The client was experiencing layout issues on their multilingual WordPress site, where the English version of pages did not match the design of the Albanian version. Additionally, the client was unsure how to translate the footer, header, and use the Slider Revolution plugin in multiple languages.
We identified that the layout discrepancy was due to some custom fields being set as non-translatable. We adjusted the settings to make these fields translatable by following the steps in our guide on Translating Custom Fields. For the issues related to translating widgets and using Slider Revolution, we provided documentation links and advised the client to open separate support tickets for each issue to ensure detailed assistance. The relevant guides can be found here:
If the provided solution does not resolve your issue, or if it seems outdated or irrelevant to your specific case, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. Should further assistance be needed, please do not hesitate to open a new support ticket at WPML Support Forum.
This topic is split from https://wpml.org/forums/topic/problem-with-wpml-plug-in/
