You have a WooCommerce product that you only want to appear in the Danish language, but it is showing in English and German as well.
If you're experiencing this issue in the backend and can see the product in other languages there, we recommend you go to Products → All Products, switch to the desired language, and delete the product translations from those languages.
However, if in the backend you only have the product in Danish, but on the frontend it still appears in other languages, then please go to:
WPML → Settings → Post Types Translation
and set Products (product) to:
“Translatable – only show translated items”
This will ensure that products only appear in languages where an actual translation exists.
Please note that this solution might be irrelevant if it’s outdated or not applicable to your case. We highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the issue persists, we encourage you to open a new support ticket at WPML support forum.
Last updated by Andrey 4 months ago.
Assisted by: Andrey.
May 7, 2026 at 9:31 pm #18021449
mikaelR-7
Site owner
I have another issue with a woocommerce product, that I only want in the Danish language. Still it is showing in English and German.
May 7, 2026 at 9:53 pm #18021452
Andrey
WPML Supporter since 06/2013
If you are referring to the backend and you can see the product in other languages there, you can go to Products → All Products, switch to the desired language, and delete the product translations from those languages.
However, if in the backend you only have the product in Danish, but on the frontend it still appears in other languages (such as English and German), then please go to:
