Last updated by Raja Mohammed 10 months, 2 weeks ago.
July 18, 2019 at 6:29 am #4235249
derekC-6
Hello and sorry about the delay,
I created a new copy of our live site in a staging environment and executed the SQL statements you indicated. I also updated the site completely.
It still gives the same issue. As soon as I save the the attributes of the product it switches the attributes to French and then when I update the product it deletes all of the attributes completely.
Any other ideas?
July 19, 2019 at 6:48 am #4244241
Raja Mohammed
I am unable to reproduce the product attribute issue, Is it happening with specific products? Can you please give me clear steps to reproduce the issue. I have followed the steps I saved the attributes and updated the products everything seems to work perfectly.
Maybe I am missing something here or the issue is temporary which I am not sure.
Please note I have updated Transalation Management to 2.8.6.2
Kind regards
Raja
July 19, 2019 at 10:39 am #4245795
derekC-6
If you edit any product, for example, ID=9953
- Scroll down to the Attributes section
- Click on QuickShip, for example
- Remove the current value (Yes or No)
- Add the other value back (Yes or No)
- Click on "Save attributes"
- Voila... it's suddenly in French
- Now click on "Update" on the right side
- When it's finished saving, go back to the Attributes section and they're all gone now
July 22, 2019 at 10:27 am #4256061
Raja Mohammed
Thanks for your patience,
I have tested this on my local environment with just the WPML plugin and WooCommerce, I am unable to reproduce the issue with the minimal required plugins please refer hidden link
The issue seems like a conflict with any of your plugin installed in your site,
Please try some basic debugging steps to isolate the issue
- Deactivate all non-wpml plugin, check if the issue persists, (I can confirm the issue disappears with this step)
- Activate the plugins one by one check if the issue can be reproduced, in this way you can single out the conflicting plugin.
Please share the results with us, I would be happy to help you further.
Kind regards
Raja
July 22, 2019 at 1:15 pm #4257753
derekC-6
I'm going to work on checking the plugins today and will get back to you as soon as I have more info.
Thanks for your help so far.
July 23, 2019 at 4:46 am #4262623
Raja Mohammed
Sure, Thanks for the update.
July 25, 2019 at 5:32 pm #4285377
derekC-6
After an investigation into the plugins on our site, it appears there was an issue with Broken Link Checker
https://wordpress.org/plugins/broken-link-checker.
Since this plugin no longer appears to be supported, I've deleted it and the issue appears to be resolved.
Thanks for your help!
July 26, 2019 at 6:42 pm #4291355
Raja Mohammed
Glad you are able to identify the conflicting plugin,
Please mark the ticket as resolved,
Kind regards
Raja
