No supporters are available to work today on this forum. Feel free to create tickets and we will handle it as soon as we are online. Thank you for your understanding.
Last updated by Radu 3 weeks, 5 days ago.
Assigned support staff: Radu.
April 2, 2021 at 8:53 am #8453917
pearm
this is a chinese site after then we install WPML to set up english version.
some page content we translate manual, but many page default wording not work.
i don't know what happen. please check the image attached
only work in products page. other pages total not work.- FAQ/CONTACT US/ BLOG/PRESS RELEASE/LATEST NEW/client portal_point_membership
our version :
WOOCOMMERCE - 5.1.0
WordPress 5.7
April 4, 2021 at 6:31 am #8462189
Radu
Hey there,
Thank you for reaching out to the WPML support!
I can see that there are a lot of strings not translated. In this case, can you go to WPML → String translation and search for these strings, please? There's a chance that most of the strings (if not all of them) can be translated from this area. Can you give this a try, please?
Also, can you attach the debug information to this ticket, please? You can find the steps for doing that right here:
https://wpml.org/faq/provide-debug-information-faster-support/
Radu
April 4, 2021 at 8:05 am #8462557
pearm
you are asking for doing translate from wpml - string translation but previous when i was working on i was tried with this method, it was not working, suppose i was translate Apply coupon in chinese, but its not translated. please check atachment
April 4, 2021 at 6:49 pm #8464005
Radu
Hey there,
Thank you for sending me the additional screenshots from your previous message and for checking WPML → String translation. Since this change is not doing the trick, could you give me access to the dashboard so I can have a look, please? The next reply is set to be private so you can safely send me the credentials.
Radu
April 7, 2021 at 8:26 am #8479723
Radu
Hey,
The elements from the contact page here:
are actually a part of the contact form from here:
In this case, you need to change the text to Chinese inside the contact form and then translate the contact form as presented here:
https://wpml.org/documentation/related-projects/using-contact-form-7-with-wpml/
I checked the page from this screenshot: hidden link
but everything is translated well now:
Chinese hidden link
English hidden link
The Memberships button from here hidden link
can be translated through WPML → String translation area:
As for the Points, I couldn't find them here:
so I can look for the strings. Can you tell me if I should access a different link?
Regarding the subscription option at the bottom, I could see that the footer is created here:
but there's a Tbay Newsletter widget used, but the text is not added there. You need to edit again the newsletter (I don't know how did you create it, maybe it's an option from the theme) and change the text.
For all the other strings from your screenshots, please search for them in the WPML → String translation area. I looked for a few of them and they are there. Like the Hello word at the top which I changed to [CH] Hello, I was able to add the translation through the WPML → String translation area.
Radu
April 8, 2021 at 2:16 am #8486845
pearm
hi radu,
i have follow all your instruction but still not work, please help.
thanks
April 8, 2021 at 10:22 am #8490335
Radu
Hey there,
I can see that you added the translation for the Membership word and it's changed here:
Can you tell me if there's another place where this word is not translated, please?
Radu
April 8, 2021 at 2:58 pm #8494345
pearm
hi Radu,
please check the image. the page are :
thank you
April 11, 2021 at 2:36 pm #8510763
Radu
Hey there,
I had a look at the elements that I mentioned in my previous message but there's no change on them.
For example, the contact form from the Contact Us and FAQ pages can be easily changed if you edit the form here:
This is the Chinese form but the strings are still in English. Can you try to change them, please?
Regarding the heading and text over the contact form on the FAQ page, you can easily change them if you edit the page:
The page is in Chinese but the text added before the contact form is in English. All you need to do is edit it, add the Chinese text there, and then edit the English translation.
Please make these changes first and then we'll check the other elements too.
Radu
April 12, 2021 at 3:27 am #8512443
pearm
hi Radu,
Contact Us have been been translated in chinese, but in english verion is not work will show in chinses.
btw others problem still haven't fix, help assist.
thank you
April 13, 2021 at 3:05 pm #8526717
pearm
hello radu,
thank you so much finally i have fix the string problem, but i still have some question, i have a mailchimp subscription form at the website, but it can't work sting, i have already install the plugin, but it still not work. would u please tell how to fix?
April 13, 2021 at 6:13 pm #8528383
Radu
Hey there,
As I can see, the footer is created here:
and the newsletter is made using the Tbay Newsletter widget. This element is using the following newsletter form created by Mailchimp here:
Once you change the text here, it will change on the footer too. The last step is to translate the subscription form as presented here: https://wpml.org/documentation/related-projects/mailchimp-for-wordpress-multilingual/#translating-your-forms
Radu
April 14, 2021 at 8:30 am #8532249
pearm
hi radu,
i have follow your instruction but i can't find any sign up form at the Translation Management. i will ask the theme to help.
and i have another problem about the customize function the code as follow:
function my_custom_wc_free_shipping_notice() {
if ( ! is_cart() && ! is_checkout() ) { // Remove partial if you don't want to show it on cart/checkout
return;
$packages = WC()->cart->get_shipping_packages();
$package = reset( $packages );
$zone = wc_get_shipping_zone( $package );
$cart_total = WC()->cart->get_displayed_subtotal();
if ( WC()->cart->display_prices_including_tax() ) {
$cart_total = round( $cart_total - ( WC()->cart->get_discount_total() + WC()->cart->get_discount_tax() ), wc_get_price_decimals() );
} else {
$cart_total = round( $cart_total - WC()->cart->get_discount_total(), wc_get_price_decimals() );
foreach ( $zone->get_shipping_methods( true ) as $k => $method ) {
$min_amount = $method->get_option( 'min_amount' );
if ( $method->id == 'free_shipping' && ! empty( $min_amount ) && $cart_total < $min_amount ) {
$remaining = $min_amount - $cart_total;
wc_add_notice( sprintf( 'Purchase HK %s more to enjoy free delivery!', wc_price( $remaining ) ) );
add_action( 'wp', 'my_custom_wc_free_shipping_notice' );
the WMPL can't find this, please help
thanks
ARty
April 15, 2021 at 12:28 pm #8544817
Radu
Hey Arty,
As you may know, helping with custom coding is outside of our support scope. However, in this case, I think that the change is pretty simple.
From what I see, the text that you might want to translate is the one at the end (Purchase HK...). All you need to do is wrap that string into a gettext function like this:
wc_add_notice( sprintf( __( 'Purchase HK %s more to enjoy free delivery!', 'text-domain' ), wc_price( $remaining ) ) );
where you need to replace the text-domain part with the text domain used by the theme or the plugin that you added this code to.
Once you did this, go to WPML → Theme and plugins localization, scan the theme or plugin where you added the code, and look for the string in WPML → String Translation area.
You can find some more details about this right here:
https://codex.wordpress.org/I18n_for_WordPress_Developers
Radu
April 19, 2021 at 4:23 am #8567393
pearm
hi Radu,
i have another problem, lanugage default from tradational chinese ---> english,
change back again eng--->tradational chinese , and language switcher drop down is not show, and i have check which is set already at backend, would you please help
thanks
Arty
The topic ‘[Closed] string is not work in default wording’ is closed to new replies.
