Last updated by Dražen Duvnjak 4 months, 3 weeks ago.
Assigned support staff: Dražen Duvnjak.
June 2, 2020 at 5:58 am #6270205
annikaN-2
I bought the advanced post types order but I can't find the setting that is on the link you send me, see below so I need to do something in WPML settings to get it to show up?
Choose the Yes option in the WPML Synchronize section to synchronize the order across different languages and then click on the Settings Update button.
Annika
June 2, 2020 at 7:23 am #6270841
Dražen Duvnjak
Hello Annika,
To be fair I am not sure I have used this plugin before and I don't have premium plugin to test it further.
I don't see the image shared, can you please send again?
1) Can you please check if the plugin is working fine even without these settings?
2) Can you please check if this is an issue only with products or with other post types also?
Please let me know.
Drazen
June 2, 2020 at 7:51 am #6271293
annikaN-2
I send you a messages that I found it under Advanced in the settings so everything fine.
But now I wonder about another thing. How to translate the emails send by Woocommerce, I saw in some comments that it need to be done by string translation but it just pick up the headlines and not the whole email message. And I also tried to go via the flags in the top of the wp-admin to change but then it change on the other language also. So is there a easy way to do this?
Annika
June 2, 2020 at 11:47 am #6273693
Dražen Duvnjak
great to hear.
1) Usually, WordPress automatically downloads WooCommerce default translation. You can download them under Dashboard>Updates>Transaltion. By default, these strings are translated by the WooCommerce .mo files.
And as you can see in WooCommerce>Email you can only add email subject/heading.
So in order to translate WooCommerce emails, you should search each string and translate it.
Follow the below steps to translate the email contents
- Go to WPML - Theme & Plugins Localizations
- Select WooCommerce plugin and scan
- Go to WPML - String Translations
- Search for your email strings
- Translate & Save
https://wpml.org/documentation/getting-started-guide/string-translation/
2) Also, it would be great if you could tell me exactly which email you'd like to translate (from WooCommerce → Settings → Emails tab). This way, I can check it on my side and see if there's an issue with it. If possible share image from backend and frontend.
Drazen
The topic ‘[Closed] Split: Advanced post types order’ is closed to new replies.
