Last updated by Dražen Duvnjak 1 year, 4 months ago.
Assigned support staff: Dražen Duvnjak.
March 11, 2021 at 6:56 am #8280829
eljaA
I checked at beta version now able to see. I did same changed code at live but not showing there. have you changes anything else too. Please let me know so I will change too at live.
March 11, 2021 at 7:01 am #8280843
Dražen Duvnjak
I have checked on this and it seems it is a compatibility issue, I was able to reproduce a similar issue on a clean install.
Topics are not showing if they are translated via backend, if you do not have a translation of the topic, then it shows fine.
For now, I suggest you do no translate topics, and they will show up fine on the frontend.
In the meantime, I will be escalating this case to our compatibility team and update you as soon as I have some news or a fix for it.
Thanks and kind regards,
Drazen
March 11, 2021 at 1:45 pm #8285503
eljaA
Thanks for replying and understanding issue. You are when I translated that forums, topics and replies at backend It will not appear at front end but kept as it is without translation It display all. In That main issue is if I created any topic in English need to be translate in dutch also. if it will as English in dutch then what use of translation.
Please check and give me solution.
March 11, 2021 at 2:43 pm #8286099
Dražen Duvnjak
I understand and have already escalated this issue to our developers. They are working on it.
I will update you as soon as I have some news or fix to share.
Kind regards,
Drazen
April 1, 2021 at 12:04 pm #8448711
Dražen Duvnjak
I have an update on this issue.
Can you please follow the next steps and let me know how it goes:
0) Make a backup
1) Set Topics, Replies and Forums as "Translatable" from WPML -> Settings.
2) Set _bbp_* custom fields as "Copy Once" from WPML -> Settings.
3) Modify sitepress-multilingual-cms\classes\query-filtering\class-wpml-query-parser.php LINES 456 to 472:
             private function maybe_adjust_parent( $q, $post_type, $current_language ) {
		$post_type = ! is_scalar( $post_type ) && count( $post_type ) === 1 ? end( $post_type ) : $post_type;
		if ( ! empty( $q->query_vars['post_parent'] )
			 && $q->query_vars['post_type'] !== 'attachment'
			 && $post_type
			 && is_scalar( $post_type )
			 && $this->sitepress->is_translated_post_type( $post_type )
			$q->query_vars['post_parent'] = $this->post_translations->element_id_in(
				$q->query_vars['post_parent'],
				$current_language,
				true
		return $q;
To:
			 && $post_type
		         && $post_type != 'topic'
		         && $post_type != 'reply'
				$current_language,
				true
		return $q;
Drazen
April 9, 2021 at 9:17 am #8499571
eljaA
Thanks for reply. I am using all latest version of plugins right now. Still I want to do above changes. Please check and let me know.
April 9, 2021 at 9:47 am #8499967
Dražen Duvnjak
yes, please follow my suggestion from the previous reply, step by step, and let me know how it goes and if you still have an issue.
Drazen
The topic ‘[Closed] Split: bbPress translated topics not showing’ is closed to new replies.
