Last updated by Bobby 8 months, 3 weeks ago.
Assigned support staff: Bobby.
September 3, 2019 at 7:51 am #4501767
Дмитрий Яблонский
yes, thanks.
Help me please - I need rename menu item, in ru and de, but in en - I can't - hidden link How do thise?
September 3, 2019 at 7:58 am #4501787
Bobby
1. Go to WPML->String Translation and find your string
2. Select it and click on "Change the language of selected strings" and pick a neutral language (any language that you are not using on your site)
3. This should allow you to edit now the English string
Please note that this is not the expected way to use String Translation as the English string is a hardcoded string , ideally it would be changed within the code but you should be able to achieve this with this workaround provided above.
The topic ‘[Closed] Split: Plugin not load po, mo translate’ is closed to new replies.
