$this->check_settings();
return $this->settings;
* @param string $key
* @param mixed|bool $default
* @since 3.1
* @return bool|mixed
function get_setting($key, $default = false)
return isset($this->settings[$key]) ? $this->settings[$key] : $default;
* @param mixed $value
* @param bool $save_now Immediately update the settings record in the DB
* @since 3.1
function set_setting($key, $value, $save_now = false)
$this->settings[$key] = $value;
if($save_now) {
function get_user_preferences()
if ( empty( $this->user_preferences ) ) {
$this->user_preferences = get_user_meta( $this->get_current_user()->ID, '_icl_preferences', true );
return $this->user_preferences;
function set_user_preferences($value) {
$this->user_preferences = $value;
function save_user_preferences()
update_user_meta( $this->get_current_user()->ID, '_icl_preferences', $this->user_preferences );
function get_option( $option_name )
return isset( $this->settings[ $option_name ] ) ? $this->settings[ $option_name ] : null;
function verify_settings()
$default_settings = array(
'interview_translators' => 1,
'existing_content_language_verified' => 0,
'language_negotiation_type' => 3,
'theme_localization_type' => 1,
'icl_lso_header' => 0,
'icl_lso_link_empty' => 0,
'icl_lso_flags' => 0,
'icl_lso_native_lang' => 1,
'icl_lso_display_lang' => 1,
'sync_page_ordering' => 1,
'sync_page_parent' => 1,
'sync_page_template' => 1,
'sync_ping_status' => 1,
'sync_comment_status' => 1,
'sync_sticky_flag' => 1,
'sync_private_flag' => 1,
'sync_post_format' => 1,
'sync_delete' => 0,
'sync_delete_tax' => 0,
'sync_post_taxonomies' => 1,
'sync_post_date' => 0,
'sync_taxonomy_parents' => 0,
'translation_pickup_method' => 0,
'notify_complete' => 1,
'translated_document_status' => 1,
'remote_management' => 0,
'auto_adjust_ids' => 1,
'alert_delay' => 0,
'promote_wpml' => 0,
'troubleshooting_options' => array( 'http_communication' => 1 ),
'automatic_redirect' => 0,
'remember_language' => 24,
'icl_lang_sel_type' => 'dropdown',
'icl_lang_sel_stype' => 'classic',
'icl_lang_sel_orientation' => 'vertical',
'icl_lang_sel_copy_parameters' => '',
'icl_widget_title_show' => 1,
'translated_document_page_url' => 'auto-generate',
'sync_comments_on_duplicates ' => 0,
'seo' => array( 'head_langs' => 1, 'canonicalization_duplicates' => 1 ),
'posts_slug_translation' => array( 'on' => 0 ),
'languages_order' => '',
'urls' => array( 'directory_for_default_language' => 0, 'show_on_root' => '', 'root_html_file_path' => '', 'root_page' => 0, 'hide_language_switchers' => 1 )
//configured for three levels
$update_settings = false;
foreach ( $default_settings as $key => $value ) {
if ( is_array( $value ) ) {
foreach ( $value as $k2 => $v2 ) {
if ( is_array( $v2 ) ) {
foreach ( $v2 as $k3 => $v3 ) {
if ( !isset( $this->settings[ $key ][ $k2 ][ $k3 ] ) ) {
$this->settings[ $key ][ $k2 ][ $k3 ] = $v3;
$update_settings = true;
} else {
if ( !isset( $this->settings[ $key ][ $k2 ] ) ) {
$this->settings[ $key ][ $k2 ] = $v2;
} else {
if ( !isset( $this->settings[ $key ] ) ) {
$this->settings[ $key ] = $value;
if ( $update_settings ) {
$this->save_settings();
function _validate_language_per_directory( $language_code )
if ( !class_exists( 'WP_Http' ) ) {
include_once ABSPATH . WPINC . '/class-http.php';
$client = new WP_Http();
if ( false === @strpos( $_POST[ 'url' ], '?' ) ) {
$url_glue = '?';
} else {
$url_glue = '&';
$response = $client->request( get_home_url() . '/' . $language_code . '/' . $url_glue . '____icl_validate_domain=1', array( 'timeout' => 15, 'decompress' => false ) );
return ( !is_wp_error( $response ) && ( $response[ 'response' ][ 'code' ] == '200' ) && ( $response[ 'body' ] == '<!--' . get_home_url() . '-->' ) );
function save_language_pairs()
// clear existing languages
$lang_pairs = $this->settings[ 'language_pairs' ];
if ( is_array( $lang_pairs ) ) {
foreach ( $lang_pairs as $from => $to ) {
$lang_pairs[ $from ] = array();
// get the from languages
$from_languages = array();
foreach ( $_POST as $k => $v ) {
if ( 0 === strpos( $k, 'icl_lng_from_' ) ) {
$f = str_replace( 'icl_lng_from_', '', $k );
$from_languages[ ] = $f;
if ( 0 !== strpos( $k, 'icl_lng_' ) ) {
continue;
if ( 0 === strpos( $k, 'icl_lng_to' ) ) {
$t = str_replace( 'icl_lng_to_', '', $k );
$exp = explode( '_', $t );
if ( in_array( $exp[ 0 ], $from_languages ) ) {
$lang_pairs[ $exp[ 0 ] ][ $exp[ 1 ] ] = 1;
$iclsettings[ 'language_pairs' ] = $lang_pairs;
$this->save_settings( $iclsettings );
function get_active_languages( $refresh = false )
global $wpdb, $current_user;
if ( $refresh || !isset($this->active_languages) || !$this->active_languages ) {
if ( defined( 'WP_ADMIN' ) && isset($this->admin_language) && $this->admin_language ) {
$in_language = $this->admin_language;
} else {
$in_language = $current_language ? $current_language : $this->get_default_language();
if ( !$refresh && isset( $this->icl_language_name_cache ) ) {
$res = $this->icl_language_name_cache->get( 'in_language_' . $in_language );
} else {
$res = null;
if ( !$res || !is_array( $res ) ) {
if(!$in_language) {
$in_language = 'en';
$res_prepared = $wpdb->prepare( "
SELECT l.id, code, english_name, active, lt.name AS display_name, l.encode_url, l.default_locale, l.tag
FROM {$wpdb->prefix}icl_languages l
JOIN {$wpdb->prefix}icl_languages_translations lt ON l.code=lt.language_code
WHERE
active=1 AND lt.display_language_code = %s
ORDER BY major DESC, english_name ASC", array($in_language));
$res = $wpdb->get_results( $res_prepared, ARRAY_A );
if ( isset( $this->icl_language_name_cache ) ) {
$this->icl_language_name_cache->set( 'in_language_' . $in_language, $res );
$languages = array();
if ( $res ) {
foreach ( $res as $r ) {
$languages[ $r[ 'code' ] ] = $r;
$res = $this->icl_language_name_cache->get( 'languages' );
} else {
$res = null;
//WPML setup
if ( !isset($this->settings[ 'setup_complete' ]) || empty( $this->settings[ 'setup_complete' ] ) ) {
$res = null;
if ( !$res && $languages ) {
$res = $wpdb->get_results( "
SELECT language_code, name
FROM {$wpdb->prefix}icl_languages_translations
WHERE language_code IN ('" . join( "','", array_keys( $languages ) ) . "') AND language_code = display_language_code
$this->icl_language_name_cache->set( 'languages', $res );
if($res) {
foreach ( $res as $row ) {
$languages[ $row->language_code ][ 'native_name' ] = $row->name;
$this->active_languages = $languages;
// hide languages for front end
if ( !is_admin() && isset( $this->settings[ 'hidden_languages' ]) && !empty( $this->settings[ 'hidden_languages' ] ) && is_array( $this->settings[ 'hidden_languages' ] ) ) {
if ( !isset( $current_user ) || !$current_user ) {
get_currentuserinfo();
if ( empty( $current_user->data ) || !get_user_meta( $this->get_current_user()->ID, 'icl_show_hidden_languages', true ) ) {
foreach ( $this->settings[ 'hidden_languages' ] as $l ) {
unset( $this->active_languages[ $l ] );
return $this->active_languages;
function order_languages( $languages )
$ordered_languages = array();
if ( is_array( $this->settings[ 'languages_order' ] ) ) {
foreach ( $this->settings[ 'languages_order' ] as $code ) {
if ( isset( $languages[ $code ] ) ) {
$ordered_languages[ $code ] = $languages[ $code ];
unset( $languages[ $code ] );
} else {
// initial save
$iclsettings[ 'languages_order' ] = array_keys( $languages );
if ( !empty( $languages ) ) {
foreach ( $languages as $code => $lang ) {
$ordered_languages[ $code ] = $lang;
return $ordered_languages;
function set_active_languages( $arr )
global $wpdb;
if ( !empty( $arr ) ) {
$tmp = array();
foreach ( $arr as $code ) {
$tmp[ ] = esc_sql( trim( $code ) );
// set the locale
$current_active_languages = (array)$wpdb->get_col( "SELECT code FROM {$wpdb->prefix}icl_languages WHERE active = 1" );
$new_languages = array_diff( $tmp, $current_active_languages );
if ( !empty( $new_languages ) ) {
foreach ( $new_languages as $code ) {
$default_locale_prepared = $wpdb->prepare( "SELECT default_locale FROM {$wpdb->prefix}icl_languages WHERE code=%s", $code );
$default_locale = $wpdb->get_var( $default_locale_prepared );
if ( $default_locale ) {
$code_exists_prepared = $wpdb->prepare( "SELECT code FROM {$wpdb->prefix}icl_locale_map WHERE code=%s", $code );
$code_exists = $wpdb->get_var( $code_exists_prepared );
if ( $code_exists ) {
$wpdb->update( $wpdb->prefix . 'icl_locale_map', array( 'locale' => $default_locale ), array( 'code' => $code ) );
} else {
$wpdb->insert( $wpdb->prefix . 'icl_locale_map', array( 'code' => $code, 'locale' => $default_locale ) );
$codes = '(\'' . join( '\',\'', $tmp ) . '\')';
$wpdb->update( $wpdb->prefix . 'icl_languages', array( 'active' => 0 ), array( 'active' => '1' ) );
$wpdb->query( "UPDATE {$wpdb->prefix}icl_languages SET active=1 WHERE code IN {$codes}" );
$this->icl_language_name_cache->clear();
SELECT code, english_name, active, lt.name AS display_name
WHERE
ORDER BY major DESC, english_name ASC", $this->get_default_language() );
$languages[ ] = $r;
return true;
* @param $lang_code
* Checks if a given language code belongs to a currently active language.
* @return bool
function is_active_language( $lang_code ) {
$result = false;
$active_languages = $this->get_active_languages();
foreach ( $active_languages as $lang ) {
if ( $lang_code == $lang[ 'code' ] ) {
$result = true;
break;
return $result;
function get_languages( $lang = false )
global $wpdb;
if ( !$lang ) {
$lang = $this->get_default_language();
$res_query = "SELECT
code, english_name, major, active, default_locale, lt.name AS display_name
WHERE lt.display_language_code = %s
ORDER BY major DESC, english_name ASC";
$res_query_prepared = $wpdb->prepare($res_query, $lang );
$res = $wpdb->get_results( $res_query_prepared, ARRAY_A );
foreach ( (array)$res as $r ) {
$languages[ ] = $r;
return $languages;
function get_language_details( $code )
global $wpdb;
$dcode = $this->admin_language;
} else {
$dcode = $code;
$details = $this->icl_language_name_cache->get( 'language_details_' . $code . $dcode );
} else {
$details = null;
if ( !$details ) {
$details = $wpdb->get_row( "
SELECT
code, english_name, major, active, lt.name AS display_name
WHERE lt.display_language_code = '{$dcode}' AND code='{$code}'
ORDER BY major DESC, english_name ASC", ARRAY_A );
$this->icl_language_name_cache->set( 'language_details_' . $code . $dcode, $details );
return $details;
function get_language_code( $english_name )
global $wpdb;
$code = $wpdb->get_row( "
SELECT
code
WHERE english_name = '{$english_name}'", ARRAY_A );
return $code[ 'code' ];
function get_icl_translator_status( &$iclsettings, $res = null )
if ( $res == null ) {
// check what languages we have translators for.
require_once ICL_PLUGIN_PATH . '/lib/Snoopy.class.php';
require_once ICL_PLUGIN_PATH . '/lib/xml2array.php';
require_once ICL_PLUGIN_PATH . '/lib/icl_api.php';
$icl_query = false;
if ( empty( $iclsettings[ 'site_id' ] ) ) {
// Must be for support
if ( !empty( $iclsettings[ 'support_site_id' ] ) ) {
$icl_query = new ICanLocalizeQuery( $iclsettings[ 'support_site_id' ], $iclsettings[ 'support_access_key' ] );
} else {
$icl_query = new ICanLocalizeQuery( $iclsettings[ 'site_id' ], $iclsettings[ 'access_key' ] );
if ( $icl_query === false ) {
return;
$res = $icl_query->get_website_details();
if ( isset( $res[ 'translation_languages' ][ 'translation_language' ] ) ) {
// reset $this->settings['icl_lang_status']
$iclsettings[ 'icl_lang_status' ] = array();
$translation_languages = $res[ 'translation_languages' ][ 'translation_language' ];
if ( !isset( $translation_languages[ 0 ] ) ) {
$buf = $translation_languages;
$translation_languages = array( 0 => $buf );
$target = array();
foreach ( $translation_languages as $lang ) {
$translators = $_tr = array();
$max_rate = false;
if ( isset( $lang[ 'translators' ] ) && !empty( $lang[ 'translators' ] ) ) {
if ( !isset( $lang[ 'translators' ][ 'translator' ][ 0 ] ) ) {
$_tr[ 0 ] = $lang[ 'translators' ][ 'translator' ];
} else {
$_tr = $lang[ 'translators' ][ 'translator' ];
foreach ( $_tr as $t ) {
if ( $max_rate === false || $t[ 'attr' ][ 'amount' ] > $max_rate ) {
$max_rate = $t[ 'attr' ][ 'amount' ];
$translators[ ] = array( 'id' => $t[ 'attr' ][ 'id' ], 'nickname' => $t[ 'attr' ][ 'nickname' ], 'contract_id' => $t[ 'attr' ][ 'contract_id' ] );
$target[ ] = array(
'from' => $this->get_language_code( ICL_Pro_Translation::server_languages_map( $lang[ 'attr' ][ 'from_language_name' ], true ) ),
'to' => $this->get_language_code( ICL_Pro_Translation::server_languages_map( $lang[ 'attr' ][ 'to_language_name' ], true ) ), 'have_translators' => $lang[ 'attr' ][ 'have_translators' ],
'available_translators' => $lang[ 'attr' ][ 'available_translators' ], 'applications' => $lang[ 'attr' ][ 'applications' ], 'contract_id' => $lang[ 'attr' ][ 'contract_id' ], 'id' => $lang[ 'attr' ][ 'id' ],
'translators' => $translators, 'max_rate' => $max_rate
$iclsettings[ 'icl_lang_status' ] = $target;
if ( isset( $res[ 'client' ][ 'attr' ] ) ) {
$iclsettings[ 'icl_balance' ] = $res[ 'client' ][ 'attr' ][ 'balance' ];
$iclsettings[ 'icl_anonymous_user' ] = $res[ 'client' ][ 'attr' ][ 'anon' ];
if ( isset( $res[ 'html_status' ][ 'value' ] ) ) {
$iclsettings[ 'icl_html_status' ] = html_entity_decode( $res[ 'html_status' ][ 'value' ] );
$iclsettings[ 'icl_html_status' ] = preg_replace_callback(
'#<a([^>]*)href="([^"]+)"([^>]*)>#i',
create_function( '$matches', 'global $sitepress; return $sitepress->create_icl_popup_link($matches[2], array(\'unload_cb\'=>\'icl_pt_reload_translation_box\'));' ),
if ( isset( $res[ 'translators_management_info' ][ 'value' ] ) ) {
$iclsettings[ 'translators_management_info' ] = html_entity_decode( $res[ 'translators_management_info' ][ 'value' ] );
$iclsettings[ 'translators_management_info' ] = preg_replace_callback(
$iclsettings[ 'icl_support_ticket_id' ] = @intval( $res[ 'attr' ][ 'support_ticket_id' ] );
function get_language_status_text( $from_lang, $to_lang, $pop_close_cb = false )
$pop_args = array( 'title' => 'ICanLocalize' );
if ( $pop_close_cb ) {
$pop_args[ 'unload_cb' ] = $pop_close_cb;
$lang_status = !empty( $this->settings[ 'icl_lang_status' ] ) ? $this->settings[ 'icl_lang_status' ] : array();
foreach ( $lang_status as $lang ) {
if ( $from_lang == $lang[ 'from' ] && $to_lang == $lang[ 'to' ] ) {
if ( isset( $lang[ 'available_translators' ] ) ) {
if ( !$lang[ 'available_translators' ] ) {
if ( $this->settings[ 'icl_support_ticket_id' ] == '' ) {
// No translators available on icanlocalize for this language pair.
$response = sprintf( __( '- (No translators available - please %sprovide more information about your site%s)', 'sitepress' ), $this->create_icl_popup_link( ICL_API_ENDPOINT . '/websites/' . $this->settings[ 'site_id' ] . '/explain?after=refresh_langs', $pop_args ), '</a>' );
} else {
$response = sprintf( __( '- (No translators available - %scheck progress%s)', 'sitepress' ), $this->create_icl_popup_link( ICL_API_ENDPOINT . '/support/show/' . $this->settings[ 'icl_support_ticket_id' ] . '?after=refresh_langs', $pop_args ), '</a>' );
} else {
if ( !$lang[ 'applications' ] ) {
// No translators have applied for this language pair.
$pop_args[ 'class' ] = 'icl_hot_link';
$response = ' | ' . $this->create_icl_popup_link( "@select-translators;{$from_lang};{$to_lang}@", $pop_args ) . __( 'Select translators', 'sitepress' ) . '</a>';
} else {
if ( !$lang[ 'have_translators' ] ) {
// translators have applied but none selected yet
} else {
// there are translators ready to translate
$translators = array();
if ( is_array( $lang[ 'translators' ] ) ) {
foreach ( $lang[ 'translators' ] as $translator ) {
$link = $this->create_icl_popup_link( ICL_API_ENDPOINT . '/websites/' . $this->settings[ 'site_id' ] . '/website_translation_offers/' . $lang[ 'id' ] . '/website_translation_contracts/' . $translator[ 'contract_id' ], $pop_args );
$translators[ ] = $link . esc_html( $translator[ 'nickname' ] ) . '</a>';
$response .= ' | ' . sprintf( __( 'Communicate with %s', 'sitepress' ), join( ', ', $translators ) );
return $response;
break;
// no status found
return $response;
function are_waiting_for_translators( $from_lang )
$lang_status = $this->settings[ 'icl_lang_status' ];
if ( $lang_status && $this->icl_account_configured() ) {
if ( $from_lang == $lang[ 'from' ] ) {
if ( $lang[ 'available_translators' ] && !$lang[ 'applications' ] ) {
return true;
return false;
function get_default_language()
return isset( $this->settings[ 'default_language' ] ) ? $this->settings[ 'default_language' ] : false;
function get_current_language()
return apply_filters( 'icl_current_language', $this->this_lang );
function get_strings_language()
return isset( $this->settings[ 'st' ][ 'strings_language' ] ) ? $this->settings[ 'st' ][ 'strings_language' ] : false;
function switch_lang( $code = null, $cookie_lang = false )
static $original_language, $original_language_cookie;
if ( is_null( $original_language ) ) {
$original_language = $this->get_current_language();
if ( is_null( $code ) ) {
$this->this_lang = $original_language;
$this->admin_language = $original_language;
// restore cookie language if case
if ( !empty( $original_language_cookie ) ) {
$this->update_language_cookie($original_language_cookie);
$original_language_cookie = false;
} else {
if ( $code == 'all' || in_array( $code, array_keys( $this->get_active_languages() ) ) ) {
$this->this_lang = $code;
$this->admin_language = $code;
// override cookie language
if ( $cookie_lang ) {
$original_language_cookie = $this->get_language_cookie();
$this->update_language_cookie($code);
function set_default_language( $code )
$previous_default = $this->get_setting('default_language');
$this->set_setting( 'default_language', $code);
$this->set_setting('admin_default_language', $code);
do_action('icl_after_set_default_language',$code, $previous_default);
// change WP locale
$locale = $this->get_locale( $code );
if ( $locale ) {
update_option( 'WPLANG', $locale );
if ( $code != 'en' && !file_exists( ABSPATH . LANGDIR . '/' . $locale . '.mo' ) ) {
return 1; //locale not installed
return true;
function get_icl_translation_enabled( $lang = null, $langto = null )
if ( !is_null( $lang ) ) {
if ( !is_null( $langto ) ) {
return $this->settings[ 'language_pairs' ][ $lang ][ $langto ];
} else {
return !empty( $this->settings[ 'language_pairs' ][ $lang ] );
} else {
return isset( $this->settings[ 'enable_icl_translations' ] ) ? $this->settings[ 'enable_icl_translations' ] : false;
function set_icl_translation_enabled()
$iclsettings[ 'translation_enabled' ] = true;
function icl_account_reqs()
$errors = array();
if ( !$this->get_icl_translation_enabled() ) {
$errors[ ] = __( 'Professional translation not enabled', 'sitepress' );
return $errors;
function icl_account_configured()
return isset( $this->settings[ 'site_id' ] ) && $this->settings[ 'site_id' ] && isset( $this->settings[ 'access_key' ] ) && $this->settings[ 'access_key' ];
function icl_support_configured()
return isset( $this->settings[ 'support_site_id' ] ) && isset( $this->settings[ 'support_access_key' ] ) && $this->settings[ 'support_site_id' ] && $this->settings[ 'support_access_key' ];
function reminders_popup()
include ICL_PLUGIN_PATH . '/modules/icl-translation/icl-reminder-popup.php';
exit;
function create_icl_popup_link( $link, $args = array(), $just_url = false, $support_mode = false )
// defaults
/** @var $id int */
/** @var $class string */
$defaults = array(
'title' => null, 'class' => '', 'id' => '', 'ar' => 0, // auto_resize
'unload_cb' => false, // onunload callback
extract( $defaults );
extract( $args, EXTR_OVERWRITE );
if ( !empty( $ar ) ) {
$auto_resize = '&auto_resize=1';
} else {
$auto_resize = '';
$unload_cb = isset( $unload_cb ) ? '&unload_cb=' . $unload_cb : '';
$url_glue = false !== strpos( $link, '?' ) ? '&' : '?';
$link .= $url_glue . 'compact=1';
if ( isset( $this->settings[ 'access_key' ] ) || isset( $this->settings[ 'support_access_key' ] ) ) {
if ( $support_mode && isset( $this->settings[ 'support_access_key' ] ) ) {
$link .= '&accesskey=' . $this->settings[ 'support_access_key' ];
} elseif ( isset( $this->settings[ 'access_key' ] ) ) {
$link .= '&accesskey=' . $this->settings[ 'access_key' ];
if ( !empty( $id ) ) {
$id = ' id="' . $id . '"';
if ( isset( $title ) && !$just_url ) {
return '<a class="icl_thickbox ' . $class . '" title="' . $title . '" href="admin.php?page=' . ICL_PLUGIN_FOLDER . "/menu/languages.php&icl_action=reminder_popup{$auto_resize}{$unload_cb}&target=" . urlencode( $link ) . '"' . $id . '>';
} else {
if ( !$just_url ) {
return '<a class="icl_thickbox ' . $class . '" href="admin.php?page=' . ICL_PLUGIN_FOLDER . "/menu/languages.php&icl_action=reminder_popup{$auto_resize}{$unload_cb}&target=" . urlencode( $link ) . '"' . $id . '>';
} else {
return 'admin.php?page=' . ICL_PLUGIN_FOLDER . "/menu/languages.php&icl_action=reminder_popup{$auto_resize}{$unload_cb}&target=" . urlencode( $link );
function js_scripts_setup()
//TODO: move javascript to external resource (use wp_localize_script() to pass arguments)
global $pagenow, $wpdb;
$default_language = $this->get_default_language();
$current_language = $this->get_current_language();
if ( isset( $_GET[ 'page' ] ) ) {
$page = basename( $_GET[ 'page' ] );
$page_basename = str_replace( '.php', '', $page );
} else {
$page_basename = false;
$icl_ajax_url_root = rtrim(get_site_url(),'/');
if(defined('FORCE_SSL_ADMIN') && FORCE_SSL_ADMIN) {
$icl_ajax_url_root = str_replace('hidden link', 'hidden link', $icl_ajax_url_root);
$icl_ajax_url = $icl_ajax_url_root . '/wp-admin/admin.php?page=' . ICL_PLUGIN_FOLDER . '/menu/languages.php';
<script type="text/javascript">
// <![CDATA[
var icl_ajx_url;
icl_ajx_url = '<?php echo $icl_ajax_url; ?>';
var icl_ajx_saved = '<?php echo icl_js_escape( __('Data saved','sitepress')); ?>';
var icl_ajx_error = '<?php echo icl_js_escape( __('Error: data not saved','sitepress')); ?>';
var icl_default_mark = '<?php echo icl_js_escape(__('default','sitepress')); ?>';
var icl_this_lang = '<?php echo $this->this_lang ?>';
var icl_ajxloaderimg_src = '<?php echo ICL_PLUGIN_URL ?>/res/img/ajax-loader.gif';
var icl_cat_adder_msg = '<?php echo icl_js_escape(sprintf(__('To add categories that already exist in other languages go to the <a%s>category management page</a>','sitepress'), ' href="'.admin_url('edit-tags.php?taxonomy=category').'"'));?>';
<?php if(!$this->get_setting('ajx_health_checked')): ?>
addLoadEvent(function () {
jQuery.ajax({type: "POST", url: icl_ajx_url, data: "icl_ajx_action=health_check", error: function (msg) {
var icl_initial_language = jQuery('#icl_initial_language');
if (icl_initial_language.length) {
icl_initial_language.find('input').attr('disabled', 'disabled');
jQuery('.wrap').prepend('<div class="error"><p><?php
echo icl_js_escape(sprintf(__("WPML can't run normally. There is an installation or server configuration problem. %sShow details%s",'sitepress'),
'<a href="#" onclick="jQuery(this).parent().next().slideToggle()">', '</a>'));
?></p><p style="display:none"><?php echo icl_js_escape(__('AJAX Error:', 'sitepress'))?> ' + msg.statusText + ' [' + msg.status + ']<br />URL:' + icl_ajx_url + '</p></div>');
<?php endif; ?>
</script>
<?php
if ( 'options-reading.php' == $pagenow ) {
list( $warn_home, $warn_posts ) = $this->verify_home_and_blog_pages_translations();
if ( $warn_home || $warn_posts ) {
jQuery('input[name="show_on_front"]').parent().parent().parent().parent().append('<?php echo str_replace("'","\\'",$warn_home . $warn_posts); ?>');
</script>
<?php
// display correct links on the posts by status break down
// also fix links to category and tag pages
if ( ( 'edit.php' == $pagenow || 'edit-pages.php' == $pagenow || 'categories.php' == $pagenow || 'edit-tags.php' == $pagenow ) && $current_language != $default_language ) {
jQuery('.subsubsub li a').each(function () {
var h = jQuery(this).attr('href');
var urlg;
if (-1 == h.indexOf('?')) urlg = '?'; else urlg = '&';
jQuery(this).attr('href', h + urlg + 'lang=<?php echo $current_language?>');
jQuery('.column-categories a, .column-tags a, .column-posts a').each(function () {
jQuery(this).attr('href', jQuery(this).attr('href') + '&lang=<?php echo $current_language?>');
</script>
<?php
if ( 'edit-tags.php' == $pagenow ) {
var edit_tag = jQuery('#edittag');
if (edit_tag.find('[name="_wp_original_http_referer"]').length && edit_tag.find('[name="_wp_http_referer"]').length) {
edit_tag.find('[name="_wp_original_http_referer"]').val('<?php
$post_type = isset($_GET['post_type']) ? '&post_type=' . esc_html($_GET['post_type']) : '';
echo admin_url('edit-tags.php?taxonomy=' . esc_js($_GET['taxonomy']) . '&lang='.$current_language.'&message=3'.$post_type) ?>');
</script>
<?php
if ( 'post-new.php' == $pagenow ) {
if ( isset( $_GET[ 'trid' ] ) ) {
$translations = $wpdb->get_col( $wpdb->prepare( "SELECT element_id FROM {$wpdb->prefix}icl_translations WHERE trid=%d", $_GET[ 'trid' ] ) );
remove_filter( 'option_sticky_posts', array( $this, 'option_sticky_posts' ) ); // remove filter used to get language relevant stickies. get them all
$sticky_posts = get_option( 'sticky_posts' );
add_filter( 'option_sticky_posts', array( $this, 'option_sticky_posts' ) ); // add filter back
$is_sticky = false;
foreach ( $translations as $t ) {
if ( in_array( $t, $sticky_posts ) ) {
$is_sticky = true;
break;
if ( isset( $_GET[ 'trid' ] ) && ( $this->settings[ 'sync_ping_status' ] || $this->settings[ 'sync_comment_status' ] ) ) {
$res = $wpdb->get_row( $wpdb->prepare( "SELECT comment_status, ping_status FROM {$wpdb->prefix}icl_translations t
JOIN {$wpdb->posts} p ON t.element_id = p.ID WHERE t.trid=%d", $_GET[ 'trid' ] ) ); ?>
<script type="text/javascript">addLoadEvent(function () {
var comment_status = jQuery('#comment_status');
var ping_status = jQuery('#ping_status');
<?php if($this->settings['sync_comment_status']): ?>
<?php if($res->comment_status == 'open'): ?>
comment_status.attr('checked', 'checked');
<?php else: ?>
comment_status.removeAttr('checked');
<?php endif; ?>
<?php endif; ?>
<?php if($this->settings['sync_ping_status']): ?>
<?php if($res->ping_status == 'open'): ?>
ping_status.attr('checked', 'checked');
<?php else: ?>
ping_status.removeAttr('checked');
<?php endif; ?>
<?php endif; ?>
});</script><?php
if ( isset( $_GET[ 'trid' ] ) && $this->settings[ 'sync_private_flag' ] ) {
if ( 'private' == $wpdb->get_var( $wpdb->prepare( "
SELECT p.post_status FROM {$wpdb->prefix}icl_translations t
WHERE t.trid=%d AND t.element_type='post_post'
jQuery('#visibility-radio-private').attr('checked', 'checked');
jQuery('#post-visibility-display').html('<?php echo icl_js_escape(__('Private', 'sitepress')); ?>');
</script><?php
if ( isset( $_GET[ 'trid' ] ) && $this->settings[ 'sync_post_taxonomies' ] ) {
$post_type = isset( $_GET[ 'post_type' ] ) ? $_GET[ 'post_type' ] : 'post';
$source_lang = isset( $_GET[ 'source_lang' ] ) ? $_GET[ 'source_lang' ] : $default_language;
$translatable_taxs = $this->get_translatable_taxonomies( true, $post_type );
$all_taxs = get_object_taxonomies( $post_type );
$translations = $this->get_element_translations( $_GET[ 'trid' ], 'post_' . $post_type );
$js = array();
if ( !empty( $all_taxs ) ) {
foreach ( $all_taxs as $tax ) {
$tax_detail = get_taxonomy( $tax );
$terms = get_the_terms( $translations[ $source_lang ]->element_id, $tax );
$term_names = array();
if ( $terms ) {
foreach ( $terms as $term ) {
if ( $tax_detail->hierarchical ) {
if ( in_array( $tax, $translatable_taxs ) ) {
$term_id = icl_object_id( $term->term_id, $tax, false );
} else {
$term_id = $term->term_id;
$js[ ] = "jQuery('#in-" . $tax . "-" . $term_id . "').attr('checked', 'checked');";
} else {
if ( $term_id ) {
$term = get_term_by( 'id', $term_id, $tax );
$term_names[ ] = esc_js( $term->name );
} else {
if ( $term_names ) {
$js[ ] = "jQuery('#{$tax} .taghint').css('visibility','hidden');";
$js[ ] = "jQuery('#new-tag-{$tax}').val('" . join( ', ', $term_names ) . "');";
if ( $js ) {
echo '<script type="text/javascript">';
echo PHP_EOL . '// <![CDATA[' . PHP_EOL;
echo 'addLoadEvent(function(){' . PHP_EOL;
echo join( PHP_EOL, $js );
echo PHP_EOL . 'jQuery().ready(function() {
jQuery(".tagadd").click();
jQuery(\'html, body\').prop({scrollTop:0});
jQuery(\'#title\').focus();
});' . PHP_EOL;
echo PHP_EOL . '});' . PHP_EOL;
echo PHP_EOL . '// ]]>' . PHP_EOL;
echo '</script>';
// sync custom fields
if ( !empty( $this->settings[ 'translation-management' ] ) ) {
foreach ( (array)$this->settings[ 'translation-management' ][ 'custom_fields_translation' ] as $key => $sync_opt ) {
if ( $sync_opt == 1 ) {
$copied_cf[ ] = $key;
if ( !empty( $copied_cf ) ) {
$lang_details = $this->get_language_details( $source_lang );
$original_custom = get_post_custom( $translations[ $source_lang ]->element_id );
$copied_cf = array_intersect( $copied_cf, array_keys( $original_custom ) );
$copied_cf = apply_filters( 'icl_custom_fields_to_be_copied', $copied_cf, $translations[ $source_lang ]->element_id );
if ( !empty( $copied_cf ) && ( empty( $this->user_preferences[ 'notices' ] ) || empty( $this->user_preferences[ 'notices' ][ 'hide_custom_fields_copy' ] ) ) ) {
$ccf_note = '<img src="' . ICL_PLUGIN_URL . '/res/img/alert.png" alt="Notice" width="16" height="16" style="margin-right:8px" />';
$ccf_note .= '<a class="icl_user_notice_hide" href="#hide_custom_fields_copy" style="float:right;margin-left:20px;">' . __( 'Never show this.', 'sitepress' ) . '</a>';
$ccf_note .= wp_nonce_field( 'save_user_preferences_nonce', '_icl_nonce_sup', false, false );
$ccf_note .= sprintf( __( 'WPML will copy %s from %s when you save this post.', 'sitepress' ), '' . join( ', ', $copied_cf ) . '', $lang_details[ 'display_name' ] );
$this->admin_notices( $ccf_note, 'error' );
<?php if ( !empty( $is_sticky ) && $this->settings[ 'sync_sticky_flag' ] ): ?>
addLoadEvent(
function () {
jQuery('#sticky').attr('checked', 'checked');
var post_visibility_display = jQuery('#post-visibility-display');
post_visibility_display.html(post_visibility_display.html() + ', <?php echo icl_js_escape(__('Sticky', 'sitepress')) ?>');
</script>
<?php endif; ?>
<?php
if ( 'page-new.php' == $pagenow || ( 'post-new.php' == $pagenow && isset( $_GET[ 'post_type' ] ) ) ) {
if ( isset( $_GET[ 'trid' ] ) && ( $this->settings[ 'sync_page_template' ] || $this->settings[ 'sync_page_ordering' ] ) ) {
SELECT p.ID, p.menu_order FROM {$wpdb->prefix}icl_translations t
WHERE t.trid=%d AND p.post_type=%s AND t.element_type=%s
", $_GET[ 'trid' ], $_GET[ 'post_type' ], 'post_' . $_GET[ 'post_type' ] ) );
if ( $this->settings[ 'sync_page_ordering' ] ) {
$menu_order = $res->menu_order;
} else {
$menu_order = false;
if ( $this->settings[ 'sync_page_template' ] ) {
$page_template = get_post_meta( $res->ID, '_wp_page_template', true );
} else {
$page_template = false;
if ( $menu_order || $page_template ) {
<script type="text/javascript">addLoadEvent(function () { <?php
if($menu_order){ ?>
jQuery('#menu_order').val(<?php echo $menu_order ?>);
<?php }
if($page_template && 'default' != $page_template){ ?>
jQuery('#page_template').val('<?php echo $page_template ?>');
<?php }
});</script><?php
} elseif ( 'edit-comments.php' == $pagenow || 'index.php' == $pagenow || 'post.php' == $pagenow ) {
wp_enqueue_script( 'sitepress-' . $page_basename, ICL_PLUGIN_URL . '/res/js/comments-translation.js', array(), ICL_SITEPRESS_VERSION );
// sync post dates
if ( icl_is_post_edit() ) {
// @since 3.1.5
// Enqueing 'wp-jquery-ui-dialog', just in case it doesn't get automatically enqueued
wp_enqueue_style( 'wp-jquery-ui-dialog' );
wp_enqueue_style( 'sitepress-post-edit', ICL_PLUGIN_URL . '/res/css/post-edit.css', array( ), ICL_SITEPRESS_VERSION );
wp_enqueue_script( 'sitepress-post-edit', ICL_PLUGIN_URL . '/res/js/post-edit.js', array( 'jquery-ui-dialog', 'jquery-ui-autocomplete', 'autosave' ), ICL_SITEPRESS_VERSION );
if ( $this->settings[ 'sync_post_date' ] ) {
$trid = intval( $_GET[ 'trid' ] );
} else {
$post_id = @intval( $_GET[ 'post' ] );
$trid = $this->get_element_trid( $post_id, 'post_' . $post_type );
$translations = $this->get_element_translations( $trid, 'post_' . $post_type );
if ( !empty( $translations ) && isset( $translations[ $current_language ] ) && !$translations[ $current_language ]->original ) {
if ( isset( $translations[ $source_lang ] ) ) {
$original_date = $wpdb->get_var( $wpdb->prepare( "SELECT post_date FROM {$wpdb->posts} WHERE ID=%d", $translations[ $source_lang ]->element_id ) );
$exp = explode( ' ', $original_date );
list( $aa, $mm, $jj ) = explode( '-', $exp[ 0 ] );
list( $hh, $mn, $ss ) = explode( ':', $exp[ 1 ] );
addLoadEvent(
function () {
jQuery('#aa').val('<?php echo $aa ?>').attr('readonly', 'readonly');
jQuery('#mm').val('<?php echo $mm ?>').attr('readonly', 'readonly');
jQuery('#jj').val('<?php echo $jj ?>').attr('readonly', 'readonly');
jQuery('#hh').val('<?php echo $hh ?>').attr('readonly', 'readonly');
jQuery('#mn').val('<?php echo $mn ?>').attr('readonly', 'readonly');
jQuery('#ss').val('<?php echo $ss ?>').attr('readonly', 'readonly');
var timestamp = jQuery('#timestamp');
timestamp.find('b').html('<?php esc_html_e('copy from original', 'sitepress') ?>');
timestamp.next().html('<?php esc_html_e('show', 'sitepress') ?>');
</script>
<?php
if ( 'post-new.php' == $pagenow && isset( $_GET[ 'trid' ] ) && $this->settings[ 'sync_post_format' ] && function_exists( 'get_post_format' ) ) {
$format = get_post_format( $wpdb->get_var( $wpdb->prepare( "SELECT element_id FROM {$wpdb->prefix}icl_translations WHERE trid=%d and language_code=%s", $_GET[ 'trid' ], $_GET[ 'source_lang' ] ) ) );
jQuery('#post-format-' + '<?php echo $format ?>').attr('checked', 'checked');
</script><?php
if ( is_admin() ) {
wp_enqueue_script( 'thickbox' );
wp_enqueue_script( 'theme-preview' );
wp_enqueue_script( 'sitepress-icl_reminders', ICL_PLUGIN_URL . '/res/js/icl_reminders.js', array(), ICL_SITEPRESS_VERSION );
//if('content-translation' == $page_basename) {
// wp_enqueue_script('icl-sidebar-scripts', ICL_PLUGIN_URL . '/res/js/icl_sidebar.js', array(), ICL_SITEPRESS_VERSION);
if ( 'languages' == $page_basename || 'string-translation' == $page_basename ) {
wp_enqueue_script( 'colorpicker' );
wp_enqueue_script( 'jquery-ui-sortable' );
function js_load()
if ( is_admin() && !defined( 'DOING_AJAX' ) ) {
} else {
if ( isset( $_SERVER[ 'SCRIPT_NAME' ] ) && ( strpos( $_SERVER[ 'SCRIPT_NAME' ], 'post-new.php' ) || strpos( $_SERVER[ 'SCRIPT_NAME' ], 'post.php' ) ) ) {
wp_register_script( 'sitepress-post-edit-tags', ICL_PLUGIN_URL . '/res/js/post-edit-terms.js', array( 'jquery', 'underscore' ) );
$post_edit_messages = array(
'switch_language_title' => __( 'You are about to change the language of {post_name}.', 'sitepress' ),
'switch_language_alert' => __( 'All categories and tags will be translated if possible.', 'sitepress' ),
'connection_loss_alert' => __( 'The following terms do not have a translation in the chosen language and will be disconnected from this post:', 'sitepress' ),
'loading' => __( 'Loading Language Data for {post_name}', 'sitepress' ),
'switch_language_message' => __( 'Please make sure that you\'ve saved all the changes. We will have to reload the page.', 'sitepress' ),
'switch_language_confirm' => __( 'Do you want to continue?', 'sitepress' ),
wp_localize_script( 'sitepress-post-edit-tags', 'icl_post_edit_messages', $post_edit_messages );
wp_enqueue_script( 'sitepress-post-edit-tags' );
if ( isset( $_SERVER[ 'SCRIPT_NAME' ] ) && strpos( $_SERVER[ 'SCRIPT_NAME' ], 'edit.php' ) ) {
wp_register_script( 'sitepress-post-list-quickedit', ICL_PLUGIN_URL . '/res/js/post-list-quickedit.js', array( 'jquery') );
wp_enqueue_script( 'sitepress-post-list-quickedit' );
wp_enqueue_script( 'sitepress-scripts', ICL_PLUGIN_URL . '/res/js/scripts.js', array( 'jquery' ), ICL_SITEPRESS_VERSION );
if ( isset( $page_basename ) && file_exists( ICL_PLUGIN_PATH . '/res/js/' . $page_basename . '.js' ) ) {
$dependencies = array();
$localization = false;
switch ( $page_basename ) {
case 'languages':
$dependencies[ ] = 'colorpicker';
break;
case 'troubleshooting':
$dependencies [ ] = 'jquery-ui-dialog';
$localization = array(
'object_name' => 'troubleshooting_strings',
'strings' => array(
'success_1' => __( "Post type and source language assignment have been fixed for ", 'sitepress' ),
'success_2' => __( " elements", 'sitepress' ),
'no_problems' => __( "No errors were found in the assignment of post types." ),
'suffixesRemoved' => __( "Language suffixes were removed from the selected terms." )
wp_enqueue_style("wp-jquery-ui-dialog");
break;
$handle = 'sitepress-' . $page_basename;
wp_register_script( $handle, ICL_PLUGIN_URL . '/res/js/' . $page_basename . '.js', $dependencies, ICL_SITEPRESS_VERSION );
if ( $localization ) {
wp_localize_script( $handle, $localization[ 'object_name' ], $localization[ 'strings' ] );
wp_enqueue_script( $handle );
} else {
wp_enqueue_script( 'translate-taxonomy', ICL_PLUGIN_URL . '/res/js/taxonomy-translation.js', array( 'jquery' ), ICL_SITEPRESS_VERSION );
if ( !wp_style_is( 'toolset-font-awesome', 'registered' ) ) { // check if styles are already registered
wp_register_style( 'toolset-font-awesome', ICL_PLUGIN_URL . '/res/css/font-awesome.min.css', null, ICL_SITEPRESS_VERSION ); // register if not
wp_enqueue_style( 'toolset-font-awesome' ); // enqueue styles
function front_end_js()
if ( defined( 'ICL_DONT_LOAD_LANGUAGES_JS' ) && ICL_DONT_LOAD_LANGUAGES_JS ) {
return;
wp_register_script( 'sitepress', ICL_PLUGIN_URL . '/res/js/sitepress.js', false );
wp_enqueue_script( 'sitepress' );
$vars = array(
'current_language' => $this->this_lang, 'icl_home' => $this->language_url(),
wp_localize_script( 'sitepress', 'icl_vars', $vars );
function js_scripts_categories()
wp_enqueue_script( 'sitepress-categories', ICL_PLUGIN_URL . '/res/js/categories.js', array(), ICL_SITEPRESS_VERSION );
function js_scripts_tags()
wp_enqueue_script( 'sitepress-tags', ICL_PLUGIN_URL . '/res/js/tags.js', array(), ICL_SITEPRESS_VERSION );
function rtl_fix()
global $wp_styles;
if ( !empty( $wp_styles ) && $this->is_rtl() ) {
$wp_styles->text_direction = 'rtl';
function css_setup()
wp_enqueue_style( 'sitepress-style', ICL_PLUGIN_URL . '/res/css/style.css', array(), ICL_SITEPRESS_VERSION );
if ( isset( $page_basename ) && file_exists( ICL_PLUGIN_PATH . '/res/css/' . $page_basename . '.css' ) ) {
wp_enqueue_style( 'sitepress-' . $page_basename, ICL_PLUGIN_URL . '/res/css/' . $page_basename . '.css', array(), ICL_SITEPRESS_VERSION );
if ( is_admin() ) {
wp_enqueue_style( 'thickbox' );
wp_enqueue_style( 'translate-taxonomy', ICL_PLUGIN_URL . '/res/css/taxonomy-translation.css', array(), ICL_SITEPRESS_VERSION );
function transfer_icl_account( $create_account_and_transfer )
$user = $_POST[ 'user' ];
$user[ 'site_id' ] = $this->settings[ 'site_id' ];
$user[ 'accesskey' ] = $this->settings[ 'access_key' ];
$user[ 'create_account' ] = $create_account_and_transfer ? '1' : '0';
$icl_query = new ICanLocalizeQuery();
list( $success, $access_key ) = $icl_query->transfer_account( $user );
if ( $success ) {
$this->settings[ 'access_key' ] = $access_key;
// set the support data the same.
$this->settings[ 'support_access_key' ] = $access_key;
return true;
} else {
$_POST[ 'icl_form_errors' ] = $access_key;
return false;
function process_forms()
global $wpdb;
if ( isset( $_POST[ 'icl_post_action' ] ) ) {
switch ( $_POST[ 'icl_post_action' ] ) {
case 'save_theme_localization':
$locales = array();
if ( 0 !== strpos( $k, 'locale_file_name_' ) || !trim( $v ) ) {
continue;
$locales[ str_replace( 'locale_file_name_', '', $k ) ] = $v;
if ( !empty( $locales ) ) {
$this->set_locale_file_names( $locales );
break;
return;
$create_account = isset( $_POST[ 'icl_create_account_nonce' ] ) && $_POST[ 'icl_create_account_nonce' ] == wp_create_nonce( 'icl_create_account' );
$create_account_and_transfer = isset( $_POST[ 'icl_create_account_and_transfer_nonce' ] ) && $_POST[ 'icl_create_account_and_transfer_nonce' ] == wp_create_nonce( 'icl_create_account_and_transfer' );
$config_account = isset( $_POST[ 'icl_configure_account_nonce' ] ) && $_POST[ 'icl_configure_account_nonce' ] == wp_create_nonce( 'icl_configure_account' );
$create_support_account = isset( $_POST[ 'icl_create_support_account_nonce' ] ) && $_POST[ 'icl_create_support_account_nonce' ] == wp_create_nonce( 'icl_create_support_account' );
$config_support_account = isset( $_POST[ 'icl_configure_support_account_nonce' ] ) && $_POST[ 'icl_configure_support_account_nonce' ] == wp_create_nonce( 'icl_configure_support_account' );
$use_existing_account = isset( $_POST[ 'icl_use_account_nonce' ] ) && $_POST[ 'icl_use_account_nonce' ] == wp_create_nonce( 'icl_use_account' );
$transfer_to_account = isset( $_POST[ 'icl_transfer_account_nonce' ] ) && $_POST[ 'icl_transfer_account_nonce' ] == wp_create_nonce( 'icl_transfer_account' );
if ( $create_account || $config_account || $create_support_account || $config_support_account ) {
if ( isset( $_POST[ 'icl_content_trans_setup_back_2' ] ) ) {
// back button in wizard mode.
$this->settings[ 'content_translation_setup_wizard_step' ] = 2;
} else {
$user[ 'create_account' ] = ( isset( $_POST[ 'icl_create_account_nonce' ] ) || isset( $_POST[ 'icl_create_support_account_nonce' ] ) ) ? 1 : 0;
$user[ 'platform_kind' ] = 2;
$user[ 'cms_kind' ] = 1;
$user[ 'blogid' ] = $wpdb->blogid ? $wpdb->blogid : 1;
$user[ 'url' ] = get_home_url();
$user[ 'title' ] = get_option( 'blogname' );
$user[ 'description' ] = $this->settings[ 'icl_site_description' ];
$user[ 'is_verified' ] = 1;
if ( $user[ 'create_account' ] && defined( 'ICL_AFFILIATE_ID' ) && defined( 'ICL_AFFILIATE_KEY' ) ) {
$user[ 'affiliate_id' ] = ICL_AFFILIATE_ID;
$user[ 'affiliate_key' ] = ICL_AFFILIATE_KEY;
$user[ 'interview_translators' ] = $this->settings[ 'interview_translators' ];
$user[ 'project_kind' ] = $this->settings[ 'website_kind' ];
if(is_null($user['project_kind']) || $user['project_kind']==''){
$_POST['icl_form_errors'] = __('Please select the kind of website','sitepress');
return;
$user[ 'pickup_type' ] = intval( $this->settings[ 'translation_pickup_method' ] );
$notifications = 0;
if ( $this->settings[ 'icl_notify_complete' ] ) {
$notifications += 1;
if ( $this->settings[ 'alert_delay' ] ) {
$notifications += 2;
$user[ 'notifications' ] = $notifications;
// prepare language pairs
$pay_per_use = $this->settings[ 'translator_choice' ] == 1;
$language_pairs = $this->settings[ 'language_pairs' ];
$lang_pairs = array();
if ( isset( $language_pairs ) ) {
foreach ( $language_pairs as $k => $v ) {
$english_fr = $wpdb->get_var( "SELECT english_name FROM {$wpdb->prefix}icl_languages WHERE code='{$k}' " );
$pay_per_use_increment = 0;
foreach ( $v as $k => $v ) {
$pay_per_use_increment++;
$english_to = $wpdb->get_var( "SELECT english_name FROM {$wpdb->prefix}icl_languages WHERE code='{$k}' " );
$lang_pairs[ 'from_language' . $pay_per_use_increment ] = ICL_Pro_Translation::server_languages_map( $english_fr );
$lang_pairs[ 'to_language' . $pay_per_use_increment ] = ICL_Pro_Translation::server_languages_map( $english_to );
if ( $pay_per_use ) {
$lang_pairs[ 'pay_per_use' . $pay_per_use_increment ] = 1;
list( $site_id, $access_key ) = $icl_query->createAccount( array_merge( $user, $lang_pairs ) );
if ( !$site_id ) {
$user[ 'pickup_type' ] = ICL_PRO_TRANSLATION_PICKUP_POLLING;
if ( !$site_id ) {
if ( $access_key ) {
} else {
$_POST[ 'icl_form_errors' ] = __( 'An unknown error has occurred when communicating with the ICanLocalize server. Please try again.', 'sitepress' );
// We will force the next try to be http.
update_option( '_force_mp_post_http', 1 );
} else {
if ( $create_account || $config_account ) {
$iclsettings[ 'site_id' ] = $site_id;
$iclsettings[ 'access_key' ] = $access_key;
$iclsettings[ 'icl_account_email' ] = $user[ 'email' ];
$iclsettings[ 'support_site_id' ] = $site_id;
$iclsettings[ 'support_access_key' ] = $access_key;
$iclsettings[ 'support_icl_account_email' ] = $user[ 'email' ];
} else {
if ( isset( $user[ 'pickup_type' ] ) && $user[ 'pickup_type' ] == ICL_PRO_TRANSLATION_PICKUP_POLLING ) {
$iclsettings[ 'translation_pickup_method' ] = ICL_PRO_TRANSLATION_PICKUP_POLLING;
if ( $user[ 'create_account' ] == 1 ) {
$_POST[ 'icl_form_success' ] = __( 'A project on ICanLocalize has been created.', 'sitepress' ) . '<br />';
} else {
$_POST[ 'icl_form_success' ] = __( 'Project added', 'sitepress' );
$this->get_icl_translator_status( $iclsettings );
if ( !$create_support_account && !$config_support_account && intval( $site_id ) > 0 && $access_key && $this->settings[ 'content_translation_setup_complete' ] == 0 && $this->settings[ 'content_translation_setup_wizard_step' ] == 3 && !isset( $_POST[ 'icl_form_errors' ] ) ) {
// we are running the wizard, so we can finish it now.
$this->settings[ 'content_translation_setup_complete' ] = 1;
$this->settings[ 'content_translation_setup_wizard_step' ] = 0;
} elseif ( $use_existing_account || $transfer_to_account || $create_account_and_transfer ) {
} else {
if ( $transfer_to_account ) {
$_POST[ 'user' ][ 'email' ] = $_POST[ 'user' ][ 'email2' ];
// we will be using the support account for the icl_account
$this->settings[ 'site_id' ] = $this->settings[ 'support_site_id' ];
$this->settings[ 'access_key' ] = $this->settings[ 'support_access_key' ];
$this->settings[ 'icl_account_email' ] = $this->settings[ 'support_icl_account_email' ];
if ( $transfer_to_account || $create_account_and_transfer ) {
if ( !$this->transfer_icl_account( $create_account_and_transfer ) ) {
return;
$iclsettings[ 'site_id' ] = $this->settings[ 'site_id' ];
$iclsettings[ 'access_key' ] = $this->settings[ 'access_key' ];
} elseif ( isset( $_POST[ 'icl_initial_languagenonce' ] ) && $_POST[ 'icl_initial_languagenonce' ] == wp_create_nonce( 'icl_initial_language' ) ) {
$this->prepopulate_translations( $_POST[ 'icl_initial_language_code' ] );
$wpdb->update( $wpdb->prefix . 'icl_languages', array( 'active' => '1' ), array( 'code' => $_POST[ 'icl_initial_language_code' ] ) );
$blog_default_cat = get_option( 'default_category' );
$blog_default_cat_tax_id = $wpdb->get_var( "SELECT term_taxonomy_id FROM {$wpdb->term_taxonomy} WHERE term_id='{$blog_default_cat}' AND taxonomy='category'" );
if ( isset( $_POST[ 'save_one_language' ] ) ) {
$this->settings[ 'setup_wizard_step' ] = 0;
$this->settings[ 'setup_complete' ] = 1;
} else {
$this->settings[ 'setup_wizard_step' ] = 2;
$this->settings[ 'default_categories' ] = array( $_POST[ 'icl_initial_language_code' ] => $blog_default_cat_tax_id );
$this->settings[ 'existing_content_language_verified' ] = 1;
$this->settings[ 'default_language' ] = $_POST[ 'icl_initial_language_code' ];
$this->settings[ 'admin_default_language' ] = $this->admin_language = $_POST[ 'icl_initial_language_code' ];
// set the locale in the icl_locale_map (if it's not set)
$q = "SELECT code FROM {$wpdb->prefix}icl_locale_map WHERE code=%s";
$q_prepared = $wpdb->prepare($q, $_POST['icl_initial_language_code']);
if ( !$wpdb->get_var( $q_prepared ) ) {
$q = "SELECT default_locale FROM {$wpdb->prefix}icl_languages WHERE code=%s";
$default_locale = $wpdb->get_var( $q_prepared );
$wpdb->insert( $wpdb->prefix . 'icl_locale_map', array( 'code' => $_POST[ 'icl_initial_language_code' ], 'locale' => $default_locale ) );
global $sitepress_settings;
$this->get_active_languages( true ); //refresh active languages list
do_action( 'icl_initial_language_set' );
} elseif ( isset( $_POST[ 'icl_language_pairs_formnounce' ] ) && $_POST[ 'icl_language_pairs_formnounce' ] == wp_create_nonce( 'icl_language_pairs_form' ) ) {
$this->save_language_pairs();
$this->settings[ 'content_translation_languages_setup' ] = 1;
// Move onto the site description page
$this->settings[ 'website_kind' ] = 2;
$this->settings[ 'interview_translators' ] = 1;
} elseif ( isset( $_POST[ 'icl_site_description_wizardnounce' ] ) && $_POST[ 'icl_site_description_wizardnounce' ] == wp_create_nonce( 'icl_site_description_wizard' ) ) {
// back button.
$this->settings[ 'content_translation_languages_setup' ] = 0;
$this->settings[ 'content_translation_setup_wizard_step' ] = 1;
} elseif ( isset( $_POST[ 'icl_content_trans_setup_next_2' ] ) || isset( $_POST[ 'icl_content_trans_setup_next_2_enter' ] ) ) {
// next button.
$description = $_POST[ 'icl_description' ];
if ( $description == "" ) {
$_POST[ 'icl_form_errors' ] = __( 'Please provide a short description of the website so that translators know what background is required from them.', 'sitepress' );
} else {
$this->settings[ 'icl_site_description' ] = $description;
$this->settings[ 'content_translation_setup_wizard_step' ] = 3;
function prepopulate_translations( $lang )
global $wpdb;
if ( !empty( $this->settings[ 'existing_content_language_verified' ] ) ) {
return;
$this->icl_translations_cache->clear();
// case of icl_sitepress_settings accidentally lost
// if there's at least one translation do not initialize the languages for elements
$one_translation = $wpdb->get_var( $wpdb->prepare( "SELECT translation_id FROM {$wpdb->prefix}icl_translations WHERE language_code<>%s", $lang ) );
if ( $one_translation ) {
return;
$wpdb->query( "TRUNCATE TABLE {$wpdb->prefix}icl_translations" );
$wpdb->query( $wpdb->prepare("
INSERT INTO {$wpdb->prefix}icl_translations(element_type, element_id, trid, language_code, source_language_code)
SELECT CONCAT('post_',post_type), ID, ID, %s, NULL FROM {$wpdb->posts} WHERE post_status IN ('draft', 'publish','schedule','future','private', 'pending')
", $lang) );
$maxtrid = 1 + $wpdb->get_var( "SELECT MAX(trid) FROM {$wpdb->prefix}icl_translations" );
global $wp_taxonomies;
$taxonomies = array_keys( (array)$wp_taxonomies );
foreach ( $taxonomies as $tax ) {
SELECT 'tax_" . $tax . "', term_taxonomy_id, {$maxtrid}+term_taxonomy_id, %s, NULL FROM {$wpdb->term_taxonomy} WHERE taxonomy = %s
", $lang, $tax) );
$wpdb->query( $wpdb->prepare( "
SELECT 'comment', comment_ID, {$maxtrid}+comment_ID, %s, NULL FROM {$wpdb->comments}
", $lang) );
function post_edit_language_options()
global $post, $iclTranslationManagement, $post_new_file, $post_type_object;
if(!isset($post) || !$this->settings['setup_complete']) return;
if ( !function_exists( 'post_type_supports' ) || post_type_supports( $post->post_type, 'editor' ) ) {
add_action( 'icl_post_languages_options_after', array( $this, 'copy_from_original' ) );
if ( current_user_can( 'manage_options' ) ) {
add_meta_box( 'icl_div_config', __( 'Multilingual Content Setup', 'sitepress' ), array( $this, 'meta_box_config' ), $post->post_type, 'normal', 'low' );
if ( isset( $_POST[ 'icl_action' ] ) && $_POST[ 'icl_action' ] == 'icl_mcs_inline' ) {
if ( !in_array( $_POST[ 'custom_post' ], array( 'post', 'page' ) ) ) {
$iclsettings[ 'custom_posts_sync_option' ][ $_POST[ 'custom_post' ] ] = @intval( $_POST[ 'translate' ] );
if ( @intval( $_POST[ 'translate' ] ) ) {
$this->verify_post_translations( $_POST[ 'custom_post' ] );
if ( !empty( $_POST[ 'custom_taxs_off' ] ) ) {
foreach ( $_POST[ 'custom_taxs_off' ] as $off ) {
$iclsettings[ 'taxonomies_sync_option' ][ $off ] = 0;
if ( !empty( $_POST[ 'custom_taxs_on' ] ) ) {
foreach ( $_POST[ 'custom_taxs_on' ] as $on ) {
$iclsettings[ 'taxonomies_sync_option' ][ $on ] = 1;
$this->verify_taxonomy_translations( $on );
if ( !empty( $_POST[ 'cfnames' ] ) ) {
foreach ( $_POST[ 'cfnames' ] as $k => $v ) {
$custom_field_name = base64_decode( $v );
$iclTranslationManagement->settings[ 'custom_fields_translation' ][ $custom_field_name ] = @intval( $_POST[ 'cfvals' ][ $k ] );
$iclTranslationManagement->save_settings();
// sync the custom fields for the current post
if ( 1 == @intval( $_POST[ 'cfvals' ][ $k ] ) ) {
$trid = $this->get_element_trid( $_POST[ 'post_id' ], 'post_' . $_POST[ 'custom_post' ] );
$translations = $this->get_element_translations( $trid, 'post_' . $_POST[ 'custom_post' ] );
// determine original post id
$original_post_id = false;
if ( $t->original ) {
$original_post_id = $t->element_id;
break;
// get a list of $custom_field_name values that the original document has
$custom_fields_copy = get_post_meta( $original_post_id, $custom_field_name );
continue;
// if none, then attempt to delete any that the tranlations would have
if ( empty( $custom_fields_copy ) ) {
delete_post_meta( $t->element_id, $custom_field_name );
} else {
// get a list of $custom_field_name values that the translated document has
$translation_cfs = get_post_meta( $t->element_id, $custom_field_name );
// see what elements have been deleted in the original document
$deleted_fields = $translation_cfs;
foreach ( $custom_fields_copy as $cfc ) {
$tc_key = array_search( $cfc, $translation_cfs );
if ( $tc_key !== false ) {
unset( $deleted_fields[ $tc_key ] );
if ( !empty( $deleted_fields ) ) {
foreach ( $deleted_fields as $meta_value ) {
delete_post_meta( $t->element_id, $custom_field_name, $meta_value );
// update each custom field in the translated document
foreach ( $custom_fields_copy as $meta_value ) {
if ( !in_array( $meta_value, $translation_cfs ) ) {
// if it doesn't exist, add
add_post_meta( $t->element_id, $custom_field_name, $meta_value );
if ( !empty( $iclsettings ) ) {
$post_types = array_keys( $this->get_translatable_documents() );
if ( in_array( $post->post_type, $post_types ) ) {
add_meta_box( 'icl_div', __( 'Language', 'sitepress' ), array( $this, 'meta_box' ), $post->post_type, 'side', 'high' );
//Fix the "Add new" button adding the language argument, so to create new content in the same language
if(isset($post_new_file) && isset($post_type_object) && $this->is_translated_post_type($post_type_object->name)) {
$post_language = $this->get_language_for_element($post->ID, 'post_' . $post_type_object->name);
$post_new_file = add_query_arg(array('lang' => $post_language), $post_new_file);
* @param int $el_id
* @param string $el_type
* @param int $trid
* @param string $language_code
* @param null|string $src_language_code
* @param bool $check_duplicates
* @return bool|int|null|string
function set_element_language_details( $el_id, $el_type = 'post_post', $trid, $language_code, $src_language_code = null, $check_duplicates = true )
global $wpdb;
// Do not set language for the front page, if defined
$is_root_page = isset( $this->settings[ 'urls' ][ 'root_page' ] ) && $this->settings[ 'urls' ][ 'root_page' ] != 0 && $this->settings[ 'urls' ][ 'root_page' ] == $el_id;
if ( $is_root_page ) {
$trid = $this->get_element_trid($el_id, $el_type);
if($trid) {
$this->delete_element_translation($trid, $el_type);
return false;
// special case for posts and taxonomies
// check if a different record exists for the same ID
// if it exists don't save the new element and get out
if ( $check_duplicates && $el_id ) {
$exp = explode( '_', $el_type );
$_type = $exp[ 0 ];
if ( in_array( $_type, array( 'post', 'tax' ) ) ) {
$_el_exists = $wpdb->get_var( "
WHERE element_id={$el_id} AND element_type <> '{$el_type}' AND element_type LIKE '{$_type}\\_%'" );
if ( $_el_exists ) {
trigger_error( 'Element ID already exists with a different type', E_USER_NOTICE );
return false;
if ( $trid ) { // it's a translation of an existing element
// check whether we have an orphan translation - the same trid and language but a different element id
$translation_id = $wpdb->get_var( "
WHERE trid = '{$trid}'
AND language_code = '{$language_code}'
AND element_id <> '{$el_id}'
AND source_language_code IS NOT NULL
if ( $translation_id ) {
$wpdb->query( $wpdb->prepare( "DELETE FROM {$wpdb->prefix}icl_translations WHERE translation_id=%d", $translation_id ) );
if ( !is_null( $el_id ) && $translation_id = $wpdb->get_var( "SELECT translation_id FROM {$wpdb->prefix}icl_translations
WHERE element_type='{$el_type}' AND element_id='{$el_id}' AND trid='{$trid}' AND element_id IS NOT NULL" )
//case of language change
$wpdb->update( $wpdb->prefix . 'icl_translations', array( 'language_code' => $language_code ), array( 'translation_id' => $translation_id ) );
} elseif ( !is_null( $el_id ) && $translation_id = $wpdb->get_var( "SELECT translation_id FROM {$wpdb->prefix}icl_translations
WHERE element_type='{$el_type}' AND element_id='{$el_id}' AND element_id IS NOT NULL " )
//case of changing the "translation of"
if ( empty( $src_language_code ) ) {
$src_language_code = $wpdb->get_var( "SELECT language_code FROM {$wpdb->prefix}icl_translations WHERE trid={$trid} AND source_language_code IS NULL" );
$wpdb->update( $wpdb->prefix . 'icl_translations', array( 'trid' => $trid, 'language_code' => $language_code, 'source_language_code' => $src_language_code ), array( 'element_type' => $el_type, 'element_id' => $el_id ) );
} elseif ( $translation_id = $wpdb->get_var( $wpdb->prepare( "
SELECT translation_id FROM {$wpdb->prefix}icl_translations WHERE trid=%d AND language_code='%s' AND element_id IS NULL", $trid, $language_code ) )
$wpdb->update( $wpdb->prefix . 'icl_translations', array( 'element_id' => $el_id ), array( 'translation_id' => $translation_id ) );
} else {
//get source
// case of adding a new language
$new = array(
'trid' => $trid, 'element_type' => $el_type, 'language_code' => $language_code, 'source_language_code' => $src_language_code
if ( $el_id ) {
$new[ 'element_id' ] = $el_id;
$wpdb->insert( $wpdb->prefix . 'icl_translations', $new );
$translation_id = $wpdb->insert_id;
} else { // it's a new element or we are removing it from a trid
if ( $translation_id = $wpdb->get_var( "
FROM {$wpdb->prefix}icl_translations WHERE element_type='{$el_type}' AND element_id='{$el_id}' AND element_id IS NOT NULL" )
$trid = 1 + $wpdb->get_var( "SELECT MAX(trid) FROM {$wpdb->prefix}icl_translations" );
$new = array(
if ( $el_id ) {
if ( $translation_id && substr( $el_type, 0, 4 ) === 'tax_' ) {
$taxonomy = substr( $el_type, 4 );
do_action( 'created_term_translation', $taxonomy, $el_id, $language_code );
return $translation_id;
function delete_element_translation( $trid, $el_type, $language_code = false )
global $wpdb;
$trid = intval( $trid );
$el_type = esc_sql( $el_type );
$where = '';
$delete_args = array($trid, $el_type);
if ( $language_code ) {
$where .= " AND language_code=%s";
$delete_args[] = $language_code;
$delete_sql = "DELETE FROM {$wpdb->prefix}icl_translations WHERE trid=%d AND element_type=%s" . $where;
$delete_sql_prepared = $wpdb->prepare($delete_sql, $delete_args);
$wpdb->query( $delete_sql_prepared );
function get_element_language_details( $el_id, $el_type = 'post_post' )
$cache_key = $el_id . ':' . $el_type;
$cache_group = 'element_language_details';
$cached_details = wp_cache_get($cache_key, $cache_group);
if($cached_details) return $cached_details;
global $wpdb;
static $pre_load_done = false;
if ( !$pre_load_done && !ICL_DISABLE_CACHE ) {
// search previous queries for a group of posts
foreach ( $this->queries as $query ) {
$pos = strstr( $query, 'post_id IN (' );
if ( $pos !== false ) {
$group = substr( $pos, 10 );
$group = substr( $group, 0, strpos( $group, ')' ) + 1 );
$query = "SELECT element_id, trid, language_code, source_language_code
WHERE element_id IN {$group} AND element_type=%s";
$query_prepared = $wpdb->prepare($query, $el_type );
$ret = $wpdb->get_results( $query_prepared );
foreach ( $ret as $details ) {
if ( isset( $this->icl_translations_cache ) ) {
$this->icl_translations_cache->set( $details->element_id . $el_type, $details );
// get the taxonomy for the posts for later use
// categories first
$query = "SELECT DISTINCT(tr.term_taxonomy_id), tt.term_id, tt.taxonomy, icl.trid, icl.language_code, icl.source_language_code
FROM {$wpdb->prefix}term_relationships as tr
LEFT JOIN {$wpdb->prefix}term_taxonomy AS tt
ON tr.term_taxonomy_id = tt.term_taxonomy_id
LEFT JOIN {$wpdb->prefix}icl_translations as icl ON tr.term_taxonomy_id = icl.element_id
WHERE tr.object_id IN {$group}
AND (icl.element_type='tax_category' and tt.taxonomy='category')
$query .= "UNION
$query .= "SELECT DISTINCT(tr.term_taxonomy_id), tt.term_id, tt.taxonomy, icl.trid, icl.language_code, icl.source_language_code
AND (icl.element_type='tax_post_tag' and tt.taxonomy='post_tag')";
$custom_taxonomies = array_diff( array_keys( $wp_taxonomies ), array( 'post_tag', 'category', 'link_category' ) );
if ( !empty( $custom_taxonomies ) ) {
foreach ( $custom_taxonomies as $tax ) {
$query .= " UNION
AND (icl.element_type='tax_{$tax}' and tt.taxonomy='{$tax}')";
$ret = $wpdb->get_results( $query );
// save language details
$lang_details = new stdClass();
$lang_details->trid = $details->trid;
$lang_details->language_code = $details->language_code;
$lang_details->source_language_code = $details->source_language_code;
$this->icl_translations_cache->set( $details->term_taxonomy_id . 'tax_' . $details->taxonomy, $lang_details );
// save the term taxonomy
$this->icl_term_taxonomy_cache->set( 'category_' . $details->term_id, $details->term_taxonomy_id );
break;
$pre_load_done = true;
if ( isset( $this->icl_translations_cache ) && $this->icl_translations_cache->has_key( $el_id . $el_type ) ) {
return $this->icl_translations_cache->get( $el_id . $el_type );
$details_prepared_sql = $wpdb->prepare( "
SELECT trid, language_code, source_language_code
WHERE element_id=%d AND element_type=%s", array( $el_id, $el_type ) );
$details = $wpdb->get_row( $details_prepared_sql );
$this->icl_translations_cache->set( $el_id . $el_type, $details );
wp_cache_add($cache_key, $details, $cache_group);
return $details;
//if set option "When deleting a taxonomy (category, tag or custom), delete translations as well"
//when editing post and deleting tag or category or custom taxonomy in original language then delete this taxonomy in other languages
function deleted_term_relationships( $object_id, $delete_terms )
global $wpdb;
if ( $this->settings[ 'sync_post_taxonomies' ] ) {
$post = get_post( $object_id );
$trid = $this->get_element_trid( $object_id, 'post_' . $post->post_type );
if ( $trid ) {
$translations = $this->get_element_translations( $trid, 'post_' . $post->post_type );
foreach ( $translations as $translation ) {
if ( $translation->original == 1 && $translation->element_id == $object_id ) {
$taxonomies = get_object_taxonomies( $post->post_type );
foreach ( $taxonomies as $taxonomy ) {
foreach ( $delete_terms as $delete_term ) {
$trid = $this->get_element_trid( $delete_term, 'tax_' . $taxonomy );
if ( $trid ) {
$tags = $this->get_element_translations( $trid, 'tax_' . $taxonomy );
foreach ( $tags as $tag ) {
if ( !$tag->original && isset( $translations[ $tag->language_code ] ) ) {
$translated_post = $translations[ $tag->language_code ];
$wpdb->query( $wpdb->prepare( "DELETE FROM $wpdb->term_relationships WHERE object_id = %d AND term_taxonomy_id = $tag->element_id", $translated_post->element_id ) );
function save_post_actions( $pidd, $post )
global $wpdb;
wp_defer_term_counting( true );
list( $post_type, $post_status ) = $wpdb->get_row( "SELECT post_type, post_status FROM {$wpdb->posts} WHERE ID = " . $pidd, ARRAY_N );
// exceptions
if ( !$this->is_translated_post_type( $post_type ) || (isset( $post) && $post->post_status == "auto-draft" ) || isset( $_POST[ 'autosave' ] ) || isset( $_POST[ 'skip_sitepress_actions' ] ) || ( isset( $_POST[ 'post_ID' ] ) && $_POST[ 'post_ID' ] != $pidd ) || ( isset( $_POST[ 'post_type' ] ) && $_POST[ 'post_type' ] == 'revision' ) || $post_type == 'revision' || get_post_meta( $pidd, '_wp_trash_meta_status', true ) || ( isset( $_GET[ 'action' ] ) && $_GET[ 'action' ] == 'untrash' )) {
wp_defer_term_counting( false );
return;
if(!isset($post) && $pidd) {
$post = get_post($pidd);
// exception for auto-drafts - setting the right language
// allow post arguments to be passed via wp_insert_post directly and not be expected on $_POST exclusively
$post_vars = (array)$_POST;
foreach ( (array)$post as $k => $v ) {
$post_vars[ $k ] = $v;
if ( !isset( $post_vars[ 'post_type' ] ) ) {
$post_vars[ 'post_type' ] = $post_type;
$element_type = 'post_' . $post_type;
$language_code = false;
if ( isset( $post_vars[ 'action' ] ) && $post_vars[ 'action' ] == 'post-quickpress-publish' ) {
$post_id = $pidd;
$language_code = $default_language;
} elseif ( isset( $_GET[ 'bulk_edit' ] ) ) {
$post_id = $pidd;
} else {
$post_id = isset( $post_vars[ 'post_ID' ] ) ? $post_vars[ 'post_ID' ] : $pidd; //latter case for XML-RPC publishing
if ( isset( $post_vars[ 'icl_post_language' ] ) ) {
$language_code = $post_vars[ 'icl_post_language' ];
} elseif ( isset( $_GET[ 'lang' ] ) ) {
$language_code = $_GET[ 'lang' ];
} elseif ( $_ldet = $this->get_element_language_details( $post_id, $element_type ) ) {
$language_code = $_ldet->language_code;
} elseif(isset($this->this_lang)) {
$language_code = $this->this_lang;
} else {
$language_code = $default_language; //latter case for XML-RPC publishing
if ( isset( $post_vars[ 'action' ] ) && $post_vars[ 'action' ] == 'inline-save' || isset( $_GET[ 'bulk_edit' ] ) || isset( $_GET[ 'doing_wp_cron' ] ) || ( isset( $_GET[ 'action' ] ) && $_GET[ 'action' ] == 'untrash' ) ) {
$res = $this->get_element_language_details($post_id, 'post_' . $post->post_type);
if(!isset($res) || !$res) return;
$language_code = $res->language_code;
$trid = $res->trid;
} else {
if ( isset( $post_vars[ 'icl_trid' ] ) ) {
$trid = @intval( $post_vars[ 'icl_trid' ] );
} elseif ( isset( $_GET[ 'trid' ] ) ) {
$trid = @intval( $_GET[ 'trid' ] );
} else {
$trid = $this->get_element_trid( $post_id, 'post_' . $post->post_type );
// see if we have a "translation of" setting.
if ( isset( $post_vars[ 'icl_translation_of' ] ) ) {
if ( is_numeric( $post_vars[ 'icl_translation_of' ] ) ) {
$translation_of_data_prepared = $wpdb->prepare( "SELECT trid, language_code FROM {$wpdb->prefix}icl_translations WHERE element_id=%d AND element_type=%s", $post_vars[ 'icl_translation_of' ], 'post_' . $post->post_type );
list($trid, $source_language) = $wpdb->get_row( $translation_of_data_prepared, 'ARRAY_N' );
} else {
if ( empty( $post_vars[ 'icl_trid' ] ) ) {
$trid = null;
if ( isset( $_POST[ 'action' ] ) && $_POST[ 'action' ] == 'inline-save' ) {
} else if ( isset( $post_vars[ 'icl_translation_of' ] ) && $post_vars[ 'icl_translation_of' ] == 'none' ) {
$trid = null;
if (!$trid) {
$trid_from_referrer = $this->get_trid_from_referer();
if ($trid_from_referrer) {
$trid = $trid_from_referrer;
if ( ! $this->is_active_language( $language_code ) ) {
// set trid if front-end translation creating
$trid = apply_filters( 'wpml_save_post_trid_value', $trid, $post_status );
// set post language if front-end translation creating
$language_code = apply_filters( 'wpml_save_post_lang', $language_code );
// after getting the right trid set the source language from it by referring to the root translation
// of this trid, in case no proper source language is set already
if ( ! isset( $source_language ) || ! $source_language || $source_language == $language_code ) {
//if we are in the editor we can get the source language from the http-referer of the ajax request
$source_language = self::get_source_language_from_referer();
if ( ! $source_language ) {
//if getting the source language from the referer fails too, we get that of the first element of the trid
$source_language = self::get_source_language_by_trid( $trid );
/* Before setting the language of the post to be saved, check if a translation in this language already exists
* This check is necessary, so that synchronization actions like thrashing or un-trashing of posts, do not lead to
* database corruption, due to erroneously changing a posts language into a state,
* where it collides with an existing translation. While the UI prevents this sort of action for the most part,
* this is not necessarily the case for other plugins like TM.
* The logic here first of all checks if an existing translation id is present in the desired language_code.
* If so but this translation is actually not the currently to be saved post,
* then this post will be saved to its current language. If the translation already exists,
* the existing translation id will be used. In all other cases a new entry in icl_translations will be created.
$existing_translations = $this->get_element_translations( $trid, $element_type );
if ( $existing_translations && isset( $existing_translations[ $language_code ] ) ) {
$current_language_details = $this->get_element_language_details( $post_id, $element_type );
$existing_translation = $existing_translations[ $language_code ];
if ( $current_language_details
&& isset( $current_language_details->language_code )
&& $existing_translation
&& isset( $existing_translation->element_id )
&& isset( $current_language_details->element_id )
&& $existing_translation->element_id != $current_language_details->element_id
$translation_id = $existing_translations[ $current_language_details->language_code ]->translation_id;
$language_code = $current_language_details->language_code;
} else {
$translation_id = $existing_translations[ $existing_translation->language_code ]->translation_id;
} else {
$translation_id = $this->set_element_language_details( $post_id, $element_type, $trid, $language_code, $source_language );
//get trid of $translation_id
$translated_id_trid = $wpdb->get_var( $wpdb->prepare( "SELECT trid FROM {$wpdb->prefix}icl_translations WHERE translation_id=%d", array( $translation_id) ) );
//get all translations
$translated_element_id = $wpdb->get_col( $wpdb->prepare( "SELECT element_id FROM {$wpdb->prefix}icl_translations WHERE trid=%d", $translated_id_trid ) );
if ( !in_array( $post_type, array( 'post', 'page' ) ) && !$this->is_translated_post_type( $post_type ) ) {
return;
// synchronize the page order for translations
if ( $trid && $this->settings[ 'sync_page_ordering' ] && $translated_element_id && is_array( $translated_element_id ) ) {
$menu_order = esc_sql( $post_vars[ 'menu_order' ] );
// Only use non-null element ids for the menu ordering.
$non_null_eids = array_filter( $translated_element_id );
$wpdb->query( "UPDATE {$wpdb->posts} SET menu_order={$menu_order} WHERE ID IN (" . join( ',', $non_null_eids ) . ")" );
// synchronize the page parent for translations
if ( $trid && $this->settings[ 'sync_page_parent' ] ) {
$original_id = $this->get_original_element_id($post_id, 'post_' . $post_vars[ 'post_type' ]);
if ($original_id == $post_id) {
$translations = $this->get_element_translations( $trid, 'post_' . $post_vars[ 'post_type' ] );
foreach ( $translations as $target_lang => $target_details ) {
if ( $target_lang != $language_code ) {
if ( $target_details->element_id ) {
$this->fix_translated_parent( $post_id, $target_details->element_id, $target_lang);
// synchronize the page template
if ( isset( $post_vars[ 'page_template' ] ) && $trid && $post_vars[ 'post_type' ] == 'page' && $this->settings[ 'sync_page_template' ] ) {
if ( $translated_element_id && is_array($translated_element_id) ) {
foreach ( $translated_element_id as $tp ) {
if ( $tp != $post_id ) {
update_post_meta( $tp, '_wp_page_template', $post_vars[ 'page_template' ] );
// synchronize comment and ping status
if ( $trid && ( $this->settings[ 'sync_ping_status' ] || $this->settings[ 'sync_comment_status' ] ) ) {
$arr = array();
if ( $this->settings[ 'sync_comment_status' ] ) {
$arr[ 'comment_status' ] = $post_vars[ 'comment_status' ];
if ( $this->settings[ 'sync_ping_status' ] ) {
$arr[ 'ping_status' ] = $post_vars[ 'ping_status' ];
if ( !empty( $arr ) && $translated_element_id && is_array($translated_element_id) ) {
$wpdb->update( $wpdb->posts, $arr, array( 'ID' => $tp ) );
// copy custom fields from original
if ( !empty( $translations ) ) {
break;
// this runs only for translated documents
if ( $post_id != $original_post_id ) {
$this->copy_custom_fields( $original_post_id, $post_id );
} else {
if ( $original_post_id != $t->element_id ) {
$this->copy_custom_fields( $original_post_id, $t->element_id );
//sync posts stickiness
if ( isset( $post_vars[ 'post_type' ] ) && $post_vars[ 'post_type' ] == 'post' && isset( $post_vars[ 'action' ] ) && $post_vars[ 'action' ] != 'post-quickpress-publish' && $this->settings[ 'sync_sticky_flag' ] ) { //not for quick press
// get ids of the translations
if ( $trid ) {
$translations = $wpdb->get_col( $wpdb->prepare( "SELECT element_id FROM {$wpdb->prefix}icl_translations WHERE trid=%d", $trid ) );
} else {
$translations = array();
if ( isset( $post_vars[ 'sticky' ] ) && $post_vars[ 'sticky' ] == 'sticky' ) {
$sticky_posts = array_unique( array_merge( $sticky_posts, $translations ) );
} else {
//makes sure translations are not set to sticky if this posts switched from sticky to not-sticky
$sticky_posts = array_diff( $sticky_posts, $translations );
update_option( 'sticky_posts', $sticky_posts );
//sync private flag
if ( $this->settings[ 'sync_private_flag' ] ) {
if ( $post_status == 'private' && ( empty( $post_vars[ 'original_post_status' ] ) || $post_vars[ 'original_post_status' ] != 'private' ) ) {
$wpdb->update( $wpdb->posts, array( 'post_status' => 'private' ), array( 'ID' => $tp ) );
} elseif ( $post_status != 'private' && isset( $post_vars[ 'original_post_status' ] ) && $post_vars[ 'original_post_status' ] == 'private' ) {
$wpdb->update( $wpdb->posts, array( 'post_status' => $post_status ), array( 'ID' => $tp ) );
//sync post format
if ( $this->settings[ 'sync_post_format' ] && function_exists( 'set_post_format' ) ) {
$format = get_post_format( $post_id );
set_post_format( $tp, $format );
// sync post dates
if ( !empty( $this->settings[ 'sync_post_date' ] ) ) {
if ( $language_code == $default_language ) {
$post_date = $wpdb->get_var( $wpdb->prepare( "SELECT post_date FROM {$wpdb->posts} WHERE ID=%d", $post_id ) );
$wpdb->update( $wpdb->posts, array( 'post_date' => $post_date, 'post_date_gmt' => get_gmt_from_date( $post_date ) ), array( 'ID' => $tp ) );
} else {
if ( !is_null( $trid ) ) {
$original_id = $wpdb->get_var( $wpdb->prepare( "SELECT element_id FROM {$wpdb->prefix}icl_translations WHERE trid=%d AND language_code=%s", $trid, $source_lang ) );
if ( ! $original_id ) {
global $post;
if ( isset ( $post->ID ) ) {
$original_id = $post->ID;
if ( isset ( $original_id ) ) {
$post_date = $wpdb->get_var( $wpdb->prepare( "SELECT post_date FROM {$wpdb->posts} WHERE ID=%d", $original_id ) );
$wpdb->update( $wpdb->posts, array( 'post_date' => $post_date, 'post_date_gmt' => get_gmt_from_date( $post_date ) ), array( 'ID' => $post_id ) );
if ( isset( $post_vars[ 'icl_tn_note' ] ) ) {
update_post_meta( $post_id, '_icl_translator_note', $post_vars[ 'icl_tn_note' ] );
//fix guid
if ( $this->settings[ 'language_negotiation_type' ] == 2 && $this->get_current_language() != $default_language ) {
$guid = $this->convert_url( get_post_field( 'guid', $post_id ) );
$wpdb->update( $wpdb->posts, array( 'guid' => $guid ), array( 'id' => $post_id ) );
require_once ICL_PLUGIN_PATH . '/inc/cache.php';
icl_cache_clear( $post_vars[ 'post_type' ] . 's_per_language', true );
function get_trid_from_referer() {
if (isset($_SERVER['HTTP_REFERER'])) {
$query = parse_url($_SERVER['HTTP_REFERER'], PHP_URL_QUERY);
parse_str($query);
if (isset($trid)) {
return $trid;
return false;
static function get_source_language_from_referer() {
if ( isset( $_SERVER[ 'HTTP_REFERER' ] ) ) {
$query = parse_url( $_SERVER[ 'HTTP_REFERER' ], PHP_URL_QUERY );
parse_str( $query );
if ( isset( $source_lang ) ) {
return $source_lang;
return false;
* If post has translations and is the original, returns false
* @param $post WP_Post
* @return bool
function can_post_be_deleted( $post )
global $sitepress;
$sitepress_settings = $sitepress->get_settings();
if ( $sitepress_settings[ 'sync_delete' ] != 1 ) {
$trid = $sitepress->get_element_trid( $post->ID, 'post_' . $post->post_type );
if ( $trid ) {
$translations = $sitepress->get_element_translations( $trid, 'post_' . $post->post_type );
$original_id = false;
$can_delete = true;
//TODO: check that the post exists too
if ( $translation->language_code != $sitepress->get_default_language() ) {
$can_delete = false;
} else {
$original_id = $translation->element_id;
if ( $post->ID == $original_id && !$can_delete ) {
return false;
} else {
return true;
return true;
function wp_unique_post_slug( $slug, $post_id, $post_status, $post_type, $post_parent ) {
global $wpdb;
$cache_key_array = array( $slug, $post_id, $post_status, $post_type, $post_parent );
$cache_key = md5( serialize( $cache_key_array ) );
$cache_group = 'wp_unique_post_slug';
$cache_found = false;
$result = wp_cache_get( $cache_key, $cache_group, false, $cache_found );
if ( $cache_found ) {
return $result;
if ( $this->is_translated_post_type( $post_type ) && $post_id ) {
$post_prepared = $wpdb->prepare( "SELECT ID, post_status, post_name, post_title FROM {$wpdb->posts} WHERE ID=%d", $post_id );
$post = $wpdb->get_row( $post_prepared );
if ( !in_array( $post->post_status, array( 'draft', 'pending', 'auto-draft' ) ) ) {
global $wp_rewrite;
$feeds = $wp_rewrite->feeds;
if ( !is_array( $feeds ) ) {
$feeds = array();
$post_language = $this->get_language_for_element( $post_id, 'post_' . $post_type );
if ( isset( $_POST[ 'new_slug' ] ) ) {
if ( $_POST[ 'new_slug' ] === '' ) {
$slug = sanitize_title( $_POST[ 'new_title' ], $post->ID );
} else {
$slug = sanitize_title( $_POST[ 'new_slug' ], $post->ID );
} elseif ( isset( $_POST[ 'action' ] ) && $_POST[ 'action' ] == 'inline-save' ) {
$slug = sanitize_title( $_POST[ 'post_name' ], $post->ID );
} else {
$slug = sanitize_title( $post->post_name ? $post->post_name : $post->post_title, $post->ID );
$hierarchical_post_types = get_post_types( array( 'hierarchical' => true ) );
if ( in_array( $post_type, $hierarchical_post_types ) ) {
// Page slugs must be unique within their own trees. Pages are in a separate
// namespace than posts so page slugs are allowed to overlap post slugs.
$post_name_check_sql = "SELECT p.post_name
FROM $wpdb->posts p
JOIN {$wpdb->prefix}icl_translations t ON p.ID = t.element_id AND t.element_type = %s
WHERE p.post_name = %s AND p.post_type IN ( '" . implode( "', '", esc_sql( $hierarchical_post_types ) ) . "' )
AND p.ID != %d AND p.post_parent = %d AND t.language_code = %s LIMIT 1";
$post_name_check = $wpdb->get_var( $wpdb->prepare( $post_name_check_sql, 'post_' . $post_type, $slug, $post_id, $post_parent, $post_language ) );
if ( $post_name_check || in_array( $slug, $feeds ) || preg_match( "@^($wp_rewrite->pagination_base)?\d+$@", $slug ) || apply_filters( 'wp_unique_post_slug_is_bad_hierarchical_slug', false, $slug, $post_type, $post_parent ) ) {
$suffix = 2;
do {
$alt_post_name = substr( $slug, 0, 200 - ( strlen( $suffix ) + 1 ) ) . "-$suffix";
$post_name_check = $wpdb->get_var( $wpdb->prepare( $post_name_check_sql, 'post_' . $post_type, $alt_post_name, $post_id, $post_parent, $post_language ) );
$suffix++;
} while ( $post_name_check );
$slug = $alt_post_name;
} else {
// Post slugs must be unique across all posts.
FROM $wpdb->posts p
WHERE p.post_name = %s AND p.post_type = %s AND p.ID != %d AND t.language_code = %s LIMIT 1";
$post_name_check_prepared = $wpdb->prepare( $post_name_check_sql, 'post_' . $post_type, $slug, $post_type, $post_id, $post_language );
$post_name_check = $wpdb->get_var( $post_name_check_prepared );
if ( $post_name_check || in_array( $slug, $feeds ) || apply_filters( 'wp_unique_post_slug_is_bad_flat_slug', false, $slug, $post_type ) ) {
$suffix = 2;
do {
$post_name_check = $wpdb->get_var( $wpdb->prepare( $post_name_check_sql, 'post_' . $post_type, $alt_post_name, $post_type, $post_id, $post_language ) );
$suffix++;
$wpdb->update( $wpdb->posts, array( 'post_name' => $slug ), array( 'ID' => $post_id ) );
wp_cache_set( $cache_key, $slug, $cache_group );
return $slug;
/** Fix parent of translation
* User changed parent for $orginal_id and we are setting proper parent for $translation_id in $language_code_translated language
* @param $original_id - id of post with changed parent
* @param $translated_id - translation of changed post
* @param $translation_language - language we are fixing
function fix_translated_parent( $original_id, $translated_id, $translation_language )
global $wpdb;
$icl_post_type = isset( $_POST[ 'post_type' ] ) ? 'post_' . $_POST[ 'post_type' ] : 'post_page';
// get parent of original page
$original_parent = $wpdb->get_var( $wpdb->prepare( "SELECT post_parent FROM {$wpdb->posts} WHERE ID = %d AND post_type = %s", array($original_id, 'page') ) );
if ( !is_null( $original_parent ) ) {
if ( $original_parent == 0){
$wpdb->query( $wpdb->prepare( "UPDATE {$wpdb->posts} SET post_parent=%d WHERE ID = %d", array( 0, $translated_id ) ) );
}else {
$trid = $this->get_element_trid( $original_parent, $icl_post_type );
if ( $trid ) {
//get parent translations
$translations_of_parent = $this->get_element_translations( $trid, $icl_post_type );
if ( isset( $translations_of_parent[ $translation_language ] ) ) {
$current_translated_parent = $wpdb->get_var( $wpdb->prepare( "SELECT post_parent FROM {$wpdb->posts} WHERE ID = %d", array($translated_id) ) );
if ( !is_null( $translations_of_parent[ $translation_language ]->element_id ) && $current_translated_parent != $translations_of_parent[ $translation_language ]->element_id ) {
$wpdb->query( $wpdb->prepare( "UPDATE {$wpdb->posts} SET post_parent=%d WHERE ID = %d", array( $translations_of_parent[$translation_language]->element_id, $translated_id ) ) );
/* Custom fields synchronization - START */
function _sync_custom_field( $post_id_from, $post_id_to, $meta_key )
global $wpdb;
$values_from_prepared = $wpdb->prepare( "SELECT meta_value FROM {$wpdb->postmeta} WHERE post_id=%d AND meta_key=%s", array($post_id_from, $meta_key) );
$values_to_prepared = $wpdb->prepare( "SELECT meta_value FROM {$wpdb->postmeta} WHERE post_id=%d AND meta_key=%s", array($post_id_to, $meta_key) );
$values_from = $wpdb->get_col( $values_from_prepared );
$values_to = $wpdb->get_col( $values_to_prepared );
// handle the case of 1 key - 1 value with updates in case of change
// if ( count( $values_from ) == 1 && count( $values_to ) == 1 ) {
// if ( $values_from[ 0 ] != $values_to[ 0 ] ) {
// $update_prepared = $wpdb->prepare( "UPDATE {$wpdb->postmeta} SET meta_value=%s WHERE post_id=%d AND meta_key=%s", array( $values_from[ 0 ], $post_id_to, $meta_key ) );
// $wpdb->query( $update_prepared );
// } else {
//removed
$removed = array_diff( $values_to, $values_from );
foreach ( $removed as $v ) {
$delete_prepared = $wpdb->prepare( "DELETE FROM {$wpdb->postmeta} WHERE post_id=%d AND meta_key=%s AND meta_value=%s", $post_id_to, $meta_key, $v );
$wpdb->query( $delete_prepared );
//added
$added = array_diff( $values_from, $values_to );
foreach ( $added as $v ) {
$insert_prepared = $wpdb->prepare( "INSERT INTO {$wpdb->postmeta}(post_id, meta_key, meta_value) VALUES(%d, %s, %s)", $post_id_to, $meta_key, $v );
$wpdb->query( $insert_prepared );
function copy_custom_fields( $post_id_from, $post_id_to )
$cf_copy = array();
if ( isset( $this->settings[ 'translation-management' ][ 'custom_fields_translation' ] ) ) {
foreach ( $this->settings[ 'translation-management' ][ 'custom_fields_translation' ] as $meta_key => $option ) {
if ( $option == 1 ) {
$cf_copy[ ] = $meta_key;
foreach ( $cf_copy as $meta_key ) {
$meta_from = get_post_meta($post_id_from, $meta_key) ;
$meta_to = get_post_meta($post_id_to, $meta_key) ;
if($meta_from || $meta_to) {
$this->_sync_custom_field( $post_id_from, $post_id_to, $meta_key );
function update_post_meta( $meta_id, $object_id, $meta_key, $_meta_value )
return;
global $wpdb, $iclTranslationManagement;
// only handle custom fields that need to be copied
$custom_fields_translation = isset($this->settings[ 'translation-management' ][ 'custom_fields_translation' ]) ? $this->settings[ 'translation-management' ][ 'custom_fields_translation' ] : false;
if (!$custom_fields_translation || !isset( $custom_fields_translation[ $meta_key ] ) || !in_array( $custom_fields_translation[ $meta_key ], array( 1, 2 ) ) ) {
return;
if ( $custom_fields_translation[ $meta_key ] == '2' ) {
if ( $trid ) {
$is_original = true;
break;
if ( isset( $is_original ) ) {
$md5 = $iclTranslationManagement->post_md5( $object_id );
if ( !$translation->original ) {
$emd5 = $wpdb->get_var( $wpdb->prepare( "SELECT md5 FROM {$wpdb->prefix}icl_translation_status WHERE translation_id = %d", $translation->translation_id ) );
if ( $md5 != $emd5 ) {
$translation_package = $iclTranslationManagement->create_translation_package( $object_id );
$translation_data = array(
'translation_id' => $translation->translation_id,
'needs_update' => 1,
'md5' => $md5,
'translation_package' => serialize( $translation_package )
list( $rid ) = $iclTranslationManagement->update_translation_status( $translation_data );
$translator_id_prepared = $wpdb->prepare( "SELECT translator_id FROM {$wpdb->prefix}icl_translation_status WHERE translation_id = %d", $translation->translation_id );
$translator_id = $wpdb->get_var( $translator_id_prepared );
$iclTranslationManagement->add_translation_job( $rid, $translator_id, $translation_package );
} else {
$translated_docs = $this->get_translatable_documents();
if ( !empty( $translated_docs[ $post->post_type ] ) ) {
$original_id = $this->get_original_element_id($object_id, 'post_' . $post->post_type, true, $all_statuses = true);
if ( $trid ) {
$translations = $this->get_element_translations( $trid, 'post_' . $post->post_type, true, true );
// CASE of updating the original document (source)
if ( isset( $original_id ) ) {
if ( $object_id == $original_id ) {
if ( $object_id != $t->element_id ) {
$this->_sync_custom_field( $object_id, $t->element_id, $meta_key, true );
} else { // CASE of updating the translated document (target) - don't let writing something else here
$_meta_value = get_post_meta($original_id, $meta_key);
$this->update_post_meta( $meta_id, $original_id, $meta_key, $_meta_value );
function delete_post_meta( $meta_id )
return;
if(!isset($this->settings[ 'translation-management' ][ 'custom_fields_translation' ])) return;
if ( !function_exists( 'get_post_meta_by_id' ) ) {
require_once ABSPATH . 'wp-admin/includes/post.php';
if ( is_array( $meta_id ) ) {
$meta_id = $meta_id[ 0 ];
$meta = get_post_meta_by_id( $meta_id );
if(!isset($this->settings[ 'translation-management' ][ 'custom_fields_translation' ][ $meta->meta_key ])) return;
$custom_fields_translation_meta = $this->settings[ 'translation-management' ][ 'custom_fields_translation' ][ $meta->meta_key ];
if ( $meta && in_array( $custom_fields_translation_meta, array( 1, 2 ) ) ) {
$post = get_post( $meta->post_id );
$trid = $this->get_element_trid( $meta->post_id, 'post_' . $post->post_type );
if ( $trid ) {
if ( $translations ) {
foreach ( $translations as $t ) {
$original_id = $t->element_id;
if ( $original_id == $meta->post_id ) {
if ( !$t->original ) {
$this->_sync_custom_field( $meta->post_id, $t->element_id, $meta->meta_key, $custom_fields_translation_meta==1 );
} else {
$this->_sync_custom_field( $original_id, $meta->post_id, $meta->meta_key, $custom_fields_translation_meta==1 );
/* Custom fields synchronization - END */
function before_delete_post_actions( $post_id )
global $wpdb;
if ( !isset( $post_id ) || !$post_id ) {
$post = get_post();
$post_id = $post->ID;
} else {
$post = get_post( $post_id );
if ( $post == null ) {
return;
$post_type = $post->post_type;
//we need to save information which for which children we have to update translations after parent post delete
if ( is_post_type_hierarchical( $post_type ) && $this->settings[ 'sync_page_parent' ] && !$this->settings[ 'sync_delete' ] ) {
//get children of deleted post
$children_ids = $wpdb->get_col( $wpdb->prepare("SELECT ID FROM {$wpdb->posts} WHERE post_parent=%d AND post_type=%s", array($post_id, $post_type) ) );
//cache value will be used in in deleted_post_actions
wp_cache_set('children_before_delete_post_actions_'.$post_id, $children_ids, 'icl_before_delete_post_actions');
function deleted_post_actions( $post_id )
global $wpdb;
$post = get_post();
} else {
return;
$post_type_exceptions = array('nav_menu_item');
if(in_array($post_type, $post_type_exceptions)) return;
icl_cache_clear( $post_type . 's_per_language', true );
$trid = $this->get_element_trid( $post_id, $element_type );
if ( $trid ) {
$language_details = $this->get_element_language_details( $post_id, $element_type );
if ( $language_details ) {
$is_original = ! $language_details->source_language_code;
$original_language = $language_details->language_code;
//delete translation for original language (icl_translations)
$this->delete_element_translation( $trid, $element_type, $language_details->language_code );
//select translations for all other languages (icl_translations)
$post_translations = $this->get_element_translations( $trid, $element_type, false, false, true );
if ( $post_translations ) {
//delete empty translations (icl_translations)
foreach ( $post_translations as $post_language => $post_translation ) {
if ( empty ( $post_translation->element_id ) ){
//delete element translation for given laguage
$this->delete_element_translation( $trid, $element_type, $post_language );
//remove translation from the list
unset( $post_translations[ $post_language ] );
//If we've just deleted the original and there are still translations, let's set the original to the first available translation
if ( $is_original && $post_translations ) {
$languages = $this->get_active_languages( true );
$languages = $this->order_languages( $languages );
$fallback_language = false;
$new_source_translation_id = false;
//Get first available languages (to keep their order)
foreach ( $languages as $language ) {
if ( $language[ 'code' ] != $original_language ) {
if ( isset( $post_translations[ $language[ 'code' ] ] ) ) {
$fallback_language = $language[ 'code' ];
$new_source_translation_id = $post_translations[ $fallback_language ]->element_id;
break;
foreach ( $post_translations as $post_translation ) {
$element_language_details = $this->get_element_language_details( $post_translation->element_id, $element_type );
if ( $post_translation->element_id == $new_source_translation_id ) {
$source_language = false;
} elseif ( $original_language == $element_language_details->source_language_code ) {
$source_language = $fallback_language;
} else {
$source_language = $element_language_details->source_language_code;
$update_data = array(
'language_code' => $element_language_details->language_code
if ( $source_language ) {
$update_data[ 'source_language_code' ] = $source_language;
} else {
$update_data[ 'source_language_code' ] = null;
$update_where = array(
'translation_id' => $post_translation->translation_id
$wpdb->update( $wpdb->prefix . 'icl_translations', $update_data, $update_where );
$_icl_lang_duplicate_of = get_post_meta( $post_translation->element_id, '_icl_lang_duplicate_of', true );
if ( $_icl_lang_duplicate_of ) {
if ( $element_language_details->language_code == $fallback_language ) {
delete_post_meta( $post_translation->element_id, '_icl_lang_duplicate_of' );
} else {
update_post_meta( $post_translation->element_id, '_icl_lang_duplicate_of', $new_source_translation_id );
// synchronize the page parent for translations only when we do not delete translations and only for hierarchical types
//get deleted post parent
$parent_trid = $this->get_element_trid( $post->post_parent, $element_type );
//get translations of deleted post parent
$parent_translations = $this->get_element_translations( $parent_trid, $element_type );
// get children of deleted post (stored in before_post_delete_actions)
$children_ids = wp_cache_get( 'children_before_delete_post_actions_' . $post_id, 'icl_before_delete_post_actions' );
if ( $children_ids ) {
//for each children of deleted post
foreach ( $children_ids as $child_id ) {
//get translations
$child_trid = $this->get_element_trid( $child_id, $element_type );
$child_translations = $this->get_element_translations( $child_trid, $element_type );
//for each translation of child
foreach ( $child_translations as $child_target_lang => $child_target_details ) {
//if parent translation exists and it is a translations (not child of deleted post)
if ( $child_target_details->element_id != $child_id ) {
if ( isset( $parent_translations[ $child_target_lang ]->element_id ) ) {
//set parent
$wpdb->update( $wpdb->posts, array( 'post_parent' => $parent_translations[ $child_target_lang ]->element_id ), array( 'ID' => $child_target_details->element_id ) );
} else {
$wpdb->update( $wpdb->posts, array( 'post_parent' => 0 ), array( 'ID' => $child_target_details->element_id ) );
// remove children of deleted post (stored in before_post_delete_actions)
wp_cache_delete( 'children_before_delete_post_actions_' . $post_id, 'icl_before_delete_post_actions' );
if ( !$this->settings[ 'sync_delete' ] ) {
return;
static $deleted_posts;
if ( isset( $deleted_posts[ $post_id ] ) ) {
return; // avoid infinite loop
if ( !isset( $_REQUEST['delete_all'] ) && !isset( $_REQUEST['delete_all2'] ) ) {
if ( ( empty( $deleted_posts ) || ( is_array( $deleted_posts ) && !isset( $deleted_posts[ $post_id ] ) ) ) ) {
$translations = $this->get_element_translations( $trid, $element_type );
if ( $t->element_id != $post_id ) {
$deleted_posts[ ] = $post_id;
$post_exists_sql = $wpdb->prepare( "SELECT ID FROM $wpdb->posts WHERE id = %d", $t->element_id );
$post_exists = $wpdb->get_col( $post_exists_sql );
if ( $post_exists ) {
wp_delete_post( $t->element_id );
function trash_post_actions( $post_id )
global $wpdb;
$post_type = $wpdb->get_var( "SELECT post_type FROM {$wpdb->posts} WHERE ID={$post_id}" );
// bulk deleting
// using this to not try to delete a post that's going to be deleted anyway
static $posts_to_delete_in_bulk;
if ( is_null( $posts_to_delete_in_bulk ) ) {
$posts_to_delete_in_bulk = isset( $_GET[ 'post' ] ) && is_array( $_GET[ 'post' ] ) ? $_GET[ 'post' ] : array();
if ( $this->settings[ 'sync_delete' ] ) {
static $trashed_posts = array();
if ( isset( $trashed_posts[ $post_id ] ) ) {
$trashed_posts[ $post_id ] = $post_id;
$trid = $this->get_element_trid( $post_id, 'post_' . $post_type );
$translations = $this->get_element_translations( $trid, 'post_' . $post_type );
if ( $t->element_id != $post_id && !in_array( $t->element_id, $posts_to_delete_in_bulk ) ) {
wp_trash_post( $t->element_id );
function untrashed_post_actions( $post_id )
global $wpdb;
/* The first line of these checks ensures, that we are actually restoring a trashed post.
* The second line ensures, that this post is not going to be restored anyways through a bulk
* action from the UI.
if ( isset( $t->element_id ) && $t->element_id != $post_id && get_post_status( $t->element_id ) == 'trash'
&& ! ( isset( $_REQUEST[ 'post' ] ) && is_array( $_REQUEST[ 'post' ] ) && in_array( $t->element_id, $_REQUEST[ 'post' ] ) )
remove_action( 'untrashed_post', array( $this, 'untrashed_post_actions' ) );
wp_untrash_post( $t->element_id );
add_action( 'untrashed_post', array( $this, 'untrashed_post_actions' ) );
* @param int $trid
* @param string $el_type Use comment, post, page, {custom post time name}, nav_menu, nav_menu_item, category, post_tag, etc. (prefixed with 'post_', 'tax_', or nothing for 'comment')
* @param bool $skip_empty
* @param bool $all_statuses
* @param bool $skip_cache
* @return array|bool|mixed
function get_element_translations( $trid, $el_type = 'post_post', $skip_empty = false, $all_statuses = false, $skip_cache = false )
$cache_key_args = array_filter( array( $trid, $el_type, $skip_empty, $all_statuses ) );
$cache_key = md5(json_encode( $cache_key_args ));
$cache_group = 'element_translations';
$temp_elements = $skip_cache ? false : wp_cache_get($cache_key, $cache_group);
if($temp_elements) return $temp_elements;
global $wpdb;
$sel_add = '';
$where_add = '';
if ( $trid ) {
if ( 0 === strpos( $el_type, 'post_' ) ) {
$sel_add = ', p.post_title, p.post_status';
$join_add = " LEFT JOIN {$wpdb->posts} p ON t.element_id=p.ID";
$groupby_add = "";
if ( ! is_admin() && empty( $all_statuses ) && $el_type != 'post_attachment' ) {
// the current user may not be the admin but may have read private post/page caps!
if ( current_user_can( 'read_private_pages' ) || current_user_can( 'read_private_posts' ) ) {
$where_add .= " AND (p.post_status = 'publish' OR p.post_status = 'private' OR p.post_status = 'pending')";
} else {
$where_add .= " AND (";
$where_add .= "p.post_status = 'publish' OR p.post_status = 'pending' ";
if ( $uid = $this->get_current_user()->ID ) {
$where_add .= " OR (post_status in ('draft', 'private', 'pending') AND post_author = {$uid})";
$where_add .= ") ";
} elseif ( preg_match( '#^tax_(.+)$#', $el_type ) ) {
$sel_add = ', tm.name, tm.term_id, COUNT(tr.object_id) AS instances';
$join_add = " LEFT JOIN {$wpdb->term_taxonomy} tt ON t.element_id=tt.term_taxonomy_id
LEFT JOIN {$wpdb->terms} tm ON tt.term_id = tm.term_id
LEFT JOIN {$wpdb->term_relationships} tr ON tr.term_taxonomy_id=tt.term_taxonomy_id
$groupby_add = "GROUP BY tm.term_id";
$where_add .= " AND t.trid='{$trid}'";
if ( !isset( $join_add ) ) {
$join_add = "";
if ( !isset( $groupby_add ) ) {
$groupby_add = "";
$query = "
SELECT t.translation_id, t.language_code, t.element_id, t.source_language_code, NULLIF(t.source_language_code, '') IS NULL AS original {$sel_add}
FROM {$wpdb->prefix}icl_translations t
{$join_add}
WHERE 1 {$where_add}
{$groupby_add}
foreach ( $ret as $t ) {
if ( ( preg_match( '#^tax_(.+)$#', $el_type ) ) && $t->instances == 0 && !_icl_tax_has_objects_recursive( $t->element_id ) && $skip_empty ) {
continue;
$cached_object_key = $t->element_id . '#' . $el_type . '#0#' . $t->language_code;
wp_cache_set( $cached_object_key, $cached_object_key, 'icl_object_id' );
$translations[ $t->language_code ] = $t;
if($translations) {
wp_cache_set($cache_key, $translations, $cache_group);
return $translations;
static function get_original_element_id($element_id, $element_type = 'post_post', $skip_empty = false, $all_statuses = false, $skip_cache = false) {
$cache_key_args = array_filter( array( $element_id, $element_type, $skip_empty, $all_statuses ) );
$cache_group = 'original_element';
global $sitepress;
$original_element_id = false;
$trid = $sitepress->get_element_trid($element_id, $element_type);
if($trid) {
$element_translations = $sitepress->get_element_translations($trid, $element_type,$skip_empty,$all_statuses,$skip_cache);
foreach($element_translations as $element_translation) {
if($element_translation->original) {
$original_element_id = $element_translation->element_id;
break;
if($original_element_id) {
wp_cache_set($cache_key, $original_element_id, $cache_group);
return $original_element_id;
* @param int $element_id Use term_taxonomy_id for taxonomies, post_id for posts
* @return bool|mixed|null|string
function get_element_trid( $element_id, $el_type = 'post_post' ) {
$cache_key = $element_id . ':' . $el_type;
$cache_group = 'element_trid';
$temp_trid = wp_cache_get($cache_key, $cache_group);
if($temp_trid) return $temp_trid;
global $wpdb;
$trid_prepared = $wpdb->prepare( "SELECT trid FROM {$wpdb->prefix}icl_translations WHERE element_id=%d AND element_type=%s", array( $element_id, $el_type ) );
$trid = $wpdb->get_var( $trid_prepared );
if($trid) {
wp_cache_add($cache_key, $trid, $cache_group);
return $trid;
* @param int $trid
* @return int|bool
static function get_original_element_id_by_trid( $trid ) {
global $wpdb;
$original_element_id_prepared = $wpdb->prepare( "SELECT element_id FROM {$wpdb->prefix}icl_translations WHERE trid=%d AND source_language_code IS NULL", $trid );
$element_id = $wpdb->get_var( $original_element_id_prepared );
return $element_id;
static function get_source_language_by_trid( $trid ) {
global $wpdb;
$source_language_prepared = $wpdb->prepare( "SELECT language_code FROM {$wpdb->prefix}icl_translations WHERE trid=%d AND source_language_code IS NULL", $trid );
$source_language = $wpdb->get_var( $source_language_prepared );
return $source_language;
* @return null|string
function get_language_for_element( $element_id, $el_type = 'post_post' ) {
global $wpdb;
$cache_key_array = array( $element_id, $el_type );
$cache_group = 'get_language_for_element';
return $result;
$language_for_element_prepared = $wpdb->prepare( "SELECT language_code FROM {$wpdb->prefix}icl_translations WHERE element_id=%d AND element_type=%s", array( $element_id, $el_type ) );
$result = $wpdb->get_var( $language_for_element_prepared );
if ( $result ) {
wp_cache_set( $cache_key, $result, $cache_group );
return $result;
* @param string $target_lang Target language code
* @param string $source_lang Source language code
* @return array
function get_elements_without_translations( $el_type, $target_lang, $source_lang )
global $wpdb;
// first get all the trids for the target languages
// These will be the trids that we don't want.
$sql = "SELECT
trid
FROM
WHERE
language_code = '{$target_lang}'
AND element_type = '{$el_type}'
$trids_for_target = $wpdb->get_col( $sql );
if ( sizeof( $trids_for_target ) > 0 ) {
$trids_for_target = join( ',', $trids_for_target );
$not_trids = 'AND trid NOT IN (' . $trids_for_target . ')';
} else {
$not_trids = '';
$join = $where = '';
// exclude trashed posts
$join .= " JOIN {$wpdb->posts} ON {$wpdb->posts}.ID = {$wpdb->prefix}icl_translations.element_id";
$where .= " AND {$wpdb->posts}.post_status <> 'trash' AND {$wpdb->posts}.post_status <> 'auto-draft'";
// Now get all the elements that are in the source language that
// are not already translated into the target language.
$sql = "SELECT
element_id
FROM
{$join}
WHERE
language_code = '{$source_lang}'
{$not_trids}
AND element_type= '{$el_type}'
{$where}
return $wpdb->get_col( $sql );
* @param string $selected_language
* @param string $default_language
* @param string $post_type
* @used_by SitePress:meta_box
* @return array
function get_posts_without_translations( $selected_language, $default_language, $post_type = 'post_post' )
global $wpdb;
$untranslated_ids = $this->get_elements_without_translations( $post_type, $selected_language, $default_language );
$untranslated = array();
foreach ( $untranslated_ids as $id ) {
$untranslated[ $id ] = $wpdb->get_var( "SELECT post_title FROM {$wpdb->prefix}posts WHERE ID = {$id}" );
return $untranslated;
static function get_orphan_translations($trid, $post_type = 'post', $source_language) {
global $sitepress, $wpdb;
$translations = $sitepress->get_element_translations($trid, 'post_' . $post_type);
if(count($translations) == 1) {
$sql = " SELECT trid, ";
$active_languages = $sitepress->get_active_languages();
$language_codes = array_keys($active_languages);
$sql_languages = array();
$sql_languages_having = array();
foreach($language_codes as $language_code) {
$sql_languages[] = "SUM(CASE language_code WHEN '" . esc_sql($language_code) . "' THEN 1 ELSE 0 END) AS
&quot; . esc_sql($language_code) . '
if($language_code==$source_language) {
$sql_languages_having[] = '
' . $language_code . '
= 0';
$sql .= implode(',', $sql_languages);
$sql .= " FROM {$wpdb->prefix}icl_translations
WHERE element_type = %s ";
$sql .= 'GROUP BY trid ';
$sql .= 'HAVING ' . implode(' AND ', $sql_languages_having);
$sql .= " ORDER BY trid;";
$sql_prepared = $wpdb->prepare($sql, array('post_' . $post_type));
$trid_results = $wpdb->get_results($sql_prepared, 'ARRAY_A');
$trid_list = array_column($trid_results, 'trid');
if($trid_list) {
$sql = "SELECT trid AS value, CONCAT('[', t.language_code, '] ', (CASE p.post_title WHEN '' THEN CONCAT(LEFT(p.post_content, 30), '...') ELSE p.post_title END)) AS label
FROM {$wpdb->posts} p
INNER JOIN {$wpdb->prefix}icl_translations t
WHERE t.element_type = %s
AND t.language_code <> %s
AND t.trid IN (" . implode(',', $trid_list) . ')';
$sql_prepared = $wpdb->prepare($sql, array('post_' . $post_type, $source_language));
$results = $wpdb->get_results($sql_prepared);
} else {
$results = array();
return $results;
return false;
* @param WP_Post $post
function meta_box( $post ) {
if($this->settings['setup_complete']) {
if ( in_array( $post->post_type, array_keys( $this->get_translatable_documents() ) ) ) {
include ICL_PLUGIN_PATH . '/menu/post-menu.php';
function icl_get_metabox_states()
global $icl_meta_box_globals, $wpdb;
$translation = false;
$source_id = null;
$translated_id = null;
if ( sizeof( $icl_meta_box_globals[ 'translations' ] ) > 0 ) {
if ( !isset( $icl_meta_box_globals[ 'translations' ][ $icl_meta_box_globals[ 'selected_language' ] ] ) ) {
// We are creating a new translation
$translation = true;
// find the original
foreach ( $icl_meta_box_globals[ 'translations' ] as $trans_data ) {
if ( $trans_data->original == '1' ) {
$source_id = $trans_data->element_id;
break;
} else {
$trans_data = $icl_meta_box_globals[ 'translations' ][ $icl_meta_box_globals[ 'selected_language' ] ];
// see if this is an original or a translation.
if ( $trans_data->original == '0' ) {
// double check that it's not the original
// This is because the source_language_code field in icl_translations is not always being set to null.
$source_language_code = $wpdb->get_var( "SELECT source_language_code FROM {$wpdb->prefix}icl_translations WHERE translation_id = $trans_data->translation_id" );
$translation = !( $source_language_code == "" || $source_language_code == null );
if ( $translation ) {
$source_id = $icl_meta_box_globals[ 'translations' ][ $source_language_code ]->element_id;
$translated_id = $trans_data->element_id;
} else {
} else {
return array( $translation, $source_id, $translated_id );
function meta_box_config( $post )
global $iclTranslationManagement;
global $wp_taxonomies, $wp_post_types, $sitepress_settings;
if ( ! $this->settings[ 'setup_complete' ] ) {
return false;
echo '<div class="icl_form_success" style="display:none">' . __( 'Settings saved', 'sitepress' ) . '</div>';
$cp_editable = false;
$checked = false;
if ( !in_array( $post->post_type, array( 'post', 'page' ) ) ) {
if ( !isset( $iclTranslationManagement->settings[ 'custom_types_readonly_config' ][ $post->post_type ] ) || $iclTranslationManagement->settings[ 'custom_types_readonly_config' ][ $post->post_type ] !== 0 ) {
$checked = ' checked="checked"';
$radio_disabled = isset( $iclTranslationManagement->settings[ 'custom_types_readonly_config' ][ $post->post_type ] ) ? 'disabled="disabled"' : '';
} else {
$checked = $radio_disabled = '';
if ( !$radio_disabled ) {
$cp_editable = true;
echo '<br style="line-height:8px;" /><label><input id="icl_make_translatable" type="checkbox" value="' . $post->post_type . '"' . $checked . $radio_disabled . '/> ' . sprintf( __( "Make '%s' translatable", 'sitepress' ), $wp_post_types[ $post->post_type ]->labels->name ) . '</label><br style="line-height:8px;" />';
} else {
echo '<input id="icl_make_translatable" type="checkbox" checked="checked" value="' . $post->post_type . '" style="display:none" />';
$checked = true;
echo '<br clear="all" /><span id="icl_mcs_details">';
if ( $checked ) {
//echo '<div style="width:49%;float:left;min-width:265px;margin-right:5px;margin-top:3px;">';
$custom_taxonomies = array_diff( get_object_taxonomies( $post->post_type ), array( 'post_tag', 'category', 'nav_menu', 'link_category', 'post_format' ) );
<table class="widefat">
<thead>
<tr>
<th colspan="2"><?php _e( 'Custom taxonomies', 'sitepress' ); ?></th>
</tr>
</thead>
<tbody>
<?php foreach ( $custom_taxonomies as $ctax ): ?>
<?php
$checked1 = !empty( $sitepress_settings[ 'taxonomies_sync_option' ][ $ctax ] ) ? ' checked="checked"' : '';
$checked0 = empty( $sitepress_settings[ 'taxonomies_sync_option' ][ $ctax ] ) ? ' checked="checked"' : '';
$radio_disabled = isset( $iclTranslationManagement->settings[ 'taxonomies_readonly_config' ][ $ctax ] ) ? ' disabled="disabled"' : '';
<tr>
<td><?php echo $wp_taxonomies[ $ctax ]->labels->name ?></td>
<td align="right">
<label><input name="icl_mcs_custom_taxs_<?php echo $ctax ?>" class="icl_mcs_custom_taxs" type="radio"
value="<?php echo $ctax ?>" <?php echo $checked1; ?><?php echo $radio_disabled ?> /> <?php _e( 'Translate', 'sitepress' ) ?></label>
<label><input name="icl_mcs_custom_taxs_<?php echo $ctax ?>" type="radio" value="0" <?php echo $checked0; ?><?php echo $radio_disabled ?> /> <?php _e( 'Do nothing', 'sitepress' ) ?></label>
</td>
</tr>
<?php endforeach; ?>
</tbody>
</table>
<br/>
<?php
//echo '</div><div style="width:50%;float:left;min-width:265px;margin-top:3px;">';
if ( defined( 'WPML_TM_VERSION' ) ) {
$custom_keys = (array)get_post_custom_keys( $post->ID );
$cf_keys_exceptions = array(
'_edit_last', '_edit_lock', '_wp_page_template', '_wp_attachment_metadata', '_icl_translator_note', '_alp_processed', '_pingme', '_encloseme', '_icl_lang_duplicate_of', '_wpml_media_duplicate', '_wpml_media_featured',
'_thumbnail_id'
$custom_keys = array_diff( $custom_keys, $cf_keys_exceptions );
$cf_settings_read_only = isset( $iclTranslationManagement->settings[ 'custom_fields_readonly_config' ] ) ? (array)$iclTranslationManagement->settings[ 'custom_fields_readonly_config' ] : array();
$cf_settings = isset( $iclTranslationManagement->settings[ 'custom_fields_translation' ] ) ? $iclTranslationManagement->settings[ 'custom_fields_translation' ] : array();
if ( !empty( $custom_keys ) ) {
<thead>
<tr>
<th colspan="2"><?php _e( 'Custom fields', 'sitepress' ); ?></th>
</tr>
</thead>
<tbody>
<?php
foreach ( $custom_keys as $cfield ) {
if ( empty( $cf_settings[ $cfield ] ) || $cf_settings[ $cfield ] != 3 ) {
$radio_disabled = in_array( $cfield, $cf_settings_read_only ) ? 'disabled="disabled"' : '';
$checked0 = empty( $cf_settings[ $cfield ] ) ? ' checked="checked"' : '';
$checked1 = isset( $cf_settings[ $cfield ] ) && $cf_settings[ $cfield ] == 1 ? ' checked="checked"' : '';
$checked2 = isset( $cf_settings[ $cfield ] ) && $cf_settings[ $cfield ] == 2 ? ' checked="checked"' : '';
<tr>
<td><?php echo $cfield; ?></td>
<td align="right">
<label><input class="icl_mcs_cfs" name="icl_mcs_cf_<?php echo base64_encode( $cfield ); ?> " type="radio"
value="0" <?php echo $radio_disabled . $checked0 ?> /> <?php _e( "Don't translate", 'sitepress' ) ?></label>
<label><input class="icl_mcs_cfs" name="icl_mcs_cf_<?php echo base64_encode( $cfield ); ?> " type="radio" value="1" <?php echo $radio_disabled . $checked1 ?> /> <?php _e( "Copy", 'sitepress' ) ?>
</label>
<label><input class="icl_mcs_cfs" name="icl_mcs_cf_<?php echo base64_encode( $cfield ); ?> " type="radio" value="2" <?php echo $radio_disabled . $checked2 ?> /> <?php _e( "Translate", 'sitepress' ) ?>
</label>
</td>
</tr>
<?php
</tbody>
</table>
<br/>
<?php
//echo '</div><br clear="all" />';
if ( !empty( $custom_taxonomies ) || !empty( $custom_keys ) ) {
echo '<small>' . __( 'Note: Custom taxonomies and custom fields are shared across different post types.', 'sitepress' ) . '</small>';
echo '</span>';
if ( $cp_editable || !empty( $custom_taxonomies ) || !empty( $custom_keys ) ) {
echo '<p class="submit" style="margin:0;padding:0"><input class="button-secondary" id="icl_make_translatable_submit" type="button" value="' . __( 'Apply', 'sitepress' ) . '" /></p><br clear="all" />';
wp_nonce_field( 'icl_mcs_inline_nonce', '_icl_nonce_imi' );
} else {
_e( 'Nothing to configure.', 'sitepress' );
function pre_get_posts( $wpq )
// case of internal links list
if ( isset( $_POST[ 'action' ] ) && 'wp-link-ajax' == $_POST[ 'action' ] ) {
$default_language = $this->get_default_language();
if ( !empty( $_SERVER[ 'HTTP_REFERER' ] ) ) {
$parts = parse_url( $_SERVER[ 'HTTP_REFERER' ] );
parse_str( strval( $parts[ 'query' ] ), $query );
$lang = isset( $query[ 'lang' ] ) ? $query[ 'lang' ] : $default_language;
} else $lang = $default_language;
$this->this_lang = $lang;
$wpq->query_vars[ 'suppress_filters' ] = false;
if ($this->is_gallery_on_root_page($wpq)) {
$wpq->query_vars['page_id'] = 0;
$wpq->query['page_id'] = 0;
return $wpq;
function is_gallery_on_root_page( $wpq ) {
// are we on root page and we are searching for attachments to gallery on it?
if ( isset( $this->settings[ 'urls' ][ 'show_on_root' ] ) &&
$this->settings[ 'urls' ][ 'show_on_root' ] == 'page' &&
isset( $wpq->query_vars[ 'page_id' ] ) &&
$wpq->query_vars[ 'page_id' ] > 0 &&
$wpq->query_vars[ 'page_id' ] == $this->settings[ 'urls' ][ 'root_page' ] &&
isset( $wpq->query_vars[ 'post_type' ] ) &&
$wpq->query_vars[ 'post_type' ] == 'attachment'
return true;
return false;
* @param $join string
* @param $query WP_Query
* @return string
function posts_join_filter( $join, $query )
global $wpdb, $pagenow, $wp_taxonomies, $sitepress_settings;
$attachment_is_translatable = $this->is_translated_post_type( 'attachment' );
if ( (($pagenow == 'upload.php' || $pagenow == 'media-upload.php' || $query->is_attachment()) && !$attachment_is_translatable) || ( isset( $query->queried_object ) && isset( $query->queried_object->ID ) && $query->queried_object->ID == $sitepress_settings[ 'urls' ][ 'root_page' ] ) ) {
return $join;
// determine post type
$debug_backtrace = $this->get_backtrace( 0, true, false ); //Limit to a maximum level?
$post_type = false;
foreach ( $debug_backtrace as $o ) {
if ( $o[ 'function' ] == 'apply_filters_ref_array' && $o[ 'args' ][ 0 ] == 'posts_join' ) {
$post_type = esc_sql( $o[ 'args' ][ 1 ][ 1 ]->query_vars[ 'post_type' ] );
break;
if ( $post_type == 'any' || 'all' == $this->this_lang ) {
$left_join = "LEFT";
} else {
$left_join = "";
if ( is_array( $post_type ) ) {
$post_types = array();
foreach ( $post_type as $ptype ) {
if ( $this->is_translated_post_type( $ptype ) ) {
$post_types[ ] = esc_sql( 'post_' . $ptype );
if ( !empty( $post_types ) ) {
$join .= " {$left_join} JOIN {$wpdb->prefix}icl_translations t ON {$wpdb->posts}.ID = t.element_id
AND t.element_type IN ('" . join( "','", $post_types ) . "') JOIN {$wpdb->prefix}icl_languages l ON t.language_code=l.code AND l.active=1";
} elseif ( $post_type ) {
if ( $this->is_translated_post_type( $post_type ) ) {
AND t.element_type = 'post_{$post_type}' JOIN {$wpdb->prefix}icl_languages l ON t.language_code=l.code AND l.active=1";
} elseif ( $post_type == 'any' ) {
AND t.element_type LIKE 'post\\_%' {$left_join} JOIN {$wpdb->prefix}icl_languages l ON t.language_code=l.code AND l.active=1";
} else {
if ( $query->is_tax() && $query->is_main_query() ) {
$tax = $query->get( 'taxonomy' );
$taxonomy_post_types = $wp_taxonomies[ $tax ]->object_type;
foreach ( $taxonomy_post_types as $k => $v ) {
if ( !$this->is_translated_post_type( $v ) ) {
unset( $taxonomy_post_types[ $k ] );
} else {
$taxonomy_post_types = array_keys( $this->get_translatable_documents( false ) );
if ( !empty( $taxonomy_post_types ) ) {
$taxonomy_post_types[ $k ] = 'post_' . $v;
$post_types = "'" . join( "','", $taxonomy_post_types ) . "'";
AND t.element_type IN ({$post_types}) JOIN {$wpdb->prefix}icl_languages l ON t.language_code=l.code AND l.active=1";
return $join;
* @param string $where
* @param WP_Query $query
* @return string
function posts_where_filter( $where, $query )
global $pagenow, $wp_taxonomies, $sitepress, $sitepress_settings;
//exceptions
$post_type = false;
if ( isset( $query->queried_object ) && isset( $query->queried_object->ID ) && $query->queried_object->ID == $sitepress_settings[ 'urls' ][ 'root_page' ] ) {
return $where;
if ( $o[ 'function' ] == 'apply_filters_ref_array' && $o[ 'args' ][ 0 ] == 'posts_where' ) {
$post_type = $o[ 'args' ][ 1 ][ 1 ]->query_vars[ 'post_type' ];
break;
// case of taxonomy archive
if ( empty( $post_type ) && $query->is_tax() ) {
$post_type = $wp_taxonomies[ $tax ]->object_type;
foreach ( $post_type as $k => $v ) {
unset( $post_type[ $k ] );
if ( empty( $post_type ) ) {
return $where;
} // don't filter
if ( !$post_type ) {
$post_type = 'post';
if ( is_array( $post_type ) && !empty( $post_type ) ) {
$none_translated = true;
$none_translated = false;
if ( $none_translated ) {
return $where;
} else {
if ( !$this->is_translated_post_type( $post_type ) && 'any' != $post_type ) {
return $where;
$attachment_is_translatable = $sitepress->is_translated_post_type( 'attachment' );
if ( ($pagenow == 'upload.php' || $pagenow == 'media-upload.php' || $query->is_attachment()) && !$attachment_is_translatable) {
return $where;
$current_language = $sitepress->get_current_language();
$requested_id = false;
// Fix for when $sitepress->get_current_language() does not return the correct value (e.g. when request is made for an attachment, an iframe or an ajax call)
if ( isset( $_REQUEST[ 'attachment_id' ] ) && $_REQUEST[ 'attachment_id' ] ) {
$requested_id = $_REQUEST[ 'attachment_id' ];
if ( isset( $_REQUEST[ 'post_id' ] ) && $_REQUEST[ 'post_id' ] ) {
$requested_id = $_REQUEST[ 'post_id' ];
if($requested_id) {
$post_type = get_post_type( $requested_id );
$current_language = $sitepress->get_language_for_element( $requested_id, 'post_' . $post_type );
if(!$current_language) {
if ( 'all' != $this->this_lang ) {
if ( 'any' == $post_type ) {
$condition = " AND (t.language_code='" . esc_sql( $current_language ) . "' OR t.language_code IS NULL )";
} else {
$condition = " AND t.language_code='" . esc_sql( $current_language ) . "'";
} else {
$condition = '';
$where .= $condition;
return $where;
function comment_feed_join( $join )
global $wpdb, $wp_query;
$type = $wp_query->query_vars[ 'post_type' ] ? esc_sql( $wp_query->query_vars[ 'post_type' ] ) : 'post';
$wp_query->query_vars[ 'is_comment_feed' ] = true;
$join .= " JOIN {$wpdb->prefix}icl_translations t ON {$wpdb->comments}.comment_post_ID = t.element_id
AND t.element_type='post_{$type}' AND t.language_code='" . esc_sql( $this->this_lang ) . "'";
return $join;
function comments_clauses( $clauses, $obj )
global $wpdb;
if ( isset( $obj->query_vars[ 'post_id' ] ) ) {
$post_id = $obj->query_vars[ 'post_id' ];
} elseif ( isset( $obj->query_vars[ 'post_ID' ] ) ) {
$post_id = $obj->query_vars[ 'post_ID' ];
if ( !empty( $post_id ) ) {
if ( !$this->is_translated_post_type( $post->post_type ) ) {
return $clauses;
$current_language = $this->get_current_language();
if ( $current_language != 'all' ) {
$clauses[ 'join' ] .= " JOIN {$wpdb->prefix}icl_translations icltr1 ON
icltr1.element_id = {$wpdb->comments}.comment_ID
JOIN {$wpdb->prefix}icl_translations icltr2 ON
icltr2.element_id = {$wpdb->comments}.comment_post_ID
$clauses[ 'where' ] .= " AND icltr1.element_type = 'comment'
AND icltr1.language_code = '" . $current_language . "'
AND icltr2.language_code = '" . $current_language . "'
AND icltr2.element_type LIKE 'post\\_%' ";
return $clauses;
function language_filter()
global $wpdb;
$type = isset( $_GET[ 'post_type' ] ) ? $_GET[ 'post_type' ] : 'post';
if ( !in_array( $type, array( 'post', 'page' ) ) && !in_array( $type, array_keys( $this->get_translatable_documents() ) ) ) {
return;
$active_languages = $this->get_active_languages();
$post_status = get_query_var( 'post_status' );
if ( is_string( $post_status ) ) {
$post_status = $post_status ? array( $post_status ) : array();
$key = join( ',', $post_status );
if ( $key ) {
$key = '#' . $key;
$languages = icl_cache_get( $type . 's_per_language' . $key );
if ( !$languages ) {
$extra_conditions = "";
if ( $post_status ) {
$extra_conditions .= apply_filters( '_icl_posts_language_count_status', " AND post_status IN('" . join( "','", $post_status ) . "') " );
if ( $post_status != array( 'trash' ) ) {
$extra_conditions .= " AND post_status <> 'trash'";
// dont count auto drafts
$extra_conditions .= " AND post_status <> 'auto-draft'";
// only active language
$extra_conditions .= " AND t.language_code IN ('" . join( "','", array_keys( $active_languages ) ) . "') ";
$res = $wpdb->get_results( "
SELECT language_code, COUNT(p.ID) AS c FROM {$wpdb->prefix}icl_translations t
JOIN {$wpdb->prefix}icl_languages l ON t.language_code=l.code AND l.active = 1
WHERE p.post_type='{$type}' AND t.element_type='post_{$type}' {$extra_conditions}
GROUP BY language_code
$languages[ 'all' ] = 0;
foreach ( $res as $r ) {
$languages[ $r->language_code ] = $r->c;
$languages[ 'all' ] += $r->c;
icl_cache_set( $type . 's_per_language' . $key, $languages );
$active_languages[ ] = array( 'code' => 'all', 'display_name' => __( 'All languages', 'sitepress' ) );
$as = array();
foreach ( $active_languages as $lang ) {
if ( $lang[ 'code' ] == $this->this_lang ) {
$px = '';
$sx = ' <span class="count">(' . @intval( $languages[ $lang[ 'code' ] ] ) . ')<\/span><\/strong>';
} elseif ( !isset( $languages[ $lang[ 'code' ] ] ) ) {
$px = '<span>';
$sx = '<\/span>';
} else {
$px = '<a href="?post_type=' . $type . '&post_status=' . join( ',', $post_status ) . '&lang=' . $lang[ 'code' ] . '">';
} else {
$px = '<a href="?post_type=' . $type . '&lang=' . $lang[ 'code' ] . '">';
$sx = '<\/a> <span class="count">(' . intval( $languages[ $lang[ 'code' ] ] ) . ')<\/span>';
$as[ ] = $px . $lang[ 'display_name' ] . $sx;
$allas = join( ' | ', $as );
if ( empty( $this->settings[ 'hide_how_to_translate' ] ) && $type == 'page' && !$this->get_icl_translation_enabled() ) {
$prot_link = '<span id="icl_how_to_translate_link" class="button" style="padding-right:3px;" ><img align="baseline" src="' . ICL_PLUGIN_URL . '/res/img/icon16.png" width="16" height="16" style="margin-bottom:-4px" /> <a href="https://wpml.org/?page_id=3416">' . __( 'How to translate', 'sitepress' ) . '</a><a href="#" title="' . esc_attr__( 'hide this', 'sitepress' ) . '" onclick=" if(confirm(\\\'' . __( 'Are you sure you want to remove this button?', 'sitepress' ) . '\\\')) jQuery.ajax({url:icl_ajx_url,type:\\\'POST\\\',data:{icl_ajx_action:\\\'update_option\\\', option:\\\'hide_how_to_translate\\\',value:1,_icl_nonce:\\\'' . wp_create_nonce( 'update_option_nonce' ) . '\\\'},success:function(){jQuery(\\\'#icl_how_to_translate_link\\\').fadeOut()}});return false;" style="outline:none;"><img src="' . ICL_PLUGIN_URL . '/res/img/close2.png" width="10" height="10" style="border:none" alt="' . esc_attr__( 'hide', 'sitepress' ) . '" /><\/a>' . '<\/span>';
} else {
$prot_link = '';
<script type="text/javascript">
jQuery(".subsubsub").append('<br /><span id="icl_subsubsub"><?php echo $allas ?></span><br /><?php echo $prot_link ?>');
</script>
<?php
function exclude_other_language_pages2( $arr )
$new_arr = $arr;
$cache_key = md5(json_encode($new_arr));
$cache_group = 'exclude_other_language_pages2';
$found = false;
$result = wp_cache_get($cache_key, $cache_group, false, $found);
if(!$found) {
global $wpdb;
if ( is_array( $new_arr ) && !empty( $new_arr[ 0 ]->post_type ) ) {
$post_type = $new_arr[ 0 ]->post_type;
} else {
$post_type = 'page';
$filtered_pages = array();
// grab list of pages NOT in the current language
$excl_pages = $wpdb->get_col( $wpdb->prepare( "
SELECT p.ID FROM {$wpdb->posts} p
WHERE t.element_type=%s AND p.post_type=%s AND t.language_code <> %s
", 'post_' . $post_type, $post_type, $current_language ) );
// exclude them from the result set
if ( !empty( $new_arr ) ) {
foreach ( $new_arr as $page ) {
if ( !in_array( $page->ID, $excl_pages ) ) {
$filtered_pages[ ] = $page;
$new_arr = $filtered_pages;
wp_cache_set($cache_key, $new_arr, $cache_group);
} else {
$new_arr = $result;
return $new_arr;
function wp_dropdown_pages( $output )
global $wpdb;
if ( isset( $_POST[ 'lang_switch' ] ) ) {
$post_id = esc_sql( $_POST[ 'lang_switch' ] );
$lang = esc_sql( strip_tags( $_GET[ 'lang' ] ) );
$parent = $wpdb->get_var( $wpdb->prepare( "SELECT post_parent FROM {$wpdb->posts} WHERE ID=%d", $post_id ) );
if ( $parent ) {
$trid = $wpdb->get_var( "SELECT trid FROM {$wpdb->prefix}icl_translations WHERE element_id='{$parent}' AND element_type='post_page'" );
$translated_parent_id = $wpdb->get_var( "SELECT element_id FROM {$wpdb->prefix}icl_translations WHERE trid='{$trid}' AND element_type='post_page' AND language_code='{$lang}'" );
if ( $translated_parent_id ) {
$output = str_replace( 'selected="selected"', '', $output );
$output = str_replace( 'value="' . $translated_parent_id . '"', 'value="' . $translated_parent_id . '" selected="selected"', $output );
} elseif ( isset( $_GET[ 'lang' ] ) && isset( $_GET[ 'trid' ] ) ) {
$trid = esc_sql( $_GET[ 'trid' ] );
$post_type = isset( $_GET[ 'post_type' ] ) ? $_GET[ 'post_type' ] : 'page';
$elements_id = $wpdb->get_col( $wpdb->prepare( "SELECT element_id FROM {$wpdb->prefix}icl_translations
WHERE trid=%d AND element_type=%s AND element_id IS NOT NULL", $trid, 'post_' . $post_type ) );
$translated_parent_id = 0;
foreach ( $elements_id as $element_id ) {
$parent = $wpdb->get_var( $wpdb->prepare( "SELECT post_parent FROM {$wpdb->posts} WHERE ID=%d", $element_id ) );
$trid = $wpdb->get_var( $wpdb->prepare( "
SELECT trid FROM {$wpdb->prefix}icl_translations WHERE element_id=%d AND element_type=%s", $parent, 'post_' . $post_type ) );
$translated_parent_id = $wpdb->get_var( $wpdb->prepare( "
WHERE trid=%d AND element_type=%s AND language_code=%s", $trid, 'post_' . $post_type, $lang ) );
break;
if ( !$output ) {
$output = '<select id="parent_id"><option value="">' . __( 'Main Page (no parent)', 'sitepress' ) . '</option></select>';
return $output;
function edit_term_form( $term )
include ICL_PLUGIN_PATH . '/menu/taxonomy-menu.php';
function wp_dropdown_cats_select_parent( $html )
global $wpdb;
$element_type = $taxonomy = isset( $_GET[ 'taxonomy' ] ) ? $_GET[ 'taxonomy' ] : 'post_tag';
$icl_element_type = 'tax_' . $element_type;
$trid = intval( $_GET[ 'trid' ] );
$source_lang = isset( $_GET[ 'source_lang' ] ) ? $_GET[ 'source_lang' ] : $this->get_default_language();
$parent = $wpdb->get_var( "
SELECT parent
FROM {$wpdb->term_taxonomy} tt
JOIN {$wpdb->prefix}icl_translations tr ON tr.element_id=tt.term_taxonomy_id
AND tr.element_type='{$icl_element_type}' AND tt.taxonomy='{$taxonomy}'
WHERE trid='{$trid}' AND tr.language_code='{$source_lang}'
if ( $parent ) {
$parent = icl_object_id( $parent, $element_type );
$html = str_replace( 'value="' . $parent . '"', 'value="' . $parent . '" selected="selected"', $html );
return $html;
function add_language_selector_to_page( $active_languages, $selected_language, $translations, $element_id, $type )
<div id="icl_tax_menu" style="display:none">
<div id="dashboard-widgets" class="metabox-holder">
<div class="postbox-container" style="width: 99%;line-height:normal;">
<div id="icl_<?php echo $type ?>_lang" class="postbox" style="line-height:normal;">
<h3 class="hndle">
<span><?php echo __( 'Language', 'sitepress' ) ?></span>
</h3>
<div class="inside" style="padding: 10px;">
<select name="icl_<?php echo $type ?>_language">
<?php
if ( $lang[ 'code' ] == $selected_language ) {
<option value="<?php echo $selected_language ?>" selected="selected"><?php echo $lang[ 'display_name' ] ?></option>
<?php
<?php foreach ( $active_languages as $lang ): ?>
<?php if ( $lang[ 'code' ] == $selected_language || ( isset( $translations[ $lang[ 'code' ] ]->element_id ) && $translations[ $lang[ 'code' ] ]->element_id != $element_id ) ) {
continue;
<option value="<?php echo $lang[ 'code' ] ?>"<?php if ( $selected_language == $lang[ 'code' ] ): ?> selected="selected"<?php endif; ?>><?php echo $lang[ 'display_name' ] ?></option>
</select>
<?php
function get_category_name( $id )
_deprecated_function( __FUNCTION__, '2.3.1', 'get_cat_name()' );
global $wpdb;
$term_id = $wpdb->get_var( "SELECT term_id FROM {$wpdb->prefix}term_taxonomy WHERE term_taxonomy_id = {$id}" );
if ( $term_id ) {
return $wpdb->get_var( "SELECT name FROM {$wpdb->prefix}terms WHERE term_id = {$term_id}" );
} else {
return null;
function add_translation_of_selector_to_page( $trid, $selected_language, $default_language, $source_language, $untranslated_ids, $element_id, $type )
global $wpdb;
if(!$this->settings['setup_complete']){
return false;
<input type="hidden" name="icl_trid" value="<?php echo $trid ?>"/>
<?php
if ( $selected_language != $default_language && 'all' != $this->get_current_language() ) {
<br/><br/>
<?php echo __( 'This is a translation of', 'sitepress' ); ?><br/>
<select name="icl_translation_of" id="icl_translation_of"<?php if ( ( !isset( $_GET[ 'action' ] ) || $_GET[ 'action' ] != 'edit' ) && $trid ) {
echo " disabled";
<?php
if ( !$source_language || $source_language == $default_language ) {
if ( $trid ) {
<option value="none"><?php echo __( '--None--', 'sitepress' ) ?></option>
<?php
//get source
$src_language_id = $wpdb->get_var( $wpdb->prepare( "SELECT element_id FROM {$wpdb->prefix}icl_translations WHERE trid=%d AND language_code=%s", $trid, $default_language ) );
if ( !$src_language_id ) {
// select the first id found for this trid
$src_language_id = $wpdb->get_var( $wpdb->prepare( "SELECT element_id FROM {$wpdb->prefix}icl_translations WHERE trid=%d", $trid ) );
if ( $src_language_id && $src_language_id != $element_id ) {
$term_id = $wpdb->get_var( $wpdb->prepare( "SELECT term_id FROM {$wpdb->term_taxonomy} WHERE term_taxonomy_id=%d", $src_language_id ) );
$src_language_title = $wpdb->get_var( $wpdb->prepare( "SELECT name FROM {$wpdb->terms} WHERE term_id=%d", $term_id ) );
if ( !empty( $src_language_title ) ) {
<option value="<?php echo $src_language_id; ?>" selected="selected"><?php echo $src_language_title; ?></option>
<?php
} else {
<option value="none" selected="selected"><?php echo __( '--None--', 'sitepress' ); ?></option>
<?php
foreach ( $untranslated_ids as $translation_of_id ) {
$title = $wpdb->get_var( $wpdb->prepare( "SELECT name FROM {$wpdb->terms} WHERE term_id=%d", $wpdb->get_var( $wpdb->prepare( "SELECT term_id FROM {$wpdb->term_taxonomy} WHERE term_taxonomy_id=%d", $translation_of_id ) ) ) );
if ( !empty( $title ) ) {
<option value="<?php echo $translation_of_id; ?>"><?php echo $title; ?></option>
<?php
} else {
if ( $trid ) {
$src_language_title = false;
// add the source language
$src_language_id = $wpdb->get_var( "SELECT element_id FROM {$wpdb->prefix}icl_translations WHERE trid={$trid} AND language_code='{$source_language}'" );
if ( $src_language_id ) {
if ( $src_language_title ) {
<?php
} else {
<?php
</select>
<?php
function add_translate_options( $trid, $active_languages, $selected_language, $translations, $type )
if ( $trid && isset( $_GET[ 'action' ] ) && $_GET[ 'action' ] == 'edit' ):
return false;
<div id="icl_translate_options">
<?php
// count number of translated and un-translated pages.
$translations_found = 0;
$untranslated_found = 0;
if ( $selected_language == $lang[ 'code' ] ) {
continue;
if ( isset( $translations[ $lang[ 'code' ] ]->element_id ) ) {
$translations_found += 1;
} else {
$untranslated_found += 1;
<?php if ( $untranslated_found > 0 ): ?>
<table cellspacing="1" class="icl_translations_table" style="min-width:200px;margin-top:10px;">
<thead>
<tr>
<th colspan="2" style="padding:4px;background-color:#DFDFDF"><b><?php _e( 'Translate', 'sitepress' ); ?></b></th>
</tr>
</thead>
<tbody>
<?php foreach ( $active_languages as $lang ): if ( $selected_language == $lang[ 'code' ] ) {
continue;
<tr>
<?php if ( !isset( $translations[ $lang[ 'code' ] ]->element_id ) ): ?>
<td style="padding:4px;line-height:normal;"><?php echo $lang[ 'display_name' ] ?></td>
<?php
$taxonomy = $_GET[ 'taxonomy' ];
$post_type_q = isset( $_GET[ 'post_type' ] ) ? '&post_type=' . esc_html( $_GET[ 'post_type' ] ) : '';
$add_link = admin_url( "edit-tags.php?taxonomy=" . esc_html( $taxonomy ) . "&trid=" . $trid . "&lang=" . $lang[ 'code' ] . "&source_lang=" . $selected_language . $post_type_q );
<td style="padding:4px;line-height:normal;"><a href="<?php echo $add_link ?>"><?php echo __( 'add', 'sitepress' ) ?></a></td>
<?php endif; ?>
</tr>
</tbody>
</table>
<?php endif; ?>
<?php if ( $translations_found > 0 ): ?>
<p style="clear:both;margin:5px 0 5px 0">
<b><?php _e( 'Translations', 'sitepress' ) ?></b>
(<a class="icl_toggle_show_translations" href="#" <?php if (empty( $this->settings[ 'show_translations_flag' ] )): ?>style="display:none;"<?php endif; ?>><?php _e( 'hide', 'sitepress' ) ?></a><a
class="icl_toggle_show_translations" href="#" <?php if (!empty( $this->settings[ 'show_translations_flag' ] )): ?>style="display:none;"<?php endif; ?>><?php _e( 'show', 'sitepress' ) ?></a>)
<?php wp_nonce_field( 'toggle_show_translations_nonce', '_icl_nonce_tst' ) ?>
<table cellspacing="1" width="100%" id="icl_translations_table" style="<?php if ( empty( $this->settings[ 'show_translations_flag' ] ) ): ?>display:none;<?php endif; ?>margin-left:0;">
continue; ?>
<tr>
<?php if ( isset( $translations[ $lang[ 'code' ] ]->element_id ) ): ?>
<td style="line-height:normal;"><?php echo $lang[ 'display_name' ] ?></td>
<?php
$edit_link = admin_url( "edit-tags.php?taxonomy=" . esc_html( $taxonomy ) . "&action=edit&tag_ID=" . $translations[ $lang[ 'code' ] ]->term_id . "&lang=" . $lang[ 'code' ] . $post_type_q );
<td align="right" width="30%"
style="line-height:normal;"><?php echo isset( $translations[ $lang[ 'code' ] ]->name ) ? '<a href="' . $edit_link . '" title="' . __( 'Edit', 'sitepress' ) . '">' . $translations[ $lang[ 'code' ] ]->name . '</a>' : __( 'n/a', 'sitepress' ) ?></td>
<?php endif; ?>
</tr>
</table>
<?php endif; ?>
<br clear="all" style="line-height:1px;"/>
</div>
<?php
endif;
* @param $name
* @deprecated deprecated since version 3.1.8
* @return array|mixed
function the_category_name_filter( $name ) {
if ( is_array( $name ) ) {
foreach ( $name as $k => $v ) {
$name[ $k ] = $this->the_category_name_filter( $v );
return $name;
if ( false === strpos( $name, '@' ) ) {
return $name;
if ( false !== strpos( $name, '<a' ) ) {
$int = preg_match_all( '|<a([^>]+)>([^<]+)</a>|i', $name, $matches );
if ( $int && count( $matches[ 0 ] ) > 1 ) {
$originals = $filtered = array();
foreach ( $matches[ 0 ] as $m ) {
$originals[ ] = $m;
$filtered[ ] = $this->the_category_name_filter( $m );
$name = str_replace( $originals, $filtered, $name );
} else {
$name_sh = strip_tags( $name );
$exp = explode( '@', $name_sh );
$name = str_replace( $name_sh, trim( $exp[ 0 ] ), $name );
} else {
$name = preg_replace( '#(.*) @(.*)#i', '$1', $name );
return $name;
* @param $terms
* @return mixed
function get_terms_filter( $terms ) {
if ( is_wp_error( $terms ) ) {
return $terms;
foreach ( $terms as $k => $v ) {
if ( isset( $terms[ $k ]->name ) ) {
$terms[ $k ]->name = $this->the_category_name_filter( $terms[ $k ]->name );
return $terms;
* @param $terms
* @param $id
* @param $taxonomy
* @return mixed
function get_the_terms_filter( $terms, $id, $taxonomy ) {
return $terms;
function create_term( $cat_id, $tt_id )
global $wpdb, $wp_taxonomies;
// case of ajax inline category creation
// ajax actions
$ajx_actions = array();
foreach ( $wp_taxonomies as $ktx => $tx ) {
$ajx_actions[ ] = 'add-' . $ktx;
if ( isset( $_POST[ '_ajax_nonce' ] ) && in_array( $_POST[ 'action' ], $ajx_actions ) ) {
$referer = $_SERVER[ 'HTTP_REFERER' ];
$url_pieces = parse_url( $referer );
@parse_str( $url_pieces[ 'query' ], $qvars );
if ( !empty( $qvars[ 'post' ] ) ) {
$post_type = $wpdb->get_var( $wpdb->prepare( "SELECT post_type FROM {$wpdb->posts} WHERE ID = %d", $qvars[ 'post' ] ) );
$term_lang = $qvars[ 'lang' ];
if($this->is_translated_post_type($post_type)) {
$lang_details = $this->get_element_language_details( $qvars[ 'post' ], 'post_' . $post_type );
if(isset($lang_details->language_code)) {
$term_lang = $lang_details->language_code;
} else {
$term_lang = isset( $qvars[ 'lang' ] ) ? $qvars[ 'lang' ] : $this->get_language_cookie();
$el_type = $wpdb->get_var( "SELECT taxonomy FROM {$wpdb->term_taxonomy} WHERE term_taxonomy_id={$tt_id}" );
if ( !$this->is_translated_taxonomy( $el_type ) ) {
return;
$icl_el_type = 'tax_' . $el_type;
// case of adding a tag via post save
$post_action = isset( $_POST[ 'action' ] ) ? $_POST[ 'action' ] : false;
if ( $post_action == 'editpost' && !empty( $_POST[ 'icl_post_language' ] ) ) {
$term_lang = $_POST[ 'icl_post_language' ];
} elseif ( $post_action == 'post-quickpress-publish' ) {
$term_lang = $default_language;
} elseif ( $post_action == 'inline-save-tax' ) {
$lang_details = $this->get_element_language_details( $tt_id, $icl_el_type );
} elseif ( $post_action == 'inline-save' ) {
$post_type = $wpdb->get_var( "SELECT post_type FROM {$wpdb->posts} WHERE ID=" . $_POST[ 'post_ID' ] );
$lang_details = $this->get_element_language_details( $_POST[ 'post_ID' ], 'post_' . $post_type );
// has trid only when it's a translation of another tag
$trid = isset( $_POST[ 'icl_trid' ] ) && ( isset( $_POST[ 'icl_' . $icl_el_type . '_language' ] ) ) ? $_POST[ 'icl_trid' ] : null;
// see if we have a "translation of" setting.
$src_language = false;
if ( isset( $_POST[ 'icl_translation_of' ] ) && $_POST[ 'icl_translation_of' ] ) {
$src_term_id = $_POST[ 'icl_translation_of' ];
$trid = $this->get_element_trid( $src_term_id, $icl_el_type );
if ( $src_term_id != 'none' && $trid ) {
$language_details = $this->get_element_language_details( $trid, $icl_el_type );
if ( empty( $language_details ) || !is_object( $language_details ) || !isset( $language_details->source_language_code ) ) {
$src_language = null;
} else {
$src_language = $language_details->source_language_code;
} else {
$trid = null;
if ( !isset( $term_lang ) ) {
$term_lang = isset( $_POST[ 'icl_' . $icl_el_type . '_language' ] ) ? $_POST[ 'icl_' . $icl_el_type . '_language' ] : $this->this_lang;
if ( $post_action == 'inline-save-tax' || $post_action == 'add-' . $el_type ) {
$trid = $this->get_element_trid( $tt_id, $icl_el_type );
// set term language if front-end translation creating
$term_lang = apply_filters( 'wpml_create_term_lang', $term_lang );
if ( ! $this->is_active_language( $term_lang ) ) {
$this->set_element_language_details( $tt_id, $icl_el_type, $trid, $term_lang, $src_language );
// sync translations parent
if ( $this->settings[ 'sync_taxonomy_parents' ] && isset( $_POST[ 'parent' ] ) && $term_lang == $default_language ) {
$parent = intval( $_POST[ 'parent' ] );
$translations = $this->get_element_translations( $trid, $icl_el_type );
$taxonomy = isset($_POST[ 'taxonomy' ]) ? $_POST[ 'taxonomy' ] : false;
foreach ( $translations as $lang => $translation ) {
if ( $lang != $default_language ) {
$translated_parent = false;
//check for translation only if we know the id
if ( $parent > 0 ) {
$translated_parent = icl_object_id( $parent, $el_type, false, $lang );
//update information about parent only if translation exists or we are setting parent to None
if ( $parent == 0 || $parent == -1 || $translated_parent != $parent ) {
$wpdb->update( $wpdb->term_taxonomy, array( 'parent' => $translated_parent ), array( 'term_taxonomy_id' => $translation->element_id ) );
$this->update_terms_relationship_cache( $parent, $taxonomy );
function get_language_for_term( $term_id, $el_type )
global $wpdb;
$ttid = $wpdb->get_var( "SELECT term_taxonomy_id FROM {$wpdb->prefix}term_taxonomy WHERE term_id = {$term_id} AND taxonomy = '{$el_type}' " );
if ( $ttid ) {
$el_type = 'tax_' . $el_type;
return $wpdb->get_var( "SELECT language_code FROM {$wpdb->prefix}icl_translations WHERE element_id = {$ttid} AND element_type = '{$el_type}'" );
} else {
return $this->get_default_language();
function terms_language_filter()
global $wpdb;
$icl_element_type = 'tax_' . $taxonomy;
$current_language=$this->get_current_language();
$default_language=$this->get_default_language();
$res_query = "
SELECT language_code, COUNT(tm.term_id) AS c FROM {$wpdb->prefix}icl_translations t
JOIN {$wpdb->term_taxonomy} tt ON t.element_id = tt.term_taxonomy_id
JOIN {$wpdb->prefix}icl_languages l ON t.language_code = l.code
WHERE t.element_type=%s AND tt.taxonomy=%s AND l.active=1
$res_query_prepared = $wpdb->prepare($res_query, array($icl_element_type, $taxonomy) );
$res = $wpdb->get_results( $res_query_prepared );
$languages = array( 'all' => 0 );
$languages_links = array();
$px = '
$sx = ' (' . @intval( $languages[ $lang[ 'code' ] ] ) . ')<\/strong>';
}elseif(!isset($langs[$lang['code']])){
$px = '<span>';
$sx = '<\/span>';
} else {
$px = '<a href="?taxonomy=' . $taxonomy . '&lang=' . $lang[ 'code' ];
$px .= isset( $_GET[ 'post_type' ] ) ? '&post_type=' . $_GET[ 'post_type' ] : '';
$px .= '">';
$sx = '<\/a> (' . @intval( $languages[ $lang[ 'code' ] ] ) . ')';
$languages_links[ ] = $px . $lang[ 'display_name' ] . $sx;
$all_languages_links = join( ' | ', $languages_links );
jQuery('table.widefat').before('<span id="icl_subsubsub"><?php echo $all_languages_links ?><\/span>');
<?php // the search form, add language ?>
<?php if($current_language != $default_language): ?>
jQuery('.search-form').append('<input type="hidden" name="lang" value="<?php echo $current_language ?>" />');
<?php endif; ?>
</script>
<?php
function get_terms_args_filter( $args )
// Unique cache domain for each language.
if ( isset( $args[ 'cache_domain' ] ) ) {
$args[ 'cache_domain' ] .= '_' . $this->get_current_language();
// special case for when term hierarchy is cached in wp_options
$debug_backtrace = $this->get_backtrace( 5 ); //Limit to first 5 stack frames, since 4 is the highest index we use
if ( isset( $debug_backtrace[ 4 ] ) && $debug_backtrace[ 4 ][ 'function' ] == '_get_term_hierarchy' ) {
$args[ '_icl_show_all_langs' ] = true;
return $args;
function exclude_other_terms( $exclusions, $args )
if ( !version_compare( $GLOBALS[ 'wp_version' ], '3.1', '>=' ) ) {
if ( isset( $args[ '_icl_show_all_langs' ] ) && $args[ '_icl_show_all_langs' ] )
return $exclusions;
// get_terms doesn't seem to have a filter that can be used efficiently in order to filter the terms by language
// in addition the taxonomy name is not being passed to this filter we're using 'list_terms_exclusions'
// getting the taxonomy name from debug_backtrace
global $wpdb, $pagenow;
$taxonomy = false;
if ( isset( $_GET[ 'taxonomy' ] ) ) {
} elseif ( isset( $args[ 'taxonomy' ] ) ) {
$taxonomy = $args[ 'taxonomy' ];
} elseif ( isset( $_POST[ 'action' ] ) && $_POST[ 'action' ] == 'get-tagcloud' ) {
$taxonomy = $_POST[ 'tax' ];
} else {
if ( in_array( $pagenow, array( 'post-new.php', 'post.php', 'edit.php' ) ) ) {
$debug_backtrace = $this->get_backtrace( 4, false, true ); //Limit to first 4 stack frames, since 3 is the highest index we use
if ( isset( $debug_backtrace[ 3 ][ 'args' ][ 0 ] ) ) {
$taxonomy = $debug_backtrace[ 3 ][ 'args' ][ 0 ];
} else {
$taxonomy = 'post_tag';
if ( ! $taxonomy || ! $this->is_translated_taxonomy( $taxonomy ) ) {
return $exclusions;
if ( isset( $_GET[ 'lang' ] ) && $_GET[ 'lang' ] == 'all' ) {
return $exclusions;
if ( isset( $_GET[ 'tag_ID' ] ) && $_GET[ 'tag_ID' ] ) {
$element_lang_details = $this->get_element_language_details( $wpdb->get_var( $wpdb->prepare( "SELECT term_taxonomy_id FROM {$wpdb->term_taxonomy} WHERE term_id=%d AND taxonomy=%s", $_GET[ 'tag_ID' ], $taxonomy ) ), $icl_element_type );
$this_lang = $element_lang_details->language_code;
} elseif ( $this->this_lang != $default_language ) {
$this_lang = $this->get_current_language();
} elseif ( isset( $_GET[ 'post' ] ) ) {
$icl_post_type = isset( $_GET[ 'post_type' ] ) ? 'post_' . $_GET[ 'post_type' ] : 'post_' . $wpdb->get_var( $wpdb->prepare( "SELECT post_type FROM {$wpdb->posts} WHERE ID = %d", $_GET[ 'post' ] ) );
$element_lang_details = $this->get_element_language_details( $_GET[ 'post' ], $icl_post_type );
$this_lang = $element_lang_details ? $element_lang_details->language_code : $default_language;
} elseif ( isset( $_POST[ 'action' ] ) && ( $_POST[ 'action' ] == 'get-tagcloud' || $_POST[ 'action' ] == 'menu-quick-search' ) ) {
if ( ! isset( $_SERVER[ 'HTTP_REFERER' ] ) ) {
$this_lang = $default_language;
} else {
$urlparts = parse_url( $_SERVER[ 'HTTP_REFERER' ] );
@parse_str( $urlparts[ 'query' ], $qvars );
$this_lang = isset( $qvars[ 'lang' ] ) ? $qvars[ 'lang' ] : $default_language;
} else {
$exclude = $wpdb->get_col( "
SELECT tt.term_taxonomy_id FROM {$wpdb->term_taxonomy} tt
LEFT JOIN {$wpdb->prefix}icl_translations t ON (tt.term_taxonomy_id = t.element_id OR t.element_id IS NULL)
WHERE tt.taxonomy='{$taxonomy}' AND t.element_type='{$icl_element_type}' AND t.language_code <> '{$this_lang}'
$exclude[ ] = 0;
$exclusions .= ' AND tt.term_taxonomy_id NOT IN (' . join( ',', $exclude ) . ')';
return $exclusions;
function terms_clauses( $clauses, $taxonomies, $args )
if ( version_compare( $GLOBALS[ 'wp_version' ], '3.1', '>=' ) ) {
global $wpdb;
$debug_backtrace = $this->get_backtrace( 6 ); //Limit to first 5 stack frames, since 4 is the highest index we use
return $clauses;
//Todo: to remove: this is for debug purposes and only temporary
if(defined('WP_DEBUG') && WP_DEBUG===true) {
$wp_upload_dir = wp_upload_dir();
$icl_log_file = $wp_upload_dir['basedir'] . "/wpml.debug.txt";
foreach($debug_backtrace as $index => $data) {
if($index!=4 && $debug_backtrace[ $index ][ 'function' ] == '_get_term_hierarchy') {
file_put_contents($icl_log_file, '_get_term_hierarchy found on position ' . $index . PHP_EOL, FILE_APPEND);
file_put_contents($icl_log_file, 'Stack: ' . print_r($debug_backtrace, true) . PHP_EOL, FILE_APPEND);
$int = preg_match( '#tt\.taxonomy IN \(([^\)]+)\)#', $clauses[ 'where' ], $matches );
$left_join = '';
$icl_taxonomies = array();
if ( $int ) {
$exp = explode( ',', $matches[ 1 ] );
foreach ( $exp as $v ) {
$tax = trim( $v, ' \'' );
if ( $this->is_translated_taxonomy( $tax ) ) {
$icl_taxonomies[ ] = 'tax_' . $tax;
} else {
$left_join = ' LEFT';
} else {
// taxonomy type not found
return $clauses;
if ( empty( $icl_taxonomies ) )
return $clauses;
$icl_taxonomies = "'" . join( "','", $icl_taxonomies ) . "'";
$lang = $this->get_current_language();
if ( $lang == 'all' ) {
$where_lang = '';
} else {
$where_lang = " AND icl_t.language_code = '{$lang}'";
$clauses[ 'join' ] .= "{$left_join} JOIN {$wpdb->prefix}icl_translations icl_t ON icl_t.element_id = tt.term_taxonomy_id";
$clauses[ 'where' ] .= "{$where_lang} AND icl_t.element_type IN({$icl_taxonomies})";
//echo '<pre>' . print_r($clauses) . '</pre>';
return $clauses;
function set_wp_query()
global $wp_query;
$this->wp_query = $wp_query;
private function home_url_in_language_switcher($debug_backtrace) {
$level_7 = isset($debug_backtrace[7]);
$in_footer = ($debug_backtrace[7]['function']=='language_selector_footer');
$in_dropdown_widget = ( $debug_backtrace[7]['function']=='language_selector' );
$in_list_widget = ( $debug_backtrace[7]['function']=='icl_get_languages' );
$in_nav_menu = ( $debug_backtrace[7]['function']=='wp_nav_menu_items_filter' );
return ( $level_7 && ( $in_footer || $in_dropdown_widget || $in_list_widget || $in_nav_menu ) );
// filter for WP home_url function
function home_url( $url, $path, $orig_scheme, $blog_id )
$debug_backtrace = $this->get_backtrace( 8 ); //Limit to first 8 stack frames, since 7 is the highest index we use
// exception for get_page_num_link and language_negotiation_type = 3
if ( $this->settings[ 'language_negotiation_type' ] == 3 ) {
if ( !empty( $debug_backtrace[ 6 ] ) && $debug_backtrace[ 6 ][ 'function' ] == 'get_pagenum_link' )
return $url;
$convert_url = false;
// only apply this in some specific cases (1)
if(isset($debug_backtrace[5]) && $debug_backtrace[5]['function']=='get_post_type_archive_link') {
$convert_url = true;
if($this->home_url_in_language_switcher($debug_backtrace)) {
remove_filter( 'home_url', array( $this, 'home_url' ), 1 );
// only apply this in some specific cases (2)
if(!$convert_url && ( did_action( 'template_redirect' ) && rtrim( $url, '/' ) == rtrim( get_home_url(), '/' ) ) || $path == '/') {
if ( $convert_url ) {
$url = $this->convert_url( $url );
add_filter( 'home_url', array( $this, 'home_url' ), 1, 4 );
return $url;
* Converts WP generated url to language specific based on plugin settings
* @param string $url
* @param null|string $code (if null, fallback to detaulf language for root page, or current language in all other cases)
* @return bool|string
function convert_url( $url, $code = null ) {
global $wpdb;
if(!$url) return false;
$language_negotiation_type = $this->settings[ 'language_negotiation_type' ];
if ( is_null( $code ) && $language_negotiation_type == '2' && isset( $this->settings[ 'language_domains' ] ) ) {
foreach ( $this->settings[ 'language_domains' ] as $lang => $domain ) {
$domain = preg_replace( '/^https?\:\/\//', '', $domain );
$domain_data = explode('/', $domain);
$domain = $domain_data[0];
if ( $domain == $this->get_server_host_name() ) {
$code = $lang;
if ( is_null( $code ) ) {
$code = $default_language;
$code = $this->this_lang;
$cache_key_args = array( $url, $code, $current_language );
$cache_group = 'convert_url';
$cache_found = false;
$new_url = wp_cache_get($cache_key, $cache_group, false, $cache_found);
if(!$cache_found) {
$new_url = $url;
if ( $code && ( $code != $default_language || in_array( $language_negotiation_type, array( 1, 2 ) ) ) ) {
$absolute_home_url = preg_replace( '@\?lang=' . $code . '@i', '', get_home_url() );
switch ( $language_negotiation_type ) {
case '1':
if ( 0 === strpos( $new_url, 'hidden link' ) ) {
$absolute_home_url = preg_replace( '#^hidden link', 'hidden link', $absolute_home_url );
if ( $absolute_home_url == $new_url ) {
$new_url .= '/';
if ( false === strpos( $new_url, $absolute_home_url . '/' . $code . '/' ) ) {
//we have to check if we have a language slug in the current url
$current_lang_slug = "";
if ( false !== strpos( $new_url, $absolute_home_url . '/' . $current_language . '/' ) ) {
$current_lang_slug = '/' . $current_language;
if ( ! $this->settings[ 'urls' ][ 'directory_for_default_language' ] && $code == $default_language ) {
//in case the default language has no directory we have to treat it differently
$code = '';
} else {
$code = '/' . $code;
$new_url = str_replace( $absolute_home_url . $current_lang_slug, $absolute_home_url . $code, $new_url );
break;
case '2':
$is_https = strpos( $new_url, 'hidden link' ) === 0;
if ( $is_https ) {
preg_replace( '#^hidden link', 'hidden link', $new_url );
} // normalize protocol
$this->settings[ 'language_domains' ][ $default_language ] = $wpdb->get_var( "SELECT option_value FROM $wpdb->options WHERE option_name = 'home'");//rich bug fix
$new_url = str_replace( $absolute_home_url, $this->settings[ 'language_domains' ][ $code ], $new_url );
if ( $is_https ) {
} // normalize protocol (rev)
break;
case '3':
default:
// remove any previous value.
if ( strpos( $new_url, '?lang=' . $code . '&' ) !== false ) {
$new_url = str_replace( '?lang=' . $code . '&', '', $new_url );
} elseif ( strpos( $new_url, '?lang=' . $code . '/' ) !== false ) {
$new_url = str_replace( '?lang=' . $code . '/', '', $new_url );
} elseif ( strpos( $new_url, '?lang=' . $code ) !== false ) {
$new_url = str_replace( '?lang=' . $code, '', $new_url );
} elseif ( strpos( $new_url, '&lang=' . $code . '/' ) !== false ) {
$new_url = str_replace( '&lang=' . $code . '/', '', $new_url );
} elseif ( strpos( $new_url, '&lang=' . $code ) !== false ) {
$new_url = str_replace( '&lang=' . $code, '', $new_url );
if ( false === strpos( $new_url, '?' ) ) {
$new_url_glue = '?';
} else {
$new_url_glue = '&';
$new_url .= $new_url_glue . 'lang=' . $code;
wp_cache_set($cache_key, $new_url, $cache_group);
return $new_url;
function language_url( $code = null )
global $wpdb;
$abs_home = false;
if ( $code == $this->get_default_language() && $this->settings[ 'language_negotiation_type' ] == 2 ) {
$option_value = $wpdb->get_var( "SELECT option_value FROM $wpdb->options WHERE option_name = 'siteurl'");
if($option_value){
$abs_home = $option_value;
} else {
$abs_home = get_home_url();
if ( $this->settings[ 'language_negotiation_type' ] == 1 || $this->settings[ 'language_negotiation_type' ] == 2 ) {
$url = trailingslashit( $this->convert_url( $abs_home, $code ) );
} else {
$url = $this->convert_url( $abs_home, $code );
return $url;
function permalink_filter( $p, $pid )
global $wp_query;
if ( is_object( $pid ) ) {
$post_type = $pid->post_type;
$pid = $pid->ID;
} else {
$_post = get_post( $pid );
$post_type = $_post->post_type;
if ( !$this->is_translated_post_type( $post_type ) )
return $p;
if ( $pid == (int)get_option( 'page_on_front' ) ) {
return $p;
$element_lang_details = $this->get_element_language_details( $pid, 'post_' . $post_type );
$use_directory = $this->settings[ 'language_negotiation_type' ] == 1 && $this->settings[ 'urls' ][ 'directory_for_default_language' ];
if ( !empty( $element_lang_details ) && $element_lang_details->language_code && ( $default_language != $element_lang_details->language_code || $use_directory ) ) {
$p = $this->convert_url( $p, $element_lang_details->language_code );
} elseif ( isset( $_POST[ 'action' ] ) && $_POST[ 'action' ] == 'sample-permalink' ) { // check whether this is an autosaved draft
if ( !isset( $_SERVER[ 'HTTP_REFERER' ] ) ) {
$p = $this->convert_url( $p, $default_language );
} else {
$exp = explode( '?', $_SERVER[ "HTTP_REFERER" ] );
if ( isset( $exp[ 1 ] ) )
parse_str( $exp[ 1 ], $args );
if ( isset( $args[ 'lang' ] ) && $default_language != $args[ 'lang' ] ) {
$p = $this->convert_url( $p, $args[ 'lang' ] );
if ( isset( $wp_query ) && is_feed() ) {
$p = str_replace( "&lang=", "&lang=", $p );
return $p;
function category_permalink_filter( $p, $cat_id )
global $wpdb;
if ( isset( $this->icl_term_taxonomy_cache ) ) {
$term_cat_id = $this->icl_term_taxonomy_cache->get( 'category_' . $cat_id );
} else {
$term_cat_id = null;
if ( !$term_cat_id ) {
$term_cat_id = $wpdb->get_var( "SELECT term_taxonomy_id FROM {$wpdb->term_taxonomy} WHERE term_id={$cat_id} AND taxonomy='category'" );
$this->icl_term_taxonomy_cache->set( 'category_' . $cat_id, $term_cat_id );
$cat_id = $term_cat_id;
$element_lang_details = $this->get_element_language_details( $cat_id, 'tax_category' );
if ( $this->get_default_language() != $element_lang_details->language_code || $use_directory ) {
return $p;
function post_type_archive_link_filter( $link, $post_type )
if ( isset( $this->settings[ 'custom_posts_sync_option' ][ $post_type ] ) && $this->settings[ 'custom_posts_sync_option' ][ $post_type ] ) {
$link = $this->convert_url( $link );
$link = $this->adjust_cpt_in_url( $link, $post_type );
return $link;
function adjust_cpt_in_url($link, $post_type) {
global $sitepress_settings;
if ( function_exists('icl_t') && isset($sitepress_settings['st']['strings_language']) && $this->get_current_language() != $sitepress_settings['st']['strings_language']) {
if ( isset($this->settings['posts_slug_translation']['types'][$post_type]) && $this->settings['posts_slug_translation']['types'][$post_type] ) {
$post_type_object = get_post_type_object($post_type);
if (isset($post_type_object->rewrite)) {
$slug = $post_type_object->rewrite['slug'];
} else {
$slug = $post_type_object->name;
$translated_slug = icl_t('WordPress', 'URL slug: ' . $slug, $slug);
if (is_string($translated_slug)) {
$link = preg_replace("/". preg_quote($slug, "/") ."/", $translated_slug, $link, 1);
return $link;
function tax_permalink_filter( $p, $tag )
global $wpdb;
if ( is_object( $tag ) ) {
$tag_id = $tag->term_taxonomy_id;
$taxonomy = $tag->taxonomy;
} else {
if ( empty( $tag_id ) ) {
$tag_id = $wpdb->get_var( "SELECT term_taxonomy_id FROM {$wpdb->term_taxonomy} WHERE term_id={$tag} AND taxonomy='{$taxonomy}'" );
$this->icl_term_taxonomy_cache->set( $taxonomy . '_' . $tag, $tag_id );
$cached_permalink_key = $tag_id . '.' . $taxonomy;
$cached_permalink = wp_cache_get($cached_permalink_key, 'icl_tax_permalink_filter');
if($cached_permalink) {
return $cached_permalink;
$element_lang_details = $this->get_element_language_details( $tag_id, 'tax_' . $taxonomy );
if ( !empty( $element_lang_details ) && ( $this->get_default_language() != $element_lang_details->language_code || $use_directory ) ) {
wp_cache_set($cached_permalink_key, $p, 'icl_tax_permalink_filter');
return $p;
function get_comment_link_filter( $link )
// decode html characters since they are already encoded in the template for some reason
$link = html_entity_decode( $link );
return $link;
function attachment_link_filter( $link, $id )
//FIXME: check if we really need to call SitePress::convert_url in all other cases
if($this->get_setting( 'language_negotiation_type' ) == 2) {
$convert_url = $this->permalink_filter( $link, $id );
} else {
$convert_url = $this->convert_url( $link );
return $convert_url;
function get_ls_languages( $template_args = array() )
//Returns false if is admin and settings are corrupted
if(is_admin() && !SitePress::check_settings_integrity()) return false;
/** @var $wp_query WP_Query */
global $sitepress, $wpdb, $wp_query, $w_this_lang;
$cache_key_args = $template_args ? array_filter($template_args) : array('default');
$cache_key_args[] = $current_language;
$cache_key_args[] = $default_language;
$cache_key_args = array_filter($cache_key_args);
$cache_key = md5(json_encode($cache_key_args));
$cache_group = 'ls_languages';
$found = false;
$ls_languages = wp_cache_get($cache_key, $cache_group, $found);
if($found) return $ls_languages;
if ( is_null( $this->wp_query ) )
$this->set_wp_query();
// use original wp_query for this
// backup current $wp_query
if ( !isset( $wp_query ) )
return $this->get_active_languages();
$_wp_query_back = clone $wp_query;
unset( $wp_query );
global $wp_query; // make it global again after unset
$wp_query = clone $this->wp_query;
$w_active_languages = $this->get_active_languages();
$this_lang = $this->this_lang;
if ( $this_lang == 'all' ) {
$w_this_lang = array(
'code' => 'all', 'english_name' => 'All languages', 'display_name' => __( 'All languages', 'sitepress' )
} else {
$w_this_lang = $this->get_language_details( $this_lang );
if ( isset( $template_args[ 'skip_missing' ] ) ) {
//override default setting
$icl_lso_link_empty = !$template_args[ 'skip_missing' ];
} else {
$icl_lso_link_empty = $this->settings[ 'icl_lso_link_empty' ];
// 1. Determine translations
if ( is_category() ) {
$skip_empty = false;
$term_taxonomy_id_prepared = $wpdb->prepare( "SELECT term_taxonomy_id FROM {$wpdb->term_taxonomy} WHERE term_id=%d AND taxonomy=%s", array( get_query_var( 'cat' ), 'category' ) );
$term_taxonomy_id = $wpdb->get_var( $term_taxonomy_id_prepared );
$trid = $sitepress->get_element_trid( $term_taxonomy_id, 'tax_category' );
$translations = $this->get_element_translations( $trid, 'tax_category', $skip_empty );
} elseif ( is_tag() ) {
$term_taxonomy_id_prepared = $wpdb->prepare( "SELECT term_taxonomy_id FROM {$wpdb->term_taxonomy} WHERE term_id=%d AND taxonomy=%s", array( get_query_var( 'tag_id' ), 'post_tag' ) );
$trid = $sitepress->get_element_trid( $term_taxonomy_id, 'tax_post_tag' );
$translations = $this->get_element_translations( $trid, 'tax_post_tag', $skip_empty );
} elseif ( is_tax() ) {
$term_taxonomy_id_prepared = $wpdb->prepare( "SELECT term_taxonomy_id FROM {$wpdb->term_taxonomy} WHERE term_id=%d AND taxonomy=%s", array( $wp_query->get_queried_object_id(), get_query_var( 'taxonomy' ) ) );
if ( $this->is_translated_taxonomy( get_query_var( 'taxonomy' ) ) ) {
$trid = $this->get_element_trid( $term_taxonomy_id, 'tax_' . get_query_var( 'taxonomy' ) );
$translations = $this->get_element_translations( $trid, 'tax_' . get_query_var( 'taxonomy' ), $skip_empty );
} else {
$translations[ $this->get_current_language() ] = (object)array(
'translation_id' => 0,
'language_code' => $this->get_default_language(),
'original' => 1,
'name' => get_query_var( 'taxonomy' ),
'term_id' => $wp_query->get_queried_object_id()
} elseif ( is_archive() ) {
$translations = array();
} elseif ( is_attachment() ) { // Exception for attachments. Not translated.
$trid = $sitepress->get_element_trid($wp_query->get_queried_object_id(), 'post_attachment' );
$translations = $this->get_element_translations( $trid, 'post_attachment' );
} elseif (is_page() || ('page' == get_option( 'show_on_front' ) && ( isset( $this->wp_query->queried_object_id ) && $this->wp_query->queried_object_id == get_option( 'page_on_front' ) || ( isset( $this->wp_query->queried_object_id ) && $this->wp_query->queried_object_id == get_option( 'page_for_posts' )) ) ) ) {
$trid = $sitepress->get_element_trid($wp_query->get_queried_object_id(), 'post_page' );
$translations = $this->get_element_translations( $trid, 'post_page' );
} elseif ( is_singular() && !empty( $wp_query->posts ) ) {
$trid = $sitepress->get_element_trid($this->wp_query->post->ID, 'post_' . $wp_query->posts[ 0 ]->post_type);
$translations = $this->get_element_translations( $trid, 'post_' . $wp_query->posts[ 0 ]->post_type );
} else {
$wp_query->is_singular = false;
$wp_query->is_archive = false;
$wp_query->is_category = false;
$wp_query->is_404 = true;
// 2. determine url
foreach ( $w_active_languages as $k => $lang ) {
$skip_lang = false;
if ( is_singular() || ( !empty( $this->wp_query->queried_object_id ) && $this->wp_query->queried_object_id == get_option( 'page_for_posts' ) ) ) {
$this_lang_tmp = $this->this_lang;
$this->this_lang = $lang[ 'code' ];
$lang_page_on_front = get_option( 'page_on_front' );
$lang_page_for_posts = get_option( 'page_for_posts' );
if($lang_page_on_front && $lang[ 'code' ] != $default_language) {
$lang_page_on_front = icl_object_id($lang_page_on_front, 'page', false, $lang[ 'code' ]);
if($lang_page_for_posts && $lang[ 'code' ] != $default_language) {
$lang_page_for_posts = icl_object_id($lang_page_for_posts, 'page', false, $lang[ 'code' ]);
if ( 'page' == get_option( 'show_on_front' ) && !empty( $translations[ $lang[ 'code' ] ] ) && $translations[ $lang[ 'code' ] ]->element_id == $lang_page_on_front ) {
$lang[ 'translated_url' ] = $this->language_url( $lang[ 'code' ] );
} elseif ( 'page' == get_option( 'show_on_front' ) && !empty( $translations[ $lang[ 'code' ] ] ) && $translations[ $lang[ 'code' ] ]->element_id && $translations[ $lang[ 'code' ] ]->element_id == $lang_page_for_posts ) {
if ( $lang_page_for_posts ) {
$lang[ 'translated_url' ] = get_permalink( $lang_page_for_posts );
} else {
} else {
if ( !empty( $translations[ $lang[ 'code' ] ] ) && isset( $translations[ $lang[ 'code' ] ]->post_title ) ) {
$lang[ 'translated_url' ] = get_permalink( $translations[ $lang[ 'code' ] ]->element_id );
$lang[ 'missing' ] = 0;
} else {
if ( $icl_lso_link_empty ) {
if ( !empty( $template_args[ 'link_empty_to' ] ) ) {
$lang[ 'translated_url' ] = str_replace( '{%lang}', $lang[ 'code' ], $template_args[ 'link_empty_to' ] );
} else {
} else {
$skip_lang = true;
$lang[ 'missing' ] = 1;
$this->this_lang = $this_lang_tmp;
} elseif ( is_category() ) {
if ( isset( $translations[ $lang[ 'code' ] ] ) ) {
global $icl_adjust_id_url_filter_off; // force the category_link_adjust_id to not modify this
$icl_adjust_id_url_filter_off = true;
$lang[ 'translated_url' ] = get_category_link( $translations[ $lang[ 'code' ] ]->term_id );
$icl_adjust_id_url_filter_off = false; // restore default bahavior
} else {
} else {
} else {
// dont skip the currrent language
if ( $current_language != $lang[ 'code' ] ) {
$skip_lang = true;
$lang[ 'translated_url' ] = get_term_link( (int)$translations[ $lang[ 'code' ] ]->term_id, get_query_var( 'taxonomy' ) );
} else {
} else {
} else {
$skip_lang = true;
$lang[ 'translated_url' ] = get_tag_link( $translations[ $lang[ 'code' ] ]->term_id );
} else {
} else {
} else {
$skip_lang = true;
} elseif ( is_author() ) {
global $authordata, $wp_query;
if ( empty( $authordata ) ) {
$authordata = get_userdata( get_query_var( 'author' ) );
$post_type = get_query_var( 'post_type' ) ? get_query_var( 'post_type' ) : 'post';
if ( $wpdb->get_var( "SELECT COUNT(p.ID) FROM {$wpdb->posts} p
JOIN {$wpdb->prefix}icl_translations t ON p.ID=t.element_id AND t.element_type = 'post_{$post_type}'
WHERE p.post_author='{$authordata->ID}' AND post_type='{$post_type}' AND post_status='publish' AND language_code='{$lang['code']}'" )
remove_filter( 'home_url', array( $this, 'home_url' ), 1, 4 );
remove_filter( 'author_link', array( $this, 'author_link' ) );
$author_url = get_author_posts_url( $authordata->ID );
add_filter( 'author_link', array( $this, 'author_link' ) );
$lang[ 'translated_url' ] = $this->convert_url( $author_url, $lang[ 'code' ] );
} else {
} else {
} else {
$skip_lang = true;
} elseif ( is_archive() && !is_tag() ) {
global $icl_archive_url_filter_off;
$icl_archive_url_filter_off = true;
if ( $this->wp_query->is_year ) {
if ( isset( $this->wp_query->query_vars[ 'm' ] ) && !$this->wp_query->query_vars[ 'year' ] ) {
$this->wp_query->query_vars[ 'year' ] = substr( $this->wp_query->query_vars[ 'm' ], 0, 4 );
$lang[ 'translated_url' ] = $this->archive_url( get_year_link( $this->wp_query->query_vars[ 'year' ] ), $lang[ 'code' ] );
} elseif ( $this->wp_query->is_month ) {
$this->wp_query->query_vars[ 'monthnum' ] = substr( $this->wp_query->query_vars[ 'm' ], 4, 2 );
} else {
} else {
$lang[ 'translated_url' ] = $this->archive_url( get_month_link( $this->wp_query->query_vars[ 'year' ], $this->wp_query->query_vars[ 'monthnum' ] ), $lang[ 'code' ] );
} elseif ( $this->wp_query->is_day ) {
$this->wp_query->query_vars[ 'day' ] = substr( $this->wp_query->query_vars[ 'm' ], 6, 2 );
gmdate( 'Y', current_time( 'timestamp' ) ); //force wp_timezone_override_offset to be called
$lang[ 'translated_url' ] = $this->archive_url( get_day_link( $this->wp_query->query_vars[ 'year' ], $this->wp_query->query_vars[ 'monthnum' ], $this->wp_query->query_vars[ 'day' ] ), $lang[ 'code' ] );
} else if ( isset( $this->wp_query->query_vars[ 'post_type' ] ) ) {
do_action( '_icl_before_archive_url', $this->wp_query->query_vars[ 'post_type' ], $lang[ 'code' ] );
if ( $this->is_translated_post_type( $this->wp_query->query_vars[ 'post_type' ] ) && function_exists( 'get_post_type_archive_link' ) ) {
remove_filter( 'post_type_archive_link', array( $this, 'post_type_archive_link_filter' ), 10 );
$lang[ 'translated_url' ] = $this->convert_url( get_post_type_archive_link( $this->wp_query->query_vars[ 'post_type' ] ), $lang[ 'code' ] );
} else {
if($k != $this->get_default_language()){
$skip_lang = true;
unset( $w_active_languages[ $k ] );
do_action( '_icl_after_archive_url', $this->wp_query->query_vars[ 'post_type' ], $lang[ 'code' ] );
add_filter( 'post_type_archive_link', array( $this, 'post_type_archive_link_filter' ), 10, 2 );
$icl_archive_url_filter_off = false;
} elseif ( is_search() ) {
$url_glue = strpos( $this->language_url( $lang[ 'code' ] ), '?' ) === false ? '?' : '&';
$lang[ 'translated_url' ] = $this->language_url( $lang[ 'code' ] ) . $url_glue . 's=' . urlencode( $wp_query->query[ 's' ] );
} else {
global $icl_language_switcher_preview;
if ( $icl_lso_link_empty || is_home() || is_404() || ( 'page' == get_option( 'show_on_front' ) && ( $this->wp_query->queried_object_id == get_option( 'page_on_front' ) || $this->wp_query->queried_object_id == get_option( 'page_for_posts' ) ) ) || $icl_language_switcher_preview || $this->is_root_page() ) {
$skip_lang = false;
} else {
$skip_lang = true;
if ( !$skip_lang ) {
$w_active_languages[ $k ] = $lang;
} else {
// 3.
foreach ( $w_active_languages as $k => $v ) {
$lang_code = $w_active_languages[ $k ][ 'language_code' ] = $w_active_languages[ $k ][ 'code' ];
unset( $w_active_languages[ $k ][ 'code' ] );
$native_name = $this->get_display_language_name( $lang_code, $lang_code );
if ( !$native_name )
$native_name = $w_active_languages[ $k ][ 'english_name' ];
$w_active_languages[ $k ][ 'native_name' ] = $native_name;
$translated_name = $this->get_display_language_name( $lang_code, $current_language );
if ( !$translated_name )
$translated_name = $w_active_languages[ $k ][ 'english_name' ];
$w_active_languages[ $k ][ 'translated_name' ] = $translated_name;
unset( $w_active_languages[ $k ][ 'display_name' ] );
unset( $w_active_languages[ $k ][ 'english_name' ] );
if ( isset( $w_active_languages[ $k ][ 'translated_url' ] ) ) {
$w_active_languages[ $k ][ 'url' ] = $w_active_languages[ $k ][ 'translated_url' ];
unset( $w_active_languages[ $k ][ 'translated_url' ] );
} else {
$w_active_languages[ $k ][ 'url' ] = $this->language_url( $k );
$flag = $this->get_flag( $lang_code );
if ( $flag->from_template ) {
$flag_url = $wp_upload_dir[ 'baseurl' ] . '/flags/' . $flag->flag;
} else {
$flag_url = ICL_PLUGIN_URL . '/res/flags/' . $flag->flag;
$w_active_languages[ $k ][ 'country_flag_url' ] = $flag_url;
$w_active_languages[ $k ][ 'active' ] = $current_language == $lang_code ? '1' : 0;;
// 4. pass GET parameters
$parameters_copied = apply_filters( 'icl_lang_sel_copy_parameters', array_map( 'trim', explode( ',', $this->settings[ 'icl_lang_sel_copy_parameters' ] ) ) );
if ( $parameters_copied ) {
foreach ( $_GET as $k => $v ) {
if ( in_array( $k, $parameters_copied ) ) {
$gets_passed[ $k ] = $v;
if ( !empty( $gets_passed ) ) {
$gets_passed = http_build_query( $gets_passed );
foreach ( $w_active_languages as $code => $al ) {
if ( empty( $al[ 'missing' ] ) ) {
$glue = false !== strpos( $w_active_languages[ $code ][ 'url' ], '?' ) ? '&' : '?';
$w_active_languages[ $code ][ 'url' ] .= $glue . $gets_passed;
// restore current $wp_query
unset( $wp_query );
$wp_query = clone $_wp_query_back;
unset( $_wp_query_back );
$w_active_languages = apply_filters( 'icl_ls_languages', $w_active_languages );
$w_active_languages = $this->sort_ls_languages( $w_active_languages, $template_args );
// Change the url, in case languages in subdomains are set.
if ( $this->settings[ 'language_negotiation_type' ] == 2 ) {
foreach ( $w_active_languages as $lang => $element ) {
$w_active_languages[ $lang ][ 'url' ] = $this->convert_url( $element[ 'url' ], $lang );
wp_reset_query();
wp_cache_set($cache_key, $w_active_languages, $cache_group);
return $w_active_languages;
function sort_ls_languages( $w_active_languages, $template_args )
// sort languages according to parameters
$orderby = isset( $template_args[ 'orderby' ] ) ? $template_args[ 'orderby' ] : 'custom';
$order = isset( $template_args[ 'order' ] ) ? $template_args[ 'order' ] : 'asc';
$comp = $order == 'asc' ? '>' : '<';
switch ( $orderby ) {
case 'id':
uasort( $w_active_languages, create_function( '$a,$b', 'return $a[\'id\'] ' . $comp . ' $b[\'id\'];' ) );
break;
case 'code':
ksort( $w_active_languages );
if ( $order == 'desc' ) {
$w_active_languages = array_reverse( $w_active_languages );
break;
case 'name':
uasort( $w_active_languages, create_function( '$a,$b', 'return $a[\'translated_name\'] ' . $comp . ' $b[\'translated_name\'];' ) );
break;
case 'custom':
default:
$w_active_languages = $this->order_languages( $w_active_languages );
function get_display_language_name( $lang_code, $display_code )
global $wpdb;
if ( isset( $this->icl_language_name_cache ) ) {
$translated_name = $this->icl_language_name_cache->get( $lang_code . $display_code );
} else {
$translated_name = null;
if ( !$translated_name ) {
$display_code = $display_code == 'all' ? $this->get_admin_language() : $display_code;
$translated_name = $wpdb->get_var( "SELECT name FROM {$wpdb->prefix}icl_languages_translations WHERE language_code='{$lang_code}' AND display_language_code='{$display_code}'" );
$this->icl_language_name_cache->set( $lang_code . $display_code, $translated_name );
return $translated_name;
function get_flag( $lang_code )
global $wpdb;
if ( isset( $this->icl_flag_cache ) ) {
$flag = $this->icl_flag_cache->get( $lang_code );
} else {
$flag = null;
if ( !$flag ) {
$flag = $wpdb->get_row( "SELECT flag, from_template FROM {$wpdb->prefix}icl_flags WHERE lang_code='{$lang_code}'" );
$this->icl_flag_cache->set( $lang_code, $flag );
return $flag;
function get_flag_url( $code )
$flag = $this->get_flag( $code );
} else {
return $flag_url;
function set_up_language_selector()
// language selector
// load js and style for js language selector
if (isset($this->settings[ 'icl_lang_sel_type' ]) && $this->settings[ 'icl_lang_sel_type' ] == 'dropdown' && ( !is_admin() || ( isset( $_GET[ 'page' ] ) && $_GET[ 'page' ] == ICL_PLUGIN_FOLDER . '/menu/languages.php' ) ) ) {
if ( $this->settings[ 'icl_lang_sel_stype' ] == 'mobile-auto' ) {
include ICL_PLUGIN_PATH . '/lib/mobile-detect.php';
$WPML_Mobile_Detect = new WPML_Mobile_Detect;
$this->is_mobile = $WPML_Mobile_Detect->isMobile();
$this->is_tablet = $WPML_Mobile_Detect->isTablet();
if ( ( $this->settings[ 'icl_lang_sel_stype' ] == 'mobile-auto' && ( !empty( $this->is_mobile ) || !empty( $this->is_tablet ) ) ) || $this->settings[ 'icl_lang_sel_stype' ] == 'mobile'
if(!defined('ICL_DONT_LOAD_LANGUAGES_JS') || !ICL_DONT_LOAD_LANGUAGES_JS) {
wp_enqueue_script( 'language-selector', ICL_PLUGIN_URL . '/res/js/language-selector.js', false, ICL_SITEPRESS_VERSION, true );
if(!defined('ICL_DONT_LOAD_LANGUAGE_SELECTOR_CSS') || !ICL_DONT_LOAD_LANGUAGE_SELECTOR_CSS) {
wp_enqueue_style( 'language-selector', ICL_PLUGIN_URL . '/res/css/language-selector-click.css', ICL_SITEPRESS_VERSION );
function get_desktop_language_selector() {
$active_languages = $this->get_ls_languages();
if ( $active_languages ) {
* @var $main_language bool|string
* @used_by menu/language-selector.php
foreach ( $active_languages as $k => $al ) {
if ( $al[ 'active' ] == 1 ) {
unset( $active_languages[ $k ] );
break;
} else {
return '';
global $w_this_lang;
if($w_this_lang['code']=='all'){
$main_language['native_name'] = __('All languages', 'sitepress');
$main_language['translated_name'] = $main_language['native_name'];
$main_language['language_code'] = 'all';
if(empty($main_language)){
$main_language['native_name'] = $w_this_lang['display_name'];
$main_language['translated_name'] = $w_this_lang['display_name'];
$main_language['language_code'] = $w_this_lang['code'];
$style_display_none_icl_lang_sel_type = $this->settings['icl_lang_sel_type'] == 'list' ? ' style="display:none;"' : '';
$class_icl_rtl = $this->is_rtl() ? 'class="icl_rtl"' : '';
$language_selector = '<div id="lang_sel" '.$style_display_none_icl_lang_sel_type.' '.$class_icl_rtl.' >
  • <a href="#" class="lang_sel_sel icl-'.$w_this_lang['code'].'">';
    if ( $this->settings[ 'icl_lso_flags' ] || $icl_language_switcher_preview ) {
    $flag = $this->get_flag($w_this_lang['code']);
    if ( isset( $flag->from_template ) && $flag->from_template && isset( $flag->flag ) ) {
    $main_language['country_flag_url'] = $wp_upload_dir['baseurl'] . '/flags/' . $flag->flag;
    }else{
    if(isset($flag->flag)){
    $main_language['country_flag_url'] = ICL_PLUGIN_URL . '/res/flags/'.$flag->flag;
    } else {
    $main_language['country_flag_url'] = ICL_PLUGIN_URL . '/res/img/icon16.png';
    $language_selector .= '<img ' . ( !$this->settings['icl_lso_flags'] ? 'style="display:none"' : '' )
    . ' class="iclflag" '
    . 'src="'.$main_language['country_flag_url'].'" '
    . 'alt="'.$main_language['language_code'].'" '
    . 'title="'. ($this->settings['icl_lso_display_lang'] ? esc_attr($main_language['translated_name']) : esc_attr($main_language['native_name']) ) .'" />
    if($icl_language_switcher_preview){
    $lang_native = $main_language['native_name'];
    if($this->settings['icl_lso_native_lang']){
    $lang_native_hidden = false;
    }else{
    $lang_native_hidden = true;
    $lang_translated = $main_language['translated_name'];
    if($this->settings['icl_lso_display_lang']){
    $lang_translated_hidden = false;
    }else{
    $lang_translated_hidden = true;
    }else{
    }else{
    $lang_native = false;
    }else{
    $lang_translated = false;
    $language_selector .= icl_disp_language($lang_native, $lang_translated, $lang_native_hidden, $lang_translated_hidden);
    if(!isset($ie_ver) || $ie_ver > 6):
    $language_selector .= '</a> ';
    endif;
    if(!empty($active_languages)) {
    if(isset($ie_ver) && $ie_ver <= 6):
    $language_selector .= '<table><tr><td>';
    endif;
      $active_languages_ordered = $this->order_languages($active_languages);
      foreach($active_languages_ordered as $lang) {
      $language_selector .= '<li class="icl-'.$lang['language_code'].'">
      <a href="'.apply_filters('WPML_filter_link', $lang['url'], $lang).'">';
      if( $this->settings['icl_lso_flags'] || $icl_language_switcher_preview):
      $language_selector .= '<img '. ( !$this->settings['icl_lso_flags'] ? 'style="display:none"' : '' )
      . 'src="'.$lang['country_flag_url'].'" '
      . 'alt="'.$lang['language_code'].'" '
      . 'title="'. ($this->settings['icl_lso_display_lang'] ? esc_attr($lang['translated_name']) : esc_attr($lang['native_name']) ) .'" /> ';
      endif;
      $lang_native = $lang['native_name'];
      }else{
      $lang_translated = $lang['translated_name'];
      }else{
      }else{
      }else{
      }else{
$language_selector .= '</td></tr></table></a>';
endif;
</div>';
return $language_selector;
function get_mobile_language_selector() {
$languages = $this->get_ls_languages();
foreach($languages as $code => $language){
if($code == $this->get_current_language()){
$current_language = $language;
unset($languages[$code]);
break;
$user_agent = $_SERVER['HTTP_USER_AGENT'];
if(preg_match('#MSIE ([0-9]+)\.[0-9]#',$user_agent,$matches)){
$ie_ver = $matches[1];
$language_selector_mobile = '<div id="lang_sel_click" '
. 'onclick="wpml_language_selector_click.toggle();" '
. 'class="lang_sel_click'.($this->is_rtl() ? 'icl_rtl' : '').'" >'
    $language_selector_mobile .= '<a href="javascript:;" class="lang_sel_sel icl-'.$current_language['language_code'].'">';
    if( $this->settings['icl_lso_flags'] ):
    $language_selector_mobile .= '<img class="iclflag" '
    . 'src="'.$current_language['country_flag_url'].'" '
    . 'alt="'.$current_language['language_code'].'" '
    . 'title="'. ($this->settings['icl_lso_display_lang'] ? esc_attr($current_language['translated_name']) : esc_attr($current_language['native_name']) ) .'" />';
    endif;
    if($this->settings['icl_lso_display_lang'] || $this->settings['icl_lso_native_lang']){
    $language_selector_mobile .= $current_language['native_name'];
    $language_selector_mobile .= '</a>';
    endif;
    $language_selector_mobile .= '<table><tr><td>';
    endif;
      foreach($languages as $code => $language) {
      $language_selector_mobile .= '<li class="icl-'.$language['language_code'].'">'
      . '<a rel="alternate" href="'.apply_filters('WPML_filter_link', $language['url'], $language).'">';
      . 'src="'.$language['country_flag_url'].'" '
      . 'alt="'.$language['language_code'].'" '
      . 'title="'.($this->settings['icl_lso_display_lang'] ? esc_attr($language['translated_name']) : esc_attr($language['native_name']) ).'" /> ';
      endif;
      if($this->settings['icl_lso_display_lang'] && $this->settings['icl_lso_native_lang']){
      $language_name = '<span class="icl_lang_sel_native">' . $language['native_name'] .'</span>
      <span class="icl_lang_sel_translated">(' . $language['translated_name'] . ')</span>';
      }elseif($this->settings['icl_lso_display_lang']){
      $language_name = '<span class="icl_lang_sel_translated">' . $language['translated_name'] . '</span>';
      }elseif($this->settings['icl_lso_native_lang']){
      $language_name = '<span class="icl_lang_sel_native">' . $language['native_name'] .'</span>';
      }else{
      $language_name = '';
      $language_selector_mobile .= $language_name;
$language_selector_mobile .= '</td></tr></table></a>';
endif;
$language_selector_mobile .= ''
. '</div>';
return $language_selector_mobile;
function get_language_selector() {
// Mobile or auto
$is_mobile = $this->settings[ 'icl_lang_sel_stype' ] == 'mobile' || ( $this->settings[ 'icl_lang_sel_stype' ] == 'mobile-auto' && (!empty( $this->is_tablet ) || !empty( $this->is_mobile ) ) );
if ( $this->settings[ 'icl_lang_sel_type' ] == 'dropdown' && ( $is_mobile )
return $this->get_mobile_language_selector();;
} else {
if ( $this->settings[ 'icl_lang_sel_type' ] == 'list' || $icl_language_switcher_preview ) {
global $icl_language_switcher;
$icl_language_switcher->widget_list();
if ( ! $icl_language_switcher_preview ) {
return '';
return $this->get_desktop_language_selector();
return '';
function language_selector()
echo $this->get_language_selector();
function have_icl_translator( $source, $target )
// returns true if we have ICL translators for the language pair
if ( isset( $this->settings[ 'icl_lang_status' ] ) ) {
foreach ( $this->settings[ 'icl_lang_status' ] as $lang ) {
if ( $lang[ 'from' ] == $source && $lang[ 'to' ] == $target ) {
return $lang[ 'have_translators' ];
return false;
public function add_extra_debug_info( $extra_debug ) {
$extra_debug[ 'WMPL' ] = $this->get_settings();
return $extra_debug;
function get_default_categories()
$default_categories_all = $this->settings[ 'default_categories' ];
$active_languages_codes = false;
foreach ( $this->active_languages as $l ) {
$active_languages_codes[ ] = $l[ 'code' ];
$default_categories = array();
if ( is_array( $default_categories_all ) && is_array( $active_languages_codes ) ) {
foreach ( $default_categories_all as $c => $v ) {
if ( in_array( $c, $active_languages_codes ) ) {
$default_categories[ $c ] = $v;
return $default_categories;
function set_default_categories( $def_cat )
$this->settings[ 'default_categories' ] = $def_cat;
$this->save_settings();
function pre_option_default_category( $setting )
global $wpdb;
if ( isset( $_POST[ 'icl_post_language' ] ) && $_POST[ 'icl_post_language' ] || ( isset( $_GET[ 'lang' ] ) && $_GET[ 'lang' ] != 'all' ) ) {
$lang = isset( $_POST[ 'icl_post_language' ] ) && $_POST[ 'icl_post_language' ] ? $_POST[ 'icl_post_language' ] : $_GET[ 'lang' ];
$ttid = @intval( $this->settings[ 'default_categories' ][ $lang ] );
return $tid = $wpdb->get_var( "SELECT term_id FROM {$wpdb->term_taxonomy} WHERE term_taxonomy_id={$ttid} AND taxonomy='category'" );
return false;
function update_option_default_category( $oldvalue, $new_value )
global $wpdb;
$new_value = $wpdb->get_var( $wpdb->prepare( "SELECT term_taxonomy_id FROM {$wpdb->term_taxonomy} WHERE taxonomy='category' AND term_id=%d", $new_value ) );
$translations = $this->get_element_translations( $this->get_element_trid( $new_value, 'tax_category' ) );
if ( !empty( $translations ) ) {
foreach ( $translations as $t ) {
$icl_settings[ 'default_categories' ][ $t->language_code ] = $t->element_id;
if ( isset( $icl_settings ) ) {
$this->save_settings( $icl_settings );
function get_term_adjust_id( $term ) {
//TODO: To remove? I couldn't find a single place where this is used, since $term->term_id == $translated_id. Testing always returning the passed value.
// comment from Konrad: don't remove this as it is still used by nav menus
if ( $icl_adjust_id_url_filter_off ) {
return $term;
} // special cases when we need the category in a different language
// exception: don't filter when called from get_permalink. When category parents are determined
$debug_backtrace = $this->get_backtrace( 7 ); //Limit to first 7 stack frames, since 6 is the highest index we use
if ( isset( $debug_backtrace[ 5 ][ 'function' ] ) &&
$debug_backtrace[ 5 ][ 'function' ] == 'get_category_parents' ||
isset( $debug_backtrace[ 6 ][ 'function' ] ) &&
$debug_backtrace[ 6 ][ 'function' ] == 'get_permalink' ||
isset( $debug_backtrace[ 4 ][ 'function' ] ) &&
$debug_backtrace[ 4 ][ 'function' ] == 'get_permalink' // WP 3.5
return $term;
$translated_id = icl_object_id( $term->term_id, $term->taxonomy, true );
$cache_key = $term->taxonomy . ':' . $translated_id;
$cache_group = 'icl_get_term_adjust_id';
$cached_term = wp_cache_get( $cache_key, $cache_group, false, $cache_found );
if ( $cache_found ) {
return $cached_term;
if ( $translated_id != $term->term_id ) {
//$translated_id = $wpdb->get_var("SELECT term_id FROM {$wpdb->term_taxonomy} WHERE term_taxonomy_id='{$translated_id}'");
remove_filter( 'get_term', array( $this, 'get_term_adjust_id' ), 1 );
$t_term = get_term( $translated_id, $term->taxonomy );
if ( !is_wp_error( $t_term ) ) {
$term = $t_term;
add_filter( 'get_term', array( $this, 'get_term_adjust_id' ), 1, 1 );
wp_cache_set( $cache_key, $term, $cache_group );
return $term;
function set_term_translation( $original_term, $translation_id, $type, $lang, $original_lang )
global $wpdb;
if ( $original_term ) {
$trid = $this->get_element_trid( $original_term->term_taxonomy_id, 'tax_' . $type );
$this->set_element_language_details( $translation_id, 'tax_' . $type, $trid, $lang, $original_lang );
} else {
// Original has been deleled.
// we need to set the language of the new term.
$wpdb->update( $wpdb->prefix . 'icl_translations', array( 'language_code' => $lang ), array( 'element_type' => 'tax_' . $type, 'element_id' => $translation_id ) );
function wp_list_pages_adjust_ids( $out, $args )
static $__run_once = false; // only run for calls that have 'include' as an argument. ant only run once.
if ( $args[ 'include' ] && !$__run_once && $this->get_current_language() != $this->get_default_language() ) {
$__run_once = true;
$include = array_map( 'trim', explode( ',', $args[ 'include' ] ) );
$tr_include = array();
foreach ( $include as $i ) {
$t = icl_object_id( $i, 'page', true );
if ( $t ) {
$tr_include[ ] = $t;
$args[ 'include' ] = join( ',', $tr_include );
$out = wp_list_pages( $args );
return $out;
function get_terms_adjust_ids( $terms, $taxonomies, $args )
$__run_once = true;
if ( is_array( $args[ 'include' ] ) ) {
$include = $args[ 'include' ];
} else {
$t = icl_object_id( $i, $taxonomies[ 0 ], true );
if ( $t ) {
$terms = get_terms( $taxonomies, $args );
return $terms;
function get_pages_adjust_ids( $pages, $args )
if ($pages && $this->get_current_language() != $this->get_default_language() ) {
$cache_key_args = md5(json_encode(wp_list_pluck($pages, 'ID')));
$cache_key_args .= ":";
$cache_key_args .= md5(json_encode($args));
$cache_key = $cache_key_args;
$cache_group = 'get_pages_adjust_ids';
$found = false;
$cached_result = wp_cache_get($cache_key, $cache_group, false, $found);
if(!$found) {
$args_updated = false;
if ( $args[ 'include' ] ) {
if ( $t ) {
$args_updated = true;
if ( $args[ 'exclude' ] ) {
$exclude = array_map( 'trim', explode( ',', $args[ 'exclude' ] ) );
$tr_exclude = array();
foreach ( $exclude as $i ) {
if ( $t ) {
$tr_exclude[ ] = $t;
$args[ 'exclude' ] = join( ',', $tr_exclude );
if ( $args[ 'child_of' ] ) {
$args[ 'child_of' ] = icl_object_id( $args[ 'child_of' ], 'page', true );
if ( $args_updated ) {
remove_filter( 'get_pages', array( $this, 'get_pages_adjust_ids' ), 1 );
$pages = get_pages( $args );
add_filter( 'get_pages', array( $this, 'get_pages_adjust_ids' ), 1, 2 );
wp_cache_set($cache_key, $pages, $cache_group);
} else {
$pages = $cached_result;
return $pages;
function category_link_adjust_id( $catlink, $cat_id )
global $icl_adjust_id_url_filter_off, $wpdb;
return $catlink; // special cases when we need the categiry in a different language
$translated_id = icl_object_id( $cat_id, 'category', true );
if ( $translated_id && $translated_id != $cat_id ) {
$translated_id = $wpdb->get_var( "SELECT term_id FROM {$wpdb->term_taxonomy} WHERE term_taxonomy_id='{$translated_id}'" );
remove_filter( 'category_link', array( $this, 'category_link_adjust_id' ), 1 );
$catlink = get_category_link( $translated_id, 'category' );
add_filter( 'category_link', array( $this, 'category_link_adjust_id' ), 1, 2 );
return $catlink;
// adjacent posts links
function get_adjacent_post_join( $join )
global $wpdb;
$post_type = get_query_var( 'post_type' );
$cache_key = md5( json_encode( array( $post_type, $join ) ) );
$cache_group = 'adjacent_post_join';
$temp_join = wp_cache_get( $cache_key, $cache_group );
if ( $temp_join ) {
return $temp_join;
if ( !$post_type ) {
$post_type = 'post';
if ( $this->is_translated_post_type( $post_type ) ) {
$join .= " JOIN {$wpdb->prefix}icl_translations t ON t.element_id = p.ID AND t.element_type = 'post_{$post_type}'";
wp_cache_set( $cache_key, $join, $cache_group );
return $join;
function get_adjacent_post_where( $where )
$cache_key = md5(json_encode( array( $post_type, $where ) ) );
$cache_group = 'adjacent_post_where';
$temp_where = wp_cache_get( $cache_key, $cache_group );
if ( $temp_where ) {
return $temp_where;
$where .= " AND language_code = '" . esc_sql( $this->this_lang ) . "'";
wp_cache_set( $cache_key, $where, $cache_group );
return $where;
// feeds links
function feed_link( $out )
return $this->convert_url( $out );
// commenting links
function post_comments_feed_link( $out )
$out = preg_replace( '@(\?|&)lang=([^/]+)/feed/@i', 'feed/$1lang=$2', $out );
return $out;
//return $this->convert_url($out);
function trackback_url( $out )
function user_trailingslashit( $string, $type_of_url )
// fixes comment link for when the comments list pagination is enabled
if ( $type_of_url == 'comment' ) {
$string = preg_replace( '@(.*)/\?lang=([a-z-]+)/(.*)@is', '$1/$3?lang=$2', $string );
return $string;
// archives links
function getarchives_join( $join )
global $wpdb;
$join .= " JOIN {$wpdb->prefix}icl_translations t ON t.element_id = {$wpdb->posts}.ID AND t.element_type='post_post'";
return $join;
function getarchives_where( $where )
return $where;
function archives_link( $out )
if ( !$icl_archive_url_filter_off ) {
$out = $this->archive_url( $out, $this->this_lang );
return $out;
function archive_url( $url, $lang )
$url = $this->convert_url( $url, $lang );
return $url;
function author_link( $url )
return preg_replace( '#^hidden link', 'hidden link', $url );
function pre_option_home( $setting = false )
if ( !defined( 'TEMPLATEPATH' ) )
return $setting;
$template_real_path = realpath( TEMPLATEPATH );
$debug_backtrace = $this->get_backtrace( 7 ); //Ignore objects and limit to first 7 stack frames, since 6 is the highest index we use
$inc_methods = array( 'include', 'include_once', 'require', 'require_once' );
if ( isset( $debug_backtrace[ 4 ] ) && $debug_backtrace[ 4 ][ 'function' ] == 'get_bloginfo' && isset( $debug_backtrace[ 5 ] ) && $debug_backtrace[ 5 ][ 'function' ] == 'bloginfo' ) {
// case of bloginfo
$is_template_file = false !== strpos( $debug_backtrace[ 5 ][ 'file' ], $template_real_path );
$is_direct_call = in_array( $debug_backtrace[ 6 ][ 'function' ], $inc_methods ) || ( false !== strpos( $debug_backtrace[ 6 ][ 'file' ], $template_real_path ) );
} elseif ( isset( $debug_backtrace[ 4 ] ) && $debug_backtrace[ '4' ][ 'function' ] == 'get_bloginfo' ) {
// case of get_bloginfo
$is_template_file = false !== strpos( $debug_backtrace[ 4 ][ 'file' ], $template_real_path );
$is_direct_call = in_array( $debug_backtrace[ 5 ][ 'function' ], $inc_methods ) || ( false !== strpos( $debug_backtrace[ 5 ][ 'file' ], $template_real_path ) );
} elseif ( isset( $debug_backtrace[ 4 ] ) && $debug_backtrace[ '4' ][ 'function' ] == 'get_settings' ) {
// case of get_settings
} else {
// case of get_option
$is_template_file = isset( $debug_backtrace[ 3 ][ 'file' ] ) && ( false !== strpos( $debug_backtrace[ 3 ][ 'file' ], $template_real_path ) );
$is_direct_call = isset( $debug_backtrace[ 4 ] ) && in_array( $debug_backtrace[ 4 ][ 'function' ], $inc_methods ) || ( isset( $debug_backtrace[ 4 ][ 'file' ] ) && false !== strpos( $debug_backtrace[ 4 ][ 'file' ], $template_real_path ) );
//if($dbbt[3]['file'] == @realpath(TEMPLATEPATH . '/header.php')){
if ( $is_template_file && $is_direct_call ) {
$ret = $this->language_url( $this->this_lang );
} else {
$ret = $setting;
return $ret;
function query_vars( $public_query_vars )
$public_query_vars[ ] = 'lang';
global $wp_query;
$wp_query->query_vars[ 'lang' ] = $this->this_lang;
return $public_query_vars;
function parse_query( $q )
global $wp_query, $wpdb;
//if($q == $wp_query) return; // not touching the WP query
if ( is_admin() ) {
return $q;
$current_language = $this->get_current_language();
$default_language = $this->get_default_language();
if ( $current_language != $default_language ) {
$cat_array = array();
// cat
if ( isset( $q->query_vars[ 'cat' ] ) && !empty( $q->query_vars[ 'cat' ] ) ) {
$cat_array = array_map( 'intval', array_map( 'trim', explode( ',', $q->query_vars[ 'cat' ] ) ) );
// category_name
if ( isset( $q->query_vars[ 'category_name' ] ) && !empty( $q->query_vars[ 'category_name' ] ) ) {
$categories = explode(",", $q->query_vars[ 'category_name' ] );
foreach ($categories as $category) {
$category = trim($category);
if ($category == "") { // it happens for category_name = "some-cat,some-cat-2,", with comma at end
continue;
$cat = get_term_by( 'slug', preg_replace( '#((.*)/)#', '', $category), 'category' );
if ( !$cat ) {
$cat = get_term_by( 'name', $category, 'category' );
if ( isset($cat) && is_object($cat) && $cat->term_id ) {
$cat_array[] = $cat->term_id;
if (empty($cat_array)) {
$q->query_vars[ 'p' ] = -1;
// category_and
if ( isset( $q->query_vars[ 'category__and' ] ) && !empty( $q->query_vars[ 'category__and' ] ) ) {
$cat_array = $q->query_vars[ 'category__and' ];
// category_in
if ( isset( $q->query_vars[ 'category__in' ] ) && !empty( $q->query_vars[ 'category__in' ] ) ) {
$cat_array = array_unique( array_merge( $cat_array, array_map( 'intval', $q->query_vars[ 'category__in' ] ) ) );
// category__not_in
if ( isset( $q->query_vars[ 'category__not_in' ] ) && !empty( $q->query_vars[ 'category__not_in' ] ) ) {
$__cats = array_map( create_function( '$a', 'return -1*intval($a);' ), $q->query_vars[ 'category__not_in' ] );
$cat_array = array_unique( array_merge( $cat_array, $__cats ) );
if ( !empty( $cat_array ) ) {
$translated_ids = array();
foreach ( $cat_array as $c ) {
if ( intval( $c ) < 0 ) {
$sign = -1;
} else {
$sign = 1;
$translated_ids[ ] = $sign * intval( icl_object_id( abs( $c ), 'category', true ) );
//cat
$q->query_vars[ 'cat' ] = join( ',', $translated_ids );
// category_name
$_ctmp = get_term_by( 'id', $translated_ids[ 0 ], 'category' );
$q->query_vars[ 'category_name' ] = $_ctmp->slug;
// category__and
$q->query_vars[ 'category__and' ] = $translated_ids;
// category__in
$q->query_vars[ 'category__in' ] = array_filter( $translated_ids, create_function( '$a', 'return $a>0;' ) );
// category__not_in
$q->query_vars[ 'category__not_in' ] = array_filter( $translated_ids, create_function( '$a', 'return $a<0;' ) );
// TAGS
$tag_array = array();
// tag
$tag_glue = '';
if ( isset( $q->query_vars[ 'tag' ] ) && !empty( $q->query_vars[ 'tag' ] ) ) {
if ( false !== strpos( $q->query_vars[ 'tag' ], ' ' ) ) {
$tag_glue = '+';
$exp = explode( ' ', $q->query_vars[ 'tag' ] );
} else {
$tag_glue = ',';
$exp = explode( ',', $q->query_vars[ 'tag' ] );
foreach ( $exp as $e ) {
$tag_array[ ] = $wpdb->get_var( $wpdb->prepare( "SELECT x.term_id FROM $wpdb->terms t
JOIN $wpdb->term_taxonomy x ON t.term_id=x.term_id WHERE x.taxonomy='post_tag' AND t.slug=%s", $e ) );
$_tmp = array_unique( $tag_array );
if ( count( $_tmp ) == 1 && empty( $_tmp[ 0 ] ) ) {
// tag_id
if ( isset( $q->query_vars[ 'tag_id' ] ) && !empty( $q->query_vars[ 'tag_id' ] ) ) {
$tag_array = array_map( 'trim', explode( ',', $q->query_vars[ 'tag_id' ] ) );
// tag__and
if ( isset( $q->query_vars[ 'tag__and' ] ) && !empty( $q->query_vars[ 'tag__and' ] ) ) {
$tag_array = $q->query_vars[ 'tag__and' ];
// tag__in
if ( isset( $q->query_vars[ 'tag__in' ] ) && !empty( $q->query_vars[ 'tag__in' ] ) ) {
$tag_array = $q->query_vars[ 'tag__in' ];
// tag__not_in
if ( isset( $q->query_vars[ 'tag__not_in' ] ) && !empty( $q->query_vars[ 'tag__not_in' ] ) ) {
$tag_array = $q->query_vars[ 'tag__not_in' ];
// tag_slug__in
if ( isset( $q->query_vars[ 'tag_slug__in' ] ) && !empty( $q->query_vars[ 'tag_slug__in' ] ) ) {
foreach ( $q->query_vars[ 'tag_slug__in' ] as $t ) {
if ( $tg = $wpdb->get_var( $wpdb->prepare( "
WHERE x.taxonomy='post_tag' AND t.slug=%s", $t ) )
$tag_array[ ] = $tg;
// tag_slug__and
if ( isset( $q->query_vars[ 'tag_slug__and' ] ) && !empty( $q->query_vars[ 'tag_slug__and' ] ) ) {
foreach ( $q->query_vars[ 'tag_slug__and' ] as $t ) {
JOIN $wpdb->term_taxonomy x ON t.term_id=x.term_id WHERE x.taxonomy='post_tag' AND t.slug=%s", $t ) );
if ( !empty( $tag_array ) ) {
foreach ( $tag_array as $c ) {
$sign = -1;
} else {
$sign = 1;
$_tid = intval( icl_object_id( abs( $c ), 'post_tag', true ) );
$translated_ids[ ] = $sign * $_tid;
if ( !empty( $translated_ids ) ) {
//tag
$slugs = $wpdb->get_col( "SELECT slug FROM $wpdb->terms WHERE term_id IN (" . join( ',', $translated_ids ) . ")" );
$q->query_vars[ 'tag' ] = join( $tag_glue, $slugs );
//tag_id
$q->query_vars[ 'tag_id' ] = join( ',', $translated_ids );
// tag__and
$q->query_vars[ 'tag__and' ] = $translated_ids;
// tag__in
$q->query_vars[ 'tag__in' ] = $translated_ids;
// tag__not_in
$q->query_vars[ 'tag__not_in' ] = array_map( 'abs', $translated_ids );
// tag_slug__in
$q->query_vars[ 'tag_slug__in' ] = $wpdb->get_col( "SELECT slug FROM $wpdb->terms WHERE term_id IN (" . join( ',', $translated_ids ) . ")" );
// tag_slug__and
$q->query_vars[ 'tag_slug__and' ] = $wpdb->get_col( "SELECT slug FROM $wpdb->terms WHERE term_id IN (" . join( ',', $translated_ids ) . ")" );
// POST & PAGES
$post_type = !empty( $q->query_vars[ 'post_type' ] ) ? $q->query_vars[ 'post_type' ] : 'post';
if(!is_array($post_type)) {
$post_type = (array)$post_type;
// page_id
if ( isset( $q->query_vars[ 'page_id' ] ) && !empty( $q->query_vars[ 'page_id' ] ) ) {
$q->query_vars[ 'page_id' ] = icl_object_id( $q->query_vars[ 'page_id' ], 'page', true );
$q->query = preg_replace( '/page_id=[0-9]+/', 'page_id=' . $q->query_vars[ 'page_id' ], $q->query );
// Adjust included IDs adjusting them with translated element, if present
if ( isset( $q->query_vars[ 'include' ] ) && !empty( $q->query_vars[ 'include' ] ) ) {
$include_arr = is_array( $q->query_vars[ 'include' ] ) ? $q->query_vars[ 'include' ] : explode( ',', $q->query_vars[ 'include' ] );
$include_arr_adjusted = array();
foreach ( $include_arr as $include_arr_id ) {
$include_arr_adjusted[ ] = icl_object_id( $include_arr_id, get_post_type($include_arr_id), true );
$q->query_vars[ 'include' ] = is_array( $q->query_vars[ 'include' ] ) ? $include_arr_adjusted : implode( ',', $include_arr_adjusted );
// Adjust excluded IDs adjusting them with translated element, if present
if ( isset( $q->query_vars[ 'exclude' ] ) && !empty( $q->query_vars[ 'exclude' ] ) ) {
$exclude_arr = is_array( $q->query_vars[ 'exclude' ] ) ? $q->query_vars[ 'exclude' ] : explode( ',', $q->query_vars[ 'exclude' ] );
$exclude_arr_adjusted = array();
foreach ( $exclude_arr as $exclude_arr_id ) {
$exclude_arr_adjusted[ ] = icl_object_id( $exclude_arr_id, get_post_type($exclude_arr_id), true );
$q->query_vars[ 'exclude' ] = is_array( $q->query_vars[ 'exclude' ] ) ? $exclude_arr_adjusted : implode( ',', $exclude_arr_adjusted );
// Adjust post id
if ( isset( $q->query_vars[ 'p' ] ) && !empty( $q->query_vars[ 'p' ] ) ) {
$q->query_vars[ 'p' ] = icl_object_id( $q->query_vars[ 'p' ], $post_type[0], true );
// Adjust name
if ( $this->is_translated_post_type($post_type[0]) && isset( $q->query_vars[ 'name' ] ) && !empty( $q->query_vars[ 'name' ] ) ) {
$pid_prepared = $wpdb->prepare("SELECT ID FROM $wpdb->posts WHERE post_name=%s AND post_type=%s", array($q->query_vars[ 'name' ], $post_type[0]));
$pid = $wpdb->get_var( $pid_prepared );
if ( !empty( $pid ) ) {
$q->query_vars[ 'p' ] = icl_object_id( $pid, $post_type[0], true );
unset( $q->query_vars[ 'name' ] );
// Adjust page name
if ( isset( $q->query_vars[ 'pagename' ] ) && !empty( $q->query_vars[ 'pagename' ] ) ) {
// find the page with the page name in the current language.
$pid = $wpdb->get_var( $wpdb->prepare( "
SELECT ID
FROM $wpdb->posts p
ON p.ID = t.element_id AND element_type='post_page'
WHERE p.post_name=%s AND t.language_code = %s
", $q->query_vars[ 'pagename' ], $current_language ) );
if ( $pid ) {
$q->query_vars[ 'page_id' ] = $pid;
// We have found the page id
unset( $q->query_vars[ 'pagename' ] );
if ( $q->query_vars[ 'page_id' ] == get_option( 'page_for_posts' ) ) {
// it's the blog page.
$q->is_page = false; // $wp_query->is_page = false;
$q->is_home = true; // $wp_query->is_home = true;
$q->is_posts_page = true; // $wp_query->is_posts_page = true;
// post__in
if ( isset( $q->query_vars[ 'post__in' ] ) && !empty( $q->query_vars[ 'post__in' ] ) ) {
$pid = array();
foreach ( $q->query_vars[ 'post__in' ] as $p ) {
if ( $post_type ) {
foreach ( $post_type as $pt ) {
$pid[ ] = icl_object_id( $p, $pt, true );
$q->query_vars[ 'post__in' ] = $pid;
// post__not_in
if ( isset( $q->query_vars[ 'post__not_in' ] ) && !empty( $q->query_vars[ 'post__not_in' ] ) ) {
$pid = array();
foreach ( $q->query_vars[ 'post__not_in' ] as $p ) {
if ( $post_type ) {
$q->query_vars[ 'post__not_in' ] = $pid;
// post_parent
if ( isset( $q->query_vars[ 'post_parent' ] ) && !empty( $q->query_vars[ 'post_parent' ] ) && $q->query_vars[ 'post_type' ] != 'attachment' ) {
if ( $post_type ) {
$_parent_type = $wpdb->get_var( $wpdb->prepare( "SELECT post_type FROM {$wpdb->posts} WHERE ID=%d", $q->query_vars[ 'post_parent' ] ) );
$q->query_vars[ 'post_parent' ] = icl_object_id( $q->query_vars[ 'post_parent' ], $_parent_type, true );
// custom taxonomies
if ( isset( $q->query_vars[ 'taxonomy' ] ) && $q->query_vars[ 'taxonomy' ] ) {
$tax_id = $wpdb->get_var( $wpdb->prepare( "SELECT term_id FROM {$wpdb->terms} WHERE slug=%s", $q->query_vars[ 'term' ] ) );
if ( $tax_id ) {
$translated_tax_id = icl_object_id( $tax_id, $q->query_vars[ 'taxonomy' ], true );
if ( isset( $translated_tax_id ) ) {
$q->query_vars[ 'term' ] = $wpdb->get_var( $wpdb->prepare( "SELECT slug FROM {$wpdb->terms} WHERE term_id = %d", $translated_tax_id ) );
$q->query[ $q->query_vars[ 'taxonomy' ] ] = $q->query_vars[ 'term' ];
// TODO Discuss this. Why WP assumes it's there if query vars are altered?
// Look at wp-includes/query.php line #2468 search: if ( $this->query_vars_changed ) {
if ( !isset( $q->query_vars[ 'meta_query' ] ) ) {
$q->query_vars[ 'meta_query' ] = array();
if ( isset( $q->query_vars[ 'tax_query' ] ) && is_array( $q->query_vars[ 'tax_query' ] ) ) {
foreach ( $q->query[ 'tax_query' ] as $num => $fields ) {
if ( ! isset( $fields[ 'terms' ] ) ) {
continue;
if ( is_array( $fields[ 'terms' ] ) ) {
foreach ( $fields[ 'terms' ] as $term ) {
$taxonomy = get_term_by( $fields[ 'field' ], $term, $fields[ 'taxonomy' ] );
if ( is_object( $taxonomy ) ) {
if ( $fields[ 'field' ] == 'id' ) {
$field = isset($taxonomy->term_id) ? $taxonomy->term_id : null;
} else {
$field = isset($taxonomy->{$fields[ 'field' ]}) ? $taxonomy->{$fields[ 'field' ]} : null;
//$q->query[ 'tax_query' ][ $num ][ 'terms' ] = array_diff( $q->query[ 'tax_query' ][ $num ][ 'terms' ], array( $term ) ); // removes from array element with original value
//$q->query[ 'tax_query' ][ $num ][ 'terms' ][ ] = $field;
//$q->tax_query->queries[ $num ][ 'terms' ] = array_diff( $q->tax_query->queries[ $num ][ 'terms' ], array( $term ) ); // see above
//$q->tax_query->queries[ $num ][ 'terms' ][ ] = $field;
//$q->query_vars[ 'tax_query' ][ $num ][ 'terms' ] = array_diff( $q->query_vars[ 'tax_query' ][ $num ][ 'terms' ], array( $term ) ); // see above
//$q->query_vars[ 'tax_query' ][ $num ][ 'terms' ][ ] = $field;
$tmp = $q->query[ 'tax_query' ][ $num ][ 'terms' ];
$tmp = array_diff( (array)$tmp, array( $term ) ); // removes from array element with original value
$tmp[ ] = $field;
//Reindex array
$q->query[ 'tax_query' ][ $num ][ 'terms' ] = array_values( $tmp );
if (isset($q->tax_query->queries[ $num ][ 'terms' ])) {
$tmp = $q->tax_query->queries[ $num ][ 'terms' ];
} else {
$tmp = array(); // clean $tmp variable
$tmp = array_diff( (array)$tmp, array( $term ) ); // see above
$tmp[ ] = $field;
//Reindex array
$q->tax_query->queries[ $num ][ 'terms' ] = array_values( $tmp );
$tmp = $q->query_vars[ 'tax_query' ][ $num ][ 'terms' ];
$tmp[ ] = $field;
//Reindex array
$q->query_vars[ 'tax_query' ][ $num ][ 'terms' ] = array_values( $tmp );
if ($fields['field'] == 'id') {
$field = $taxonomy->term_id;
} else {
$field = $taxonomy->{$fields[ 'field' ]};
unset( $tmp );
} else if ( is_string( $fields[ 'terms' ] ) ) {
$taxonomy = get_term_by( $fields[ 'field' ], $fields[ 'terms' ], $fields[ 'taxonomy' ] );
$q->query[ 'tax_query' ][ $num ][ 'terms' ] = $field;
$q->tax_query->queries[ $num ][ 'terms' ][ 0 ] = $field;
$q->query_vars[ 'tax_query' ][ $num ][ 'terms' ] = $field;
return $q;
function adjust_wp_list_pages_excludes( $pages )
foreach ( $pages as $k => $v ) {
$pages[ $k ] = icl_object_id( $v, 'page', true );
return $pages;
function language_attributes( $output )
if ( preg_match( '#lang="[a-z-]+"#i', $output ) ) {
$output = preg_replace( '#lang="([a-z-]+)"#i', 'lang="' . $this->this_lang . '"', $output );
} else {
$output .= ' lang="' . $this->this_lang . '"';
return $output;
// Localization
function plugin_localization()
load_plugin_textdomain( 'sitepress', false, ICL_PLUGIN_FOLDER . '/locale' );
function locale()
global $locale;
add_filter( 'language_attributes', array( $this, '_language_attributes' ) );
$l = false;
if(defined('DOING_AJAX') && DOING_AJAX && isset($_REQUEST['action']) && isset($_REQUEST['lang'])) {
$l = $this->get_locale($_REQUEST['lang']);
if(!$l) {
if (defined( 'WP_ADMIN' ) ) {
if ( get_user_meta( $this->get_current_user()->ID, 'icl_admin_language_for_edit', true ) && icl_is_post_edit() ) {
$l = $this->get_locale( $this->get_current_language() );
} else {
$l = $this->get_locale( $this->admin_language );
} else {
$l = $this->get_locale( $this->this_lang );
if ( $l ) {
$locale = $l;
// theme localization
remove_filter( 'locale', array( $this, 'locale' ) ); //avoid infinite loop
static $theme_locales_loaded = false;
if ( !$theme_locales_loaded && !empty( $this->settings[ 'theme_localization_load_textdomain' ] ) && !empty( $this->settings[ 'gettext_theme_domain_name' ] ) && !empty( $this->settings[ 'theme_language_folders' ] )
foreach ( $this->settings[ 'theme_language_folders' ] as $folder ) {
load_textdomain( $this->settings[ 'gettext_theme_domain_name' ], $folder . '/' . $locale . '.mo' );
$theme_locales_loaded = true;
add_filter( 'locale', array( $this, 'locale' ) );
return $locale;
function _language_attributes( $latr )
global $locale;
$latr = preg_replace( '#lang="(.[a-z])"#i', 'lang="' . str_replace( '_', '-', $locale ) . '"', $latr );
return $latr;
function get_language_tag( $code )
global $wpdb;
static $all_tags = null;
return false;
if ( $tag = wp_cache_get( 'icl_language_tags_' . $code ) ) {
return $tag;
if($all_tags==null) {
$all_tags_data = $wpdb->get_results( "SELECT code, tag FROM {$wpdb->prefix}icl_languages" );
foreach($all_tags_data as $tag_data) {
$all_tags[$tag_data->code] = $tag_data->tag;
$tag = $this->get_locale( $code );
if($all_tags) {
$tag = isset($all_tags[$code]) ? $all_tags[$code] : false;
if ( $tag ) {
wp_cache_set( 'icl_language_tags_' . $code, $tag );
return $tag;
function get_locale( $code )
global $wpdb;
$all_locales = null;
return false;
$found = false;
$locale = wp_cache_get( 'get_locale' . $code, '', false, $found );
if ( $found ) {
return $locale;
$all_locales_data = $wpdb->get_results("SELECT code, locale FROM {$wpdb->prefix}icl_locale_map" );
foreach($all_locales_data as $locales_data) {
$all_locales[$locales_data->code] = $locales_data->locale;
$locale = isset($all_locales[$code]) ? $all_locales[$code] : false;
if ($locale == false) {
$this_locale_data = $wpdb->get_row( $wpdb->prepare("SELECT code, default_locale FROM {$wpdb->prefix}icl_languages WHERE code = '%s'", $code) );
if ($this_locale_data) {
$locale = $this_locale_data->default_locale;
wp_cache_set( 'get_locale' . $code, $locale );
return $locale;
function switch_locale( $lang_code = false )
global $l10n;
static $original_l10n;
if ( !empty( $lang_code ) ) {
$original_l10n = $l10n[ 'sitepress' ];
unset( $l10n[ 'sitepress' ] );
load_textdomain( 'sitepress', ICL_PLUGIN_PATH . '/locale/sitepress-' . $this->get_locale( $lang_code ) . '.mo' );
} else { // switch back
$l10n[ 'sitepress' ] = $original_l10n;
function get_locale_file_names()
global $wpdb;
$locales = array();
$res = $wpdb->get_results( "
SELECT lm.code, locale
FROM {$wpdb->prefix}icl_locale_map lm JOIN {$wpdb->prefix}icl_languages l ON lm.code = l.code AND l.active=1" );
foreach ( $res as $row ) {
$locales[ $row->code ] = $row->locale;
return $locales;
function set_locale_file_names( $locale_file_names_pairs )
global $wpdb;
$lfn = $this->get_locale_file_names();
$new = array_diff( array_keys( $locale_file_names_pairs ), array_keys( $lfn ) );
if ( !empty( $new ) ) {
foreach ( $new as $code ) {
$wpdb->insert( $wpdb->prefix . 'icl_locale_map', array( 'code' => $code, 'locale' => $locale_file_names_pairs[ $code ] ) );
$remove = array_diff( array_keys( $lfn ), array_keys( $locale_file_names_pairs ) );
if ( !empty( $remove ) ) {
$wpdb->query( "DELETE FROM {$wpdb->prefix}icl_locale_map WHERE code IN (" . join( ',', array_map( create_function( '$a', 'return "\'".$a."\'";' ), $remove ) ) . ")" );
$update = array_diff( $locale_file_names_pairs, $lfn );
foreach ( $update as $code => $locale ) {
$wpdb->update( $wpdb->prefix . 'icl_locale_map', array( 'locale' => $locale ), array( 'code' => $code ) );
$this->icl_locale_cache->clear();
return true;
function pre_option_page_on_front() {
global $wpdb;
$result = null;
static $page_on_front = null;
if ($page_on_front===false || ($GLOBALS[ 'pagenow' ] == 'site-new.php' && isset( $_REQUEST[ 'action' ] ) && 'add-site' == $_REQUEST[ 'action' ] )) {
return false;
$cache_key = $this->this_lang;
$cache_group = 'pre_option_page_on_front';
$found = false;
$result = wp_cache_get( $cache_key, $cache_group, false, $found );
if ( !$found || $result == false || ICL_DISABLE_CACHE ) {
$result = false;
$page_on_front = $wpdb->get_var( "SELECT option_value FROM {$wpdb->options} WHERE option_name='page_on_front'" );
if ( $page_on_front ) {
$_el_lang_det = $this->get_element_language_details( $page_on_front, 'post_page' );
if ($_el_lang_det && !empty( $_el_lang_det->trid ) ) {
$trid = $_el_lang_det->trid;
$translations = $wpdb->get_results( $wpdb->prepare("SELECT element_id, language_code FROM {$wpdb->prefix}icl_translations WHERE trid=%d", $trid ));
if ( $t->language_code == $this->this_lang ) {
$result = $t->element_id;
$page = get_post( $result );
if ( !$page || $page->post_type != 'page' ) {
$result = false;
$cache_key = $t->language_code;
$found = false;
if ( !$found && $result !== false ) {
wp_cache_set( $cache_key, $result, $cache_group );
return $result;
else /* rich fix */
//error_log("rich:caching:[" . $cache_key . "][" . $cache_group . "][" . $page_on_front . "]");
wp_cache_set($cache_key, $page_on_front, $cache_group);
$result = $page_on_front;
return $result;
function pre_option_page_for_posts() {
global $wpdb;
static $page_for_posts = null;
static $result = null;
if ($page_for_posts===false || $result != null ) {
return $result;
$cache_group = 'pre_option_page_for_posts';
$found = false;
$result = wp_cache_get($cache_key, $cache_group, false, $found);
if ( !$found || ICL_DISABLE_CACHE ) {
$page_for_posts = $wpdb->get_var( "SELECT option_value FROM {$wpdb->options} WHERE option_name='page_for_posts'" );
$result = false;
if ( $page_for_posts ) {
$_el_lang_det = $this->get_element_language_details( $page_for_posts, 'post_page' );
//Cache all translations
return $result;
else /* rich fix */
//error_log("richPageForPosts:caching:[" . $cache_key . "][" . $cache_group . "][" . $page_for_posts . "]");
wp_cache_set($cache_key, $page_for_posts, $cache_group);
$result = $page_for_posts;
return $result;
function verify_home_and_blog_pages_translations()
global $wpdb;
$warn_home = $warn_posts = '';
$page_on_front = get_option( 'page_on_front' );
if ( 'page' == get_option( 'show_on_front' ) && $page_on_front ) {
$page_home_trid = $wpdb->get_var( "SELECT trid FROM {$wpdb->prefix}icl_translations WHERE element_id={$page_on_front} AND element_type='post_page'" );
$page_home_translations = $this->get_element_translations( $page_home_trid, 'post_page' );
$missing_home = array();
foreach ( $this->active_languages as $lang ) {
if ( !isset( $page_home_translations[ $lang[ 'code' ] ] ) ) {
$missing_home[ ] = $lang[ 'display_name' ];
} elseif ( $page_home_translations[ $lang[ 'code' ] ]->post_status != 'publish' ) {
if ( !empty( $missing_home ) ) {
$warn_home = '<div class="icl_form_errors" style="font-weight:bold">';
$warn_home .= sprintf( __( 'Your home page does not exist or its translation is not published in %s.', 'sitepress' ), join( ', ', $missing_home ) );
$warn_home .= '<br />';
$warn_home .= '<a href="' . get_edit_post_link( $page_on_front ) . '">' . __( 'Edit this page to add translations', 'sitepress' ) . '</a>';
$warn_home .= '</div>';
if ( get_option( 'page_for_posts' ) ) {
$page_for_posts = get_option( 'page_for_posts' );
$page_posts_trid = $wpdb->get_var( "SELECT trid FROM {$wpdb->prefix}icl_translations WHERE element_id={$page_for_posts} AND element_type='post_page'" );
$page_posts_translations = $this->get_element_translations( $page_posts_trid, 'post_page' );
$missing_posts = array();
if ( !isset( $page_posts_translations[ $lang[ 'code' ] ] ) ) {
$missing_posts[ ] = $lang[ 'display_name' ];
} elseif ( $page_posts_translations[ $lang[ 'code' ] ]->post_status != 'publish' ) {
if ( !empty( $missing_posts ) ) {
$warn_posts = '<div class="icl_form_errors" style="font-weight:bold;margin-top:4px;">';
$warn_posts .= sprintf( __( 'Your blog page does not exist or its translation is not published in %s.', 'sitepress' ), join( ', ', $missing_posts ) );
$warn_posts .= '<br />';
$warn_posts .= '<a href="' . get_edit_post_link( $page_for_posts ) . '">' . __( 'Edit this page to add translations', 'sitepress' ) . '</a>';
$warn_posts .= '</div>';
return array( $warn_home, $warn_posts );
// adds the language parameter to the admin post filtering/search
function restrict_manage_posts()
echo '<input type="hidden" name="lang" value="' . $this->this_lang . '" />';
// adds the language parameter to the admin pages search
function restrict_manage_pages()
<script type="text/javascript">
addLoadEvent(function () {
jQuery('p.search-box').append('<input type="hidden" name="lang" value="<?php echo $this->this_lang ?>">');
</script>
<?php
function get_edit_post_link( $link, $id, $context = 'display' )
global $wpdb;
$_cache_key = $link . '|' . $id . '|' . $context;
$cached_edit_post_link = wp_cache_get($_cache_key, 'icl_get_edit_post_link');
if ( $cached_edit_post_link ) {
$link = $cached_edit_post_link;
} else {
if ( current_user_can( 'edit_post', $id ) ) {
if ( 'display' == $context )
$and = '&'; else
$and = '&';
if ( $id ) {
$post_type = $wpdb->get_var( "SELECT post_type FROM {$wpdb->posts} WHERE ID='{$id}'" );
$details = $this->get_element_language_details( $id, 'post_' . $post_type );
if ( isset( $details->language_code ) ) {
$lang = $details->language_code;
} else {
$lang = $this->get_current_language();
$link .= $and . 'lang=' . $lang;
wp_cache_set($_cache_key , $link,'icl_get_edit_post_link');
return $link;
function get_edit_term_link( $link, $term_id, $taxonomy, $object_type )
global $wpdb;
$term_tax_id = $wpdb->get_var( $wpdb->prepare( "SELECT term_taxonomy_id FROM {$wpdb->term_taxonomy} WHERE term_id=%d AND taxonomy=%s", $term_id, $taxonomy ) );
$details = $this->get_element_language_details( $term_tax_id, 'tax_' . $taxonomy );
$and = '&';
} else {
$lang = $current_language;
if ( $lang != $default_language || $current_language != $default_language ) {
return $link;
function option_sticky_posts( $posts ) {
global $wpdb;
if ( is_array( $posts ) && !empty( $posts ) ) {
$md5_posts = md5( json_encode( $posts ) );
$cache_key = $this->this_lang . ':' . $md5_posts;
$cache_group = 'icl_option_sticky_posts';
$cached_sticky_posts = wp_cache_get( $cache_key, $cache_group );
if ( $cached_sticky_posts ) {
return $cached_sticky_posts;
$new_posts = array();
$posts = array_filter( $posts, create_function( '$a', 'return $a > 0;' ) );
if(count($posts)==1) {
$option_sticky_posts_trids_prepared = $wpdb->prepare( "SELECT trid FROM {$wpdb->prefix}icl_translations WHERE element_id = %d AND element_type='post_post'", array($posts[0]) );
} else {
$option_sticky_posts_trids_prepared = "SELECT trid FROM {$wpdb->prefix}icl_translations WHERE element_id IN (" . join( ',', $posts ) . ") AND element_type='post_post'";
$trids = $wpdb->get_col( $option_sticky_posts_trids_prepared );
if ( $trids ) {
if ( count( $trids ) == 1 ) {
$option_sticky_posts_prepared = $wpdb->prepare( "SELECT trid, element_id, language_code FROM {$wpdb->prefix}icl_translations WHERE trid = %d AND element_type='post_post'", array( $trids[ 0 ] ) );
} else {
$option_sticky_posts_prepared = "SELECT trid, element_id, language_code FROM {$wpdb->prefix}icl_translations WHERE trid IN (" . join( ',', $trids ) . ") AND element_type='post_post'";
$option_sticky_posts = $wpdb->get_results( $option_sticky_posts_prepared );
foreach ( $option_sticky_posts as $option_sticky_post ) {
if ( $option_sticky_post->language_code == $this->this_lang ) {
if ( !in_array( $option_sticky_post->element_id, $new_posts ) ) {
$new_posts[ ] = $option_sticky_post->element_id;
wp_cache_set( $cache_key, $new_posts, $cache_group );
return $new_posts;
return $posts;
function request_filter( $request )
if ( !defined( 'WP_ADMIN' ) && $this->settings[ 'language_negotiation_type' ] == 3 && isset( $request[ 'lang' ] ) ) {
// Count the parameters that have settings and remove our 'lang ' setting it's the only one.
// This is required so that home page detection works for other languages.
$count = 0;
foreach ( $request as $data ) {
if ( $data !== '' ) {
$count += 1;
if ( $count == 1 ) {
unset( $request[ 'lang' ] );
return $request;
function noscript_notice()
<noscript>
<div class="error"><?php echo __( 'WPML admin screens require JavaScript in order to display. JavaScript is currently off in your browser.', 'sitepress' ) ?></div></noscript><?php
function filter_queries( $sql )
global $wpdb, $pagenow;
// keep a record of the queries
$this->queries[ ] = $sql;
if ( $pagenow == 'categories.php' || $pagenow == 'edit-tags.php' ) {
if ( preg_match( '#^SELECT COUNT\(\*\) FROM ' . $wpdb->term_taxonomy . ' WHERE taxonomy = \'(category|post_tag)\' $#', $sql, $matches ) ) {
$element_type = 'tax_' . $matches[ 1 ];
$sql = "
SELECT COUNT(*) FROM {$wpdb->term_taxonomy} tx
JOIN {$wpdb->prefix}icl_translations tr ON tx.term_taxonomy_id=tr.element_id
WHERE tx.taxonomy='{$matches[1]}' AND tr.element_type='{$element_type}' AND tr.language_code='" . $current_language . "'";
if ( $pagenow == 'edit.php' || $pagenow == 'edit-pages.php' ) {
$post_type = isset( $_GET[ 'post_type' ] ) ? $_GET[ 'post_type' ] : 'post';
$element_type = 'post_' . $post_type;
if ( preg_match( '#SELECT post_status, COUNT\( \* \) AS num_posts FROM ' . $wpdb->posts . ' WHERE post_type = \'(.+)\' GROUP BY post_status#i', $sql, $matches ) ) {
if ( 'all' != $current_language ) {
$sql = '
SELECT post_status, COUNT( * ) AS num_posts
FROM ' . $wpdb->posts . ' p
JOIN ' . $wpdb->prefix . 'icl_translations t ON p.ID = t.element_id
WHERE p.post_type = \'' . $matches[ 1 ] . '\'
AND t.element_type=\'' . $element_type . '\'
AND t.language_code=\'' . $current_language . '\'
GROUP BY post_status';
} else {
$sql = '
JOIN ' . $wpdb->prefix . 'icl_languages l ON t.language_code = l.code AND l.active = 1
if ( isset( $_GET[ 'action' ] ) && $_GET[ 'action' ] == 'ajax-tag-search' ) {
$search = 'SELECT t.name FROM ' . $wpdb->term_taxonomy . ' AS tt INNER JOIN ' . $wpdb->terms . ' AS t ON tt.term_id = t.term_id WHERE tt.taxonomy = \'' . esc_sql( $_GET[ 'tax' ] ) . '\' AND t.name LIKE (\'%' . esc_sql( $_GET[ 'q' ] ) . '%\')';
if ( $sql == $search ) {
$parts = parse_url( $_SERVER[ 'HTTP_REFERER' ] );
@parse_str( $parts[ 'query' ], $query );
$lang = isset( $query[ 'lang' ] ) ? $query[ 'lang' ] : $this->get_language_cookie();
$element_type = 'tax_' . $_GET[ 'tax' ];
$sql = 'SELECT t.name FROM ' . $wpdb->term_taxonomy . ' AS tt
JOIN ' . $wpdb->prefix . 'icl_translations tr ON tt.term_taxonomy_id = tr.element_id
WHERE tt.taxonomy = \'' . esc_sql( $_GET[ 'tax' ] ) . '\' AND tr.language_code=\'' . $lang . '\' AND element_type=\'' . $element_type . '\'
// filter get page by path WP 3.9+
if ( version_compare( $GLOBALS[ 'wp_version' ], '3.9', '>=' ) ) {
if ( preg_match( "#\n\t\tSELECT ID, post_name, post_parent, post_type\n\t\tFROM {$wpdb->posts}\n\t\tWHERE post_name IN \(([^)]+)\)\n\t\tAND post_type IN \(([^)]+)\)#", $sql, $matches ) ) {
//add 'post_' at the beginning of each post type
$post_types = explode( ',', str_replace('\'', '', $matches[2]) );
$element_types = array();
foreach ($post_types as $post_type){
$element_types[] = "'post_".$post_type."'";
$element_types = implode(',', $element_types);
$sql = "SELECT p.ID, p.post_name, p.post_parent, post_type
LEFT JOIN {$wpdb->prefix}icl_translations t on t.element_id = p.ID AND t.element_type IN ({$element_types}) AND t.language_code='" . $current_language . "'
WHERE p.post_name IN ({$matches[1]}) AND p.post_type IN ({$matches[2]})
ORDER BY t.language_code='" . $current_language . "' DESC
// added order by to ensure that we get the result in teh current language first
}elseif( version_compare( $GLOBALS[ 'wp_version' ], '3.5', '>=' ) ){
if ( preg_match( "#SELECT ID, post_name, post_parent, post_type FROM {$wpdb->posts} WHERE post_name IN \(([^)]+)\) AND \(post_type = '([^']+)' OR post_type = 'attachment'\)#", $sql, $matches ) ) {
LEFT JOIN {$wpdb->prefix}icl_translations t on t.element_id = p.ID AND t.element_type = 'post_{$matches[2]}' AND t.language_code='" . $current_language . "'
WHERE p.post_name IN ({$matches[1]}) AND (p.post_type = '{$matches[2]}' OR p.post_type = 'attachment')
} else {
// filter get page by path WP 3.3+
if ( preg_match( "#SELECT ID, post_name, post_parent FROM {$wpdb->posts} WHERE post_name IN \(([^)]+)\) AND \(post_type = '([^']+)' OR post_type = 'attachment'\)#", $sql, $matches ) ) {
} // filter get page by path < WP 3.3
elseif ( preg_match( "#SELECT ID, post_name, post_parent FROM {$wpdb->posts} WHERE post_name = '([^']+)' AND \(post_type = '([^']+)' OR post_type = 'attachment'\)#", $sql, $matches ) ) {
WHERE p.post_name = '{$matches[1]}' AND (p.post_type = '{$matches[2]}' OR p.post_type = 'attachment')
AND t.language_code='" . $current_language . "'";
// filter calendar widget queries
//elseif( preg_match("##", $sql, $matches) ){
return $sql;
function get_inactive_content()
global $wpdb;
$inactive = array();
$res_p_prepared = $wpdb->prepare( "
SELECT COUNT(p.ID) AS c, p.post_type, lt.name AS language FROM {$wpdb->prefix}icl_translations t
JOIN {$wpdb->posts} p ON t.element_id=p.ID AND t.element_type LIKE %s
JOIN {$wpdb->prefix}icl_languages l ON t.language_code = l.code AND l.active = 0
JOIN {$wpdb->prefix}icl_languages_translations lt ON lt.language_code = l.code AND lt.display_language_code=%s
GROUP BY p.post_type, t.language_code
", array( wpml_like_escape('post_') . '%', $current_language) );
$res_p = $wpdb->get_results( $res_p_prepared );
if ($res_p) {
foreach ( $res_p as $r ) {
$inactive[ $r->language ][ $r->post_type ] = $r->c;
$res_t_query = "
SELECT COUNT(p.term_taxonomy_id) AS c, p.taxonomy, lt.name AS language FROM {$wpdb->prefix}icl_translations t
JOIN {$wpdb->term_taxonomy} p ON t.element_id=p.term_taxonomy_id
WHERE t.element_type LIKE %s
GROUP BY p.taxonomy, t.language_code
$res_t_query_prepared = $wpdb->prepare($res_t_query, $current_language, wpml_like_escape('tax_') . '%');
$res_t = $wpdb->get_results( $res_t_query_prepared );
if ($res_t) {
foreach ( $res_t as $r ) {
if ( $r->taxonomy == 'category' && $r->c == 1 ) {
continue; //ignore the case of just the default category that gets automatically created for a new language
$inactive[ $r->language ][ $r->taxonomy ] = $r->c;
return $inactive;
function menu_footer()
include ICL_PLUGIN_PATH . '/menu/menu-footer.php';
function _allow_calling_template_file_directly()
if ( is_404() ) {
global $wp_query;
$parts = parse_url( get_bloginfo( 'url' ) );
if ( !isset( $parts[ 'path' ] ) )
$parts[ 'path' ] = '';
$req = str_replace( $parts[ 'path' ], '', $_SERVER[ 'REQUEST_URI' ] );
$whitelisted_extensions = array('php'=> 1);
if ( file_exists( ABSPATH . $req ) && !is_dir( ABSPATH . $req ) && isset( $whitelisted_extensions[ pathinfo($req, PATHINFO_EXTENSION) ] ) ) {
$wp_query->is_404 = false;
header( 'HTTP/1.1 200 OK' );
include ABSPATH . $req;
exit;
function show_user_options()
global $current_user;
$active_languages = $this->get_active_languages();
$user_language = get_user_meta( $current_user->data->ID, 'icl_admin_language', true );
if ( $this->settings[ 'admin_default_language' ] == '_default_' ) {
$this->settings[ 'admin_default_language' ] = $default_language;
$lang_details = $this->get_language_details( $this->settings[ 'admin_default_language' ] );
$admin_default_language = $lang_details[ 'display_name' ];
<a name="wpml"></a>
<h3><?php _e( 'WPML language settings', 'sitepress' ); ?></h3>
<table class="form-table">
<tbody>
<tr>
<th><?php _e( 'Select your language:', 'sitepress' ) ?></th>
<td>
<select name="icl_user_admin_language">
<option value=""<?php if ( $user_language == $this->settings[ 'admin_default_language' ] )
echo ' selected="selected"' ?>><?php printf( __( 'Default admin language (currently %s)', 'sitepress' ), $admin_default_language ); ?> </option>
<?php foreach ( $active_languages as $al ): ?>
<option value="<?php echo $al[ 'code' ] ?>"<?php if ( $user_language == $al[ 'code' ] )
echo ' selected="selected"' ?>><?php echo $al[ 'display_name' ];
if ( $this->admin_language != $al[ 'code' ] )
echo ' (' . $al[ 'native_name' ] . ')'; ?> </option>
<?php endforeach; ?>
</select>
<span class="description"><?php _e( 'this will be your admin language and will also be used for translating comments.', 'sitepress' ); ?></span>
<br/>
<label><input type="checkbox" name="icl_admin_language_for_edit" value="1"
<?php if (get_user_meta( $this->get_current_user()->ID, 'icl_admin_language_for_edit', true )): ?>checked="checked"<?php endif; ?> /> <?php _e( 'Set admin language as editing language.', 'sitepress' ); ?>
</label>
</td>
</tr>
<?php //display "hidden languages block" only if user can "manage_options"
if ( current_user_can( 'manage_options' ) || current_user_can('translate') ): ?>
<tr>
<th><?php _e( 'Hidden languages:', 'sitepress' ) ?></th>
<td>
<p>
<?php if ( !empty( $this->settings[ 'hidden_languages' ] ) ): ?>
<?php
if ( 1 == count( $this->settings[ 'hidden_languages' ] ) ) {
printf( __( '%s is currently hidden to visitors.', 'sitepress' ), $active_languages[ $this->settings[ 'hidden_languages' ][ 0 ] ][ 'display_name' ] );
} else {
$hidden_languages_array = array();
foreach ( $this->settings[ 'hidden_languages' ] as $l ) {
$hidden_languages_array[ ] = $active_languages[ $l ][ 'display_name' ];
$hidden_languages = join( ', ', $hidden_languages_array );
printf( __( '%s are currently hidden to visitors.', 'sitepress' ), $hidden_languages );
<?php else: ?>
<?php _e( 'All languages are currently displayed. Choose what to do when site languages are hidden.', 'sitepress' ); ?>
<?php endif; ?>
</p>
<p>
<label><input name="icl_show_hidden_languages" type="checkbox" value="1" <?php
if (get_user_meta( $current_user->data->ID, 'icl_show_hidden_languages', true )):?>checked="checked"<?php endif ?> /> <?php
_e( 'Display hidden languages', 'sitepress' ) ?></label>
</p>
</td>
</tr>
<?php endif; ?>
</tbody>
</table>
<?php
function save_user_options()
$user_id = $_POST[ 'user_id' ];
if ( $user_id ) {
update_user_meta( $user_id, 'icl_admin_language', $_POST[ 'icl_user_admin_language' ] );
update_user_meta( $user_id, 'icl_show_hidden_languages', isset( $_POST[ 'icl_show_hidden_languages' ] ) ? intval( $_POST[ 'icl_show_hidden_languages' ] ) : 0 );
update_user_meta( $user_id, 'icl_admin_language_for_edit', isset( $_POST[ 'icl_admin_language_for_edit' ] ) ? intval( $_POST[ 'icl_admin_language_for_edit' ] ) : 0 );
$this->reset_admin_language_cookie();
function help_admin_notice()
$args = array(
'name' => 'wpml-intro',
'iso' => defined( 'WPLANG' ) ? WPLANG : '',
'src' => get_home_url()
$q = http_build_query( $args );
<br clear="all"/>
<div id="message" class="updated message fade" style="clear:both;margin-top:5px;"><p>
<?php _e( 'WPML is a powerful plugin with many features. Would you like to see a quick overview?', 'sitepress' ); ?>
</p>
<p>
<a href="<?php echo ICL_API_ENDPOINT ?>/destinations/go?<?php echo $q ?>" target="_blank" class="button-primary"><?php _e( 'Yes', 'sitepress' ) ?></a>
<input type="hidden" id="icl_dismiss_help_nonce" value="<?php echo $icl_dhn = wp_create_nonce( 'dismiss_help_nonce' ) ?>"/>
<a href="admin.php?page=<?php echo basename( ICL_PLUGIN_PATH ) . '/menu/languages.php&icl_action=dismiss_help&_icl_nonce=' . $icl_dhn; ?>" class="button"><?php _e( 'No thanks, I will configure myself', 'sitepress' ) ?></a>
<a title="<?php _e( 'Stop showing this message', 'sitepress' ) ?>" id="icl_dismiss_help" href=""><?php _e( 'Dismiss', 'sitepress' ) ?></a>
</p>
</div>
<?php
function upgrade_notice()
include ICL_PLUGIN_PATH . '/menu/upgrade_notice.php';
function icl_reminders()
include ICL_PLUGIN_PATH . '/menu/icl_reminders.php';
function add_posts_management_column( $columns )
global $posts, $wpdb, $__management_columns_posts_translations;
$element_type = isset( $_REQUEST[ 'post_type' ] ) ? 'post_' . $_REQUEST[ 'post_type' ] : 'post_post';
if ( count( $this->get_active_languages() ) <= 1 || get_query_var( 'post_status' ) == 'trash' ) {
return $columns;
if ( isset( $_POST[ 'action' ] ) && $_POST[ 'action' ] == 'inline-save' && $_POST[ 'post_ID' ] ) {
$p = new stdClass();
$p->ID = $_POST[ 'post_ID' ];
$posts = array( $p );
} elseif ( empty( $posts ) ) {
return $columns;
if ( is_null( $__management_columns_posts_translations ) ) {
$post_ids = array();
foreach ( $posts as $p ) {
$post_ids[ ] = $p->ID;
// get posts translations
// get trids
$trid_array = $wpdb->get_col( "
SELECT trid FROM {$wpdb->prefix}icl_translations WHERE element_type='{$element_type}' AND element_id IN (" . join( ',', $post_ids ) . ")
$elements_translations = $wpdb->get_results( "
SELECT trid, element_id, language_code, source_language_code FROM {$wpdb->prefix}icl_translations WHERE trid IN (" . join( ',', $trid_array ) . ")
foreach ( $elements_translations as $v ) {
$by_trid[ $v->trid ][ ] = $v;
if ( in_array( $v->element_id, $post_ids ) ) {
$el_trid = $v->trid;
foreach ( $elements_translations as $val ) {
if ( $val->trid == $el_trid ) {
$__management_columns_posts_translations[ $v->element_id ][ $val->language_code ] = $val;
$languages = array();
foreach ( $active_languages as $v ) {
if ( $v[ 'code' ] == $this->get_current_language() )
continue;
$languages[ ] = $v[ 'code' ];
SELECT f.lang_code, f.flag, f.from_template, l.name
FROM {$wpdb->prefix}icl_flags f
JOIN {$wpdb->prefix}icl_languages_translations l ON f.lang_code = l.language_code
WHERE l.display_language_code = '" . $this->admin_language . "' AND f.lang_code IN('" . join( "','", $languages ) . "')
foreach ( $res as $r ) {
if ( $r->from_template ) {
$wp_upload_dir = wp_upload_dir();
$flag_path = $wp_upload_dir[ 'baseurl' ] . '/flags/';
} else {
$flag_path = ICL_PLUGIN_URL . '/res/flags/';
$flags[ $r->lang_code ] = '<img src="' . $flag_path . $r->flag . '" width="18" height="12" alt="' . $r->name . '" title="' . $r->name . '" />';
$flags_column = '';
if ( isset( $flags[ $v[ 'code' ] ] ) )
$flags_column .= $flags[ $v[ 'code' ] ];
$new_columns = array();
foreach ( $columns as $k => $v ) {
$new_columns[ $k ] = $v;
if ( $k == 'title' ) {
$new_columns[ 'icl_translations' ] = $flags_column;
return $new_columns;
function add_content_for_posts_management_column( $column_name )
if ( $column_name != 'icl_translations' )
return;
global $wpdb, $id, $__management_columns_posts_translations, $sitepress, $iclTranslationManagement;
if ( $v[ 'code' ] == $current_language )
continue;
$post_type = isset( $_REQUEST[ 'post_type' ] ) ? $_REQUEST[ 'post_type' ] : 'post';
if ( isset( $__management_columns_posts_translations[ $id ][ $v[ 'code' ] ] ) && $__management_columns_posts_translations[ $id ][ $v[ 'code' ] ]->element_id ) {
// Translation exists
$exist_translation = true;
$trid = $this->get_element_trid( $__management_columns_posts_translations[ $id ][ $v[ 'code' ] ]->element_id, 'post_' . $post_type );
$source_language_code = $wpdb->get_var( $wpdb->prepare( "SELECT language_code FROM {$wpdb->prefix}icl_translations WHERE trid=%d AND source_language_code IS NULL", $trid ) );
$needs_update = $wpdb->get_var( $wpdb->prepare( "
SELECT needs_update
FROM {$wpdb->prefix}icl_translation_status s JOIN {$wpdb->prefix}icl_translations t ON t.translation_id = s.translation_id
WHERE t.trid = %d AND t.language_code = '%s'
", $trid, $v[ 'code' ] ) );
if ( $needs_update ) {
$img = 'needs-update.png';
$alt = sprintf( __( 'Update %s translation', 'sitepress' ), $v[ 'display_name' ] );
} else {
$img = 'edit_translation.png';
$alt = sprintf( __( 'Edit the %s translation', 'sitepress' ), $v[ 'display_name' ] );
switch ( $iclTranslationManagement->settings[ 'doc_translation_method' ] ) {
case ICL_TM_TMETHOD_EDITOR:
$job_id = $iclTranslationManagement->get_translation_job_id( $__management_columns_posts_translations[ $id ][ $v[ 'code' ] ]->trid, $v[ 'code' ] );
$args = array( 'lang_from' => $current_language, 'lang_to' => $v[ 'code' ], 'job_id' => @intval( $job_id ) );
// is a translator of this document?
$current_user_is_translator = $iclTranslationManagement->is_translator( $this->get_current_user()->ID, $args );
if ( !$current_user_is_translator ) {
$img = 'edit_translation_disabled.png';
$link = '#';
// is a translator of this language?
unset( $args[ 'job_id' ] );
if ( $current_user_is_translator ) {
$alt = sprintf( __( "You can't edit this translation because you're not the translator. <a%s>Learn more.</a>", 'sitepress' ), ' href="https://wpml.org/?page_id=52218"' );
} else {
$alt = sprintf( __( "You can't edit this translation because you're not a %s translator. <a%s>Learn more.</a>", 'sitepress' ), $v[ 'display_name' ], ' href="https://wpml.org/?page_id=52218"' );
} elseif ( $v[ 'code' ] == $source_language_code ) {
$link = '#';
$alt = __( "You can't edit the original document using the translation editor", 'sitepress' );
} else {
if ( $job_id ) {
$link = admin_url( 'admin.php?page=' . WPML_TM_FOLDER . '/menu/translations-queue.php&job_id=' . $job_id . '&lang=' . $v[ 'code' ] );
} else {
$link = admin_url( 'admin.php?page=' . WPML_TM_FOLDER . '/menu/translations-queue.php&icl_tm_action=create_job&iclpost[]=' . $id . '&translate_to[' . $v[ 'code' ] . ']=1&iclnonce=' . wp_create_nonce( 'pro-translation-icl' ) . '&lang=' . $v[ 'code' ] );
break;
case ICL_TM_TMETHOD_PRO:
if ( !$__management_columns_posts_translations[ $id ][ $v[ 'code' ] ]->source_language_code ) {
$link = get_edit_post_link( $__management_columns_posts_translations[ $id ][ $v[ 'code' ] ]->element_id );
$alt = __( 'Edit the original document', 'sitepress' );
} else {
if ( $job_id ) {
$job_details = $iclTranslationManagement->get_translation_job( $job_id );
if ( $job_details->status == ICL_TM_IN_PROGRESS || $job_details->status == ICL_TM_WAITING_FOR_TRANSLATOR ) {
$img = 'in-progress.png';
$alt = sprintf( __( 'Translation to %s is in progress', 'sitepress' ), $v[ 'display_name' ] );
$link = false;
echo '<img style="padding:1px;margin:2px;" border="0" src="' . ICL_PLUGIN_URL . '/res/img/' . $img . '" title="' . $alt . '" alt="' . $alt . '" width="16" height="16" />';
} else {
$link = admin_url( 'admin.php?page=' . WPML_TM_FOLDER . '/menu/translations-queue.php&job_id=' . $job_id );
break;
default:
$link = 'post.php?post_type=' . $post_type . '&action=edit&post=' . $__management_columns_posts_translations[ $id ][ $v[ 'code' ] ]->element_id . '&lang=' . $v[ 'code' ];
} else {
// Translation does not exist
$exist_translation = false;
$img = 'add_translation.png';
$alt = sprintf( __( 'Add translation to %s', 'sitepress' ), $v[ 'display_name' ] );
$src_lang = $current_language;
if($src_lang == 'all') {
$trid = $sitepress->get_element_trid($id, 'post_' . $post_type);
$element_translations = $sitepress->get_element_translations($trid, 'post_' . $post_type);
foreach($element_translations as $element_translation) {
if($element_translation->original) {
$src_lang = $element_translation->language_code;
break;
if ( isset( $__management_columns_posts_translations[ $id ][ $v[ 'code' ] ] ) ) {
} else {
$job_id = 0;
$args = array( 'lang_from' => $src_lang, 'lang_to' => $v[ 'code' ], 'job_id' => @intval( $job_id ) );
if ( $job_id ) {
if ( $job_details && $job_details->status == ICL_TM_IN_PROGRESS ) {
} else {
$link = '#';
$tres = $wpdb->get_row( $wpdb->prepare( "
SELECT s.* FROM {$wpdb->prefix}icl_translation_status s
JOIN {$wpdb->prefix}icl_translate_job j ON j.rid = s.rid
WHERE job_id=%d
", $job_id ) );
if ( $tres->status == ICL_TM_IN_PROGRESS ) {
$alt = sprintf( __( 'Translation to %s is in progress (by a different translator)', 'sitepress' ), $v[ 'display_name' ] );
} elseif ( $tres->status == ICL_TM_NOT_TRANSLATED || $tres->status == ICL_TM_WAITING_FOR_TRANSLATOR ) {
$img = 'add_translation_disabled.png';
} elseif ( $tres->status == ICL_TM_NEEDS_UPDATE || $tres->status == ICL_TM_COMPLETE ) {
$alt = sprintf( __( 'Translation to %s is maintained by a different translator', 'sitepress' ), $v[ 'display_name' ] );
} else {
$link = admin_url( 'admin.php?page=' . WPML_TM_FOLDER . '/menu/translations-queue.php&icl_tm_action=create_job&iclpost[]=' . $id . '&translate_to[' . $v[ 'code' ] . ']=1&iclnonce=' . wp_create_nonce( 'pro-translation-icl' ) );
$link .= '&translate_from=' . $current_language;
} else {
$link = '#';
$alt = sprintf( __( "You can't add this translation because you're not a %s translator. <a%s>Learn more.</a>", 'sitepress' ), $v[ 'display_name' ], ' href="https://wpml.org/?page_id=52218"' );
break;
if ( $this->have_icl_translator( $src_lang, $v[ 'code' ] ) ) {
if ( !isset( $__management_columns_posts_translations[ $id ][ $v[ 'code' ] ] ) )
$job_id = false; else
$job_id = @$iclTranslationManagement->get_translation_job_id( $__management_columns_posts_translations[ $id ][ $v[ 'code' ] ]->trid, $v[ 'code' ] );
if ( $job_id ) {
$link = false;
} else {
} else {
$qs = array();
if ( !empty( $_SERVER[ 'QUERY_STRING' ] ) )
foreach ( $_exp = explode( '&', $_SERVER[ 'QUERY_STRING' ] ) as $q => $qv ) {
$__exp = explode( '=', $qv );
$__exp[ 0 ] = preg_replace( '#\[(.*)\]#', '', $__exp[ 0 ] );
if ( !in_array( $__exp[ 0 ], array( 'icl_tm_action', 'translate_from', 'translate_to', 'iclpost', 'service', 'iclnonce' ) ) ) {
$qs[ $q ] = $qv;
$link = admin_url( 'edit.php?' . join( '&', $qs ) . '&icl_tm_action=send_jobs&translate_from=' . $src_lang . '&translate_to[' . $v[ 'code' ] . ']=1&iclpost[]=' . $id . '&service=icanlocalize&iclnonce=' . wp_create_nonce( 'pro-translation-icl' ) );
} else {
$link = false;
$alt = sprintf( __( 'Get %s translators', 'sitepress' ), $v[ 'display_name' ] );
$img = 'add_translators.png';
echo $this->create_icl_popup_link( "@select-translators;{$src_lang};{$v['code']}@", array(
'ar' => 1, 'title' => $alt, 'unload_cb' => 'icl_pt_reload_translation_box'
) ) . '<img style="padding:1px;margin:2px;" border="0" src="' . ICL_PLUGIN_URL . '/res/img/' . $img . '" alt="' . $alt . '" width="16" height="16" />' . '</a>';
break;
default:
global $sitepress;
$trid = $sitepress->get_element_trid( $id, 'post_' . $post_type );
$link = 'post-new.php?post_type=' . $post_type . '&trid=' . $trid . '&lang=' . $v[ 'code' ] . '&source_lang=' . $src_lang;
if ( isset($link) && $link ) {
if ( $link == '#' ) {
icl_pop_info( $alt, ICL_PLUGIN_URL . '/res/img/' . $img, array( 'icon_size' => 16, 'but_style' => array( 'icl_pop_info_but_noabs' ) ) );
} else {
$link = apply_filters( 'wpml_link_to_translation', $link, $exist_translation, $v[ 'code' ] );
echo '<a href="' . $link . '" title="' . $alt . '">';
echo '<img style="padding:1px;margin:2px;" border="0" src="' . ICL_PLUGIN_URL . '/res/img/' . $img . '" alt="' . $alt . '" width="16" height="16" />';
echo '</a>';
function __set_posts_management_column_width()
$w = 22 * count( $this->get_active_languages() );
echo '<style type="text/css">.column-icl_translations{width:' . $w . 'px;}.column-icl_translations img{margin:2px;}</style>';
function display_wpml_footer()
if ( $this->settings[ 'promote_wpml' ] ) {
$wpml_in_other_langs = array( 'es', 'de', 'ja', 'zh-hans' );
$cl = in_array( ICL_LANGUAGE_CODE, $wpml_in_other_langs ) ? ICL_LANGUAGE_CODE . '/' : '';
$wpml_in_other_langs_icl = array( 'es', 'fr', 'de' );
$cl_icl = in_array( ICL_LANGUAGE_CODE, $wpml_in_other_langs_icl ) ? ICL_LANGUAGE_CODE . '/' : '';
$nofollow_wpml = is_home() ? '' : ' rel="nofollow"';
if ( in_array( ICL_LANGUAGE_CODE, array( 'ja', 'zh-hans', 'zh-hant', 'ko' ) ) ) {
// parameters order is set according to teh translation
echo '<p id="wpml_credit_footer">' . sprintf( __( '<a href="%s"%s>Multilingual WordPress</a> by <a href="%s" rel="nofollow">ICanLocalize</a>', 'sitepress' ), 'http://www.icanlocalize.com/site/' . $cl_icl, 'https://wpml.org/' . $cl, $nofollow_wpml ) . '</p>';
} else {
echo '<p id="wpml_credit_footer">' . sprintf( __( '<a href="%s"%s>Multilingual WordPress</a> by <a href="%s" rel="nofollow">ICanLocalize</a>', 'sitepress' ), 'https://wpml.org/' . $cl, $nofollow_wpml, 'http://www.icanlocalize.com/site/' . $cl_icl ) . '</p>';
function xmlrpc_methods( $methods )
$methods[ 'icanlocalize.get_languages_list' ] = array( $this, 'xmlrpc_get_languages_list' );
return $methods;
function xmlrpc_call_actions( $action )
global $HTTP_RAW_POST_DATA, $wpdb;
$params = icl_xml2array( $HTTP_RAW_POST_DATA );
add_filter( 'is_protected_meta', array( $this, 'xml_unprotect_wpml_meta' ), 10, 3 );
switch ( $action ) {
case 'wp.getPage':
case 'blogger.getPost': // yet this doesn't return custom fields
if ( isset( $params[ 'methodCall' ][ 'params' ][ 'param' ][ 1 ][ 'value' ][ 'int' ][ 'value' ] ) ) {
$page_id = $params[ 'methodCall' ][ 'params' ][ 'param' ][ 1 ][ 'value' ][ 'int' ][ 'value' ];
$lang_details = $this->get_element_language_details( $page_id, 'post_' . get_post_type( $page_id ) );
$this->this_lang = $lang_details->language_code; // set the current language to the posts language
update_post_meta( $page_id, '_wpml_language', $lang_details->language_code );
update_post_meta( $page_id, '_wpml_trid', $lang_details->trid );
$res = $this->get_element_translations( $lang_details->trid );
$translations = array();
foreach ( $active_languages as $k => $v ) {
if ( $page_id != $res[ $k ]->element_id ) {
$translations[ $k ] = isset( $res[ $k ]->element_id ) ? $res[ $k ]->element_id : 0;
update_post_meta( $page_id, '_wpml_translations', json_encode( $translations ) );
break;
case 'metaWeblog.getPost':
if ( isset( $params[ 'methodCall' ][ 'params' ][ 'param' ][ 0 ][ 'value' ][ 'int' ][ 'value' ] ) ) {
$page_id = $params[ 'methodCall' ][ 'params' ][ 'param' ][ 0 ][ 'value' ][ 'int' ][ 'value' ];
if ( isset( $res[ $k ] ) && $page_id != $res[ $k ]->element_id ) {
break;
case 'metaWeblog.getRecentPosts':
if ( isset( $params[ 'methodCall' ][ 'params' ][ 'param' ][ 3 ][ 'value' ][ 'int' ][ 'value' ] ) ) {
$num_posts = intval( $params[ 'methodCall' ][ 'params' ][ 'param' ][ 3 ][ 'value' ][ 'int' ][ 'value' ] );
if ( $num_posts ) {
$posts = get_posts( 'suppress_filters=false&numberposts=' . $num_posts );
$lang_details = $this->get_element_language_details( $p->ID, 'post_post' );
update_post_meta( $p->ID, '_wpml_language', $lang_details->language_code );
update_post_meta( $p->ID, '_wpml_trid', $lang_details->trid );
if ( $p->ID != $res[ $k ]->element_id ) {
update_post_meta( $p->ID, '_wpml_translations', json_encode( $translations ) );
break;
case 'metaWeblog.newPost':
$custom_fields = false;
if ( is_array( $params[ 'methodCall' ][ 'params' ][ 'param' ][ 3 ][ 'value' ][ 'struct' ][ 'member' ] ) ) {
foreach ( $params[ 'methodCall' ][ 'params' ][ 'param' ][ 3 ][ 'value' ][ 'struct' ][ 'member' ] as $m ) {
if ( $m[ 'name' ][ 'value' ] == 'custom_fields' ) {
$custom_fields_raw = $m[ 'value' ][ 'array' ][ 'data' ][ 'value' ];
break;
if ( !empty( $custom_fields_raw ) ) {
foreach ( $custom_fields_raw as $cf ) {
$key = $value = null;
foreach ( $cf[ 'struct' ][ 'member' ] as $m ) {
if ( $m[ 'name' ][ 'value' ] == 'key' )
$key = $m[ 'value' ][ 'string' ][ 'value' ]; elseif ( $m[ 'name' ][ 'value' ] == 'value' )
$value = $m[ 'value' ][ 'string' ][ 'value' ];
if ( $key !== null && $value !== null )
$custom_fields[ $key ] = $value;
if ( is_array( $custom_fields ) && isset( $custom_fields[ '_wpml_language' ] ) && isset( $custom_fields[ '_wpml_trid' ] ) ) {
$icl_post_language = $custom_fields[ '_wpml_language' ];
$icl_trid = $custom_fields[ '_wpml_trid' ];
$post_type = $params[ 'methodCall' ][ 'params' ][ 'param' ][ 3 ][ 'value' ][ 'struct' ][ 'member' ][ 2 ][ 'value' ][ 'string' ][ 'value' ];
if ( !$wpdb->get_var( "SELECT translation_id FROM {$wpdb->prefix}icl_translations WHERE element_type='post_{$post_type}' AND trid={$icl_trid} AND language_code='{$icl_post_language}'" ) ) {
$_POST[ 'icl_post_language' ] = $icl_post_language;
$_POST[ 'icl_trid' ] = $icl_trid;
} else {
$IXR_Error = new IXR_Error( 401, __( 'A translation for this post already exists', 'sitepress' ) );
echo $IXR_Error->getXml();
exit( 1 );
break;
case 'metaWeblog.editPost':
$post_id = $params[ 'methodCall' ][ 'params' ][ 'param' ][ 0 ][ 'value' ][ 'int' ][ 'value' ];
if ( !$post_id ) {
break;
$custom_fields = $params[ 'methodCall' ][ 'params' ][ 'param' ][ 3 ][ 'value' ][ 'struct' ][ 'member' ][ 3 ][ 'value' ][ 'array' ][ 'data' ][ 'value' ];
if ( is_array( $custom_fields ) ) {
$icl_trid = false;
$icl_post_language = false;
foreach ( $custom_fields as $cf ) {
if ( $cf[ 'struct' ][ 'member' ][ 0 ][ 'value' ][ 'string' ][ 'value' ] == '_wpml_language' ) {
$icl_post_language = $cf[ 'struct' ][ 'member' ][ 1 ][ 'value' ][ 'string' ][ 'value' ];
} elseif ( $cf[ 'struct' ][ 'member' ][ 0 ][ 'value' ][ 'string' ][ 'value' ] == '_wpml_trid' ) {
$icl_trid = $cf[ 'struct' ][ 'member' ][ 1 ][ 'value' ][ 'string' ][ 'value' ];
$epost_id = $wpdb->get_var( "SELECT element_id FROM {$wpdb->prefix}icl_translations WHERE element_type='post_post'
AND trid={$icl_trid} AND language_code='{$icl_post_language}'" );
if ( $icl_trid && $icl_post_language && ( !$epost_id || $epost_id == $post_id ) ) {
} else {
$IXR_Error = new IXR_Error( 401, __( 'A translation in this language already exists', 'sitepress' ) );
exit( 1 );
break;
function xmlrpc_get_languages_list( $lang )
global $wpdb;
if ( !is_null( $lang ) ) {
if ( !$wpdb->get_var( "SELECT code FROM {$wpdb->prefix}icl_languages WHERE code='" . esc_sql( $lang ) . "'" ) ) {
$IXR_Error = new IXR_Error( 401, __( 'Invalid language code', 'sitepress' ) );
exit( 1 );
$this->admin_language = $lang;
define( 'WP_ADMIN', true ); // hack - allow to force display language
$active_languages = $this->get_active_languages( true );
return $active_languages;
function xml_unprotect_wpml_meta( $protected, $meta_key, $meta_type )
$metas_list = array( '_wpml_trid', '_wpml_translations', '_wpml_language' );
if ( in_array( $meta_key, $metas_list, true ) ) {
$protected = false;
return $protected;
function get_current_action_step()
global $wpdb;
$icl_lang_status = $this->settings[ 'icl_lang_status' ];
$has_translators = false;
foreach ( (array)$icl_lang_status as $k => $lang ) {
if ( !is_numeric( $k ) )
continue;
if ( !empty( $lang[ 'translators' ] ) ) {
$has_translators = true;
break;
if ( !$has_translators ) {
return 0;
$cms_count = $wpdb->get_var( "SELECT COUNT(rid) FROM {$wpdb->prefix}icl_core_status WHERE status=3" );
if ( $cms_count > 0 ) {
return 4;
$cms_count = $wpdb->get_var( "SELECT COUNT(rid) FROM {$wpdb->prefix}icl_core_status WHERE 1" );
if ( $cms_count == 0 ) {
// No documents sent yet
return 1;
if ( $this->settings[ 'icl_balance' ] <= 0 ) {
return 2;
return 3;
function show_action_list()
$steps = array(
__( 'Select translators', 'sitepress' ), __( 'Send documents to translation', 'sitepress' ), __( 'Deposit payment', 'sitepress' ), __( 'Translations will be returned to your site', 'sitepress' )
$current_step = $this->get_current_action_step();
if ( $current_step >= sizeof( $steps ) ) {
// everything is already setup.
if ( $this->settings[ 'last_action_step_shown' ] ) {
return '';
} else {
$this->save_settings( array( 'last_action_step_shown' => 1 ) );
$output = '
<h3>' . __( 'Setup check list', 'sitepress' ) . '</h3>
<ul id="icl_check_list">';
foreach ( $steps as $index => $step ) {
$step_data = $step;
if ( $index < $current_step || ( $index == 4 && $this->settings[ 'icl_balance' ] > 0 ) ) {
$attr = ' class="icl_tick"';
} else {
$attr = ' class="icl_next_step"';
if ( $index == $current_step ) {
$output .= '<li class="icl_info"><b>' . $step_data . '</b>';
} else {
$output .= '<li' . $attr . '>' . $step_data . '';
$output .= "\n";
$output .= '
return $output;
function show_pro_sidebar()
$output = '<div id="icl_sidebar" class="icl_sidebar" style="display:none">';
$action_list = $this->show_action_list();
$show_minimized = $this->settings[ 'icl_sidebar_minimized' ];
if ( $action_list != '' ) {
$show_minimized = false;
if ( $show_minimized ) {
$output .= '<div id="icl_sidebar_full" style="display:none">';
} else {
$output .= '<div id="icl_sidebar_full">';
if ( $action_list == '' ) {
$output .= '<a id="icl_sidebar_hide" href="#">hide</a>';
} else {
$output .= $action_list;
$output .= '<h3>' . __( 'Help', 'sitepress' ) . '</h3>';
$output .= '<div id="icl_help_links"></div>';
$output .= wp_nonce_field( 'icl_help_links_nonce', '_icl_nonce_hl', false, false );
$output .= '</div>';
$output .= '<div id="icl_sidebar_hide_div">';
} else {
$output .= '<div id="icl_sidebar_hide_div" style="display:none">';
$output .= '<a id="icl_sidebar_show" href="#"><img width="16" height="16" src="' . ICL_PLUGIN_URL . '/res/img/question1.png' . '" alt="' . __( 'Get help', 'sitepress' ) . '" title="' . __( 'Get help', 'sitepress' ) . '" /></a>';
$output .= wp_nonce_field( 'icl_show_sidebar_nonce', '_icl_nonce_ss', false, false );
return $output;
function meta_generator_tag()
$lids = array();
if($active_languages) {
foreach ( $active_languages as $l ) {
$lids[ ] = $l[ 'id' ];
$stt = join( ",", $lids );
$stt .= ";" . intval( $this->get_icl_translation_enabled() );
printf( '<meta name="generator" content="WPML ver:%s stt:%s" />' . PHP_EOL, ICL_SITEPRESS_VERSION, $stt );
function set_language_cookie()
if ( !headers_sent() ) {
if ( preg_match( '@\.(css|js|png|jpg|gif|jpeg|bmp)@i', basename( preg_replace( '@\?.*$@', '', $_SERVER[ 'REQUEST_URI' ] ) ) ) || isset( $_POST[ 'icl_ajx_action' ] ) || isset( $_POST[ '_ajax_nonce' ] ) || defined( 'DOING_AJAX' ) ) {
return;
$server_host_name = $this->get_server_host_name();
$cookie_domain = defined( 'COOKIE_DOMAIN' ) ? COOKIE_DOMAIN : $server_host_name;
$cookie_path = defined( 'COOKIEPATH' ) ? COOKIEPATH : '/';
setcookie( '_icl_current_language', $this->get_current_language(), time() + 86400, $cookie_path, $cookie_domain );
function update_language_cookie($language_code) {
$_COOKIE[ '_icl_current_language' ] = $language_code;
function get_language_cookie()
static $active_languages = false;
if ( isset( $_COOKIE[ '_icl_current_language' ] ) ) {
$lang = substr( $_COOKIE[ '_icl_current_language' ], 0, 10 );
if(!$active_languages) {
if ( !isset( $active_languages[ $lang ] ) ) {
$lang = $this->get_default_language();
} else {
$lang = '';
return $lang;
// _icl_current_language will have to be replaced with _icl_current_language
function set_admin_language_cookie( $lang = false )
if ( preg_match( '@\.(css|js|png|jpg|gif|jpeg|bmp)@i', basename( preg_replace( '@\?.*$@', '', $_SERVER[ 'REQUEST_URI' ] ) ) ) || isset( $_POST[ 'icl_ajx_action' ] ) || isset( $_POST[ '_ajax_nonce' ] ) ) {
return;
$parts = parse_url( admin_url() );
$cookie_path = $parts[ 'path' ];
if ( $lang === false )
setcookie( '_icl_current_admin_language', $lang, time() + 7200, $cookie_path );
function get_admin_language_cookie()
if ( isset( $_COOKIE[ '_icl_current_admin_language' ] ) ) {
$lang = $_COOKIE[ '_icl_current_admin_language' ];
if ( !isset( $active_languages[ $lang ] ) && $lang != 'all' ) {
} else {
$lang = '';
return $lang;
function reset_admin_language_cookie()
$this->set_admin_language_cookie( $this->get_default_language() );
function rewrite_rules_filter( $value ) {
$current_language = $this->get_current_language();
$default_language = $this->get_default_language();
$directory_for_default_language = false;
$setting_url = $this->get_setting( 'urls' );
if ( $setting_url ) {
$directory_for_default_language = $setting_url[ 'directory_for_default_language' ];
if ( $this->get_setting( 'language_negotiation_type' ) == 1 && ( $current_language != $default_language || $directory_for_default_language ) ) {
foreach ( (array)$value as $k => $v ) {
$value[ $current_language . '/' . $k ] = $v;
unset( $value[ $k ] );
$value[ $current_language . '/?$' ] = 'index.php';
return $value;
function is_rtl( $lang = false )
if ( is_admin() ) {
if ( empty( $lang ) )
$lang = $this->get_admin_language();
} else {
return in_array( $lang, array( 'ar', 'he', 'fa', 'ku' ) );
function get_translatable_documents( $include_not_synced = false )
global $wp_post_types;
$icl_post_types = array();
$attachment_is_translatable = $this->is_translated_post_type( 'attachment' );
$exceptions = array( 'revision', 'nav_menu_item' );
if(!$attachment_is_translatable) {
$exceptions[] = 'attachment';
foreach ( $wp_post_types as $k => $v ) {
if ( !in_array( $k, $exceptions ) ) {
if ( !$include_not_synced && ( empty( $this->settings[ 'custom_posts_sync_option' ][ $k ] ) || $this->settings[ 'custom_posts_sync_option' ][ $k ] != 1 ) && !in_array( $k, array( 'post', 'page' ) ) )
continue;
$icl_post_types[ $k ] = $v;
$icl_post_types = apply_filters( 'get_translatable_documents', $icl_post_types );
return $icl_post_types;
function get_translatable_taxonomies( $include_not_synced = false, $object_type = 'post' )
global $wp_taxonomies;
$t_taxonomies = array();
if ( $include_not_synced ) {
if ( in_array( $object_type, $wp_taxonomies[ 'post_tag' ]->object_type ) )
$t_taxonomies[ ] = 'post_tag';
if ( in_array( $object_type, $wp_taxonomies[ 'category' ]->object_type ) )
$t_taxonomies[ ] = 'category';
foreach ( $wp_taxonomies as $taxonomy_name => $taxonomy ) {
// exceptions
if ( 'post_format' == $taxonomy_name )
continue;
if ( in_array( $object_type, $taxonomy->object_type ) && !empty( $this->settings[ 'taxonomies_sync_option' ][ $taxonomy_name ] ) ) {
$t_taxonomies[ ] = $taxonomy_name;
if ( has_filter( 'get_translatable_taxonomies' ) ) {
$filtered = apply_filters( 'get_translatable_taxonomies', array( 'taxs' => $t_taxonomies, 'object_type' => $object_type ) );
$t_taxonomies = $filtered[ 'taxs' ];
if ( empty( $t_taxonomies ) )
return $t_taxonomies;
function is_translated_taxonomy( $tax )
global $sitepress_settings;
$settings = empty( $sitepress_settings ) ? $this->settings : $sitepress_settings;
$ret = false;
if ( is_scalar( $tax ) ) {
switch ( $tax ) {
case 'category':
case 'post_tag':
$ret = true;
break;
default:
if ( isset( $settings[ 'taxonomies_sync_option' ][ $tax ] ) ) {
$ret = $settings[ 'taxonomies_sync_option' ][ $tax ];
} elseif ( isset( $settings[ 'translation-management' ][ 'taxonomies_readonly_config' ][ $tax ] ) && $settings[ 'translation-management' ][ 'taxonomies_readonly_config' ][ $tax ] == 1 ) {
$ret = true;
} else {
$ret = false;
return $ret;
function is_translated_post_type( $type )
$ret = false;
if ( is_scalar( $type ) ) {
switch ( $type ) {
case 'post':
case 'page':
$ret = true;
break;
default:
if ( isset( $settings[ 'custom_posts_sync_option' ][ $type ] ) ) {
$ret = $settings[ 'custom_posts_sync_option' ][ $type ];
} elseif ( isset( $settings[ 'translation-management' ][ 'custom_types_readonly_config' ][ $type ] ) ) {
$ret = $settings[ 'translation-management' ][ 'custom_types_readonly_config' ][ $type ];
} else {
$ret = false;
return $ret;
function print_translatable_custom_content_status()
$icl_post_types = $this->get_translatable_documents( true );
$cposts = array();
$notice = '';
foreach ( $icl_post_types as $k => $v ) {
if ( !in_array( $k, array( 'post', 'page' ) ) ) {
$cposts[ $k ] = $v;
foreach ( $cposts as $k => $cpost ) {
if ( !isset( $this->settings[ 'custom_posts_sync_option' ][ $k ] ) ) {
$cposts_sync_not_set[ ] = $cpost->labels->name;
if ( defined( 'WPML_TM_VERSION' ) && !empty( $cposts_sync_not_set ) ) {
$notice = '<p class="updated fade">';
$notice .= sprintf( __( "You haven't set your <a %s>synchronization preferences</a> for these custom posts: %s. Default value was selected.", 'sitepress' ), 'href="admin.php?page=' . WPML_TM_FOLDER . '/menu/main.php&sm=mcsetup"', '' . join( ', ', $cposts_sync_not_set ) . '' );
$notice .= '</p>';
if ( defined( 'WPML_TM_VERSION' ) && $icl_post_types ) {
global $wpdb, $sitepress_settings;
$custom_posts = array();
$custom_posts[ $k ] = $v;
foreach ( $custom_posts as $k => $custom_post ) {
$_has_slug = isset( $custom_post->rewrite[ 'slug' ] ) && $custom_post->rewrite[ 'slug' ];
$_translate = !empty($sitepress_settings['posts_slug_translation']['types'][$k]);
if ( $_has_slug ) {
if (isset($sitepress_settings[ 'st' ]) && $default_language != $sitepress_settings[ 'st' ][ 'strings_language' ] ) {
$string_id_prepared = $wpdb->prepare( "
SELECT s.id FROM {$wpdb->prefix}icl_strings s
JOIN {$wpdb->prefix}icl_string_translations st
ON st.string_id = s.id
WHERE st.language=%s AND s.value=%s AND s.name LIKE %s
", array( $default_language, $custom_post->rewrite[ 'slug' ], 'URL slug: %' ) );
} else {
$string_id_prepared = $wpdb->prepare( "SELECT id FROM {$wpdb->prefix}icl_strings WHERE name = %s AND value = %s ", array(
'Url slug: ' . $custom_post->rewrite[ 'slug' ],
$string_id = $wpdb->get_var( $string_id_prepared );
if ( $_translate && !$string_id ) {
$message = sprintf( __( "%s slugs are set to be translated, but they are missing their translation", 'sitepress'), $custom_post->labels->name);
$notice .= ICL_AdminNotifier::displayInstantMessage( $message, 'error', 'below-h2', true );
$ctaxonomies = array_diff( array_keys( (array)$wp_taxonomies ), array( 'post_tag', 'category', 'nav_menu', 'link_category', 'post_format' ) );
foreach ( $ctaxonomies as $ctax ) {
if ( !isset( $this->settings[ 'taxonomies_sync_option' ][ $ctax ] ) ) {
$tax_sync_not_set[ ] = $wp_taxonomies[ $ctax ]->label;
if ( defined( 'WPML_TM_VERSION' ) && !empty( $tax_sync_not_set ) ) {
$notice .= '<p class="updated">';
$notice .= sprintf( __( "You haven't set your <a %s>synchronization preferences</a> for these taxonomies: %s. Default value was selected.", 'sitepress' ), 'href="admin.php?page=' . WPML_TM_FOLDER . '/menu/main.php&sm=mcsetup"', '' . join( ', ', $tax_sync_not_set ) . '' );
$notice .= '</p>';
echo $notice;
function dashboard_widget_setup()
if ( current_user_can( 'manage_options' ) ) {
$dashboard_widgets_order = (array)get_user_option( "meta-box-order_dashboard" );
$icl_dashboard_widget_id = 'icl_dashboard_widget';
$all_widgets = array();
foreach ( $dashboard_widgets_order as $v ) {
$all_widgets = array_merge( $all_widgets, explode( ',', $v ) );
if ( !in_array( $icl_dashboard_widget_id, $all_widgets ) ) {
$install = true;
} else {
$install = false;
wp_add_dashboard_widget( $icl_dashboard_widget_id, sprintf( __( 'Multi-language | WPML %s', 'sitepress' ), ICL_SITEPRESS_VERSION ), array( $this, 'dashboard_widget' ), null );
if ( $install ) {
//FIXME: reported one case of NOTICE: wp-content/plugins/sitepress-multilingual-cms/sitepress.class.php:7815 - Undefined index: side
$dashboard_widgets_order[ 'side' ] = $icl_dashboard_widget_id . ',' . @strval( $dashboard_widgets_order[ 'side' ] );
$user = wp_get_current_user();
update_user_option( $user->ID, 'meta-box-order_dashboard', $dashboard_widgets_order, true );
function dashboard_widget()
do_action( 'icl_dashboard_widget_notices' );
include_once ICL_PLUGIN_PATH . '/menu/dashboard-widget.php';
function verify_post_translations( $post_type ) {
global $wpdb;
$active_languages = count( $this->get_active_languages() );
$sql = "
SELECT p1.ID, t.translation_id
INNER JOIN {$wpdb->posts} p1
ON t.element_id = p1.ID
LEFT JOIN {$wpdb->prefix}icl_translations tt
ON t.trid = tt.trid
WHERE t.element_type = %s
AND t.source_language_code IS null
GROUP BY p1.ID, p1.post_parent
HAVING count(tt.language_code) < %d
$sql_prepared = $wpdb->prepare( $sql, array( 'post_' . $post_type, $active_languages ) );
$results = $wpdb->get_results( $sql_prepared );
if ( $results ) {
foreach ( $results as $result ) {
$id = $result->ID;
$translation_id = $result->translation_id;
if ( !$translation_id ) {
$this->set_element_language_details( $id, 'post_' . $post_type, false, $this->get_default_language() );
} else {
$post_ids = $wpdb->get_col( "SELECT ID FROM {$wpdb->posts} WHERE post_type='{$post_type}' AND post_status <> 'auto-draft'" );
if ( !empty( $post_ids ) ) {
foreach ( $post_ids as $id ) {
$translation_id_prepared = $wpdb->prepare( "SELECT translation_id FROM {$wpdb->prefix}icl_translations WHERE element_id=%d AND element_type=%s", array( $id, 'post_' . $post_type ) );
$translation_id = $wpdb->get_var( $translation_id_prepared );
function verify_taxonomy_translations( $taxonomy )
global $wpdb;
$element_ids_prepared = $wpdb->prepare( "SELECT term_taxonomy_id FROM {$wpdb->term_taxonomy} WHERE taxonomy=%s", $taxonomy);
$element_ids = $wpdb->get_col( $element_ids_prepared );
if ( !empty( $element_ids ) ) {
foreach ( $element_ids as $id ) {
$translation_id_prepared = $wpdb->prepare( "SELECT translation_id FROM {$wpdb->prefix}icl_translations WHERE element_id=%d AND element_type=%s", $id, 'tax_' . $taxonomy);
$this->set_element_language_details( $id, 'tax_' . $taxonomy, false, $this->get_default_language() );
function copy_from_original()
global $wpdb;
$show = false;
$trid = false;
$source_lang = false;
$source_lang_name = false;
$disabled = '';
if ( isset( $_GET[ 'source_lang' ] ) && isset( $_GET[ 'trid' ] ) ) {
$source_lang = $_GET[ 'source_lang' ];
$trid = intval( $_GET[ 'trid' ] );
$_lang_details = $this->get_language_details( $source_lang );
$source_lang_name = $_lang_details[ 'display_name' ];
$show = true;
} elseif ( isset( $_GET[ 'post' ] ) && isset( $_GET[ 'lang' ] ) && $_GET[ 'lang' ] != $this->get_default_language() ) {
global $post;
if ( trim( $post->post_content ) ) {
$disabled = ' disabled="disabled"';
$trid = $this->get_element_trid( $post->ID, 'post_' . $post->post_type );
$source_lang = $wpdb->get_var( $wpdb->prepare( "SELECT language_code FROM {$wpdb->prefix}icl_translations WHERE source_language_code IS NULL AND trid=%d", $trid ) );
$show = true && $source_lang;
if ( $show ) {
wp_nonce_field( 'copy_from_original_nonce', '_icl_nonce_cfo_' . $trid );
echo '<input id="icl_cfo" class="button-secondary" type="button" value="' . sprintf( __( 'Copy content from %s', 'sitepress' ), $source_lang_name ) . '"
onclick="icl_copy_from_original(\'' . esc_js( $source_lang ) . '\', \'' . esc_js( $trid ) . '\')"' . $disabled . '/>';
icl_pop_info( __( "This operation copies the content from the original language onto this translation. It's meant for when you want to start with the original content, but keep translating in this language. This button is only enabled when there's no content in the editor.", 'sitepress' ), 'question' );
echo '<br clear="all" />';
function wp_upgrade_locale( $locale )
if ( defined( 'WPLANG' ) && WPLANG ) {
$locale = WPLANG;
} else {
$locale = ICL_WP_UPDATE_LOCALE;
return $locale;
function admin_language_switcher_legacy()
global $pagenow, $wpdb;
$all_languages_enabled = true;
$current_page = basename( $_SERVER[ 'SCRIPT_NAME' ] );
// individual translations
$is_post = false;
$is_tax = false;
$is_menu = false;
$post_type = false;
$trid = false;
$translations = false;
switch ( $pagenow ) {
case 'post.php':
$is_post = true;
$all_languages_enabled = false;
$post_id = @intval( $_GET[ 'post' ] );
$post = get_post( $post_id );
$trid = $this->get_element_trid( $post_id, 'post_' . $post->post_type );
$translations = $this->get_element_translations( $trid, 'post_' . $post->post_type, true );
break;
case 'post-new.php':
if ( isset( $_GET[ 'trid' ] ) ) {
$translations = $this->get_element_translations( $trid, 'post_' . $post_type, true );
$is_post = true;
break;
case 'edit-tags.php':
$is_tax = true;
if ( isset( $_GET[ 'action' ] ) && $_GET[ 'action' ] == 'edit' ) {
$term_id = @intval( $_GET[ 'tag_ID' ] );
$taxonomy = $_GET[ 'taxonomy' ];
$term_tax_id = $wpdb->get_var( $wpdb->prepare( "SELECT term_taxonomy_id FROM {$wpdb->term_taxonomy} WHERE taxonomy=%s AND term_id=%d", $taxonomy, $term_id ) );
$trid = $this->get_element_trid( $term_tax_id, 'tax_' . $taxonomy );
$translations = $this->get_element_translations( $trid, 'tax_' . $taxonomy, true );
break;
case 'nav-menus.php':
$is_menu = true;
if ( isset( $_GET[ 'menu' ] ) && $_GET[ 'menu' ] ) {
$menu_id = $_GET[ 'menu' ];
$trid = $trid = $this->get_element_trid( $menu_id, 'tax_nav_menu' );
$translations = $this->get_element_translations( $trid, 'tax_nav_menu', true );
break;
foreach ( $this->get_active_languages() as $lang ) {
$current_page_lang = $current_page;
parse_str( $_SERVER[ 'QUERY_STRING' ], $query_vars );
unset( $query_vars[ 'lang' ], $query_vars[ 'admin_bar' ] );
if ( $is_post ) {
if ( isset( $translations[ $lang[ 'code' ] ] ) && isset( $translations[ $lang[ 'code' ] ]->element_id ) ) {
$query_vars[ 'post' ] = $translations[ $lang[ 'code' ] ]->element_id;
unset( $query_vars[ 'source_lang' ] );
$current_page_lang = 'post.php';
$query_vars[ 'action' ] = 'edit';
} else {
$current_page_lang = 'post-new.php';
if ( isset( $post ) ) {
$query_vars[ 'post_type' ] = $post->post_type;
$query_vars[ 'source_lang' ] = $current_language;
} else {
$query_vars[ 'post_type' ] = $post_type;
$query_vars[ 'trid' ] = $trid;
unset( $query_vars[ 'post' ], $query_vars[ 'action' ] );
} elseif ( $is_tax ) {
$query_vars[ 'tag_ID' ] = $translations[ $lang[ 'code' ] ]->element_id;
} else {
unset( $query_vars[ 'tag_ID' ], $query_vars[ 'action' ] );
} elseif ( $is_menu ) {
if ( !empty( $menu_id ) ) {
if ( isset( $translations[ $lang[ 'code' ] ]->element_id ) ) {
$query_vars[ 'menu' ] = $translations[ $lang[ 'code' ] ]->element_id;
} else {
$query_vars[ 'menu' ] = 0;
$query_string = http_build_query( $query_vars );
$query = '?';
if ( !empty( $query_string ) ) {
$query .= $query_string . '&';
$query .= 'lang=' . $lang[ 'code' ]; // the default language need to specified explictly yoo in order to set the lang cookie
$link_url = admin_url( $current_page_lang . $query );
$flag = $this->get_flag( $lang[ 'code' ] );
if ( $flag->from_template ) {
$flag_url = $wp_upload_dir[ 'baseurl' ] . '/flags/' . $flag->flag;
} else {
$flag_url = ICL_PLUGIN_URL . '/res/flags/' . $flag->flag;
$languages_links[ $lang[ 'code' ] ] = array(
'url' => $link_url . '&admin_bar=1', 'current' => $lang[ 'code' ] == $current_language, 'anchor' => $lang[ 'display_name' ],
'flag' => '<img class="admin_iclflag" src="' . $flag_url . '" alt="' . $lang[ 'code' ] . '" width="18" height="12" />'
if ( $all_languages_enabled ) {
$query = '?';
$query .= 'lang=all';
$link_url = admin_url( basename( $_SERVER[ 'SCRIPT_NAME' ] ) . $query );
$languages_links[ 'all' ] = array(
'url' => $link_url, 'current' => 'all' == $current_language, 'anchor' => __( 'All languages', 'sitepress' ),
'flag' => '<img class="admin_iclflag" src="' . ICL_PLUGIN_URL . '/res/img/icon16.png" alt="all" width="16" height="16" />'
} else {
// set the default language as current
if ( 'all' == $current_language ) {
$languages_links[ $this->get_default_language() ][ 'current' ] = true;
include ICL_PLUGIN_PATH . '/menu/admin-language-switcher.php';
function admin_language_switcher()
if(!SitePress::check_settings_integrity()) return;
/** @var $wp_admin_bar WP_Admin_Bar */
global $wpdb, $wp_admin_bar, $pagenow, $mode;
$post_type = false;
$trid = false;
$languages_links = array();
$is_post = false;
$is_tax = false;
$is_menu = false;
case 'post.php':
$is_post = true;
$post_language = $this->get_language_for_element( $post_id, 'post_' . get_post_type( $post_id ) );
if ( $post_language && $post_language != $current_language ) {
$this->switch_lang( $post_language );
break;
$is_post = true;
break;
$is_tax = true;
$taxonomy = $_GET['taxonomy'];
$term_tax_id = 0;
if ( isset( $_GET[ 'tag_ID' ] ) ) {
if ( $term_tax_id ) {
if ( $trid ) {
break;
$is_menu = true;
break;
case 'upload.php':
if ( $mode == 'grid' ) {
break;
if ( isset( $_SERVER[ 'QUERY_STRING' ] ) ) {
} else {
$query_vars = array();
if ( $is_post ) {
} else {
} else {
} else {
} else {
$query = '?';
$query .= 'lang=' . $lang[ 'code' ]; // the default language need to specified explicitly yoo in order to set the lang cookie
} else {
'flag' => '<img class="icl_als_iclflag" src="' . $flag_url . '" alt="' . $lang[ 'code' ] . '" width="18" height="12" />'
$query = '?';
'flag' => '<img class="icl_als_iclflag" src="' . ICL_PLUGIN_URL . '/res/img/icon16.png" alt="all" width="16" height="16" />'
} else {
$current_language = $this->get_default_language();
$languages_links[ $current_language ][ 'current' ] = true;
$parent = 'WPML_ALS';
$lang = $languages_links[ $current_language ];
// Current language
$wp_admin_bar->add_menu( array(
'parent' => false, 'id' => $parent,
'title' => $lang[ 'flag' ] . ' ' . $lang[ 'anchor' ] . '  <img title="' . __( 'help', 'sitepress' ) . '" id="wpml_als_help_link" src="' . ICL_PLUGIN_URL . '/res/img/question1.png" alt="' . __( 'help', 'sitepress' ) . '" width="16" height="16"/>',
'href' => false, 'meta' => array(
'title' => __( 'Showing content in:', 'sitepress' ) . ' ' . $lang[ 'anchor' ],
if ( $languages_links ) {
foreach ( $languages_links as $code => $lang ) {
if ( $code == $current_language )
continue;
'parent' => $parent, 'id' => $parent . '_' . $code, 'title' => $lang[ 'flag' ] . ' ' . $lang[ 'anchor' ], 'href' => $lang[ 'url' ], 'meta' => array(
'title' => __( 'Show content in:', 'sitepress' ) . ' ' . $lang[ 'anchor' ],
add_action( 'all_admin_notices', array( $this, '_admin_language_switcher_help_popup' ) );
function _admin_language_switcher_help_popup()
echo '<div id="icl_als_help_popup" class="icl_cyan_box icl_pop_info">';
echo '<img class="icl_pop_info_but_close" align="right" src="' . ICL_PLUGIN_URL . '/res/img/ico-close.png" width="12" height="12" alt="x" />';
printf( __( 'This language selector determines which content to display. You can choose items in a specific language or in all languages. To change the language of the WordPress Admin interface, go to <a%s>your profile</a>.', 'sitepress' ), ' href="' . admin_url( 'profile.php' ) . '"' );
echo '</div>';
function admin_notices( $message, $class = "updated" )
static $hook_added = 0;
$this->_admin_notices[ ] = array( 'class' => $class, 'message' => $message );
if ( !$hook_added )
add_action( 'admin_notices', array( $this, '_admin_notices_hook' ) );
$hook_added = 1;
function _admin_notices_hook()
if ( !empty( $this->_admin_notices ) )
foreach ( $this->_admin_notices as $n ) {
echo '<div class="' . $n[ 'class' ] . '">';
echo '<p>' . $n[ 'message' ] . '</p>';
echo '</div>';
* Adjust template (taxonomy-)$taxonomy-$term.php for translated term slugs and IDs
* @since 3.1
* @param string $template
* @return string The template filename if found.
function slug_template($template){
global $wp_query;
$term = $wp_query->get_queried_object();
//Taxonomies
if(!isset($term) || !$term) return $template;
$taxonomy = $term->taxonomy;
if(!isset($taxonomy) || !$taxonomy) return $template;
$templates = array();
$template_prefix = 'taxonomy-';
$is_taxonomy = true;
if(in_array($taxonomy, array('category','tag'))) {
$template_prefix = '';
$is_taxonomy = false;
remove_filter( 'get_term', array( $this, 'get_term_adjust_id' ), 1 );
if (!$is_taxonomy || $this->is_translated_taxonomy( $taxonomy ) && $current_language != $default_language ) {
$current_term = get_term_by( "id", $term->term_id, $taxonomy );
if ( $current_term ) {
$templates[ ] = "$template_prefix$taxonomy-{$current_language}-{$current_term->slug}.php";
$templates[ ] = "$template_prefix$taxonomy-{$current_language}-{$term->term_id}.php";
$templates[ ] = "$template_prefix$taxonomy-{$current_language}.php";
$templates[ ] = "$template_prefix$taxonomy-{$current_term->slug}.php";
$templates[ ] = "$template_prefix$taxonomy-{$term->term_id}.php";
$original_term_id = icl_object_id( $term->term_id, $taxonomy, true, $default_language );
$original_term = get_term_by( "id", $original_term_id, $taxonomy );
if ( $original_term ) {
$templates[ ] = "$template_prefix$taxonomy-{$current_language}-{$original_term->slug}.php";
$templates[ ] = "$template_prefix$taxonomy-{$current_language}-{$original_term_id}.php";
$templates[ ] = "$template_prefix$taxonomy-{$original_term->slug}.php";
$templates[ ] = "$template_prefix$taxonomy-{$original_term_id}.php";
$templates[ ] = "$template_prefix$taxonomy.php";
if ( $is_taxonomy ) {
$templates[ ] = 'taxonomy-{$current_language}.php';
$templates[ ] = 'taxonomy.php';
$templates = array_unique($templates);
add_filter( 'get_term', array( $this, 'get_term_adjust_id' ), 1, 1 );
$new_template = locate_template( $templates );
if($new_template) {
$template = $new_template;
return $template;
function setup_canonical_urls()
global $wp_the_query;
// Yoast Exception
global $wpseo_front;
if ( isset( $wpseo_front ) && has_filter( 'wp_head', array( $wpseo_front, 'head' ) ) )
return;
if ( is_singular() ) {
$id = $wp_the_query->get_queried_object_id();
$master_post_id = get_post_meta( $id, '_icl_lang_duplicate_of', true );
if ( $id && $master_post_id != $id ) {
remove_action( 'wp_head', 'rel_canonical' );
add_action( 'wp_head', array( $this, 'rel_canonical' ) );
function rel_canonical()
if ( $master_post_id = get_post_meta( $id, '_icl_lang_duplicate_of', true ) ) {
$link = get_permalink( $master_post_id );
echo "<link rel='canonical' href='$link' />\n";
function head_langs()
$languages = $this->get_ls_languages( array( 'skip_missing' => true ) );
// If there are translations and is not paged content...
//Renders head alternate links only on certain conditions
$the_post = get_post();
$the_id = $the_post ? $the_post->ID : false;
$is_valid = count( $languages ) > 1 && !is_paged() && ( ( ( is_single() || is_page() ) && $the_id && get_post_status( $the_id ) == 'publish' ) || ( is_home() || is_front_page() || is_archive() ) );
if ( $is_valid ) {
foreach ( $languages as $code => $lang ) {
printf( '<link rel="alternate" hreflang="%s" href="%s" />' . PHP_EOL, $this->get_language_tag( $code ), str_replace( '&', '&', $lang[ 'url' ] ) );
function allowed_redirect_hosts( $hosts )
if ( $this->settings[ 'language_negotiation_type' ] == 2 ) {
foreach ( $this->settings[ 'language_domains' ] as $code => $url ) {
if ( !empty( $this->active_languages[ $code ] ) ) {
$parts = parse_url( $url );
if ( !in_array( $parts[ 'host' ], $hosts ) ) {
$hosts[ ] = $parts[ 'host' ];
return $hosts;
function icl_nonces()
//@since 3.1 Calls made only when in Translation Management pages
$allowed_pages = array();
if(defined('WPML_TM_FOLDER')) {
$allowed_pages[] = WPML_TM_FOLDER . '/menu/main.php';
if(!isset($_REQUEST['page']) || !in_array($_REQUEST['page'], $allowed_pages)) {
return;
//messages
wp_nonce_field( 'icl_messages_nonce', '_icl_nonce_m' );
wp_nonce_field( 'icl_show_reminders_nonce', '_icl_nonce_sr' );
//For when it will be possible to add custom bulk actions
function bulk_actions($actions) {
$actions['duplicate_all'] = 'duplicate_all';
foreach($active_languages as $language_code => $language_name) {
$actions['duplicate_' . $language_code] = 'duplicate_' . $language_code;
return $actions;
* Returns SERVER_NAME, or HTTP_HOST if the first is not available
* @return mixed
private function get_server_host_name() {
if(!isset($_SERVER[ 'HTTP_HOST' ])) {
$host = $_SERVER[ 'SERVER_NAME' ];
if(isset( $_SERVER[ 'SERVER_PORT' ] ) && $_SERVER[ 'SERVER_PORT' ]!=80) {
$host .= ':' . $_SERVER[ 'SERVER_PORT' ];
} else {
$host = $_SERVER[ 'HTTP_HOST' ];
//Removes standard ports 443 (80 should be already omitted in all cases)
$result = preg_replace( "@:[443]+([/]?)@", '$1', $host );
return $result;
public static function get_installed_plugins() {
if(!function_exists('get_plugins')) {
require_once(ABSPATH . 'wp-admin/includes/plugin.php');
$wp_plugins = get_plugins();
$wpml_plugins_list = array(
'WPML Multilingual CMS' => array( 'installed' => false, 'active' => false, 'file' => false, 'plugin' => false, 'slug' => 'sitepress-multilingual-cms' ),
'WPML CMS Nav' => array( 'installed' => false, 'active' => false, 'file' => false, 'plugin' => false, 'slug' => 'wpml-cms-nav' ),
'WPML String Translation' => array( 'installed' => false, 'active' => false, 'file' => false, 'plugin' => false, 'slug' => 'wpml-string-translation' ),
'WPML Sticky Links' => array( 'installed' => false, 'active' => false, 'file' => false, 'plugin' => false, 'slug' => 'wpml-sticky-links' ),
'WPML Translation Management' => array( 'installed' => false, 'active' => false, 'file' => false, 'plugin' => false, 'slug' => 'wpml-translation-management' ),
'WPML Translation Analytics' => array( 'installed' => false, 'active' => false, 'file' => false, 'plugin' => false, 'slug' => 'wpml-translation-analytics' ),
'WPML XLIFF' => array( 'installed' => false, 'active' => false, 'file' => false, 'plugin' => false, 'slug' => 'wpml-xliff' ),
'WPML Media' => array( 'installed' => false, 'active' => false, 'file' => false, 'plugin' => false, 'slug' => 'wpml-media' ),
'WooCommerce Multilingual' => array( 'installed' => false, 'active' => false, 'file' => false, 'plugin' => false, 'slug' => 'woocommerce-multilingual' ),
'JigoShop Multilingual' => array( 'installed' => false, 'active' => false, 'file' => false, 'plugin' => false, 'slug' => 'jigoshop-multilingual' ),
'Gravity Forms Multilingual' => array( 'installed' => false, 'active' => false, 'file' => false, 'plugin' => false, 'slug' => 'gravityforms-multilingual' ),
'CRED Frontend Translation' => array( 'installed' => false, 'active' => false, 'file' => false, 'plugin' => false, 'slug' => 'cred-frontend-translation' ),
'Installer' => array( 'installed' => false, 'active' => false, 'file' => false, 'plugin' => false, 'slug' => 'installer' ),
foreach ( $wpml_plugins_list as $wpml_plugin_name => $v ) {
foreach ( $wp_plugins as $file => $plugin ) {
$plugin_name = $plugin[ 'Name' ];
if ( $plugin_name == $wpml_plugin_name ) {
$wpml_plugins_list[ $plugin_name ][ 'installed' ] = true;
$wpml_plugins_list[ $plugin_name ][ 'plugin' ] = $plugin;
$wpml_plugins_list[ $plugin_name ][ 'file' ] = $file;
return $wpml_plugins_list;
public static function check_settings_integrity() {
if(wpml_is_ajax()) return true;
if ( isset( $_GET[ 'debug_action' ]) && $_GET[ 'nonce' ] == wp_create_nonce( $_GET[ 'debug_action' ] ) ) {
if($_GET[ 'debug_action' ] == 'reset_wpml_settings') {
$referrer = isset($_SERVER['HTTP_REFERER']) && $_SERVER['HTTP_REFERER'] ? $_SERVER['HTTP_REFERER'] : get_admin_url();
$current_settings = get_option( 'icl_sitepress_settings' );
unset($current_settings['setup_complete']);
unset($current_settings['setup_wizard_step']);
unset($current_settings['existing_content_language_verified']);
unset($current_settings['dont_show_help_admin_notice']);
global $wpdb;
$wpdb->query('TRUNCATE TABLE ' . $wpdb->prefix . 'icl_translations');
update_option('icl_sitepress_settings', $current_settings);
wp_redirect($referrer);
exit();
global $wpdb;
static $result;
if(isset($result)) {
return $result;
if(!$current_settings) return true;
$setup_wizard_step = false;
if ( isset( $current_settings[ 'setup_wizard_step' ] ) ) {
$setup_wizard_step = $current_settings[ 'setup_wizard_step' ];
$setup_complete = false;
$setup_complete_missing = true;
if ( isset( $current_settings[ 'setup_complete' ] ) ) {
$setup_complete = $current_settings[ 'setup_complete' ];
$setup_complete_missing = false;
//Skip checks during first setup wizard
if(($setup_wizard_step!==false && $setup_wizard_step < 4) || (!$setup_complete_missing && $setup_complete===false && $setup_wizard_step==4 )) return true;
$default_language = false;
$default_language_missing = true;
if ( isset( $current_settings[ 'default_language' ] ) ) {
$default_language = $current_settings[ 'default_language' ];
$default_language_missing = false;
// rich changes
//$active_languages_sql = "SELECT * FROM " . $wpdb->prefix . 'icl_languages WHERE active=%d';
//$active_languages_prepared = $wpdb->prepare( $active_languages_sql, array(1) );
//$active_languages = $wpdb->get_results( $active_languages_prepared );
//$existing_translations_sql = "SELECT count(*) FROM " . $wpdb->prefix . 'icl_translations';
//$existing_translations = $wpdb->get_var( $existing_translations_sql );
$show_notice = false;
$message = '';
if ( (!$setup_complete || !$default_language) ) { /* && $existing_translations ) {*/
if($existing_translations)
$message .= '<p>';
$message .= __( 'Your WPML settings seem to be corrupted. To avoid corrupting your existing data, we have hidden WPML from this site.', 'sitepress' );
$message .= '</p>';
$message .= '<p>';
$message .= __( 'If this is the first time you install WPML on this site, you may have faced a database or script connection drop, that caused settings to be not completely store.', 'sitepress' );
$message .= __( 'In this case, you can click on the
Reset Settings button: this will reset WPML settings and any language translation information, allowing you to restart the wizard.', 'sitepress' );
$message .= '</p>';
$message .= '<p>';
$message .= sprintf( __( 'If you have just upgraded WPML or after starting over you keep getting this message, please contact the <a href="%s">support forum</a> as soon as possible, in order to provide you with a fix to this issue.', 'sitepress' ), 'https://wpml.org/forums/' );
$message .= '</p>';
$message .= '<p>';
$confirm_message = _x('Are you sure you want to reset WPML Settings?', 'Reset WPML settings', 'sitepress');
$confirm_message .= ' ';
$confirm_message .= _x('This will also empty translation information (if any).', 'Reset WPML settings', 'sitepress');
$message .= '<a href="?icl_reset_settings=1&debug_action=reset_wpml_settings&nonce=' . wp_create_nonce( 'reset_wpml_settings' ) . '" class="button" onclick="return window.confirm(\'' . $confirm_message . '\');" >' . __('Reset Settings','sitepress') . '</a>';
$message .= ' ';
$message .= ' ';
$message .= ' ';
$message .= '<a href="https://wpml.org/forums/" class="button">' . __('Contact Support','sitepress') . '</a>';
$message .= '</p>';
$message .= '<p>';
$message .= __( 'Additional details for the support team (there is no need to copy it, as the support team will be able to see it once logged in):', 'sitepress' );
$message .= '</p>';
$message .= '<p><textarea rows="10" style="width:100%;display:block;" onclick="this.focus();this.select();" readonly="readonly">';
$message .= str_repeat( '=', 50 );
$wpml_plugins_list = SitePress::get_installed_plugins();
foreach ( $wpml_plugins_list as $name => $plugin_data ) {
$plugin_name = $name;
$file = $plugin_data['file'];
$message .= PHP_EOL . $plugin_name;
$message .= ' ' . (isset( $plugin_data['plugin']['Version'] ) ? $plugin_data['plugin']['Version'] : __( 'Version n/a', 'sitepress' ));
$message .= ' => ';
if ( empty( $plugin_data['plugin'] ) ) {
$message .= 'Not installed';
} else {
$message .= 'Installed';
$message .= '/';
$message .= isset( $file ) && is_plugin_active( $file ) ? 'Active' : 'Not Active';
$message .= PHP_EOL . str_repeat( '-', 50 );
$message .= PHP_EOL . 'icl_translations count: ' . ( $existing_translations ? $existing_translations : '0' );
$message .= PHP_EOL . 'setup_complete: ' . ( $setup_complete ? 'true' : 'false' );
$message .= PHP_EOL . 'setup_complete missing: ' . ( $setup_complete_missing ? 'true' : 'false' );
$message .= PHP_EOL . 'default_language: ' . ( $default_language ? $default_language : '""' );
$message .= PHP_EOL . 'default_language_missing: ' . ( $default_language_missing ? 'true' : 'false' );
$message .= PHP_EOL . PHP_EOL . 'active_languages: ' . PHP_EOL . print_r( $active_languages, true );
$message .= PHP_EOL . PHP_EOL . 'icl_sitepress_settings (serialized): ' . PHP_EOL . serialize( $current_settings );
$message .= PHP_EOL . PHP_EOL . 'icl_sitepress_settings (unserialized): ' . PHP_EOL . print_r( $current_settings, true );
$message .= PHP_EOL . str_repeat( '=', 50 );
$message .= '</textarea></p>';
$show_notice = true;
// ICL_AdminNotifier::removeMessage( 'check_settings_integrity' );
ICL_AdminNotifier::removeMessage( 'check_settings_integrity_corrupted' );
if ( $show_notice ) {
ICL_AdminNotifier::addMessage( 'check_settings_integrity_corrupted', $message, 'error', false, false, false, 'check_settings_integrity', true );
ICL_AdminNotifier::displayMessages( 'check_settings_integrity' );
$result = !$show_notice;
return $result;
* @param int $limit
* @param bool $provide_object
* @param bool $ignore_args
* @return array
public function get_backtrace($limit = 0, $provide_object = false, $ignore_args = true) {
$options = false;
if ( version_compare( phpversion(), '5.3.6' ) < 0 ) {
// Before 5.3.6, the only values recognized are TRUE or FALSE,
// which are the same as setting or not setting the DEBUG_BACKTRACE_PROVIDE_OBJECT option respectively.
$options = $provide_object;
} else {
// As of 5.3.6, 'options' parameter is a bitmask for the following options:
if ( $provide_object )
$options |= DEBUG_BACKTRACE_PROVIDE_OBJECT;
if ( $ignore_args )
$options |= DEBUG_BACKTRACE_IGNORE_ARGS;
if ( version_compare( phpversion(), '5.4.0' ) >= 0 ) {
$actual_limit = $limit == 0 ? 0 : $limit + 1;
$debug_backtrace = debug_backtrace( $options, $actual_limit ); //add one item to include the current frame
} elseif ( version_compare( phpversion(), '5.2.4' ) >= 0 ) {
//@link https://core.trac.wordpress.org/ticket/20953
$debug_backtrace = debug_backtrace();
} else {
$debug_backtrace = debug_backtrace( $options );
//Remove the current frame
if($debug_backtrace) {
array_shift($debug_backtrace);
return $debug_backtrace;
* Translate the value returned by 'option_{taxonomy}_children' and store it in cache
* @param array $original_value
* @param bool|string $current_language
* @param bool|string $taxonomy
* @return array
function option_taxonomy_children( $original_value, $current_language = false, $taxonomy = false ) {
if(!is_array($original_value) || count($original_value)==0) return $original_value;
$current_language = !$current_language ? $this->get_current_language() : $current_language;
if ( $current_language == $default_language ) {
$cache_key_array[ ] = $current_language;
$cache_key_array[ ] = $default_language;
$cache_key_array[ ] = $original_value;
$cache_key = md5( serialize( $cache_key_array ) );
$cache_group = 'translate_taxonomy_children';
$cache_found = false;
$result = wp_cache_get( $cache_key, $cache_group, false, $cache_found );
if ( $cache_found ) {
return $result;
$debug_backtrace = $this->get_backtrace( 4, false, false );
//Find the taxonomy name
if ( !$taxonomy && isset( $debug_backtrace[ 3 ] ) && isset( $debug_backtrace[ 3 ][ 'args' ] ) ) {
$option_name = $debug_backtrace[ 3 ][ 'args' ][ 0 ];
$taxonomies = explode( '_', $option_name );
$taxonomy = $taxonomies[ 0 ];
$translated_children = array();
if ( $taxonomy && is_array( $original_value ) ) {
foreach ( $original_value as $children_term_ids ) {
foreach ( $children_term_ids as $child_term_id ) {
$translated_child_term_id = icl_object_id( $child_term_id, $taxonomy, false, $current_language );
if ( $translated_child_term_id ) {
$translated_parent_term_id = wp_get_term_taxonomy_parent_id( $translated_child_term_id, $taxonomy );
if ( $translated_parent_term_id ) {
if ( ! isset( $translated_children[ $translated_parent_term_id ] ) ) {
$translated_children[ $translated_parent_term_id ] = array();
$translated_children[ $translated_parent_term_id ][ ] = $translated_child_term_id;
wp_cache_set( $cache_key, $translated_children, $cache_group );
return $translated_children;
function pre_update_option_taxonomy_children($value, $old_value) {
return $value;
$cache_key_array[ ] = $value;
$cache_key_array[ ] = $old_value;
$cache_group = 'pre_update_option_taxonomy_children';
return $result;
$taxonomy = false;
if ( isset( $debug_backtrace[ 3 ] ) && isset( $debug_backtrace[ 3 ][ 'args' ] ) ) {
if($taxonomy) {
remove_filter("option_{$taxonomy}_children", array($this, 'option_taxonomy_children'), 10 );
remove_filter("pre_update_option_{$taxonomy}_children", array($this, 'pre_update_option_taxonomy_children'), 10 );
$new_value = get_option("{$taxonomy}_children");
add_filter("option_{$taxonomy}_children", array($this, 'option_taxonomy_children'), 10 );
add_filter("pre_update_option_{$taxonomy}_children", array($this, 'pre_update_option_taxonomy_children'), 10, 2 );
return $new_value;
return $value;
* @param int|array $terms_ids
* @param $taxonomy
public function update_terms_relationship_cache( $terms_ids, $taxonomy ) {
remove_filter( 'get_terms_args', array( $this, 'get_terms_args_filter' ) );
remove_filter( 'terms_clauses', array( $this, 'terms_clauses' ), 10 );
remove_filter( 'list_terms_exclusions', array( $this, 'exclude_other_terms' ), 1 );
clean_term_cache( $terms_ids, $taxonomy );
add_filter( 'get_terms_args', array( $this, 'get_terms_args_filter' ) );
// filters terms by language
add_filter( 'terms_clauses', array( $this, 'terms_clauses' ), 10, 4 );
add_filter( 'list_terms_exclusions', array( $this, 'exclude_other_terms' ), 1, 2 );
* Used as filter for wordpress core function url_to_postid()
* @global AbsoluteLinks $absolute_links_object
* @param string $url URL to filter
* @return string URL changed into format ...?p={ID} or original
function url_to_postid($url) {
if ((strpos($url, 'wp-login.php') !== false)) {
return $url;
} else if ( strpos($url, '/wp-admin/') !== false ) {
return $url;
} else if ( strpos($url, '/wp-content/') !== false ) {
return $url;
$is_language_in_domain = false; // if language negotiation type as lang. in domain
$is_translated_domain = false; // if this url is in secondary language domain
// for 'diffrent domain per language' we need to switch_lang according to domain of parsed $url
if (2 == $this->settings['language_negotiation_type'] && isset($this->settings['language_domains'])) {
$is_language_in_domain = true;
// if url domain fits to one of secondary language domains
// switch sitepress language to this
// but save current language context in $current_language, we will have to switch to this back
foreach ($this->settings['language_domains'] as $code => $domain) {
if ( strpos($url, $domain) === 0 ) {
$is_translated_domain = true;
$this->switch_lang($code);
$url = str_replace($domain, site_url(), $url);
break;
// if it is url in original domain
// switch sitepress language to default language
if (!$is_translated_domain) {
$this->switch_lang($default_language);
// we will use AbsoluteLinks::_process_generic_text, so make sure that
// we have this object here
global $absolute_links_object;
if (!isset($absolute_links_object) || !is_a($absolute_links_object, 'AbsoluteLinks') || $is_language_in_domain ) {
require_once ICL_PLUGIN_PATH . '/inc/absolute-links/absolute-links.class.php';
$absolute_links_object = new AbsoluteLinks();
// in next steps we will have to compare processed url with original,
// so we need to save original
$original_url = $url;
// we also need site_url for comparisions
$site_url = site_url();
// _process_generic_text will change slug urls into ?p=1 or ?cpt-slug=cpt-title
// but this function operates not on clean url but on html <a> element
// we need to change temporary url into html, pass to this function and
// extract url from returned html
$html = '<a href="'.$url.'">removeit</a>';
$alp_broken_links = array();
remove_filter('url_to_postid', array($this, 'url_to_postid'));
$html = $absolute_links_object->_process_generic_text($html, $alp_broken_links);
add_filter('url_to_postid', array($this, 'url_to_postid'));
$url = str_replace(array('<a href="', '">removeit</a>'), array('', ''), $html);
// for 'diffrent domain per language', switch language back. now we can do this
if ($is_language_in_domain) {
$this->switch_lang($current_language);
// if this is not url to external site
if ( 0 === strpos($original_url, $site_url)) {
// if this is url like ...?cpt-rewrite-slug=cpt-title
// change it into ...?p=11
$url2 = $this->cpt_url_to_id_url($url, $original_url);
if ($url2 == $url && $original_url != $url) { // if it was not a case with ?cpt-slug=cpt-title
// if this is translated post and it has the same slug as original,
// _process_generic_text returns the same ID for both
// lets check if it is this case and replace ID in returned url
$url = $this->maybe_adjust_url($url, $original_url);
} else { // yes! it was not a case with ?cpt-slug=cpt-title
$url = $url2;
return $url;
* Check if $url is in format ...?cpt-slug=cpt-title and change into ...?p={ID}
* @param string $url URL, probably in format ?cpt-slug=cpt-title
* @param string $original_url URL in original format (probably with permalink)
* @return string URL, if $url was in expected format ?cpt-slug format, url is now changed into ?p={ID}, otherwise, returns $url as it was passed in parameter
function cpt_url_to_id_url($url, $original_url) {
$parsed_url = parse_url($url);
if (!isset($parsed_url['query'])) {
return $url;
$query = $parsed_url['query'];
parse_str($query, $vars);
$args = array(
'public' => true,
'_builtin' => false
$post_types = get_post_types($args, 'objects');
foreach ($post_types as $name => $attrs) {
if ( isset( $vars[ $attrs->rewrite['slug'] ] ) ) {
$post_type = $name;
$post_slug = $vars[ $attrs->rewrite['slug'] ];
break;
if (!isset($post_type, $post_slug)) {
return $url;
$args = array(
'name' => $post_slug,
'post_type' => $post_type
$post = new WP_Query($args);
if (!isset($post->post)) {
return $url;
$id = $post->post->ID;
$post_language = $this->get_language_for_element($id, 'post_' . $post_type);
$url_language = $this->get_language_from_url($original_url);
if ($post_language != $url_language) {
$trid = $this->get_element_trid( $id, 'post_' . $post_type );
$translations = $this->get_element_translations( $trid, 'post_' . $post_type );
if (isset($translations[$url_language])) {
$translation = $translations[$url_language];
if (isset($translation->element_id)) {
$nvars['p'] = $translation->element_id;
} else {
$nvars['p'] = $id;
$new_query = http_build_query($nvars);
$url = str_replace($query, $new_query, $url);
return $url;
* Fix sticky link url to have ID of translated post (used in case both translations have same slug)
* @param string $url - url in sticky link form
* @param string $original_url - url in permalink form
* @return string - url in sticky link form to correct translation
private function maybe_adjust_url($url, $original_url) {
if (isset($vars['page_id'])) {
$inurl = 'page_id';
$post_id = $vars['page_id'];
} elseif (isset($vars['p'])) {
$inurl = 'p';
$post_id = $vars['p'];
if (isset($post_id)) {
$post_type = get_post_type($post_id);
$post_language = $this->get_language_for_element($post_id, 'post_' . $post_type);
$trid = $this->get_element_trid( $post_id, 'post_' . $post_type );
$vars[$inurl] = $translation->element_id;
$new_query = http_build_query($vars);
return $url;
* Find language of document based on given permalink
* @param string $url Local url in permalink form
* @return string two letters language code
function get_language_from_url($url) {
static $languages;
if (isset($languages[$url])) {
return $languages[$url];
if (1 == $this->settings['language_negotiation_type']) {
$url_path = ltrim(
str_replace($site_url, "", $url),
$fragments = explode("/", $url_path);
$fragment = $fragments[0];
if (isset($this->active_languages[$fragment])) {
$languages[$url] = $fragment;
return $fragment;
} else {
$languages[$url] = $this->get_default_language();
return $this->get_default_language();
} else if ( 2 == $this->settings['language_negotiation_type'] ) {
if ( isset($this->settings['language_domains'])) {
$languages[$url] = $code;
return $code;
$languages[$url] = $this->get_current_language();
return $this->get_current_language();
} else if (3 == $this->settings['language_negotiation_type']) {
$url_query = parse_url($url, PHP_URL_QUERY);
if (isset($url_query)) {
parse_str($url_query, $vars);
if (isset($vars['lang']) && isset($this->active_languages[ $vars['lang'] ])) {
$languages[$url] = $vars['lang'];
return $vars['lang'];
function update_wpml_config_index_event(){
$wp_http_class = new WP_Http();
$response = $wp_http_class->get( ICL_REMOTE_WPML_CONFIG_FILES_INDEX . 'wpml-config/config-index.json');
if(!is_wp_error($response) && $response['response']['code'] == 200){
$arr = json_decode($response['body']);
if( isset( $arr->plugins ) && isset( $arr->themes ) ){
update_option('wpml_config_index',$arr);
update_option('wpml_config_index_updated',time());
$config_files_arr = maybe_unserialize(get_option('wpml_config_files_arr'));
if($config_files_arr){
$config_files_themes_arr = $config_files_arr->themes;
$config_files_plugins_arr = $config_files_arr->plugins;
}else{
$config_files_themes_arr = array();
$config_files_plugins_arr = array();
$theme_data = wp_get_theme();
foreach($arr->themes as $theme){
if( $theme_data->get( 'Name' ) == $theme->name && ( !isset( $config_files_themes_arr[$theme->name] ) || md5( $config_files_themes_arr[$theme->name] ) != $theme->hash ) ){
$response = $wp_http_class->get(ICL_REMOTE_WPML_CONFIG_FILES_INDEX . $theme->path);
if($response['response']['code'] == 200){
$config_files_themes_arr[$theme->name] = $response['body'];
if ( ! function_exists( 'get_plugins' ) ) {
require_once ABSPATH . 'wp-admin/includes/plugin.php';
$active_plugins = get_plugins();
foreach( $active_plugins as $active_plugin ){
$active_plugins_names[] = $active_plugin['Name'];
foreach($arr->plugins as $plugin){
if( in_array($plugin->name,$active_plugins_names) && ( !isset( $config_files_plugins_arr[$plugin->name] ) || md5( $config_files_plugins_arr[$plugin->name] ) != $plugin->hash ) ){
$response = $wp_http_class->get(ICL_REMOTE_WPML_CONFIG_FILES_INDEX . $plugin->path);
if(!is_wp_error($response) &&$response['response']['code'] == 200){
$config_files_plugins_arr[$plugin->name] = $response['body'];
if ( ! isset( $config_files_arr ) || ! $config_files_arr ) {
$config_files_arr = new stdClass();
$config_files_arr->themes = $config_files_themes_arr;
$config_files_arr->plugins = $config_files_plugins_arr;
update_option('wpml_config_files_arr',$config_files_arr);
return true;
return false;
function update_wpml_config_index_event_ajax(){
if($this->update_wpml_config_index_event()){
echo date('F j, Y H:i a', time());
die;
function update_index_screen(){
return include ICL_PLUGIN_PATH . '/menu/theme-plugins-compatibility.php';
* Filter to add language field to WordPress search form
* @param string $form HTML code of search for before filtering
* @return string HTML code of search form
function get_search_form_filter($form) {
if ( strpos($form, wpml_get_language_input_field() ) === false ) {
$form = str_replace("</form>", wpml_get_language_input_field() . "</form>", $form);
return $form;
November 5, 2014 at 11:44 am #506068
Robert
Hey Richard,
I've located the ticket on your speed optimization suggestion regarding your first post and I've added this ticket and code as well. I'm sorry for the inconvenience this has caused you, I am awaiting a reply from the development team and will update you as soon as possible.
Robert
November 5, 2014 at 4:14 pm #506324
Richard
Hi Robert,
Thanks for the update.
Looking forward to any improvements.
Rich
The topic ‘[Closed] Speed optimizations in 3.1.8.2’ is closed to new replies.
