Supporter timezone: Europe/Tirane (GMT+02:00)
Last updated by Marsel Nikolli 1 year, 9 months ago.
Assisted by: Marsel Nikolli.
February 13, 2024 at 3:52 pm #15298791
damienC-18
OK this one I don't understand, I didn't see it when I was looking in all domains. Maybe I simply missed it then.
Thank you very much for your assistance.
All seems to work now, except the translation of author bio still:
String translated: hidden link
February 13, 2024 at 4:26 pm #15298867
Marsel Nikolli
Could you please check that the issue could be related to the function used by the theme or plugin to display that information, try using 'get_the_author_meta()' instead of 'get_user_meta() ' on the author.php file on your theme folder, and check if that resolves the issue.
February 14, 2024 at 1:26 pm #15302559
damienC-18
I've tweaked the author.php file (screenshot) and asked my hoster for a database sweep just in case yet the issue remains.
February 15, 2024 at 10:43 am #15306437
Marsel Nikolli
Hi Damien,
I checked further and you need to edit the author.php file and find this:
$agent_bio = $current_author->description;
and change it to:
$agent_bio = get_the_author_meta('description', $author_id);
* Note: Please make sure you have a full backup of your website before making any update/changes on your website.
For more information related to the user meta data please check:
https://wpml.org/documentation/getting-started-guide/string-translation/translating-user-meta-information-with-wpml/#displaying-user-metadata-translations-on-the-front-end
Let me know how it goes,
Marsel
February 15, 2024 at 12:18 pm #15306827
damienC-18
It worked! Thank you so much Marsel, you've been so helpful!
February 15, 2024 at 12:24 pm #15306834
damienC-18
Wait, there's just one thing, the author's name is not translated as well front-end, yet it's translated everywhere as well in string translations.
Can we fix that please?
February 15, 2024 at 2:08 pm #15307662
Marsel Nikolli
On the same file, you need to change the following code:
$agent_name = $current_author->display_name;
to:
$agent_name = get_the_author_meta('display_name', $author_id);
Let me know if you have any other question,
Marsel
February 15, 2024 at 2:12 pm #15307669
damienC-18
Thank you Marsel, it works perfectly!
February 16, 2024 at 11:37 am #15311288
damienC-18
Hi Marsel, sorry but I have yet another string not translated.
When opening the registration (small login icon close to the phone number):
"I agree with your
Terms & Conditions"
is well translated in String Translations (screenshot) yet doesn't show up.
How could we fix it please?
February 16, 2024 at 11:39 am #15311293
damienC-18
It's better with the screenshots...
February 16, 2024 at 3:13 pm #15312195
Marsel Nikolli
Hi Damien,
Does the website have any cache in user (server-side cache)?
If so please try clearing the cache and let me know.
February 16, 2024 at 3:16 pm #15312198
damienC-18
As the website is still being built I'm not using any cache from WordPress or server-side at all.
February 19, 2024 at 11:00 am #15317534
Marsel Nikolli
Hi Damien,
I checked a bit further on your website and would it be possible to check if the issue happens in a minimal setup, that meaning:
- keep the theme you have
- keep active only WPML Plugins and the theme must have plugins
- disable all other plugins
After, check if the issue is still happening.
This will help checking for any possible plugin conflict.
Note: Please make sure you have a full backup (files & database) before trying anything on your website.
Marsel
February 20, 2024 at 9:01 am #15321009
damienC-18
Hi Marsel.
I just cloned the website as a staging version, credentials are exactly the same, I've deactivated all but necessary plugins, the issue persists.
Please investigate on this staging. Thank you very much.
February 21, 2024 at 9:36 am #15326353
Marsel Nikolli
Hi Damien,
I've escalated the issue to the 2-nd tier support team, in order to further troubleshoot.
I'll let you know as soon as I have a feedback from the team.
Marsel
The topic ‘[Closed] Split: Author Bio description translation not showing’ is closed to new replies.
