Problem: When the Look for strings option in turned off, the strings are in English and not in Latvian (site default language).
Solution: It seems that the original translations of Woocommerce (po/mo files) were overwriting the translations of String Translator. These steps solved the problem for our 2nd tier specialist:
- Go to WPML -> String Translator and search for the string with the issue (I tested with "Search results: “%s") - Delete the string - Go to WPML -> Theme and plugin localization -> String in the plugins and scan the "Woocommerce" plugin - Go to String Translator and translate the string again
Relevant Documentation:
Last updated by Carlos Rojas 1 year, 2 months ago.
June 28, 2020 at 1:32 pm #6470129
dmitrijsH
I am trying to: Have the product search properly translated.
Instead: When the Look for strings option in turned off, the strings are in English and not in Latvian (site default language). Please see the screenshots. At the same time, the Estonian page is correct. However, when I try to search for this string (using the Estonian words and "include translations" clicked on), I could not find it in strings translation.
June 30, 2020 at 11:31 am #6485597
Carlos Rojas
I kindly ask you to follow these steps:
- Create a full backup of the site
- Go to WPML -> Theme and plugins localization -> Scan the theme and the plugins related to Woocommerce
- Go to WPML -> Language -> Activate the Ajax cookie option
- Go to WPML -> String Translation -> Search and translate the strings. You may need to look into the Admin Texts section by following the steps described in this link: https://wpml.org/documentation/getting-started-guide/theme-localization/translating-options-coming-from-themes-and-plugins/
Could you tell me if the issue persists after the steps above?
Kind regards,
Carlos
June 30, 2020 at 1:05 pm #6486323
dmitrijsH
All these steps have been done before I opened the topic, including the AJAX option. I cannot see anything relevant in the admin screen texts.
I can give you an access to a duplication of this website. It is a bit older (not so updated) but the issue appears both there and on the production website.
Thank you,
July 1, 2020 at 8:40 am #6492489
Carlos Rojas
I would like to request temporary access (wp-admin and FTP) to your site to take a better look at the issue. You will find the needed fields for this below the comment area when you log in to leave your next reply. The information you will enter is private which means only you and I can see and have access to it.
Our Debugging Procedures
I will be checking various settings in the backend to see if the issue can be resolved. Although I won't be making changes that affect the live site, it is still good practice to back-up the site before providing us access. In the event that we do need to debug the site further, I will duplicate the site and work in a separate, local development environment to avoid affecting the live site.
Carlos
July 1, 2020 at 1:08 pm #6495879
Carlos Rojas
Thank you very much for sharing this information.
I was able to reproduce the issue and after running several troubleshooting steps the issue persisted. For this reason, I decided to escalate this ticket to our 2nd tier of support where our specialists will take a deeper look at this problem and will try to isolate its cause.
I will get back to you as soon as I get an answer from our specialists.
Carlos
July 3, 2020 at 11:27 am #6513711
Carlos Rojas
- Delete the string
Could you confirm that the issue is solved after following the steps above?
Carlos
July 3, 2020 at 12:07 pm #6514035
dmitrijsH
However, could you please confirm that in the future I can safely remove these problematic lines from the String Translation. Will they be readded after I rescan the plugin?
July 3, 2020 at 12:18 pm #6514179
Carlos Rojas
I'm glad to hear that the issue is solved 🙂
Yes, the strings will be read after scanning the plugin again.
Please don't hesitate to contact us if you need our help in the future with WPML. We will be more than happy to help.
Carlos
