10:00 – 13:00 10:00 – 13:00 10:00 – 13:00 10:00 – 13:00 10:00 – 13:00 - -
14:00 – 19:00 14:00 – 19:00 14:00 – 19:00 14:00 – 19:00 14:00 – 19:00 - -
Last updated by Dražen Duvnjak 1 year, 9 months ago.
Assisted by: Faisal Ahammad.
February 13, 2023 at 4:36 am #13016659
peterK-126
Dear Faisal !
Thanks for the help , now it works fine. :).
One more little thing. When I translated a product, it goes into the drafts first and it can be published from there and only then appears on the site. Is this normal ?
Peter
February 13, 2023 at 4:37 am #13016663
Faisal Ahammad
I suspect that there is a collision with the theme or another plugin that might cause this problem. If possible, get your site into a minimum environment.
A minimum environment means switching to a default WordPress theme like TwentyTwenty-One and no plugins activated except WPML.
First, you will need to check if the problem persists when just the theme is switched to TwentyTwenty-One. If it persists, then deactivate all plugins except the WPML, its add-ons, and WooCommerce itself (without its extensions).
Then please check if the problem persists. If it does not persist, start by activating the plugins one by one and check when the problem comes back, then report to me which was the culprit plugin.
⚠️ Important! Please make a full site backup (files and DB) before you proceed with those steps. ⚠️
** If your site is a live site, you might want first to try those procedures in a staging environment or a snapshot of your site on your local server or another server. **
Let me know how that goes!
Thank you
Faisal
February 14, 2023 at 8:04 am #13026953
peterK-126
Hi Faisal,
Thank you for your reply. I will do as you asked and get back to you.
What may cause difficulties is that my site is a live site.
Peter
February 14, 2023 at 12:21 pm #13030213
Faisal Ahammad
Hi Peter,
Thank you for agreeing to try the steps I suggested. I understand that your site is live, and I appreciate your caution in this regard.
If it's impossible to create a staging environment or a snapshot of your site, I could set up a sandbox server on our Cloudways account. Then I'll share the credentials with you so you can migrate a copy of your site to our server without any downtime on your live site.
To further investigate the issue without affecting your live site, please let me know if you're ready to move forward.
I appreciate your cooperation, and I hope you have a great day.
Faisal
February 15, 2023 at 8:44 am #13037019
peterK-126
Dear Faisal
Thank you for your efforts. The main problem was solved earlier , this problem is just a little extra work that I can live with at the moment. If it gets worse I will get back to you.
Thanks again for everything.
Peter
February 15, 2023 at 10:02 am #13038123
Dražen Duvnjak
Faisal is off today, so I am taking care of this ticket, hope that is OK. 🙂
Thanks for getting back, sounds good.
I suggest if you encounter any new issues and still need help open a new chat/ticket and we will be glad to help.
Drazen
The topic ‘[Closed] Split: After translated a product, it goes into the drafts’ is closed to new replies.
