Last updated by hlaingM 2 years ago.
July 8, 2019 at 12:36 pm #4162425
hlaingM
I tested the following after removing all the custom codes associated with duplication.
Here, I posted the following using the 2nd language. But, the photo is missing as you can see below.
When I switch on English below, the ad with the photo appears.
It is behaving abnormally like this without any customization codes? Although the ad was posted in the 2nd language, it is appearing as the original ad in English in Ads (backend). There must be issues with the settings or the WPML coding.
The normal behavior should be: if an ad is posted in the 2nd language, it should appear as the original post in the 2nd language in Ads(backend). Could you please help to resolve this issue? Thanks.
July 8, 2019 at 12:41 pm #4162467
Bigul
Welcome to the WPML support forum. I will do my best to help you to resolve these issues.
I would like to access the admin area of your site for further checking(the credentials you have shared is not working now). Please fill the private details fields after a full site backup.
Please check the following links for more details about our private information sharing policies.
Bigul
July 10, 2019 at 7:02 am #4176467
hlaingM
