If you're experiencing issues where changing a SKU causes the product to go into "Need modifications" and you're being charged for translations despite no significant content changes, this might be due to minor text alterations such as the removal of line breaks. These changes are treated as new content by the translation memory, requiring re-translation.
We recommend enabling WordPress revisions to track changes more accurately, which might help in identifying unintentional text modifications like line breaks. It's important to ensure that the text sent for translation matches exactly with previous translations to avoid unnecessary charges. If the issue persists and you believe it should not, please check our related known issues and verify you have the latest versions of themes and plugins installed. If this solution does not apply or is outdated, we encourage you to open a new support ticket for further assistance. You can do so here: WPML support forum.
Last updated by Dražen 5 months, 2 weeks ago.
Assisted by: Dražen.
March 4, 2025 at 10:20 am #16773000
nicolasF-24
Hi Drazen
Thanks for your feedback
I also noticed something,
For example if I change a SKU the product goes in "Need modifications"
I thought that WPML had a translation memory, si in my opinion, if I put these products in translation, we will pay nothing because the content didn't change
The problem is that, after some tests, I saw that we pay these translations so I don't understand at all
Can you explain me how it goes ?
March 4, 2025 at 10:23 am #16773007
Dražen
you are correct. If the content has not changed, you should not pay for any translation. If you have issue I suggest checking / review the translation in WPML translation editor to see what was newly translated.
You can also share with me product URL and time of translation and I will check the translation job from our side and see what was charged.
Drazen
March 4, 2025 at 10:25 am #16773017
nicolasF-24
Hi Drazen,
You can check the 4 last products translated called camelback at the end
I only changed the SKU and my credits came from 15 to 20 dollars
March 4, 2025 at 10:30 am #16773054
nicolasF-24
You can check for example
Only stock changed, and we have paid for these products
March 4, 2025 at 10:53 am #16773222
Dražen
I checked, and it seems the product category text was changed and is now translated as part of the product translation. Image attached.
1) I would suggest checking that your taxonomy texts are correct, since it seems English text is there instead French.
2) Does the issue still happen if you now again try to re-translate? It should not charge if nothing now to translate. Which was not part of you last job, there where some changes in relation to previous job.
Also, you can set to review automatic translation jobs, and review and see what was translated. Dotted segments means automatic translation.
Drazen
March 4, 2025 at 10:57 am #16773246
nicolasF-24
Thanks for your feedback !
I don't understand at all ... Why is it in French on your left screen, and in English on your right screen ?
Our main language is French
March 4, 2025 at 11:02 am #16773276
nicolasF-24
I made a new test
I modified the SKU of this product : hidden link
I launched on it the automatic translation, and I paid again ...
March 4, 2025 at 11:13 am #16773293
Dražen
1) You or some issue, changed your category description text in French, and they are in English now, so when you translated the product, you were charged for this, at least in example I checked and shared before.
I suggest you recheck your taxonomy and make sure they are correct in default language. So, the French language and description is in French.
2) I meant you try with the same product that you already paid for, not a new one. For example: hidden link
If you are charged again, let me know, and share the wp-admin info to the next safe reply so I can login and check. I will also re-add the credits that you used for this testing, approximately 500 credits.
Drazen
March 4, 2025 at 11:43 am #16773484
Dražen
thanks for getting back.
As for the backend admin language change, it is a bit strange, but let's leave this for a later and new ticket and concentrate on the current problem.
I am trying to test this product: hidden link
But if I change the stock status or SKU, it does not trigger the need for translation, It still says completed (pencil icon), so I am wondering what you are actually changing that then requires an update of translation and / retranslation?
Drazen
March 4, 2025 at 11:50 am #16773494
nicolasF-24
For this one is okay, it does not appear anymore now (I don't know why, it appears on the previous video)
But you can check now another example for another product, no need of translations because already made, I click just on update, and now it appears on needed translations ...
It's like I have to re-translate all the products to have the good status, I don't understand
March 4, 2025 at 11:51 am #16773507
nicolasF-24
For the language changing of the admin, I'm still wondering if it's not the reason you see English on the left ...
March 4, 2025 at 12:51 pm #16774032
Dražen
thanks.
Okay, so if you click on these icons and try to hidden link">translate via WPML editor, you will see which segments need to be translated.
For this current product you mentioned, it seems this text is newly added/changed in FR and WPML is translating it. Please share where is this added in the default language. Did somebody change it in the meantime?
- Les housses de protection sont indispensables pour maintenir l'hygiène dans les environnements médicaux. Elles sont utilisées pour couvrir et protéger divers équipements, tels que les tables de massage. Les housses de protection empêchent la contamination croisée en créant une barrière entre les patients et les surfaces souvent en contact. Elles sont généralement fabriquées à partir de matériaux imperméables et jetables, ce qui permet de les remplacer facilement après chaque utilisation, assurant ainsi un niveau de propreté optimal.
H2 : Entretien et stockage des accessoires d'hygiène
Pour garantir l'efficacité des accessoires d'hygiène, il est crucial de les entretenir et de les stocker correctement. Les gants médicaux, par exemple, doivent être conservés dans un endroit frais et sec, à l'abri de la lumière directe du soleil et de la chaleur excessive. Ils doivent être remplacés régulièrement pour éviter toute contamination. Les masques de protection doivent être stockés dans des conditions similaires, et les masques à usage unique doivent être jetés après chaque utilisation pour prévenir la contamination croisée.
Drazen
March 4, 2025 at 12:54 pm #16774040
nicolasF-24
It’s inside the description on woocommerce on the product page
But no-one changed it since
March 4, 2025 at 12:58 pm #16774069
Dražen
please share with me the exact steps where I can edit and change the text I shared in my last reply. I can not find it.
Also I do not see it anywhere on frontend: hidden link
Please explain in more details how is this added and from where it is coming from.
Drazen
March 4, 2025 at 1:00 pm #16774078
nicolasF-24
Okay I see,
It’s the category description
You can find it directly on the category by clicking edit
