The client was experiencing layout issues on their multilingual WordPress site, where the English version of pages did not match the design of the Albanian version. Additionally, the client was unsure how to translate the footer, header, and use the Slider Revolution plugin in multiple languages.
We identified that the layout discrepancy was due to some custom fields being set as non-translatable. We adjusted the settings to make these fields translatable by following the steps in our guide on Translating Custom Fields. For the issues related to translating widgets and using Slider Revolution, we provided documentation links and advised the client to open separate support tickets for each issue to ensure detailed assistance. The relevant guides can be found here:
If the provided solution does not resolve your issue, or if it seems outdated or irrelevant to your specific case, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. Should further assistance be needed, please do not hesitate to open a new support ticket at WPML Support Forum.
This topic contains 24 replies, has 0 voices.
Last updated by Carlos Rojas 3 weeks ago.
Assisted by: Carlos Rojas.
June 10, 2025 at 8:09 am #17120684
lauraK-16
I still have a problem because I did the WordPress Editor translate, overwrite and then translate independently and the English version is not in the same design as the Albanian one. Can you please help me?
June 10, 2025 at 8:12 am #17120696
Carlos Rojas
WPML Supporter since 03/2017
Hi again,
Please:
1.- Share the URL of the page where the layout problem appears
2.- Share the access credentials to the site. I have set your next answer private.
I will take a look at the page and check what is causing the different layouts. Although I suspect this might be related to missing custom fields 🙂
June 10, 2025 at 9:08 am #17121014
Carlos Rojas
Thank you for your message.
The problem was that some custom fields were set to be non-translatable. I adjusted the configuration by following the steps described in this guide: https://wpml.org/documentation/getting-started-guide/translating-custom-fields/ then updated the translation, and now the page is shown correctly.
June 10, 2025 at 9:39 am #17121126
lauraK-16
Yes perfect, but one more thing, what about the footer which is at Appearance - Widget
also the Slider Revolution?
June 10, 2025 at 10:02 am #17121271
Carlos Rojas
I kindly ask you to open a new ticket for each problem, one for the footer and another one for the Slider Revolution. That way, we can keep following our support policy of solving one issue per ticket.
Before opening any new tickets, please read these guides that explain how to correctly translate a widget and Slider Revolution:
- https://wpml.org/documentation/getting-started-guide/translating-widgets/
- https://wpml.org/documentation/plugins-compatibility/creating-multilingual-sliders-with-revolution-slider-and-wpml/
Thank you very much for your understanding!
Note: If you open new tickets you can ask directly for me and I will be more than happy to continue helping you 🙂
June 10, 2025 at 4:14 pm #17122923
lauraK-16
Before we go at slider and widget issues, The design is still being destroyed when I try to translate it. Is there a problem? How did you do it the the Contact page?
June 10, 2025 at 4:15 pm #17122924
lauraK-16
I tried it with Rreth nesh which is About us and got destroyed like Contact.
June 11, 2025 at 6:47 am #17124070
Carlos Rojas
The hidden link page translation needs to be updated and published.
June 11, 2025 at 7:57 am #17124368
lauraK-16
What do you mean by update? Can you please explain more or do a screen recording so I can see what you do to fix this issue because it is still the same problem and I am afraid it will happen with all my pages?
June 11, 2025 at 9:38 am #17124801
Carlos Rojas
Here is a video describing the situation and the steps to follow: hidden link
Here is the documentation I mentioned in the video: https://wpml.org/faq/how-to-link-already-translated-pages/
June 11, 2025 at 3:44 pm #17127035
lauraK-16
I think it is still the same problem, and I did everything on the image, but still smth is not going well.
June 11, 2025 at 3:45 pm #17127037
lauraK-16
I tried it with "Wrap" and still wrong. 🙁
June 11, 2025 at 3:52 pm #17127087
lauraK-16
Can you please just do this problem for my other pages and then I will do the rest because I am loosing time and my client is getting really angry with me. 🙁
June 12, 2025 at 7:08 am #17128569
Carlos Rojas
I'm sorry, but I don't understand what you mean by "I tried it with "Wrap" and still wrong"?
I described exactly the steps to follow in the video and shared the documentation related to it. There is the solution, you don't need us to apply it 🙂
June 12, 2025 at 10:37 am #17129612
lauraK-16
see this video and you will understand what I am saying.
the "connect with translations" wont appear on my screen.
