Problem: After installing WPML the WooCommerce Products page layout is messed up in the backend.
Solution: Solution here: https://wpml.org/forums/topic/strange-error-woocommerce-products-background/#post-3985633
Related documentation:
This topic contains 13 replies, has 3 voices.
Last updated by yao-yuT 1 year, 7 months ago.
Assigned support staff: Noman.
May 25, 2019 at 2:39 pm #3889557 | |
kellyP-7 |
Hi I got some problems over here. After installing the WPML plugin. Tryed several times but it seems to be a problem with the WPML plugin. Can someone help me please? Thank you so much |
May 26, 2019 at 11:19 am #3891591 | |
Noman Supporter
Hi, Thank you for contacting WPML Support. We have another client who had the similar issue and was also able to solve it, this may help in your case (Summary at top): Please let me know if this resolves your issue or you need further assistance with this issue. Thank you |
May 27, 2019 at 11:18 am #3896431 | |
kellyP-7 |
Hi, Thanks for your reply. I tried to fix it by using the tips i got from the other topic. but i cant change the screen options. i can only change one feauture (see image). i understand that the problem is caused by the yoast plugin in combination with WPML. Thanks. |
May 27, 2019 at 12:15 pm #3897009 | |
Noman Supporter
Hi, I have checked screen options in my localhost with fresh installation and ‘Columns’ section is there as you can see in the attached screenshot but it’s missing in your screenshot. Could you please check for a possible theme and plugin conflict. To do that you can switch back to any default theme (e.g. Twenty Seventeen theme), Disable all plugins except WPML and Yoast SEO and see if this issue goes away with default theme and only WPML activated? If still issue persists, please provide temporary access (WP-Admin and FTP Login info) to your site (preferably staging site), so that I can look into your setup and debug the issue. Your next answer will be private which means only you and I have access to it. === Please backup your database and website === ✙ I would additionally need your permission to de-activate and re-activate Plugins and the Theme, and to change configurations on the site. This is also a reason the backup is really important. Thank you |
May 30, 2019 at 8:02 pm #3925993 | |
Noman Supporter
Hi, WP login info that you have provided is not working here. Could you please provide me working login please. I have enabled private input box for your next reply. Thank you |
June 3, 2019 at 7:54 pm #3945717 | |
Noman Supporter
Hi, Wp login info still not working here as you can see in the attached screenshot. Could you please provide me working login please. Thank you |
June 7, 2019 at 7:44 pm #3978877 | |
kellyP-7 |
That is so strange, can you give me an email adress so you can set your own password? |
June 9, 2019 at 9:26 am #3982613 | |
Noman Supporter
Hi, Here is my email: [removed] Thank you |
June 9, 2019 at 2:45 pm #3983173 | |
kellyP-7 |
Hi, I send you an email so you can set up your own password. I had to change my password for the FTP for security reasons, if you need the new one please ask. Thanks for helping |
June 9, 2019 at 3:56 pm #3983295 | |
Noman Supporter
Hi, Thanks for login details. I have hidden ‘Yoast SEO Meta Box’ from SEO >> Search Appearance >> Content Types > Products as you can see in the attached screenshot and now products columns looks fine. You can show/hide ‘Yoast SEO Meta Box’ from there if needed. Please let me know if this resolves your issue or you need further assistance. Thank you |
June 9, 2019 at 5:06 pm #3983501 | |
kellyP-7 |
Hi Noman, Thanks for this quick response. I see the problem is solved now but when i go to one product the yoast plugin cant be used there. For now i can only change meta discriptions on my other pages exept the product pages. i need to use the tool for every page offcourse. im sorry Thanks |
June 10, 2019 at 7:35 am #3985633 | |
Noman Supporter
Hi, - I have enabled ‘Yoast SEO Meta Box’ from SEO >> Search Appearance >> Content Types > Products. add_action('admin_head', 'add_admin_css'); function add_admin_css() { echo '<style> .post-type-product div.wrap {overflow-x:scroll; width:98%;} .post-type-product table.wp-list-table.fixed{table-layout:auto;} .post-type-product table.wp-list-table th#title{min-width:350px;} .post-type-product table.wp-list-table th#categories{min-width:150px;} </style>'; } And now columns looks fine. Please let me know if this resolves your issue or you need further assistance. Thank you |
June 13, 2019 at 11:00 am #4012161 | |
kellyP-7 |
Hi Noman, Thanks for your help. you resolved the problem really well. Your a hero! |
October 10, 2019 at 12:13 pm #4730083 | |
yao-yuT |
The bug is well fixed, thank you for ur great help! |
